En epluchant le log je viens aussi de trouver ça :
Feb 16 12:22:26 localhost kernel: ACPI: PCI interrupt 0000:00:07.0[A] -> GSI 19 (level, low) -> IRQ 233
Feb 16 12:22:26 localhost kernel: eth0: RealTek RTL8139 at 0x1800, 00:0a:e4:43:f5:c9, IRQ 233
En afit, voici le log complet (boot + login + pon +startx) :
Feb 16 12:22:26 localhost kernel: klogd 1.4.1#17, log source = /proc/kmsg started.
Feb 16 12:22:26 localhost kernel: Inspecting /boot/System.map-2.6.8-2-386
Feb 16 12:22:26 localhost kernel: Loaded 28183 symbols from /boot/System.map-2.6.8-2-386.
Feb 16 12:22:26 localhost kernel: Symbols match kernel version 2.6.8.
Feb 16 12:22:26 localhost kernel: No module symbols loaded - kernel modules not enabled.
Feb 16 12:22:26 localhost kernel: es)
Feb 16 12:22:26 localhost kernel: Memory: 510140k/522176k available (1337k kernel code, 11248k reserved, 732k data, 204k init, 0k highmem)
Feb 16 12:22:26 localhost kernel: Checking if this processor honours the WP bit even in supervisor mode... Ok.
Feb 16 12:22:26 localhost kernel: Calibrating delay loop... 5095.42 BogoMIPS
Feb 16 12:22:26 localhost kernel: Security Scaffold v1.0.0 initialized
Feb 16 12:22:26 localhost kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Feb 16 12:22:26 localhost kernel: CPU: After generic identify, caps: bfebfbff 00000000 00000000 00000000
Feb 16 12:22:26 localhost kernel: CPU: After vendor identify, caps: bfebfbff 00000000 00000000 00000000
Feb 16 12:22:26 localhost kernel: CPU: Trace cache: 12K uops, L1 D cache: 8K
Feb 16 12:22:26 localhost kernel: CPU: L2 cache: 512K
Feb 16 12:22:26 localhost kernel: CPU: After all inits, caps: bfebfbff 00000000 00000000 00000080
Feb 16 12:22:26 localhost kernel: CPU: Intel(R) Pentium(R) 4 CPU 2.60GHz stepping 07
Feb 16 12:22:26 localhost kernel: Enabling fast FPU save and restore... done.
Feb 16 12:22:26 localhost kernel: Enabling unmasked SIMD FPU exception support... done.
Feb 16 12:22:26 localhost kernel: Checking 'hlt' instruction... OK.
Feb 16 12:22:26 localhost kernel: Checking for popad bug... OK.
Feb 16 12:22:26 localhost kernel: enabled ExtINT on CPU#0
Feb 16 12:22:26 localhost kernel: ESR value before enabling vector: 00000000
Feb 16 12:22:26 localhost kernel: ESR value after enabling vector: 00000000
Feb 16 12:22:26 localhost kernel: ENABLING IO-APIC IRQs
Feb 16 12:22:26 localhost kernel: init IO_APIC IRQs
Feb 16 12:22:26 localhost kernel: IO-APIC (apicid-pin) 1-0, 1-17, 1-18, 1-19, 1-20, 1-21, 1-22, 1-23 not connected.
Feb 16 12:22:26 localhost kernel: ..TIMER: vector=0x31 pin1=16 pin2=-1
Feb 16 12:22:26 localhost kernel: ..MP-BIOS bug: 8254 timer not connected to IO-APIC
Feb 16 12:22:26 localhost kernel: ...trying to set up timer (IRQ0) through the 8259A ... failed.
Feb 16 12:22:26 localhost kernel: ...trying to set up timer as Virtual Wire IRQ... works.
Feb 16 12:22:26 localhost kernel: Using local APIC timer interrupts.
Feb 16 12:22:26 localhost kernel: calibrating APIC timer ...
Feb 16 12:22:26 localhost kernel: ..... CPU clock speed is 2589.0170 MHz.
Feb 16 12:22:26 localhost kernel: ..... host bus clock speed is 99.0583 MHz.
Feb 16 12:22:26 localhost kernel: checking if image is initramfs...it isn't (ungzip failed); looks like an initrd
Feb 16 12:22:26 localhost kernel: Freeing initrd memory: 4216k freed
Feb 16 12:22:26 localhost kernel: NET: Registered protocol family 16
Feb 16 12:22:26 localhost kernel: EISA bus registered
Feb 16 12:22:26 localhost kernel: PCI: PCI BIOS revision 2.10 entry at 0xfd649, last bus=1
Feb 16 12:22:26 localhost kernel: PCI: Using configuration type 1
Feb 16 12:22:26 localhost kernel: mtrr: v2.0 (20020519)
Feb 16 12:22:26 localhost kernel: ACPI: Subsystem revision 20040326
Feb 16 12:22:26 localhost kernel: ACPI: Interpreter enabled
Feb 16 12:22:26 localhost kernel: ACPI: Using IOAPIC for interrupt routing
Feb 16 12:22:26 localhost kernel: ACPI: PCI Root Bridge [PCI0] (00:00)
Feb 16 12:22:26 localhost kernel: PCI: Probing PCI hardware (bus 00)
Feb 16 12:22:26 localhost kernel: Uncovering SIS962 that hid as a SIS503 (compatible=1)
Feb 16 12:22:26 localhost kernel: Enabling SiS 96x SMBus.
