Voilà :
lspci :
00:00.0 Host bridge: VIA Technologies, Inc. VT8378 [KM400/A] Chipset Host Bridge00:01.0 PCI bridge: VIA Technologies, Inc. VT8237 PCI Bridge
00:09.0 Network controller: RaLink RT2561/RT61 rev B 802.11g
00:0d.0 FireWire (IEEE 1394): VIA Technologies, Inc. IEEE 1394 Host Controller (rev 80)
00:0e.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.3 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 82)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8235 ISA Bridge
00:11.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 50)
01:00.0 VGA compatible controller: nVidia Corporation GeForce 7600 GS (rev a2)
ifconfig :
eth1 Lien encap:Ethernet HWaddr 00:11:5B:1B:29:2A
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interruption:169 Adresse de base:0xd400
lo Lien encap:Boucle locale
RX packets:24 errors:0 dropped:0 overruns:0 frame:0
TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1632 (1.5 KiB) TX bytes:1632 (1.5 KiB)
ifconfig -a :
eth0 Lien encap:UNSPEC HWaddr 00-00-0A-E6-FF-15-93-F2-00-00-00-00-00-00-00-00
dmesg :
Linux version 2.6.18-6-486 (Debian 2.6.18.dfsg.1-23) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 Mon Oct 13 15:35:23 UTC 2008
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000003fff0000 (usable)
BIOS-e820: 000000003fff0000 - 000000003fff3000 (ACPI NVS)
BIOS-e820: 000000003fff3000 - 0000000040000000 (ACPI data)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
Warning only 896MB will be used.
Use a HIGHMEM enabled kernel.
896MB LOWMEM available.
found SMP MP-table at 000f56b0
On node 0 totalpages: 229376
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 225280 pages, LIFO batch:31
DMI 2.3 present.
ACPI: RSDP (v000 KM400 ) @ 0x000f70c0
ACPI: RSDT (v001 KM400 AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x3fff3000
ACPI: FADT (v001 KM400 AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x3fff3040
ACPI: MADT (v001 KM400 AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x3fff7a40
ACPI: DSDT (v001 KM400 AWRDACPI 0x00001000 MSFT 0x0100000e) @ 0x00000000
ACPI: PM-Timer IO Port: 0x4008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 6:10 APIC version 16
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 3, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 dfl dfl)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 50000000 (gap: 40000000:bec00000)
Detected 2158.213 MHz processor.
Built 1 zonelists. Total pages: 229376
Kernel command line: root=/dev/hda2 ro
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore… done.
Enabling unmasked SIMD FPU exception support… done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 16384 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 902096k/917504k available (1499k kernel code, 14828k reserved, 599k data, 256k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode… Ok.
Calibrating delay using timer specific routine… 4320.83 BogoMIPS (lpj=8641673)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383fbff c1c3fbff 00000000 00000000 00000000 00000000 00000000
CPU: After vendor identify, caps: 0383fbff c1c3fbff 00000000 00000000 00000000 00000000 00000000
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 512K (64 bytes/line)
CPU: After all inits, caps: 0383fbff c1c3fbff 00000000 00000420 00000000 00000000 00000000
Compat vDSO mapped to ffffe000.
CPU: AMD Athlon™ XP 3000+ stepping 00
Checking ‘hlt’ instruction… OK.
ACPI: Core revision 20060707
ENABLING IO-APIC IRQs
…TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
checking if image is initramfs… it is
Freeing initrd memory: 4246k freed
NET: Registered protocol family 16
EISA bus registered
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfb350, last bus=1
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [_SB_.PCI0] bus is 0
PCI quirk: region 4000-407f claimed by vt8235 PM
PCI quirk: region 5000-500f claimed by vt8235 SMB
Boot video device is 0000:01:00.0
ACPI: PCI Interrupt Routing Table [_SB_.PCI0._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 10 11 12) *5
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 6 7 *10 11 12)
ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 6 7 10 11 12)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 *11 12)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 6 7 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 6 7 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [ALKA] (IRQs 20) *0, disabled.
ACPI: PCI Interrupt Link [ALKB] (IRQs 21) *0, disabled.
ACPI: PCI Interrupt Link [ALKC] (IRQs 22) *0, disabled.
ACPI: PCI Interrupt Link [ALKD] (IRQs 23) *0, disabled.
Linux Plug and Play Support v0.97 © Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 12 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
pnp: 00:02: ioport range 0x4000-0x407f could not be reserved
pnp: 00:02: ioport range 0x5000-0x500f has been reserved
PCI: Bridge: 0000:00:01.0
IO window: disabled.
MEM window: e8000000-eaffffff
PREFETCH window: d0000000-dfffffff
PCI: Setting latency timer of device 0000:00:01.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1225798753.800:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
isapnp: Scanning for PnP cards…
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
PNP: PS/2 controller doesn’t have AUX irq; using default 12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
EISA: Probing bus 0 at eisa.0
Cannot allocate resource for EISA slot 4
Cannot allocate resource for EISA slot 5
EISA: Detected 0 cards.
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI Shortcut mode
ACPI: (supports S0 S3 S4 S5)
Freeing unused kernel memory: 256k freed
Time: tsc clocksource has been installed.
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: Fan [FAN] (on)
ACPI: CPU0 (power states: C1[C1] C2[C2])
ACPI: Thermal Zone [THRM] (40 C)
ieee1394: Initialized config rom entry `ip1394’
8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
8139cp 0000:00:0e.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip8139cp 0000:00:0e.0: Try the “8139too” driver instead.
