Bonsoir,
Merci pour l’info Panthere
Par contre tu m’indiques de créer un dossier “opttep”, si je continue à le nommer “opt” sa peu pauser problème ?
Sachant que bien entendue j’ai fait en sorte de bien faire correspondre mon “home/opt” à mon “opt” ^^
Mais le hic … c’est que suite à cette utilisation de “mount”, l’installation semble ok, cependant dès que le script tente d’accéder aux fichiers dans “opt”, il m’indique des anomalies m’empechant l’utilisation du logiciel Zimbra
[code]root@ns38099:/home/LOGICIELS/zcs-5.0.7_GA_2444.DEBIAN4.0.20080626025055# linux32 ./install.sh
Operations logged to /tmp/install.log.22720
Checking for existing installation…
zimbra-ldap…NOT FOUND
zimbra-logger…NOT FOUND
zimbra-mta…NOT FOUND
zimbra-snmp…NOT FOUND
zimbra-store…NOT FOUND
zimbra-apache…NOT FOUND
zimbra-spell…NOT FOUND
zimbra-proxy…NOT FOUND
zimbra-archiving…NOT FOUND
zimbra-convertd…NOT FOUND
zimbra-cluster…NOT FOUND
zimbra-core…NOT FOUND
PLEASE READ THIS AGREEMENT CAREFULLY BEFORE USING THE SOFTWARE.
ZIMBRA, INC. (“ZIMBRA”) WILL ONLY LICENSE THIS SOFTWARE TO YOU IF YOU
FIRST ACCEPT THE TERMS OF THIS AGREEMENT. BY DOWNLOADING OR INSTALLING
THE SOFTWARE, OR USING THE PRODUCT, YOU ARE CONSENTING TO BE BOUND BY
THIS AGREEMENT. IF YOU DO NOT AGREE TO ALL OF THE TERMS OF THIS
AGREEMENT, THEN DO NOT DOWNLOAD, INSTALL OR USE THE PRODUCT.
License Terms for the Zimbra Collaboration Suite:
http://www.zimbra.com/license/zimbra_public_eula_2.1.html
Press Return to continue
Checking for prerequisites…
NPTL…FOUND
sudo…FOUND sudo-1.6.8p12-4
libidn11…FOUND libidn11-0.6.5-1
fetchmail…FOUND fetchmail-6.3.6-1etch1
libpcre3…FOUND libpcre3-6.7+7.4-4
libgmp3c2…FOUND libgmp3c2-2:4.2.1+dfsg-4
libexpat1…FOUND libexpat1-1.95.8-3.4
libxml2…FOUND libxml2-2.6.27.dfsg-2
libstdc++6…FOUND libstdc++6-4.1.1-21
openssl…FOUND openssl-0.9.8c-4etch3
libltdl3…FOUND libltdl3-1.5.22-4
Prerequisite check complete.
Checking for standard system perl…
perl-5.8.8…FOUND standard system perl-5.8.8
Checking for installable packages
Found zimbra-core
Found zimbra-ldap
Found zimbra-logger
Found zimbra-mta
Found zimbra-snmp
Found zimbra-store
Found zimbra-apache
Found zimbra-spell
Found zimbra-proxy
Select the packages to install
Install zimbra-ldap [Y] Y
Install zimbra-logger [Y] Y
Install zimbra-mta [Y] Y
Install zimbra-snmp [Y] Y
Install zimbra-store [Y] Y
Install zimbra-apache [Y] Y
Install zimbra-spell [Y] Y
Install zimbra-proxy [N] N
Checking required space for zimbra-core
checking space for zimbra-store
Installing:
zimbra-core
zimbra-ldap
zimbra-logger
zimbra-mta
zimbra-snmp
zimbra-store
zimbra-apache
zimbra-spell
The system will be modified. Continue? [N] Y
Removing /opt/zimbra
Installing packages
zimbra-core......zimbra-core_5.0.7_GA_2444.DEBIAN4.0_i386.deb...done
zimbra-ldap......zimbra-ldap_5.0.7_GA_2444.DEBIAN4.0_i386.deb...done
zimbra-logger......zimbra-logger_5.0.7_GA_2444.DEBIAN4.0_i386.deb...done
zimbra-mta......zimbra-mta_5.0.7_GA_2444.DEBIAN4.0_i386.deb...done
zimbra-snmp......zimbra-snmp_5.0.7_GA_2444.DEBIAN4.0_i386.deb...done
zimbra-store......zimbra-store_5.0.7_GA_2444.DEBIAN4.0_i386.deb...done
zimbra-apache......zimbra-apache_5.0.7_GA_2444.DEBIAN4.0_i386.deb...done
zimbra-spell......zimbra-spell_5.0.7_GA_2444.DEBIAN4.0_i386.deb...done
Can’t load ‘/opt/zimbra/zimbramon/lib/i486-linux-gnu-thread-multi/auto/IO/IO.so’ for module IO: /opt/zimbra/zimbramon/lib/i486-linux-gnu-thread-multi/auto/IO/IO.so: Ne peut ouvrir le fichier d’objet partagé: Aucun fichier ou répertoire de ce type at /usr/lib/perl/5.8/XSLoader.pm line 70.
at /opt/zimbra/zimbramon/lib/i486-linux-gnu-thread-multi/IO.pm line 11
Compilation failed in require at /opt/zimbra/zimbramon/lib/i486-linux-gnu-thread-multi/IO/Handle.pm line 263.
BEGIN failed–compilation aborted at /opt/zimbra/zimbramon/lib/i486-linux-gnu-thread-multi/IO/Handle.pm line 263.
Compilation failed in require at /opt/zimbra/zimbramon/lib/i486-linux-gnu-thread-multi/IO/Socket.pm line 11.
BEGIN failed–compilation aborted at /opt/zimbra/zimbramon/lib/i486-linux-gnu-thread-multi/IO/Socket.pm line 11.
Compilation failed in require at /opt/zimbra/zimbramon/lib/Net/LDAP.pm line 8.
BEGIN failed–compilation aborted at /opt/zimbra/zimbramon/lib/Net/LDAP.pm line 8.
Compilation failed in require at /opt/zimbra/libexec/zmsetup.pl line 22.
BEGIN failed–compilation aborted at /opt/zimbra/libexec/zmsetup.pl line 22.
root@ns38099:/home/LOGICIELS/zcs-5.0.7_GA_2444.DEBIAN4.0.20080626025055#[/code]
Est ce que la méthode “mount” n’est pas à l’origine de ces erreurs ?
