Effectivement cela aidera à la compréhension. J’ai une debian sid. Mon problème n’est pas de voir des vidéo j’y arrive bien avec les driver gl ou X11 de mplayer ou vlc. Mais quand j’utilise Xv cela permet de soulager nettement mon processeur et le rendu est plus agréable à l’oeil.
Merci de ton (votre) aide
Bruno
MPlayer 1.0rc2-4.2.2 (C) 2000-2007 MPlayer Team
CPU: AMD Athlon(tm) XP 3000+ (Family: 6, Model: 10, Stepping: 0)
CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
Compiled with runtime CPU detection.
Available video output drivers:
xmga Matrox G200/G4x0/G550 overlay in X11 window (using /dev/mga_vid)
mga Matrox G200/G4x0/G550 overlay (/dev/mga_vid)
tdfxfb 3Dfx Banshee/Voodoo3/Voodoo5
s3fb S3 Virge over fbdev
xv X11/Xv
x11 X11 ( XImage/Shm )
xover General X11 driver for overlay capable video output drivers
gl X11 (OpenGL)
gl2 X11 (OpenGL) - multiple textures version
dga DGA ( Direct Graphic Access V2.0 )
sdl SDL YUV/RGB/BGR renderer (SDL v1.1.7+ only!)
ggi General Graphics Interface (GGI) output
fbdev Framebuffer Device
fbdev2 Framebuffer Device
svga SVGAlib
aa AAlib
caca libcaca
dxr3 DXR3/H+ video out
v4l2 V4L2 MPEG Video Decoder Output
directfb Direct Framebuffer Device
dfbmga DirectFB / Matrox G200/G400/G450/G550
xvidix X11 (VIDIX)
cvidix console VIDIX
null Null video output
xvmc XVideo Motion Compensation
mpegpes Mpeg-PES to DVB card
yuv4mpeg yuv4mpeg output for mjpegtools
png PNG file
jpeg JPEG file
gif89a animated GIF output
tga Targa output
pnm PPM/PGM/PGMYUV file
md5sum md5sum of each frame
X-Video Extension version 2.2
screen #0
Adaptor #0: "video4linux"
number of ports: 1
port base: 73
operations supported: PutVideo
supported visuals:
depth 24, visualID 0x23
depth 24, visualID 0x24
depth 24, visualID 0x25
depth 24, visualID 0x26
depth 24, visualID 0x27
depth 24, visualID 0x28
depth 24, visualID 0x29
depth 24, visualID 0x2a
number of attributes: 7
"XV_ENCODING" (range -1000 to 1000)
client settable attribute
client gettable attribute (current value is 0)
"XV_BRIGHTNESS" (range -1000 to 1000)
"XV_CONTRAST" (range -1000 to 1000)
"XV_SATURATION" (range -1000 to 1000)
"XV_HUE" (range -1000 to 1000)
"XV_MUTE" (range 0 to 1)
"XV_FREQ" (range 0 to 16000)
number of encodings: 28
encoding ID #0: "PAL-television"
size: 768 x 576
rate: 0.020000
encoding ID #1: "NTSC-television"
size: 640 x 480
rate: 0.016683
encoding ID #2: "SECAM-television"
size: 768 x 576
rate: 0.020000
encoding ID #3: "PAL-Nc-television"
size: 640 x 576
rate: 0.020000
encoding ID #4: "PAL-M-television"
size: 640 x 576
rate: 0.020000
encoding ID #5: "PAL-N-television"
size: 768 x 576
rate: 0.020000
encoding ID #6: "NTSC-JP-television"
size: 640 x 480
rate: 0.016683
encoding ID #7: "PAL-composite1"
size: 768 x 576
rate: 0.020000
encoding ID #8: "NTSC-composite1"
size: 640 x 480
rate: 0.016683
encoding ID #9: "SECAM-composite1"
size: 768 x 576
rate: 0.020000
encoding ID #10: "PAL-Nc-composite1"
size: 640 x 576
rate: 0.020000
encoding ID #11: "PAL-M-composite1"
size: 640 x 576
rate: 0.020000
encoding ID #12: "PAL-N-composite1"
size: 768 x 576
rate: 0.020000
encoding ID #13: "NTSC-JP-composite1"
size: 640 x 480
rate: 0.016683
encoding ID #14: "PAL-svideo"
