j’ai effectuer un petit “ls” sur le répertoire d’installation pour voir
# ls /etc/phpmyadmin/
apache.conf config.footer.inc.php config.inc.php htpasswd.setup
blowfish_secret.inc.php config.header.inc.php htaccess
il ne manquerai pas des fichier ? style index.php, main.php etc…
dsl j’aiavit pas vu la réponse pour le /var/www il y’est déjà quand il s’install normalement
petit ls
# ls /var/www/
apache2-default phpmyadmin
et ls sur le répertoire phpmyadmin
ls /var/www/phpmyadmin
browse_foreigners.php README
calendar.php readme.php
ChangeLog scripts
changelog.php server_binlog.php
chk_rel.php server_collations.php
config server_databases.php
config.footer.inc.php server_engines.php
config.header.inc.php server_export.php
config.inc.php server_import.php
config.sample.inc.php server_privileges.php
css server_processlist.php
db_create.php server_sql.php
db_datadict.php server_status.php
db_details_export.php server_variables.php
db_details_importdocsql.php show_config_errors.php
db_details.php sql.php
db_details_qbe.php tbl_addfield.php
db_details_structure.php tbl_alter.php
db_import.php tbl_change.php
db_operations.php tbl_create.php
db_printview.php tbl_import.php
db_search.php tbl_indexes.php
docs.css tbl_move_copy.php
Documentation.html tbl_printview.php
error.php tbl_properties_export.php
export.php tbl_properties_operations.php
import.php tbl_properties.php
index.php tbl_properties_structure.php
INSTALL tbl_relation.php
js tbl_replace.php
lang tbl_row_action.php
left.php tbl_select.php
libraries themes
license.php themes.php
main.php transformation_overview.php
pdf_pages.php transformation_wrapper.php
pdf_schema.php translators.html
phpinfo.php user_password.php
querywindow.php
donc théoriquement il devrait etre accessible :s
