May 20 14:11:39 vmdebian named[2683]: starting BIND 9.3.4 -u bind
May 20 14:11:39 vmdebian named[2683]: found 1 CPU, using 1 worker thread
May 20 14:11:39 vmdebian named[2683]: loading configuration from '/etc/bind/named.conf’
May 20 14:11:39 vmdebian named[2683]: /etc/bind/named.conf:57: unknown option 'par’
May 20 14:11:39 vmdebian named[2683]: loading configuration: failure
May 20 14:11:39 vmdebian named[2683]: exiting (due to fatal error)
voicy la structure de mon michier named.conf
// This is the primary configuration file for the BIND DNS server named.
// Please read /usr/share/doc/bind9/README.Debian.gz for information on the
// structure of BIND configuration files in Debian, BEFORE you customize
// this configuration file.
// If you are just adding zones, please do that in /etc/bind/named.conf.local
include “/etc/bind/named.conf.options”;
// prime the server with knowledge of the root servers
zone “.” {
type hint;
file “/etc/bind/db.root”;
// be authoritative for the localhost forward and reverse zones, and for
// broadcast zones as per RFC 1912
zone “localhost” {
type master;
file “/etc/bind/db.local”;
zone “127.in-addr.arpa” {
type master;
file “/etc/bind/db.127”;
zone “0.in-addr.arpa” {
type master;
file “/etc/bind/db.0”;
zone “255.in-addr.arpa” {
type master;
file “/etc/bind/db.255”;
// zone “com” { type delegation-only; };
// zone “net” { type delegation-only; };
// From the release notes:
// Because many of our users are uncomfortable receiving undelegated answers
// from root or top level domains, other than a few for whom that behaviour
// has been trusted and expected for quite some length of time, we have now
// introduced the “root-delegations-only” feature which applies delegation-only
// logic to all top level domains, and to the root domain. An exception list
// should be specified, including “MUSEUM” and “DE”, and any other top level
// domains from whom undelegated responses are expected and trusted.
// root-delegation-only exclude { “DE”; “MUSEUM”; };
include “/etc/bind/named.conf.local”;
// Configurer le canal de communication pour adminsistrer BIND9 avec rndc
// Par défaut, la clef est située dans le fichier rndc.key et utiliser
par
// rndc et bind9 sur localhost
controls {
inet 127.0.0.1 port 53 allow { 127.0.0.1; };