Feb 16 12:22:26 localhost kernel: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
Feb 16 12:22:26 localhost kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 4 7 10 *11)
Feb 16 12:22:26 localhost kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 4 7 10 *11)
Feb 16 12:22:26 localhost kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 4 7 10 *11)
Feb 16 12:22:26 localhost kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 4 7 10 *11)
Feb 16 12:22:26 localhost kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 4 7 10 *11)
Feb 16 12:22:26 localhost kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 4 7 10 *11)
Feb 16 12:22:26 localhost kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 4 7 10 *11)
Feb 16 12:22:26 localhost kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 4 7 10 *11)
Feb 16 12:22:26 localhost kernel: ACPI: Embedded Controller [EC] (gpe 30)
Feb 16 12:22:26 localhost kernel: Linux Plug and Play Support v0.97 (c) Adam Belay
Feb 16 12:22:26 localhost kernel: PnPBIOS: Scanning system for PnP BIOS support...
Feb 16 12:22:26 localhost kernel: PnPBIOS: Found PnP BIOS installation structure at 0xc00f6870
Feb 16 12:22:26 localhost kernel: PnPBIOS: PnP BIOS version 1.0, entry 0xf0000:0x9999, dseg 0x400
Feb 16 12:22:26 localhost kernel: pnp: 00:00: ioport range 0x4d0-0x4d1 has been reserved
Feb 16 12:22:26 localhost kernel: pnp: 00:00: ioport range 0x8000-0x80fe has been reserved
Feb 16 12:22:26 localhost kernel: pnp: 00:00: ioport range 0x9000-0x907f has been reserved
Feb 16 12:22:26 localhost kernel: PnPBIOS: 16 nodes reported by PnP BIOS; 16 recorded by driver
Feb 16 12:22:26 localhost kernel: PCI: Using ACPI for IRQ routing
Feb 16 12:22:26 localhost kernel: ACPI: PCI interrupt 0000:00:02.1[B] -> GSI 17 (level, low) -> IRQ 177
Feb 16 12:22:26 localhost kernel: ACPI: PCI interrupt 0000:00:02.3[B] -> GSI 17 (level, low) -> IRQ 177
Feb 16 12:22:26 localhost kernel: ACPI: PCI interrupt 0000:00:02.5[A] -> GSI 16 (level, low) -> IRQ 185
Feb 16 12:22:26 localhost kernel: ACPI: PCI interrupt 0000:00:02.6[C] -> GSI 18 (level, low) -> IRQ 193
Feb 16 12:22:26 localhost kernel: ACPI: PCI interrupt 0000:00:02.7[C] -> GSI 18 (level, low) -> IRQ 193
Feb 16 12:22:26 localhost kernel: ACPI: PCI interrupt 0000:00:03.0[A] -> GSI 20 (level, low) -> IRQ 201
Feb 16 12:22:26 localhost kernel: ACPI: PCI interrupt 0000:00:03.1[B] -> GSI 21 (level, low) -> IRQ 209
Feb 16 12:22:26 localhost kernel: ACPI: PCI interrupt 0000:00:03.2[C] -> GSI 22 (level, low) -> IRQ 217
Feb 16 12:22:26 localhost kernel: ACPI: PCI interrupt 0000:00:03.3[D] -> GSI 23 (level, low) -> IRQ 225
Feb 16 12:22:26 localhost kernel: ACPI: PCI interrupt 0000:00:09.0[A] -> GSI 16 (level, low) -> IRQ 185
Feb 16 12:22:26 localhost kernel: ACPI: PCI interrupt 0000:00:09.1[B] -> GSI 17 (level, low) -> IRQ 177
Feb 16 12:22:26 localhost kernel: ACPI: PCI interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 185
Feb 16 12:22:26 localhost kernel: number of MP IRQ sources: 16.
Feb 16 12:22:26 localhost kernel: number of IO-APIC #1 registers: 24.
Feb 16 12:22:26 localhost kernel: testing the IO APIC.......................
Feb 16 12:22:26 localhost kernel: IO APIC #1......
