Bonjour tous le monde.
Mon problème est que quand je rentre dans un terminale compiz. Je recois le message suivant :
Fatal: Failed test: texture_from_pixmap support
Checks indicate that it's impossible to start compiz on your system.
Je vais vous donner mon Xorg.conf pour plus d’informations
[code]# /etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "bitmap"
Load "ddc"
Load “dbe”
#Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Device"
Identifier "nVidia Corporation G72 [Geforce 7500 LE]"
Driver "nvidia"
BusID "PCI:1:0:0"
Option “RenderAccel” "true"
Option “AllowGLXWithComposite” "true"
Option “AddARGBGLXVisuals” "True"
Option “DisableGLXRootClipping” "True"
Option “DamageEvents” "True"
Option “UseEvents” "False"
Option “TripleBuffer” "True"
EndSection
Section "Monitor"
Identifier "HP w1907"
Option "DPMS"
HorizSync 24-83
VertRefresh 50-76
EndSection
Section "Screen"
Identifier "Default Screen"
Device "nVidia Corporation G72 [Geforce 7500 LE]"
Monitor "HP w1907"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1440x900” “1280x1024” “1152x864” “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option “Composite” "Enable"
EndSection
J’ai fait pas mal de recherche sur google pour réparer mon problème, j’ai essayer plein de config mais rien n’y fait.
Si il vous faut d’autre rensignements, je vous les communiquerais avec plaisir.
Merci de votre aide.