8139too Fast Ethernet driver 0.9.27
ACPI: PCI Interrupt 0000:00:0e.0[A] -> GSI 19 (level, low) -> IRQ 169
eth0: RealTek RTL8139 at 0xd400, 00:11:5b:1b:29:2a, IRQ 169
eth0: Identified 8139 chip type 'RTL-8100B/8139D’
usbcore: registered new driver usbfs
usbcore: registered new driver hub
ACPI: PCI Interrupt 0000:00:0d.0[A] -> GSI 17 (level, low) -> IRQ 177
ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[177] MMIO=[eb008000-eb0087ff] Max Packet=[2048] IR/IT contexts=[4/8]
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt Link [ALKB] BIOS reported IRQ 0, using IRQ 21
ACPI: PCI Interrupt Link [ALKB] enabled at IRQ 21
ACPI: PCI Interrupt 0000:00:10.0[A] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 185
PCI: VIA IRQ fixup for 0000:00:10.0, from 5 to 9
uhci_hcd 0000:00:10.0: UHCI Host Controller
uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:10.0: irq 185, io base 0x0000d800
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ACPI: PCI Interrupt 0000:00:10.1[B] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 185
PCI: VIA IRQ fixup for 0000:00:10.1, from 10 to 9
uhci_hcd 0000:00:10.1: UHCI Host Controller
uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:10.1: irq 185, io base 0x0000dc00
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
Time: acpi_pm clocksource has been installed.
ACPI: PCI Interrupt 0000:00:10.2[C] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 185
PCI: VIA IRQ fixup for 0000:00:10.2, from 3 to 9
uhci_hcd 0000:00:10.2: UHCI Host Controller
uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:10.2: irq 185, io base 0x0000e000
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.3[D] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 185
PCI: VIA IRQ fixup for 0000:00:10.3, from 11 to 9
ehci_hcd 0000:00:10.3: EHCI Host Controller
ehci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
ehci_hcd 0000:00:10.3: irq 185, io mem 0xeb00a000
ehci_hcd 0000:00:10.3: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 6 ports detected
VP_IDE: IDE controller at PCI slot 0000:00:11.1
ACPI: PCI Interrupt Link [ALKA] BIOS reported IRQ 0, using IRQ 20
ACPI: PCI Interrupt Link [ALKA] enabled at IRQ 20
ACPI: PCI Interrupt 0000:00:11.1[A] -> Link [ALKA] -> GSI 20 (level, low) -> IRQ 193
PCI: VIA IRQ fixup for 0000:00:11.1, from 255 to 1
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8235 (rev 00) IDE UDMA133 controller on pci0000:00:11.1
ide0: BM-DMA at 0xe400-0xe407, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xe408-0xe40f, BIOS settings: hdc:pio, hdd:DMA
Probing IDE interface ide0…
hda: WDC WD1200BB-22FTA0, ATA DISK drive
hdb: ST3160212A, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1…
ieee1394: Host added: ID:BUS[0-00:1023] GUID[00000ae6ff1593f2]
usb 2-1: new low speed USB device using uhci_hcd and address 2
usb 2-1: configuration #1 chosen from 1 choice
usbcore: registered new driver hiddev
input: Microsoft Microsoft Basic Optical Mouse as /class/input/input1
input: USB HID v1.11 Mouse [Microsoft Microsoft Basic Optical Mouse] on usb-0000:00:10.1-1
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
hdd: TSSTcorpDVD-ROM TS-H352A, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 512KiB
hda: 234441648 sectors (120034 MB) w/2048KiB Cache, CHS=16383/255/63, UDMA(100)
hda: cache flushes supported
hda: hda1 hda2
hdb: max request size: 512KiB
hdb: 312581808 sectors (160041 MB) w/2048KiB Cache, CHS=19457/255/63, UDMA(100)
hdb: cache flushes supported
hdb: hdb1 hdb2 < hdb5 hdb6 >
hdd: ATAPI 48X DVD-ROM drive, 512kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
Attempting manual resume
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
eth1394: eth0: IEEE-1394 IPv4 over 1394 Ethernet (fw-host0)
ts: Compaq touchscreen protocol output
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Linux agpgart interface v0.101 © Dave Jones
agpgart: Detected VIA KM400/KM400A chipset
agpgart: AGP aperture is 128M @ 0xe0000000
input: PC Speaker as /class/input/input2
Real Time Clock Driver v1.12ac
irda_init()
NET: Registered protocol family 23
FDC 0 is a post-1991 82077
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
ACPI: PCI Interrupt Link [ALKC] BIOS reported IRQ 0, using IRQ 22
ACPI: PCI Interrupt Link [ALKC] enabled at IRQ 22
ACPI: PCI Interrupt 0000:00:11.5[C] -> Link [ALKC] -> GSI 22 (level, low) -> IRQ 201
PCI: Setting latency timer of device 0000:00:11.5 to 64
Adding 1132540k swap on /dev/hdb6. Priority:-1 extents:1 across:1132540k
EXT3 FS on hda2, internal journal
loop: loaded (max 8 devices)
SCSI subsystem initialized
ieee1394: sbp2: Driver forced to serialize I/O (serialize_io=1)
ieee1394: sbp2: Try serialize_io=0 for better performance
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
lp0: using parport0 (interrupt-driven).
ppdev: user-space parallel port driver
eth1: link down
Des idées sur le problème ?