Feb 16 12:22:26 localhost kernel: .... register #00: 01000000
Feb 16 12:22:26 localhost kernel: ....... : physical APIC id: 01
Feb 16 12:22:26 localhost kernel: ....... : Delivery Type: 0
Feb 16 12:22:26 localhost kernel: ....... : LTS : 0
Feb 16 12:22:26 localhost kernel: .... register #01: 00178011
Feb 16 12:22:26 localhost kernel: ....... : max redirection entries: 0017
Feb 16 12:22:26 localhost kernel: ....... : PRQ implemented: 1
Feb 16 12:22:26 localhost kernel: ....... : IO APIC version: 0011
Feb 16 12:22:26 localhost kernel: .... register #02: 01000000
Feb 16 12:22:26 localhost kernel: ....... : arbitration: 01
Feb 16 12:22:26 localhost kernel: .... IRQ redirection table:
Feb 16 12:22:26 localhost kernel: NR Log Phy Mask Trig IRR Pol Stat Dest Deli Vect:
Feb 16 12:22:26 localhost kernel: 00 000 00 1 0 0 0 0 0 0 00
Feb 16 12:22:26 localhost kernel: 01 001 01 0 0 0 0 0 1 1 39
Feb 16 12:22:26 localhost kernel: 02 001 01 1 0 0 0 0 1 1 41
Feb 16 12:22:26 localhost kernel: 03 001 01 0 0 0 0 0 1 1 49
Feb 16 12:22:26 localhost kernel: 04 001 01 0 0 0 0 0 1 1 51
Feb 16 12:22:26 localhost kernel: 05 001 01 0 0 0 0 0 1 1 59
Feb 16 12:22:26 localhost kernel: 06 001 01 0 0 0 0 0 1 1 61
Feb 16 12:22:26 localhost kernel: 07 001 01 0 0 0 0 0 1 1 69
Feb 16 12:22:26 localhost kernel: 08 001 01 0 0 0 0 0 1 1 71
Feb 16 12:22:26 localhost kernel: 09 001 01 0 1 0 1 0 1 1 79
Feb 16 12:22:26 localhost kernel: 0a 001 01 0 0 0 0 0 1 1 81
Feb 16 12:22:26 localhost kernel: 0b 001 01 0 0 0 0 0 1 1 89
Feb 16 12:22:26 localhost kernel: 0c 001 01 0 0 0 0 0 1 1 91
Feb 16 12:22:26 localhost kernel: 0d 001 01 0 0 0 0 0 1 1 99
Feb 16 12:22:26 localhost kernel: 0e 001 01 0 0 0 0 0 1 1 A1
Feb 16 12:22:26 localhost kernel: 0f 001 01 0 0 0 0 0 1 1 A9
Feb 16 12:22:26 localhost kernel: 10 001 01 1 1 0 1 0 1 1 B9
Feb 16 12:22:26 localhost kernel: 11 001 01 1 1 0 1 0 1 1 B1
Feb 16 12:22:26 localhost kernel: 12 001 01 1 1 0 1 0 1 1 C1
Feb 16 12:22:26 localhost kernel: 13 001 01 1 1 0 1 0 1 1 E9
Feb 16 12:22:26 localhost kernel: 14 001 01 1 1 0 1 0 1 1 C9
Feb 16 12:22:26 localhost kernel: 15 001 01 1 1 0 1 0 1 1 D1
Feb 16 12:22:26 localhost kernel: 16 001 01 1 1 0 1 0 1 1 D9
Feb 16 12:22:26 localhost kernel: 17 001 01 1 1 0 1 0 1 1 E1
Feb 16 12:22:26 localhost kernel: Using vector-based indexing
Feb 16 12:22:26 localhost kernel: IRQ to pin mappings:
Feb 16 12:22:26 localhost kernel: IRQ0 -> 0:16
Feb 16 12:22:26 localhost kernel: IRQ1 -> 0:1
Feb 16 12:22:26 localhost kernel: IRQ2 -> 0:2
Feb 16 12:22:26 localhost kernel: IRQ3 -> 0:3
Feb 16 12:22:26 localhost kernel: IRQ4 -> 0:4
Feb 16 12:22:26 localhost kernel: IRQ5 -> 0:5
Feb 16 12:22:26 localhost kernel: IRQ6 -> 0:6
Feb 16 12:22:26 localhost kernel: IRQ7 -> 0:7
Feb 16 12:22:26 localhost kernel: IRQ8 -> 0:8
Feb 16 12:22:26 localhost kernel: IRQ9 -> 0:9
Feb 16 12:22:26 localhost kernel: IRQ10 -> 0:10
Feb 16 12:22:26 localhost kernel: IRQ11 -> 0:11
Feb 16 12:22:26 localhost kernel: IRQ12 -> 0:12
Feb 16 12:22:26 localhost kernel: IRQ13 -> 0:13
Feb 16 12:22:26 localhost kernel: IRQ14 -> 0:14
Feb 16 12:22:26 localhost kernel: IRQ15 -> 0:15
Feb 16 12:22:26 localhost kernel: IRQ185 -> 0:16
Feb 16 12:22:26 localhost kernel: IRQ177 -> 0:17
Feb 16 12:22:26 localhost kernel: IRQ193 -> 0:18
Feb 16 12:22:26 localhost kernel: IRQ233 -> 0:19
Feb 16 12:22:26 localhost kernel: IRQ201 -> 0:20
Feb 16 12:22:26 localhost kernel: IRQ209 -> 0:21
Feb 16 12:22:26 localhost kernel: IRQ217 -> 0:22
Feb 16 12:22:26 localhost kernel: IRQ225 -> 0:23
Feb 16 12:22:26 localhost kernel: .................................... done.
Feb 16 12:22:26 localhost kernel: PCI: Cannot allocate resource region 4 of device 0000:00:02.1
Feb 16 12:22:26 localhost kernel: Simple Boot Flag at 0x35 set to 0x1
Feb 16 12:22:26 localhost kernel: VFS: Disk quotas dquot_6.5.1
Feb 16 12:22:26 localhost kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Feb 16 12:22:26 localhost kernel: devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
Feb 16 12:22:26 localhost kernel: devfs: boot_options: 0x0
Feb 16 12:22:26 localhost kernel: Initializing Cryptographic API
Feb 16 12:22:26 localhost kernel: isapnp: Scanning for PnP cards...
