[ resolu ]probleme d'acceleration 3d (nvidia)
Bonjour a tous , j’espere que quelqu’un saura m’aider pour mon probleme, je suis sous la debian et j’ai instaler mon pilote graphique le plus simplement possible via ENVY, maintenant mon probléme est le suivant quand j’essaye de faire un test d’acceleration 3d “glxinfo | grep Direct” la seul reponse que j’ai se trouve être : “bash: glxinfo: command not found”
je sais vraiment pas quoi faire si qu’lqu’un aurai une idée je suis prenneur .
Merci :mrgreen:
ps : mon xorg.conf
/etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section “Files”
Fontpath “/usr/share/fonts/X11/misc”
Fontpath “/usr/X11R6/lib/X11/fonts/misc”
Fontpath “/usr/share/fonts/X11/cyrillic”
Fontpath “/usr/X11R6/lib/X11/fonts/cyrillic”
Fontpath “/usr/share/fonts/X11/100dpi/:unscaled”
Fontpath “/usr/X11R6/lib/X11/fonts/100dpi/:unscaled”
Fontpath “/usr/share/fonts/X11/75dpi/:unscaled”
Fontpath “/usr/X11R6/lib/X11/fonts/75dpi/:unscaled”
Fontpath “/usr/share/fonts/X11/Type1”
Fontpath “/usr/X11R6/lib/X11/fonts/Type1”
Fontpath “/usr/share/fonts/X11/100dpi”
Fontpath “/usr/X11R6/lib/X11/fonts/100dpi”
Fontpath “/usr/share/fonts/X11/75dpi”
Fontpath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
Fontpath “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType”
EndSection
Section “Module”
Load “i2c”
Load “bitmap”
Load “ddc”
Load “dri”
Load “extmod”
Load “freetype”
Load “glx”
Load “int10”
Load “vbe”
EndSection
Section “InputDevice”
Identifier “Generic Keyboard”
Driver “kbd”
Option “CoreKeyboard”
Option “XkbRules” “xorg”
Option “XkbModel” “pc105”
Option “XkbLayout” “fr”
Option “XkbVariant” “latin9”
EndSection
Identifier “Configured Mouse”
Driver “mouse”
Option “CorePointer”
Option “Device” “/dev/input/mice”
Option “Protocol” “ImPS/2”
Option “Emulate3Buttons” “true”
EndSection
Section “Device”
Identifier “nVidia Corporation NVIDIA Default Card”
Driver “nvidia”
Busid “PCI:1:0:0”
EndSection
Section “Monitor”
Identifier “VX922”
Option “DPMS”
EndSection
Section “Screen”
Identifier “Default Screen”
Device “nVidia Corporation NVIDIA Default Card”
Monitor “VX922”
Defaultdepth 24
SubSection “Display”
Depth 1
Modes “1280x1024” “1152x864” “1024x768” “832x624” “800x600” “720x400” “640x640” “640x480”
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
Option “AddARGBGLXVisuals” “True”
EndSection
Section “ServerLayout”
Identifier “Default Layout”
screen “Default Screen”
Inputdevice “Generic Keyboard”
Inputdevice “Configured Mouse”
EndSection
Section “DRI”
Mode 0666
EndSection
Section “Extensions”
Option “Composite” “Enable”
EndSection
mmm je me trompe peut-être, mais dans mes recherches (pour résoudre mon propre problème irrésolu, lol), je me souviens avoir vu que nvidia ne gère pas glx… Vérifie ça, déjà. Et si j’ai raison, supprime la ligne qui y fait mention dans le Xorg.conf.
:slightly_smiling:
Correction : glx a l’air supporté. Au temps pour moi.
viewtopic.php?t=1682
je ne sait pas quoi corresponde ces 2 commande mais tout marche maintenant :smiley: merci a vous ,et surtout pour la rapidité et la clareté des reponse :wink:
Et pour conclure … Envy c’est pas bien :wink:
La première fois que j’ai installé le pilote nVidia sur une Ubuntu (6.06 je crois) j’ai utilisé Envy, ça a fonctionné jusqu’à une mise à jour de python, qui a relancé le script et tout foiré l’installation … Depuis le script a beaucoup évolué, et je l’ai même réutilisé il y a peut, la recompilation du noyau “en live” avec le .sh de nVidia est impressionnant ça dénote une réelle maitrise du système ! mais ça ne résoud pas les problèmes de dépendances, qu’il peut y avoir avec ce genre de machin, ni le fait que c’est typiquement une démarche “windowsienne”, qui a une réelle résonnance dans un système comme ubuntu qui a la même démarche intellectuelle (Click & Play), mais qui n’a aucun sens dans une distrib comme Debian, ou le but est de maîtriser son engin :wink:
De rien, Jimmy Somerville :wink:
Tu ne te souviens pas de Bronxy beat, ou peut-être était-ce déjà les Communards :
Tell me why?
Can you tell me why?
dailymotion.com/relevance/se … -why_music
Et Jimmy Somerville, était le “mâle” de The Communards :wink:
dailymotion.com/relevance/se … is-w_music
