salut les mia
je grave sans problème les dvd-rw mais pas les dvd-r!
message de k3b :
medias is not formatted or not supported
les infos de debogage :
System
K3b Version: 1.0.4
KDE Version: 3.5.8
QT Version: 3.3.8b
Kernel: 2.6.22-3-486
Devices
Optiarc DVD RW AD-7173A 1-01 (/dev/hdc, ) [CD-R, CD-RW, CD-ROM, DVD-ROM, DVD-R, DVD-RW, DVD-R DL, DVD+R, DVD+RW, DVD+R DL] [DVD-ROM, DVD-R séquentiel, DVD-R double couche séquentiel, DVD+R double couche à saut, DVD-RAM, DVD RW à réinscription limitée, DVD-RW séquentiel, DVD+RW, DVD+R, DVD+R double couche, CD-ROM, CD-R, CD-RW] [SAO, TAO, RAW, SAO/R96P, SAO/R96R, RAW/R16, RAW/R96P, RAW/R96R, Réinscription restreinte, Saut de couche]
SAMSUNG CD-ROM SC-152L C100 (/dev/hdd, ) [CD-ROM] [CD-ROM] [Aucune]
Burned media
DVD-R séquentiel
K3bIsoImager
mkisofs print size result: 2105471 (4312004608 bytes)
Pipe throughput: 33672192 bytes read, 33667840 bytes written.
Used versions
mkisofs: 1.1.6
growisofs: 7.0.1
growisofs
Executing ‘builtin_dd if=/dev/fd/0 of=/dev/hdc obs=32k seek=0’
/dev/hdc: “Current Write Speed” is 1.0x1352KBps.
:-[ WRITE@LBA=0h failed with SK=5h/ASC=30h/ACQ=05h]: Wrong medium type
media is not formatted or unsupported.
write failed: Wrong medium type
growisofs command:
/usr/bin/growisofs -Z /dev/hdc=/dev/fd/0 -use-the-force-luke=notray -use-the-force-luke=tty -use-the-force-luke=tracksize:2105471 -dvd-compat -speed=2.4 -use-the-force-luke=bufsize:32m
mkisofs
2105471
I: -input-charset not specified, using utf-8 (detected in locale settings)
0.02% done, estimate finish Thu Mar 6 16:26:02 2008
0.05% done, estimate finish Thu Mar 6 16:26:02 2008
0.07% done, estimate finish Thu Mar 6 16:26:02 2008
0.10% done, estimate finish Thu Mar 6 16:26:02 2008
0.12% done, estimate finish Thu Mar 6 16:26:02 2008
0.14% done, estimate finish Thu Mar 6 16:26:02 2008
0.17% done, estimate finish Thu Mar 6 16:26:02 2008
0.19% done, estimate finish Thu Mar 6 16:26:02 2008
0.21% done, estimate finish Thu Mar 6 16:26:02 2008
0.24% done, estimate finish Thu Mar 6 16:33:02 2008
0.26% done, estimate finish Thu Mar 6 16:32:24 2008
0.29% done, estimate finish Thu Mar 6 16:31:52 2008
0.31% done, estimate finish Thu Mar 6 16:31:25 2008
0.33% done, estimate finish Thu Mar 6 16:31:02 2008
0.36% done, estimate finish Thu Mar 6 16:30:42 2008
0.38% done, estimate finish Thu Mar 6 16:30:24 2008
0.40% done, estimate finish Thu Mar 6 16:30:09 2008
0.43% done, estimate finish Thu Mar 6 16:29:55 2008
0.45% done, estimate finish Thu Mar 6 16:29:43 2008
0.48% done, estimate finish Thu Mar 6 16:29:32 2008
0.50% done, estimate finish Thu Mar 6 16:29:22 2008
0.52% done, estimate finish Thu Mar 6 16:32:24 2008
0.55% done, estimate finish Thu Mar 6 16:32:08 2008
0.57% done, estimate finish Thu Mar 6 16:31:52 2008
0.59% done, estimate finish Thu Mar 6 16:31:38 2008
0.62% done, estimate finish Thu Mar 6 16:31:25 2008
0.64% done, estimate finish Thu Mar 6 16:31:13 2008
0.67% done, estimate finish Thu Mar 6 16:31:02 2008
0.69% done, estimate finish Thu Mar 6 16:30:52 2008
0.71% done, estimate finish Thu Mar 6 16:30:42 2008
0.74% done, estimate finish Thu Mar 6 16:30:33 2008
0.76% done, estimate finish Thu Mar 6 16:32:36 2008
mkisofs calculate size command:
/usr/bin/genisoimage -gui -graft-points -print-size -quiet -volid A History Of Violence Dvdrip Fr -volset -appid K3B THE CD KREATOR © 1998-2006 SEBASTIAN TRUEG AND THE K3B TEAM -publisher -preparer -sysid LINUX -volset-size 1 -volset-seqno 1 -sort /tmp/kde-diod/k3bMIgugb.tmp -rational-rock -hide-list /tmp/kde-diod/k3bZW1IRb.tmp -joliet -joliet-long -hide-joliet-list /tmp/kde-diod/k3bZ1Czbc.tmp -no-cache-inodes -full-iso9660-filenames -iso-level 2 -path-list /tmp/kde-diod/k3b47Gzqc.tmp
mkisofs command:
/usr/bin/genisoimage -gui -graft-points -volid A History Of Violence Dvdrip Fr -volset -appid K3B THE CD KREATOR © 1998-2006 SEBASTIAN TRUEG AND THE K3B TEAM -publisher -preparer -sysid LINUX -volset-size 1 -volset-seqno 1 -sort /tmp/kde-diod/k3bbxriXb.tmp -rational-rock -hide-list /tmp/kde-diod/k3bLcM4Ya.tmp -joliet -joliet-long -hide-joliet-list /tmp/kde-diod/k3bxR2cjc.tmp -no-cache-inodes -full-iso9660-filenames -iso-level 2 -path-list /tmp/kde-diod/k3bt5rAtc.tmp