Feb 16 12:22:26 localhost kernel: isapnp: No Plug & Play device found
Feb 16 12:22:26 localhost kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 54 ports, IRQ sharing enabled
Feb 16 12:22:26 localhost kernel: RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
Feb 16 12:22:26 localhost kernel: i8042.c: Detected active multiplexing controller, rev 1.1.
Feb 16 12:22:26 localhost kernel: serio: i8042 AUX0 port at 0x60,0x64 irq 12
Feb 16 12:22:26 localhost kernel: serio: i8042 AUX1 port at 0x60,0x64 irq 12
Feb 16 12:22:26 localhost kernel: serio: i8042 AUX2 port at 0x60,0x64 irq 12
Feb 16 12:22:26 localhost kernel: serio: i8042 AUX3 port at 0x60,0x64 irq 12
Feb 16 12:22:26 localhost kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Feb 16 12:22:26 localhost kernel: input: AT Translated Set 2 keyboard on isa0060/serio0
Feb 16 12:22:26 localhost kernel: EISA: Probing bus 0 at eisa0
Feb 16 12:22:26 localhost kernel: Cannot allocate resource for EISA slot 1
Feb 16 12:22:26 localhost kernel: Cannot allocate resource for EISA slot 2
Feb 16 12:22:26 localhost kernel: Cannot allocate resource for EISA slot 8
Feb 16 12:22:26 localhost kernel: EISA: Detected 0 cards.
Feb 16 12:22:26 localhost kernel: NET: Registered protocol family 2
Feb 16 12:22:26 localhost kernel: IP: routing cache hash table of 4096 buckets, 32Kbytes
Feb 16 12:22:26 localhost kernel: TCP: Hash tables configured (established 32768 bind 65536)
Feb 16 12:22:26 localhost kernel: NET: Registered protocol family 8
Feb 16 12:22:26 localhost kernel: NET: Registered protocol family 20
Feb 16 12:22:26 localhost kernel: ACPI: (supports S0 S3 S4 S5)
Feb 16 12:22:26 localhost kernel: RAMDISK: cramfs filesystem found at block 0
Feb 16 12:22:26 localhost kernel: RAMDISK: Loading 4216 blocks [1 disk] into ram disk... |^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^Hdone.
Feb 16 12:22:26 localhost kernel: VFS: Mounted root (cramfs filesystem) readonly.
Feb 16 12:22:26 localhost kernel: Freeing unused kernel memory: 204k freed
Feb 16 12:22:26 localhost kernel: vesafb: framebuffer at 0xf0000000, mapped to 0xe0823000, size 4608k
Feb 16 12:22:26 localhost kernel: vesafb: mode is 1024x768x24, linelength=3072, pages=27
Feb 16 12:22:26 localhost kernel: vesafb: protected mode interface info at c000:53bb
Feb 16 12:22:26 localhost kernel: vesafb: scrolling: redraw
Feb 16 12:22:26 localhost kernel: vesafb: directcolor: size=0:8:8:8, shift=0:16:8:0
Feb 16 12:22:26 localhost kernel: fb0: VESA VGA frame buffer device
Feb 16 12:22:26 localhost kernel: Console: switching to colour frame buffer device 128x48
Feb 16 12:22:26 localhost kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Feb 16 12:22:26 localhost kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Feb 16 12:22:26 localhost kernel: SIS5513: IDE controller at PCI slot 0000:00:02.5
Feb 16 12:22:26 localhost kernel: SIS5513: chipset revision 0
Feb 16 12:22:26 localhost kernel: SIS5513: not 100%% native mode: will probe irqs later
Feb 16 12:22:26 localhost kernel: SIS5513: SiS 962/963 MuTIOL IDE UDMA133 controller
Feb 16 12:22:26 localhost kernel: ide0: BM-DMA at 0x2000-0x2007, BIOS settings: hda:DMA, hdb:pio
Feb 16 12:22:26 localhost kernel: ide1: BM-DMA at 0x2008-0x200f, BIOS settings: hdc:DMA, hdd:pio
Feb 16 12:22:26 localhost kernel: hda: HTS541080G9AT00, ATA DISK drive
Feb 16 12:22:26 localhost kernel: Using anticipatory io scheduler
Feb 16 12:22:26 localhost kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Feb 16 12:22:26 localhost kernel: hda: max request size: 1024KiB
Feb 16 12:22:26 localhost kernel: hda: 156301488 sectors (80026 MB) w/7539KiB Cache, CHS=16383/255/63, UDMA(100)
Feb 16 12:22:26 localhost kernel: /dev/ide/host0/bus0/target0/lun0: p1 p2 p3 p4 < p5 p6 p7 >
Feb 16 12:22:26 localhost kernel: hdc: MATSHITADVD-RAM UJ-811, ATAPI CD/DVD-ROM drive
Feb 16 12:22:26 localhost kernel: ide1 at 0x170-0x177,0x376 on irq 15
Feb 16 12:22:26 localhost kernel: EXT3-fs: INFO: recovery required on readonly filesystem.
