Je me suis lancé, à savoir prendre le ssl-cert dans la Sid.
L’installation du paquet finalise l’installation des paquets “perturbés”.
Par contre, GDM a crashé 2 fois avant de vouloir m’ouvrir une session, je ne sais pas si c’est lié
/var/log/syslog :
Feb 25 21:52:59 srv-deb gdm[2526]: WARNING: gdm_cleanup_children: child 2532 crashed of signal 6
Feb 25 21:52:59 srv-deb gdm[2526]: WARNING: gdm_cleanup_children: Slave crashed, killing its children
Feb 25 22:01:51 srv-deb gdm[2526]: WARNING: gdm_cleanup_children: child 2613 crashed of signal 6
Feb 25 22:01:51 srv-deb gdm[2526]: WARNING: gdm_cleanup_children: Slave crashed, killing its children
Feb 25 22:03:27 srv-deb NetworkManager: <info> Updating allowed wireless network lists.
Feb 25 22:03:27 srv-deb NetworkManager: <WARN> nm_dbus_get_networks_cb(): error received: org.freedesktop.NetworkManagerInfo.NoNetworks - There are no wireless networks stored..
/var/log/gdm/:0.log
[code]X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Linux Debian (xorg-server 2:1.3.0.0.dfsg-12lenny2)
Current Operating System: Linux srv-deb 2.6.22-3-686 #1 SMP Sun Feb 10 20:20:49 UTC 2008 i686
Build Date: 19 January 2008
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Mon Feb 25 22:06:53 2008
(==) Using config file: “/etc/X11/xorg.conf”
(II) Module already built-in
(EE) AIGLX: Screen 0 is not DRI capable
expected keysym, got XF86KbdLightOnOff: line 70 of pc
expected keysym, got XF86KbdBrightnessDown: line 71 of pc
expected keysym, got XF86KbdBrightnessUp: line 72 of pc
The XKEYBOARD keymap compiler (xkbcomp) reports:
Warning: Type “ONE_LEVEL” has 1 levels, but has 2 symbols
Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!
Could not init font path element /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType, removing from list!
Ce serait un problème de driver graphique avec AIGLX ?
Ce que je ne comprends pas, c’est que depuis le 3ème essai, ca marche bien
