J’ai bien importé mon certificat SSL dans Icedove et la récupération en IMAP via SSL/TLS se fait correctement ; tout ce gâte lors d’un test d’envoi
voici les informations utiles :
/etc/postfix/master.cf
> smtp inet n - - - - smtpd
submission inet n - - - - smtpd -o syslog_name=postfix/submission -o smtpd_tls_dh1024_param_file=${config_directory}/dh2048.pem -o smtpd_tls_security_level=encrypt -o smtpd_sasl_auth_enable=yes -o smtpd_client_restrictions=permit_sasl_authenticated,reject pickup unix n - - 60 1 pickup cleanup unix n - - - 0 cleanup qmgr unix n - n 300 1 qmgr tlsmgr unix - - - 1000? 1 tlsmgr rewrite unix - - - - - trivial-rewrite bounce unix - - - - 0 bounce defer unix - - - - 0 bounce trace unix - - - - 0 bounce verify unix - - - - 1 verify flush unix n - - 1000? 0 flush proxymap unix - - n - - proxymap proxywrite unix - - n - 1 proxymap smtp unix - - - - - smtp relay unix - - - - - smtp showq unix n - - - - showq error unix - - - - - error retry unix - - - - - error discard unix - - - - - discard local unix - n n - - local virtual unix - n n - - virtual lmtp unix - - - - - lmtp anvil unix - - - - 1 anvil scache unix - - - - 1 scache maildrop unix - n n - - pipe flags=DRhu user=vmail argv=/usr/bin/maildrop -d ${recipient} uucp unix - n n - - pipe flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient) ifmail unix - n n - - pipe flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient) bsmtp unix - n n - - pipe flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient scalemail-backend unix - n n - 2 pipe flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension} mailman unix - n n - - pipe flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py ${nexthop} ${user}
ports :
> tcp 0 0 0.0.0.0:25 0.0.0.0:* LISTEN 4116/master
tcp 0 0 0.0.0.0:993 0.0.0.0:* LISTEN 3136/dovecot
tcp 0 0 0.0.0.0:587 0.0.0.0:* LISTEN 4116/master tcp 0 0 0.0.0.0:143 0.0.0.0:* LISTEN 3136/dovecot
Lors du test d’envoi depuis Icedove ; les logs coté serveurs :
May 14 20:49:22 x postfix/submission/smtpd[5469]: connect from nor75-7-81-57-85-231.fbx.proxad.net[xxxxxxx]
May 14 20:49:23 x postfix/submission/smtpd[5469]: Anonymous TLS connection established from nor75-7-81-57-85-231.fbx.proxad.net[xxxxxxxx]: TLSv1.2 with cipher ECDHE-RSA-AES256-SHA (256/256 bits)
May 14 20:49:23 x postfix/submission/smtpd[5469]: warning: TLS library problem: error:14094412:SSL routines:SSL3_READ_BYTES:sslv3 alert bad certificate:s3_pkt.c:1294:SSL alert number 42:
May 14 20:49:23 x postfix/submission/smtpd[5469]: lost connection after STARTTLS from nor75-7-81-57-85-231.fbx.proxad.net[xxxxxxxxx]
May 14 20:49:23 2emedb postfix/submission/smtpd[5469]: disconnect from nor75-7-81-57-85-231.fbx.proxad.net[xxxxxxxxx]
coté client :
L'envoi du message a échoué.
Le message n'a pas pu être envoyé en utilisant le serveur sortant (SMTP) « FQDN » pour une raison inconnue. Veuillez vérifier que les paramètres de votre serveur sortant (SMTP) sont corrects et essayez à nouveau.
Le certificat du serveur est déjà dans la liste des certificats autorisés, le Handshake se fait bien coté IMAP:993 mais pas pour SMTP:587
J’ai un pop-up qui me propose de télécharger le certificat sur mon fqdn:587 mais quand je mets “obtenir le certificat”, tout devient grisé et seul le bouton annuler reste actif.
Quand je fais “voir le certificat” j’ai:
> ce certificat a été certifié pour les utilisations suivantes :
Certificat client SSL Certificat serveur SSL Certificat de signature de courrier Certificat de réception de courrier
Il ne semble pas valide pour l’envoi ???
et comment modifier ça ???
openssl s_client -connect 2emedb.leotxando.net:587
CONNECTED(00000003)
139758597551760:error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol:s23_clnt.c:795:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 7 bytes and written 289 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
Aucun handshake ne se fait :’(
pourtant :
telnet localhost 25
Trying ::1…
Trying 127.0.0.1…
Connected to localhost.
Escape character is ‘^]’.
220 2emedb.leotxando.net ESMTP Postfix (Debian/GNU)
ehlo localhost
250-2emedb.leotxando.net
250-PIPELINING
250-SIZE 502400000
250-ETRN
250-STARTTLS
250-ENHANCEDSTATUSCODES
250-8BITMIME
250 DSN
STARTTLS est bien activé.
petit extrait du /etc/postfix/main.cf :
> # Smtp ( OUTGOING / Client )
smtp_tls_loglevel = 1 smtp_tls_security_level = may smtp_tls_CAfile = /etc/ssl/certs/ca.cert.pem smtp_tls_protocols = !SSLv2, !SSLv3 smtp_tls_mandatory_protocols = !SSLv2, !SSLv3 smtp_tls_mandatory_ciphers = high smtp_tls_exclude_ciphers = aNULL, eNULL, EXPORT, DES, 3DES, RC2, RC4, MD5, PSK, SRP, DSS, AECDH, ADH smtp_tls_note_starttls_offer = yes
# Smtpd ( INCOMING / Server ) smtpd_tls_loglevel = 1 smtpd_tls_auth_only = yes smtpd_tls_security_level = may smtpd_tls_received_header = yes smtpd_tls_protocols = !SSLv2, !SSLv3 smtpd_tls_mandatory_protocols = !SSLv2, !SSLv3 smtpd_tls_mandatory_ciphers = medium
# Infos (voir : postconf -d) # Medium cipherlist = aNULL:-aNULL:ALL:!EXPORT:!LOW:+RC4:@STRENGTH # High cipherlist = aNULL:-aNULL:ALL:!EXPORT:!LOW:!MEDIUM:+RC4:@STRENGTH
# smtpd_tls_exclude_ciphers = NE PAS modifier cette directive pour des raisons de compatibilité # avec les autres serveurs de mail afin d'éviter une erreur du type # "no shared cipher" ou "no cipher overlap" puis un fallback en # plain/text... # smtpd_tls_cipherlist = Ne pas modifier non plus !
smtpd_tls_CAfile = $smtp_tls_CAfile smtpd_tls_cert_file = /etc/ssl/certs/mailserver.crt smtpd_tls_key_file = /etc/ssl/private/mailserver.key smtpd_tls_dh1024_param_file = $config_directory/dh2048.pem smtpd_tls_dh512_param_file = $config_directory/dh512.pem
Un grand merci pour votre aide !