Feb 16 12:22:26 localhost kernel: EXT3-fs: write access will be enabled during recovery.
Feb 16 12:22:26 localhost kernel: kjournald starting. Commit interval 5 seconds
Feb 16 12:22:26 localhost kernel: EXT3-fs: hda6: orphan cleanup on readonly fs
Feb 16 12:22:26 localhost kernel: ext3_orphan_cleanup: deleting unreferenced inode 82583
Feb 16 12:22:26 localhost kernel: ext3_orphan_cleanup: deleting unreferenced inode 82582
Feb 16 12:22:26 localhost kernel: EXT3-fs: hda6: 2 orphan inodes deleted
Feb 16 12:22:26 localhost kernel: EXT3-fs: recovery complete.
Feb 16 12:22:26 localhost kernel: EXT3-fs: mounted filesystem with ordered data mode.
Feb 16 12:22:26 localhost kernel: Adding 506008k swap on /dev/hda5. Priority:-1 extents:1
Feb 16 12:22:26 localhost kernel: EXT3 FS on hda6, internal journal
Feb 16 12:22:26 localhost kernel: Generic RTC Driver v1.07
Feb 16 12:22:26 localhost kernel: hdc: ATAPI 24X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache, UDMA(33)
Feb 16 12:22:26 localhost kernel: Uniform CD-ROM driver Revision: 3.20
Feb 16 12:22:26 localhost kernel: Synaptics Touchpad, model: 1
Feb 16 12:22:26 localhost kernel: Firmware: 5.8
Feb 16 12:22:26 localhost kernel: 180 degree mounted touchpad
Feb 16 12:22:26 localhost kernel: Sensor: 18
Feb 16 12:22:26 localhost kernel: new absolute packet format
Feb 16 12:22:26 localhost kernel: Touchpad has extended capability bits
Feb 16 12:22:26 localhost kernel: -> 4 multi-buttons, i.e. besides standard buttons
Feb 16 12:22:26 localhost kernel: -> multifinger detection
Feb 16 12:22:26 localhost kernel: -> palm detection
Feb 16 12:22:26 localhost kernel: input: SynPS/2 Synaptics TouchPad on isa0060/serio4
Feb 16 12:22:26 localhost kernel: slamr: module license 'Smart Link Ltd.' taints kernel.
Feb 16 12:22:26 localhost kernel: slamr: SmartLink AMRMO modem.
Feb 16 12:22:26 localhost kernel: slamr: probe 1039:7013 SiS630 card...
Feb 16 12:22:26 localhost kernel: slamr: mc97 codec is SIL27
Feb 16 12:22:26 localhost kernel: slamr: slamr0 is SiS630 card.
Feb 16 12:22:26 localhost kernel: Capability LSM initialized
Feb 16 12:22:26 localhost kernel: mice: PS/2 mouse device common for all mice
Feb 16 12:22:26 localhost kernel: ts: Compaq touchscreen protocol output
Feb 16 12:22:26 localhost kernel: EXT3 FS on hda7, internal journal
Feb 16 12:22:26 localhost kernel: Linux Kernel Card Services
Feb 16 12:22:26 localhost kernel: options: [pci] [cardbus] [pm]
Feb 16 12:22:26 localhost kernel: Yenta: CardBus bridge found at 0000:00:09.0 [17c0:3202]
Feb 16 12:22:26 localhost kernel: Yenta: Enabling burst memory read transactions
Feb 16 12:22:26 localhost kernel: Yenta: Using CSCINT to route CSC interrupts to PCI
Feb 16 12:22:26 localhost kernel: Yenta: Routing CardBus interrupts to PCI
Feb 16 12:22:26 localhost kernel: Yenta TI: socket 0000:00:09.0, mfunc 0x01001022, devctl 0x64
Feb 16 12:22:26 localhost kernel: Yenta: ISA IRQ mask 0x0cb8, PCI irq 185
Feb 16 12:22:26 localhost kernel: Socket status: 30000006
Feb 16 12:22:26 localhost kernel: Yenta: CardBus bridge found at 0000:00:09.1 [17c0:3202]
Feb 16 12:22:26 localhost kernel: Yenta TI: socket 0000:00:09.1, mfunc 0x01001022, devctl 0x64
Feb 16 12:22:26 localhost kernel: Yenta: ISA IRQ mask 0x0cb8, PCI irq 177
Feb 16 12:22:26 localhost kernel: 8139too Fast Ethernet driver 0.9.27
Feb 16 12:22:26 localhost kernel: eth0: Identified 8139 chip type 'RTL-8100B/8139D'
Feb 16 12:22:26 localhost kernel: Intel 810 + AC97 Audio, version 1.01, 13:08:13 Aug 16 2005
Feb 16 12:22:26 localhost kernel: i810: SiS 7012 found at IO 0x1c80 and 0x1400, MEM 0x0000 and 0x0000, IRQ 193
Feb 16 12:22:26 localhost kernel: i810_audio: Audio Controller supports 6 channels.
Feb 16 12:22:26 localhost kernel: i810_audio: Defaulting to base 2 channel mode.
