En voulant utiliser le pilote fglrx, il y a une erreure fatale. Voici le Xorg.0.log :
[code]
X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Linux Debian (xorg-server 2:1.3.0.0.dfsg-12lenny1)
Current Operating System: Linux defouilloy 2.6.22-3-686 #1 SMP Mon Nov 12 08:32:57 UTC 2007 i686
Build Date: 20 October 2007
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Sat Dec 29 01:49:07 2007
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
() |–>Screen “Default Screen” (0)
() | |–>Monitor “LG”
() | |–>Device “ATI RADEON A9250”
() |–>Input Device “Generic Keyboard”
() |–>Input Device “Configured Mouse”
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
(WW) `fonts.dir’ not found (or not valid) in “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType”.
(Run ‘mkfontdir’ on “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType”).
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to “/etc/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81e52a0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.2
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.2
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,1a30 card 147b,7402 rev 11 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,1a31 card 0000,0000 rev 11 class 06,04,00 hdr 01
(II) PCI: 00:1d:0: chip 8086,24c2 card 147b,7402 rev 01 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,24c4 card 147b,7402 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,24c7 card 147b,7402 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,24cd card 147b,7402 rev 01 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev 81 class 06,04,00 hdr 01
(II) PCI: 00:1f:0: chip 8086,24c0 card 0000,0000 rev 01 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,24cb card 147b,7402 rev 01 class 01,01,8a hdr 00
(II) PCI: 00:1f:3: chip 8086,24c3 card 147b,7402 rev 01 class 0c,05,00 hdr 00
(II) PCI: 00:1f:5: chip 8086,24c5 card 147b,7402 rev 01 class 04,01,00 hdr 00
(II) PCI: 01:00:0: chip 1002,5960 card 1043,004c rev 01 class 03,00,00 hdr 80
(II) PCI: 01:00:1: chip 1002,5940 card 1043,004d rev 01 class 03,80,00 hdr 00
(II) PCI: 02:03:0: chip 14f1,2f00 card 14f1,2004 rev 01 class 07,80,00 hdr 00
(II) PCI: 02:05:0: chip 10ec,8139 card 147b,7402 rev 10 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000e (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
[1] -1 0 0x00009400 - 0x000094ff (0x100) IX[B]
[2] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[3] -1 0 0x00009c00 - 0x00009cff (0x100) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xe4000000 - 0xe5ffffff (0x2000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:30:0), (0,2,2), BCTRL: 0x0006 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[1] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
[2] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[3] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xe6000000 - 0xe7ffffff (0x2000000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0x20000000 - 0x200fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI:*(1:0:0) ATI Technologies Inc RV280 [Radeon 9200 PRO] rev 1, Mem @ 0xd0000000/27, 0xe5000000/16, I/O @ 0x9000/8
(–) PCI: (1:0:1) ATI Technologies Inc RV280 [Radeon 9200 PRO] (Secondary) rev 1, Mem @ 0xd8000000/27, 0xe5010000/16
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe0000000 from 0xe3ffffff to 0xdfffffff
(II) Active PCI resource ranges:
[0] -1 0 0xe7010000 - 0xe70100ff (0x100) MX[B]
[1] -1 0 0xe7000000 - 0xe700ffff (0x10000) MX[B]
[2] -1 0 0xe8002000 - 0xe80020ff (0x100) MX[B]
[3] -1 0 0xe8001000 - 0xe80011ff (0x200) MX[B]
[4] -1 0 0x20100000 - 0x201003ff (0x400) MX[B]
[5] -1 0 0xe8000000 - 0xe80003ff (0x400) MX[B]
[6] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[7] -1 0 0xe5010000 - 0xe501ffff (0x10000) MXB
[8] -1 0 0xd8000000 - 0xdfffffff (0x8000000) MXB
[9] -1 0 0xe5000000 - 0xe500ffff (0x10000) MXB
[10] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MXB
[11] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
[12] -1 0 0x0000a000 - 0x0000a007 (0x8) IX[B]
[13] -1 0 0x0000c400 - 0x0000c43f (0x40) IX[B]
[14] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[15] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[16] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[17] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[18] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[19] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[20] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[21] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[22] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[23] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[24] -1 0 0x00009000 - 0x000090ff (0x100) IXB
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
[0] -1 0 0x00100000 - 0x200fffff (0x20000000) MX[B]E(B)
(II) All system resource ranges:
[4] -1 0 0xe7010000 - 0xe70100ff (0x100) MX[B]
[5] -1 0 0xe7000000 - 0xe700ffff (0x10000) MX[B]
[6] -1 0 0xe8002000 - 0xe80020ff (0x100) MX[B]
[7] -1 0 0xe8001000 - 0xe80011ff (0x200) MX[B]
[8] -1 0 0x20100000 - 0x201003ff (0x400) MX[B]
[9] -1 0 0xe8000000 - 0xe80003ff (0x400) MX[B]
[10] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[11] -1 0 0xe5010000 - 0xe501ffff (0x10000) MXB
[12] -1 0 0xd8000000 - 0xdfffffff (0x8000000) MXB
[13] -1 0 0xe5000000 - 0xe500ffff (0x10000) MXB
[14] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MXB
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[17] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
[18] -1 0 0x0000a000 - 0x0000a007 (0x8) IX[B]
[19] -1 0 0x0000c400 - 0x0000c43f (0x40) IX[B]
[20] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[21] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[22] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[23] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[24] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[25] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[26] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[27] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[28] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[29] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[30] -1 0 0x00009000 - 0x000090ff (0x100) IXB
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 1.3.0, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “fglrx”
(II) Loading /usr/lib/xorg/modules/drivers//fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 7.1.0, module version = 8.43.2
Module class: X.Org Video Driver
(II) LoadModule: “kbd”
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.2.1
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.7
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.2.2
(II) Primary Device is: PCI 01:00:0
(II) ATI Proprietary Linux Driver Version Identifier:8.43.2
(II) ATI Proprietary Linux Driver Release Identifier: UNSUPPORTED-8.433
(II) ATI Proprietary Linux Driver Build Date: Nov 9 2007 21:19:16
(WW) fglrx: No matching Device section for instance (BusID PCI:1:0:1) found
(EE) No devices detected.
Fatal server error:
no screens found[/code]
En attendant j’utilise toujours “vesa”.