size: 768 x 576
rate: 0.020000
encoding ID #15: "NTSC-svideo"
size: 640 x 480
rate: 0.016683
encoding ID #16: "SECAM-svideo"
size: 768 x 576
rate: 0.020000
encoding ID #17: "PAL-Nc-svideo"
size: 640 x 576
rate: 0.020000
encoding ID #18: "PAL-M-svideo"
size: 640 x 576
rate: 0.020000
encoding ID #19: "PAL-N-svideo"
size: 768 x 576
rate: 0.020000
encoding ID #20: "NTSC-JP-svideo"
size: 640 x 480
rate: 0.016683
encoding ID #21: "PAL-composite3"
size: 768 x 576
rate: 0.020000
encoding ID #22: "NTSC-composite3"
size: 640 x 480
rate: 0.016683
encoding ID #23: "SECAM-composite3"
size: 768 x 576
rate: 0.020000
encoding ID #24: "PAL-Nc-composite3"
size: 640 x 576
rate: 0.020000
encoding ID #25: "PAL-M-composite3"
size: 640 x 576
rate: 0.020000
encoding ID #26: "PAL-N-composite3"
size: 768 x 576
rate: 0.020000
encoding ID #27: "NTSC-JP-composite3"
size: 640 x 480
rate: 0.016683
Adaptor #1: "ATI Radeon Video Overlay"
number of ports: 1
port base: 74
operations supported: PutImage
supported visuals:
depth 24, visualID 0x2b
depth 24, visualID 0x2c
depth 24, visualID 0x2d
depth 24, visualID 0x2e
depth 24, visualID 0x2f
depth 24, visualID 0x30
depth 24, visualID 0x31
depth 24, visualID 0x32
number of attributes: 22
"XV_DEVICE_ID" (range 0 to -1)
client gettable attribute (current value is 109)
"XV_LOCATION_ID" (range 0 to -1)
client gettable attribute (current value is 110)
"XV_INSTANCE_ID" (range 0 to -1)
client gettable attribute (current value is 111)
"XV_DUMP_STATUS" (range 0 to 1)
"XV_SET_DEFAULTS" (range 0 to 1)
"XV_AUTOPAINT_COLORKEY" (range 0 to 1)
client gettable attribute (current value is 1)
"XV_COLORKEY" (range 0 to -1)
client gettable attribute (current value is 30)
"XV_DOUBLE_BUFFER" (range 0 to 1)
"XV_OVERLAY_ALPHA" (range 0 to 255)
client gettable attribute (current value is 255)
"XV_GRAPHICS_ALPHA" (range 0 to 255)
"XV_ALPHA_MODE" (range 0 to 1)
"XV_COLOR" (range -1000 to 1000)
"XV_RED_INTENSITY" (range -1000 to 1000)
"XV_GREEN_INTENSITY" (range -1000 to 1000)
"XV_BLUE_INTENSITY" (range -1000 to 1000)
"XV_SWITCHCRT" (range 0 to 1)
"XV_GAMMA" (range 100 to 10000)
client gettable attribute (current value is 1000)
"XV_COLORSPACE" (range 0 to 1)
maximum XvImage size: 2048 x 2048
Number of image formats: 8
guid: 52474241-0000-0010-8000-00aa00389b71
bits per pixel: 32
number of planes: 1
type: RGB (packed)
depth: 32
red, green, blue masks: 0xff0000, 0xff00, 0xff
guid: 52474200-0000-0010-8000-00aa00389b71
bits per pixel: 24
number of planes: 1
type: RGB (packed)
depth: 24
guid: 52474254-0000-0010-8000-00aa00389b71
bits per pixel: 16
number of planes: 1
type: RGB (packed)
depth: 16
red, green, blue masks: 0x7c00, 0x3e0, 0x1f
bits per pixel: 16
number of planes: 1
type: RGB (packed)
depth: 16
red, green, blue masks: 0xf800, 0x7e0, 0x1f
guid: 59555932-0000-0010-8000-00aa00389b71
bits per pixel: 16
number of planes: 1
type: YUV (packed)
guid: 55595659-0000-0010-8000-00aa00389b71
bits per pixel: 16
number of planes: 1
type: YUV (packed)
guid: 59563132-0000-0010-8000-00aa00389b71
bits per pixel: 12
number of planes: 3
type: YUV (planar)
guid: 49343230-0000-0010-8000-00aa00389b71
bits per pixel: 12
number of planes: 3
type: YUV (planar)