Feb 16 12:22:26 localhost kernel: i810_audio: Resetting connection 0
Feb 16 12:22:26 localhost kernel: ac97_codec: AC97 Audio codec, id: 0x8384:0x7666 (SigmaTel STAC9750T)
Feb 16 12:22:26 localhost kernel: i810_audio: AC'97 codec 0 supports AMAP, total channels = 2
Feb 16 12:22:26 localhost kernel: i810_audio: setting clocking to 48669
Feb 16 12:22:26 localhost kernel: usbcore: registered new driver usbfs
Feb 16 12:22:26 localhost kernel: usbcore: registered new driver hub
Feb 16 12:22:26 localhost kernel: ohci_hcd: 2004 Feb 02 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
Feb 16 12:22:26 localhost kernel: ohci_hcd: block sizes: ed 64 td 64
Feb 16 12:22:26 localhost kernel: ohci_hcd 0000:00:03.0: Silicon Integrated Systems [SiS] USB 1.0 Controller
Feb 16 12:22:26 localhost kernel: ohci_hcd 0000:00:03.0: irq 201, pci mem e0d07000
Feb 16 12:22:26 localhost kernel: ohci_hcd 0000:00:03.0: new USB bus registered, assigned bus number 1
Feb 16 12:22:26 localhost kernel: hub 1-0:1.0: USB hub found
Feb 16 12:22:26 localhost kernel: hub 1-0:1.0: 2 ports detected
Feb 16 12:22:26 localhost kernel: ohci_hcd 0000:00:03.1: Silicon Integrated Systems [SiS] USB 1.0 Controller (#2)
Feb 16 12:22:26 localhost kernel: ohci_hcd 0000:00:03.1: irq 209, pci mem e0d99000
Feb 16 12:22:26 localhost kernel: ohci_hcd 0000:00:03.1: new USB bus registered, assigned bus number 2
Feb 16 12:22:26 localhost kernel: hub 2-0:1.0: USB hub found
Feb 16 12:22:26 localhost kernel: hub 2-0:1.0: 2 ports detected
Feb 16 12:22:26 localhost kernel: ohci_hcd 0000:00:03.2: Silicon Integrated Systems [SiS] USB 1.0 Controller (#3)
Feb 16 12:22:26 localhost kernel: ohci_hcd 0000:00:03.2: irq 217, pci mem e0da7000
Feb 16 12:22:26 localhost kernel: ohci_hcd 0000:00:03.2: new USB bus registered, assigned bus number 3
Feb 16 12:22:26 localhost kernel: hub 3-0:1.0: USB hub found
Feb 16 12:22:26 localhost kernel: hub 3-0:1.0: 2 ports detected
Feb 16 12:22:26 localhost kernel: usb 2-1: new low speed USB device using address 2
Feb 16 12:22:26 localhost kernel: usbcore: registered new driver hiddev
Feb 16 12:22:26 localhost kernel: input: USB HID v1.00 Mouse [1241:1122] on usb-0000:00:03.1-1
Feb 16 12:22:26 localhost kernel: usbcore: registered new driver usbhid
Feb 16 12:22:26 localhost kernel: drivers/usb/input/hid-core.c: v2.0:USB HID core driver
Feb 16 12:22:26 localhost kernel: Linux agpgart interface v0.100 (c) Dave Jones
Feb 16 12:22:26 localhost kernel: agpgart: Detected SiS 646 chipset
Feb 16 12:22:26 localhost kernel: agpgart: Maximum main memory to use for agp memory: 437M
Feb 16 12:22:26 localhost kernel: agpgart: AGP aperture is 64M @ 0xe8000000
Feb 16 12:22:26 localhost kernel: cpci_hotplug: CompactPCI Hot Plug Core version: 0.2
Feb 16 12:22:26 localhost kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Feb 16 12:22:26 localhost kernel: pciehp: PCI Express Hot Plug Controller Driver version: 0.4
Feb 16 12:22:26 localhost kernel: shpchp: shpc_init : shpc_cap_offset == 0
Feb 16 12:22:26 localhost kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Feb 16 12:22:26 localhost kernel: ieee1394: Initialized config rom entry `ip1394'
Feb 16 12:22:26 localhost kernel: ohci1394: $Rev: 1223 $ Ben Collins <bcollins@debian.org>
Feb 16 12:22:26 localhost kernel: ohci1394: fw-host0: Unexpected PCI resource length of 1000!
