J’ai installé debian et ensuite j’ai voulu installer le pilote de ma carte graphique une NVIDIA GeForce GT 525M.
Pour ce faire, j’ai suivis le wiki associé ici : http://wiki.debian.org/fr/NvidiaGraphicsDrivers
Voici comment j’ai procédé pour l’installation :
Puis j’ai créé le /etc/X11/xorg.conf suivant :
[code]Section "Module"
Load "glx"
EndSection
Section "Device"
Identifier "Video Card"
Driver "nvidia"
EndSection[/code]
Et j’ai rebooté le PC.
Mais maintenant j’ai la session graphique qui ne se lance plus, j’ai un message d’erreur qui m’invite a consulter mes logs. Voici ce que me donne mon Xorg.0.log:
[code]X.Org X Server 1.7.7
Release Date: 2010-05-04
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.37-trunk-amd64 x86_64 Debian
Current Operating System: Linux DeepThought 2.6.32-5-amd64 #1 SMP Fri Sep 9 20:23:16 UTC 2011 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=UUID=64794c13-4bc1-4623-a715-a117cfc7280b ro quiet
Build Date: 18 February 2011 08:27:24PM
xorg-server 2:1.7.7-13 (Cyril Brulebois kibi@debian.org)
Current version of pixman: 0.16.4
Before reporting problems, check http://wiki.x.org
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Sun Sep 18 08:33:29 2011
(==) Using config file: “/etc/X11/xorg.conf”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
(==) No Layout section. Using the first Screen section.
(==) No screen section available. Using defaults.
() |–>Screen “Default Screen Section” (0)
() | |–>Monitor “”
(==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
() | |–>Device “Video Card”
(==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
(II) Loader magic: 0x7c8aa0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(++) using VT number 7
(–) PCI:*(0:1:0:0) 10de:0dec:1179:fc61 nVidia Corporation rev 161, Mem @ 0xf4000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x???/524288
(II) Open ACPI successful (/var/run/acpid.socket)
(II) “extmod” will be loaded by default.
(II) “dbe” will be loaded by default.
(II) “glx” will be loaded. This was enabled by default and also specified in the config file.
(II) “record” will be loaded by default.
(II) “dri” will be loaded by default.
(II) “dri2” will be loaded by default.
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
Module class: X.Org Server Extension
(II) NVIDIA GLX Module 195.36.31 Thu Jun 3 08:59:25 PDT 2010
(II) Loading extension GLX
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.0.0
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “dri2”
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: “nvidia”
(II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: X.Org Video Driver
(II) NVIDIA dlloader X Driver 195.36.31 Thu Jun 3 08:27:29 PDT 2010
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01@00:00:0
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module “wfb”
(II) LoadModule: “wfb”
(II) Loading /usr/lib/xorg/modules/libwfb.so
(II) Module wfb: vendor=“X.Org Foundation"
(II) Loading sub module “ramdac”
(II) LoadModule: “ramdac”
(II) Module “ramdac” already built-in
(II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section” for depth/fbbpp 24/32
(==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) Sep 18 08:33:29 NVIDIA(0): Enabling RENDER acceleration
(II) Sep 18 08:33:29 NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
(II) Sep 18 08:33:29 NVIDIA(0): enabled.
(EE) Sep 18 08:33:29 NVIDIA(0): Failed to initialize the NVIDIA graphics device PCI:1:0:0.
(EE) Sep 18 08:33:29 NVIDIA(0): Please check your system’s kernel log for additional error
(EE) Sep 18 08:33:29 NVIDIA(0): messages and refer to Chapter 8: Common Problems in the
(EE) Sep 18 08:33:29 NVIDIA(0): README for additional information.
(EE) Sep 18 08:33:29 NVIDIA(0): Failed to initialize the NVIDIA graphics device!
(II) UnloadModule: “nvidia”
(II) UnloadModule: “wfb”
(II) UnloadModule: “fb”
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
Please also check the log file at “/var/log/Xorg.0.log” for additional information.[/code]
A noter aussi que si je supprime mon Xorg.conf la session graphique démarre bien, mais sans me charger le pilote graphique bien évidement.
Est ce que quelqu’un voit d’ou peux venir mon problème?
