Bonsoir,
Voilà mon problème :
Le serveur de visuels a été arrêté près de 6 fois dans les dernieres 90 secondes, il ya quelquechose de mauvais qui se passe (çà j’ aurais pu le deviner tout seul !!). Je vais attendre 2 mn avant d’ essayer de nouveau sur le visuel :0.
ci-contre le fichier XFree86.0.log
II) VESA(0): Total Memory: 1024 64KB banks (65536kB)
(II) VESA(0): e1770NSL/T: Using hsync range of 30.00-70.00 kHz
(II) VESA(0): e1770NSL/T: Using vrefresh range of 50.00-160.00 Hz
(II) VESA(0): Not using built-in mode “1280x1024” (width too large for virtual size)
(–) VESA(0): Virtual size is 1024x768 (pitch 1024)
() VESA(0): *Built-in mode “1024x768”
() VESA(0): *Built-in mode “800x600”
() VESA(0): *Built-in mode “640x480”
() VESA(0): Built-in mode “640x400”
() VESA(0): Built-in mode “640x350”
(–) VESA(0): Display dimensions: (320, 240) mm
(–) VESA(0): DPI set to (81, 81)
(II) VESA(0): Attempting to use 85Hz refresh for mode “1024x768” (118)
(II) VESA(0): Attempting to use 85Hz refresh for mode “800x600” (115)
(II) VESA(0): Attempting to use 85Hz refresh for mode “640x480” (112)
(II) VESA(0): Attempting to use 85Hz refresh for mode “640x400” (185)
(II) VESA(0): Attempting to use 85Hz refresh for mode “640x350” (1c5)
() VESA(0): Using “Shadow Framebuffer”
(II) Loading sub module “shadow”
(II) LoadModule: “shadow”
(II) Loading /usr/X11R6/lib/modules/libshadow.a
(II) Module shadow: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.0.0
ABI class: XFree86 ANSI C Emulation, version 0.2
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
(==) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don’t.
(II) resource ranges after preInit:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MXB
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0xd3101000 - 0xd3101fff (0x1000) MX[B]
[6] -1 0 0xd3000000 - 0xd3003fff (0x4000) MX[B]
[7] -1 0 0xd3004000 - 0xd30047ff (0x800) MX[B]
[8] -1 0 0xd3211000 - 0xd32110ff (0x100) MX[B]
[9] -1 0 0xd3200000 - 0xd320ffff (0x10000) MX[B]
[10] -1 0 0xd3210000 - 0xd32100ff (0x100) MX[B]
[11] -1 0 0xb0000000 - 0xafffffff (0x0) MX[B]O
[12] -1 0 0xd3100000 - 0xd3100fff (0x1000) MXB
[13] -1 0 0xd1000000 - 0xd100ffff (0x10000) MXB
[14] -1 0 0xc0000000 - 0xc7ffffff (0x8000000) MXB
[15] -1 0 0xd1010000 - 0xd101ffff (0x10000) MXB
[16] -1 0 0xc8000000 - 0xcfffffff (0x8000000) MXB
[17] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[18] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[19] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[20] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[21] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[22] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[23] -1 0 0x0000e400 - 0x0000e40f (0x10) IX[B]
[24] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
[25] -1 0 0x0000dc00 - 0x0000dc1f (0x20) IX[B]
[26] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[27] -1 0 0x0000d400 - 0x0000d407 (0x8) IX[B]
[28] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]
[29] -1 0 0x0000c000 - 0x0000c0ff (0x100) IXB
[30] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[31] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Loading sub module “int10”
(II) LoadModule: “int10”
(II) Reloading /usr/X11R6/lib/modules/linux/libint10.a
(II) VESA(0): initializing int10
(II) VESA(0): Primary V_BIOS segment is: 0xc000
(II) VESA(0): VESA BIOS detected
(II) VESA(0): VESA VBE Version 2.0
(II) VESA(0): VESA VBE Total Mem: 65536 kB
(II) VESA(0): VESA VBE OEM: ATI RADEON 9200
(II) VESA(0): VESA VBE OEM Software Rev: 1.0
(II) VESA(0): VESA VBE OEM Vendor: ATI Technologies Inc.
(II) VESA(0): VESA VBE OEM Product: V280
(II) VESA(0): VESA VBE OEM Product Rev: 01.00
(WW) VESA(0): Failed to set up write-combining range (0xc0000000,0x4000000)
(II) VESA(0): virtual address = 0x40290000,
physical address = 0xc0000000, size = 67108864
(II) VESA(0): VBESetVBEMode failed…Tried again without customized values.
(==) VESA(0): Default visual is TrueColor
(==) VESA(0): Backing store disabled
() Option “dpms”
() VESA(0): DPMS enabled
(==) RandR enabled
(II) Setting vga for screen 0.
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Keyboard “Generic Keyboard” handled by legacy driver
() Option “Protocol” “ImPS/2”
() Configured Mouse: Protocol: “ImPS/2”
() Option “CorePointer”
() Configured Mouse: Core Pointer
() Option “Device” “/dev/input/mice”
() Option “Emulate3Buttons” “true”
() Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
() Option “ZAxisMapping” “4 5”
() Configured Mouse: ZAxisMapping: buttons 4 and 5
() Configured Mouse: Buttons: 5
(II) XINPUT: Adding extended input device “Configured Mouse” (type: MOUSE)
(II) Configured Mouse: ps2EnableDataReporting: succeeded
Warning: font renderer for “.pcf” already registered at priority 0
Warning: font renderer for “.pcf.Z” already registered at priority 0
Warning: font renderer for “.pcf.gz” already registered at priority 0
Warning: font renderer for “.snf” already registered at priority 0
Warning: font renderer for “.snf.Z” already registered at priority 0
Warning: font renderer for “.snf.gz” already registered at priority 0
Warning: font renderer for “.bdf” already registered at priority 0
Warning: font renderer for “.bdf.Z” already registered at priority 0
Warning: font renderer for “.bdf.gz” already registered at priority 0
Warning: font renderer for “.pmf” already registered at priority 0
Could not init font path element unix/:7100, removing from list!
J’ ai fait un aptitude install hal
il me renvoie un message d’ erreur :
Impossible de corriger les dépendances.
Impossible de corriger le problème car les paquets défectueux sont en mode “garder en l’ état”.
Quelqu’ un peut-il m’ aider ?
Merci d’ avance