Feb 16 12:22:26 localhost kernel: ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[177] MMIO=[ec000000-ec0007ff] Max Packet=[2048]
Feb 16 12:22:26 localhost kernel: ieee1394: Host added: ID:BUS[0-00:1023] GUID[000ae403271009f1]
Feb 16 12:22:26 localhost kernel: ip1394: $Rev: 1224 $ Ben Collins <bcollins@debian.org>
Feb 16 12:22:26 localhost kernel: ip1394: eth1: IEEE-1394 IPv4 over 1394 Ethernet (fw-host0)
Feb 16 12:22:26 localhost kernel: ehci_hcd 0000:00:03.3: Silicon Integrated Systems [SiS] USB 2.0 Controller
Feb 16 12:22:26 localhost kernel: ehci_hcd 0000:00:03.3: irq 225, pci mem e0f3d000
Feb 16 12:22:26 localhost kernel: ehci_hcd 0000:00:03.3: new USB bus registered, assigned bus number 4
Feb 16 12:22:26 localhost kernel: PCI: cache line size of 128 is not supported by device 0000:00:03.3
Feb 16 12:22:26 localhost kernel: ehci_hcd 0000:00:03.3: USB 2.0 enabled, EHCI 1.00, driver 2004-May-10
Feb 16 12:22:26 localhost kernel: hub 4-0:1.0: USB hub found
Feb 16 12:22:26 localhost kernel: hub 4-0:1.0: 6 ports detected
Feb 16 12:22:26 localhost kernel: usb 2-1: USB disconnect, address 2
Feb 16 12:22:26 localhost kernel: ohci_hcd 0000:00:03.1: wakeup
Feb 16 12:22:26 localhost kernel: usb 2-1: new low speed USB device using address 3
Feb 16 12:22:26 localhost kernel: 8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
Feb 16 12:22:26 localhost kernel: input: PC Speaker
Feb 16 12:22:26 localhost kernel: inserting floppy driver for 2.6.8-2-386
Feb 16 12:22:26 localhost kernel: Floppy drive(s): fd0 is 1.44M
Feb 16 12:22:26 localhost kernel: FDC 0 is a National Semiconductor PC87306
Feb 16 12:22:26 localhost kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Feb 16 12:22:27 localhost kernel: ACPI: AC Adapter [AC] (on-line)
Feb 16 12:22:27 localhost kernel: ACPI: Processor [CPU0] (supports C1 C2)
Feb 16 12:22:27 localhost kernel: ACPI: Battery Slot [BAT0] (battery present)
Feb 16 12:22:27 localhost kernel: ACPI: Power Button (FF) [PWRF]
Feb 16 12:22:27 localhost kernel: ACPI: Sleep Button (CM) [SLP2]
Feb 16 12:22:27 localhost kernel: ACPI: Lid Switch [LID]
Feb 16 12:22:27 localhost kernel: ACPI: Thermal Zone [THRS] (61 C)
Feb 16 12:22:27 localhost kernel: ACPI: Thermal Zone [THRC] (64 C)
Feb 16 12:22:28 localhost kernel: lp: driver loaded but no devices found
Feb 16 12:22:29 localhost kernel: cs: IO port probe 0x0100-0x04ff: excluding 0x480-0x48f
Feb 16 12:22:29 localhost kernel: cs: IO port probe 0x0800-0x08ff: clean.
Feb 16 12:22:29 localhost kernel: cs: IO port probe 0x0c00-0x0cff: clean.
Feb 16 12:22:29 localhost kernel: cs: IO port probe 0x0a00-0x0aff: clean.
Feb 16 12:22:30 localhost kernel: NET: Registered protocol family 10
Feb 16 12:22:30 localhost kernel: Disabled Privacy Extensions on device c02cc960(lo)
Feb 16 12:22:30 localhost kernel: IPv6 over IPv4 tunneling driver
Feb 16 12:22:41 localhost kernel: eth0: no IPv6 routers present
Feb 16 12:24:35 localhost kernel: CSLIP: code copyright 1989 Regents of the University of California
Feb 16 12:24:35 localhost kernel: PPP generic driver version 2.4.2
Feb 16 12:25:01 localhost kernel: mtrr: 0xf0000000,0x4000000 overlaps existing 0xf0000000,0x400000
Feb 16 12:25:01 localhost kernel: [drm] Initialized radeon 1.11.0 20020828 on minor 0: ATI Technologies Inc Radeon R250 Lf [Radeon Mobility 9000 M9]
Feb 16 12:25:01 localhost kernel: agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
Feb 16 12:25:01 localhost kernel: agpgart: Putting AGP V2 device at 0000:00:00.0 into 1x mode
Feb 16 12:25:01 localhost kernel: agpgart: Putting AGP V2 device at 0000:01:00.0 into 1x mode
Feb 16 12:25:01 localhost kernel: [drm] Loading R200 Microcode
Feb 16 12:25:02 localhost kernel: irq 233: nobody cared!
Feb 16 12:25:02 localhost kernel: [__report_bad_irq+49/115] __report_bad_irq+0x31/0x73
Feb 16 12:25:02 localhost kernel: [note_interrupt+76/111] note_interrupt+0x4c/0x6f
Feb 16 12:25:02 localhost kernel: [do_IRQ+146/249] do_IRQ+0x92/0xf9
Feb 16 12:25:02 localhost kernel: [common_interrupt+24/32] common_interrupt+0x18/0x20
Feb 16 12:25:02 localhost kernel: handlers:
Feb 16 12:25:02 localhost kernel: [__crc_acpi_root_dir+162567/11227047] (rtl8139_interrupt+0x0/0x162 [8139too])
Feb 16 12:25:02 localhost kernel: Disabling IRQ #233
Feb 16 12:25:07 localhost kernel: PPP BSD Compression module registered
Feb 16 12:25:07 localhost kernel: PPP Deflate Compression module registered
Feb 16 12:25:41 localhost kernel: NET: Registered protocol family 4
Feb 16 12:25:41 localhost kernel: NET: Registered protocol family 3
Feb 16 12:25:41 localhost kernel: NET: Registered protocol family 5
Feb 16 12:25:52 localhost kernel: agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
Feb 16 12:25:52 localhost kernel: agpgart: Putting AGP V2 device at 0000:00:00.0 into 1x mode
Feb 16 12:25:52 localhost kernel: agpgart: Putting AGP V2 device at 0000:01:00.0 into 1x mode
Feb 16 12:25:52 localhost kernel: [drm] Loading R200 Microcode
Feb 16 12:27:46 localhost kernel: NETDEV WATCHDOG: eth0: transmit timed out
Feb 16 12:27:46 localhost kernel: eth0: Transmit timeout, status 0c 0005 c07f media 10.
