[Résolu] paquets non-libres
La commande vrms me retourne ça :
[code]m3t4linux@debian:/$ vrms
Non-free packages with status other than installed on debian
rar ( dei) Archiver for .rar files
Contrib packages with status other than installed on debian
ttf-mscorefonts-installer ( dei) Installer for Microsoft TrueType core fonts
1 non-free packages, 0.1% of 1408 installed packages.
1 contrib packages, 0.1% of 1408 installed packages.
Comment supprimer ces paquets qui ne sont pas installés??
Pour info, un
me donne la chose suivante
m3t4linux@debian:/$ apt-cache show rar Package: rar Status: deinstall ok config-files Priority: optional Section: non-free/utils Installed-Size: 1044 Maintainer: Martin Meredith <mez@ubuntu.com> Architecture: i386 Version: 1:3.8b3-1 Config-Version: 1:3.8b3-1 Suggests: unrar Conffiles: /etc/rarfiles.lst 7eca5a5ab439f2ff1899870bb77eff03 Description: Archiver for .rar files This is the RAR archiver from Eugene Roshal. It supports multiple volume archives and damage protection. It can also create SFX-archives. There are versions which run on DOS, Windows (3.1x,95,NT), FreeBSD, BSDI. . This program is shareware and you must register it after 40 days of use. Homepage: http://www.rarlabs.com/
et un
ceci
m3t4linux@debian:/$ apt-cache show ttf-mscorefonts-installer Package: ttf-mscorefonts-installer Status: deinstall ok config-files Priority: optional Section: contrib/x11 Installed-Size: 188 Maintainer: Thijs Kinkhorst <thijs@debian.org> Architecture: all Source: msttcorefonts Version: 2.6 Config-Version: 2.6 Replaces: msttcorefonts (<< 2.6) Provides: msttcorefonts Depends: wget, cabextract, xfonts-utils, debconf | cdebconf, defoma Recommends: ttf-liberation, x-ttcidfont-conf Conflicts: msttcorefonts (<< 2.6) Conffiles: /etc/defoma/hints/ttf-mscorefonts-installer.hints 26fd3c37389de3bfdd85044d0a50fd4f Description: Installer for Microsoft TrueType core fonts This package allows for easy installation of the Microsoft True Type Core Fonts for the Web including: . Andale Mono Arial Black Arial (Bold, Italic, Bold Italic) Comic Sans MS (Bold) Courier New (Bold, Italic, Bold Italic) Georgia (Bold, Italic, Bold Italic) Impact Times New Roman (Bold, Italic, Bold Italic) Trebuchet (Bold, Italic, Bold Italic) Verdana (Bold, Italic, Bold Italic) Webdings . You will need an Internet connection to download these fonts if you don't already have them. . NOTE: the package ttf-liberation contains free variants of the Times, Arial and Courier fonts. We recommend to use that instead unless you specifically need one of the other fonts from this package.
Merci!
tu as dû supprimer ces paquets (rar et ttf-mscorefonts-installer) mais il doit falloir les purger maintenant (i.e. supprimer aussi les fichiers de configuration):
Bonsoir ursus,
J’avais tenté quelques commandes mais pas celle-ci!!
En guise de remerciements et de réponses
[code]m3t4linux@debian:~$ vrms
No non-free or contrib packages installed on debian! rms would be proud.
:smt041
