[resolu] pas de son testing 2.6.32-5-amd64
Je viens d’installer debian testing sur une nouvelle machine et je n’ai pas de son après un:
apt-get install kmix alsa-base alsamixergui alsa-tools alsa-tools-gui alsa-utils
alsamixergui me donne une fenêtre avec alsamixer: function snd_ctl_open failed for default: no such file or directory
dpkg -l |grep alsa
ii  alsa-base                            1.0.23+dfsg-1                  ALSA driver configuration files
ii  alsa-firmware-loaders                1.0.23-3                       ALSA software loaders for specific hardware
ii  alsa-oss                             1.0.17-4                       ALSA wrapper for OSS applications
ii  alsa-source                          1.0.23+dfsg-1                  ALSA driver sources
ii  alsa-tools                           1.0.23-3                       Console based ALSA utilities for specific hardware
ii  alsa-tools-gui                       1.0.23-3                       GUI based ALSA utilities for specific hardware
ii  alsa-utils                           1.0.23-2                       Utilities for configuring and using ALSA
ii  alsamixergui                         0.9.0rc2-1-9                   graphical soundcard mixer for ALSA soundcard driver
ii  libsdl1.2debian-alsa                 1.2.14-6
lspci | grep -i audio
00:05.0 Audio device: nVidia Corporation MCP61 High Definition Audio (rev a2)
01:07.0 Multimedia video controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder (rev 05)
01:07.2 Multimedia controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [MPEG Port] (rev 05)
01:07.4 Multimedia controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [IR Port] (rev 05)
                     Simple DirectMedia Layer (with X11 and ALSA options)
alsactl init
alsactl: init:1743: No soundcards found...
Ma dernière cartouche recompiler alsa comme dans ce post :
viewtopic.php?f=3&t=8837&view=previous
Mais voila au make j’ai
make -C /lib/modules/2.6.32-5-amd64/source SUBDIRS=/home/bruno/alsa-driver-1.0.23  CPP="gcc -E" CC="gcc" modules
make[1]: entrant dans le répertoire « /usr/src/linux-headers-2.6.32-5-common »
  ERROR: Kernel configuration is invalid.
         include/linux/autoconf.h or include/config/auto.conf are missing.
         Run 'make oldconfig && make prepare' on kernel src to fix it.
  WARNING: Symbol version dump /usr/src/linux-headers-2.6.32-5-common/Module.symvers
           is missing; modules will have no dependencies and modversions.
find: "/usr/src/linux-headers-2.6.32-5-common/alsa-kernel/": Aucun fichier ou dossier de ce type
  Building modules, stage 2.
/usr/src/linux-headers-2.6.32-5-common/scripts/Makefile.modpost:42: include/config/auto.conf: Aucun fichier ou dossier de ce type
make[2]: *** Pas de règle pour fabriquer la cible « include/config/auto.conf ». Arrêt.
make[1]: *** [modules] Erreur 2
make[1]: quittant le répertoire « /usr/src/linux-headers-2.6.32-5-common »
make: *** [compile] Erreur 2
Me voila donc à bout de solution, ça peut-être un bug actuel en cour de résolution ?
Ou il y a une solution ?
devrait être géré pas le module HDA_Intel
lsmod
snd-hda-intel ?
modprobe snd-hda-intel
il son installer ceux ci ?
i   firmware-linux-free        - Binary firmware for various drivers in the Linux kernel
i   firmware-linux-nonfree        - Binary firmware for various drivers in the Linux kernel
Je vais tester ça ce soir.
J’avoue qu’à l’installation je comprenais pas trop cette histoire de firmware libre.
Et voila packages ajouté rien de mieux:
root@naruto:/home/bruno/alsa-driver-1.0.23# dpkg -l |grep firm
ii firmware-linux-free 2.6.32-15 Binary firmware for various drivers in the Linux kernel
ii firmware-linux-nonfree 0.25 Binary firmware for various drivers in the Linux kernel
C’est bon, je viens de découvrir module-assistant.
Ca fonctionne maintenant.