Feb 16 12:27:46 localhost kernel: eth0: Tx queue start entry 45 dirty entry 41.
Feb 16 12:27:46 localhost kernel: eth0: Tx descriptor 0 is 0008a05c.
Feb 16 12:27:46 localhost kernel: eth0: Tx descriptor 1 is 0008a103. (queue head)
Feb 16 12:27:46 localhost kernel: eth0: Tx descriptor 2 is 0008a05c.
Feb 16 12:27:46 localhost kernel: eth0: Tx descriptor 3 is 0008a05c.
Feb 16 12:27:46 localhost kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Feb 16 12:32:40 localhost kernel: NETDEV WATCHDOG: eth0: transmit timed out
Feb 16 12:32:40 localhost kernel: eth0: Transmit timeout, status 0c 0005 c07f media 10.
Feb 16 12:32:40 localhost kernel: eth0: Tx queue start entry 4 dirty entry 0.
Feb 16 12:32:40 localhost kernel: eth0: Tx descriptor 0 is 0008a05c. (queue head)
Feb 16 12:32:40 localhost kernel: eth0: Tx descriptor 1 is 0008a0e1.
Feb 16 12:32:40 localhost kernel: eth0: Tx descriptor 2 is 0008a103.
Feb 16 12:32:40 localhost kernel: eth0: Tx descriptor 3 is 0008a103.
Feb 16 12:32:40 localhost kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Feb 16 12:32:52 localhost kernel: NETDEV WATCHDOG: eth0: transmit timed out
Feb 16 12:32:52 localhost kernel: eth0: Transmit timeout, status 0c 0005 c07f media 10.
Feb 16 12:32:52 localhost kernel: eth0: Tx queue start entry 4 dirty entry 0.
Feb 16 12:32:52 localhost kernel: eth0: Tx descriptor 0 is 0008a05c. (queue head)
Feb 16 12:32:52 localhost kernel: eth0: Tx descriptor 1 is 0008a05c.
Feb 16 12:32:52 localhost kernel: eth0: Tx descriptor 2 is 0008a05c.
Feb 16 12:32:52 localhost kernel: eth0: Tx descriptor 3 is 0008a05c.
Feb 16 12:32:52 localhost kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Feb 16 12:37:40 localhost kernel: NETDEV WATCHDOG: eth0: transmit timed out
Feb 16 12:37:40 localhost kernel: eth0: Transmit timeout, status 0c 0005 c07f media 10.
Feb 16 12:37:40 localhost kernel: eth0: Tx queue start entry 4 dirty entry 0.
Feb 16 12:37:40 localhost kernel: eth0: Tx descriptor 0 is 0008a0e1. (queue head)
Feb 16 12:37:40 localhost kernel: eth0: Tx descriptor 1 is 0008a103.
Feb 16 12:37:40 localhost kernel: eth0: Tx descriptor 2 is 0008a05c.
Feb 16 12:37:40 localhost kernel: eth0: Tx descriptor 3 is 0008a05c.
Feb 16 12:37:40 localhost kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Feb 16 12:42:40 localhost kernel: NETDEV WATCHDOG: eth0: transmit timed out
Feb 16 12:42:40 localhost kernel: eth0: Transmit timeout, status 0c 0005 c07f media 10.
Feb 16 12:42:40 localhost kernel: eth0: Tx queue start entry 4 dirty entry 0.
Feb 16 12:42:40 localhost kernel: eth0: Tx descriptor 0 is 0008a05c. (queue head)
Feb 16 12:42:40 localhost kernel: eth0: Tx descriptor 1 is 0008a05c.
Feb 16 12:42:40 localhost kernel: eth0: Tx descriptor 2 is 0008a0e1.
Feb 16 12:42:40 localhost kernel: eth0: Tx descriptor 3 is 0008a05c.
Feb 16 12:42:40 localhost kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Feb 16 12:42:51 localhost kernel: NETDEV WATCHDOG: eth0: transmit timed out
Feb 16 12:42:51 localhost kernel: eth0: Transmit timeout, status 0c 0005 c07f media 10.
Feb 16 12:42:51 localhost kernel: eth0: Tx queue start entry 4 dirty entry 0.
Feb 16 12:42:51 localhost kernel: eth0: Tx descriptor 0 is 0008a05c. (queue head)
Feb 16 12:42:51 localhost kernel: eth0: Tx descriptor 1 is 0008a05c.
Feb 16 12:42:51 localhost kernel: eth0: Tx descriptor 2 is 0008a05c.
Feb 16 12:42:51 localhost kernel: eth0: Tx descriptor 3 is 0008a0e1.
Feb 16 12:42:51 localhost kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
En fait, je me demande si en interdisant a ACPI de gérer ma carte réseau, ca serait pa mieux.
