Pour infos,
J’ai trouvé ceci en me baladant:
bugs.debian.org/cgi-bin/bugrepor … =460514#14
Et si on regarde de plus près,le mainteneur de CRON mentionne bien le bug qu’il dit avoir fixé très récemment:
[quote]rom: Javier Fernandez-Sanguino Pen~a jfs@debian.org
To: 460514-close@bugs.debian.org
Subject: Bug#460514: fixed in cron 3.0pl1-102
Date: Sun, 13 Jan 2008 22:32:03 +0000
Source: cron
Source-Version: 3.0pl1-102
We believe that the bug you reported is fixed in the latest version of
cron, which is due to be installed in the Debian FTP archive:
cron_3.0pl1-102.diff.gz
to pool/main/c/cron/cron_3.0pl1-102.diff.gz
cron_3.0pl1-102.dsc
to pool/main/c/cron/cron_3.0pl1-102.dsc
cron_3.0pl1-102_i386.deb
to pool/main/c/cron/cron_3.0pl1-102_i386.deb
A summary of the changes between this version and the previous one is
attached.
Thank you for reporting the bug, which will now be closed. If you
have further comments please address them to 460514@bugs.debian.org,
and the maintainer will reopen the bug report if appropriate.
Debian distribution maintenance software
pp.
Javier Fernandez-Sanguino Pen~a jfs@debian.org (supplier of updated cron package)
(This message was generated automatically at their request; if you
believe that there is a problem with it please contact the archive
administrators by mailing ftpmaster@debian.org)
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Format: 1.7
Date: Sun, 13 Jan 2008 23:08:11 +0100
Source: cron
Binary: cron
Architecture: source i386
Version: 3.0pl1-102
Distribution: unstable
Urgency: low
Maintainer: Javier Fernandez-Sanguino Pen~a jfs@computer.org
Changed-By: Javier Fernandez-Sanguino Pen~a jfs@debian.org
Description:
cron - management of regular background processing
Closes: 459952 460514
Changes:
cron (3.0pl1-102) unstable; urgency=low[/quote]
Pour finir, tout ce que je constate, c’est qu’il parle bien d’une release 3.0pl1-102 et que je suis en 100.
Donc je me suis dit que mon paquet n’était pas à jour, et le
me dit que j’ai déjà la dernière version.
Pour finir, la liste de dépôts Debian ne propose que la release en 100 à cette URL: packages.debian.org/etch/cron.
Ou pourrai-je donc trouver et installer cette version 102…Mystère!
Car en effet, voici le lien vers le bulletin de mise à jour de cron qui mentionne les changements acceptés, mais je ne trouve pas les paquets:
packages.qa.debian.org/c/cron.html
Je vois les fichiers diff, qui doivent être juste des modifs de scripts.
Il y a de la bidouille dans l’air
