Je tourne sous lenny, j’avais pour le moment aucun problème particulier. J’ai voulu installer imagemagick, voilà ce que me répond aptitude :
[quote]The following NEW packages will be installed:
dictionaries-common{a} djview4{a} djvulibre-desktop{a} djvulibre-plugin{a} ghostscript{a}
gsfonts{a} hicolor-icon-theme{a} iceweasel{a} imagemagick libatk1.0-0{a} libatk1.0-data{a}
libaudio2{a} libcroco3{a} libcups2{a} libcupsimage2{a} libcupsys2{a} libdjvulibre21{a} libdrm2{a}
libgl1-mesa-glx{a} libgs8{a} libgsf-1-114{a} libgsf-1-common{a} libgtk2.0-0{a} libgtk2.0-bin{a}
libgtk2.0-common{a} libhunspell-1.2-0{a} libilmbase6{a} libjasper1{a} liblcms1{a} libmagick10{a}
libmng1{a} libnspr4-0d{a} libnss3-1d{a} libopenexr6{a} libpaper-utils{a} libpaper1{a}
libqt4-assistant{a} libqt4-core{a} libqt4-dbus{a} libqt4-designer{a} libqt4-gui{a}
libqt4-network{a} libqt4-opengl{a} libqt4-qt3support{a} libqt4-script{a} libqt4-sql{a}
libqt4-sql-mysql{a} libqt4-svg{a} libqt4-test{a} libqt4-xml{a} libqtcore4{a} libqtgui4{a}
librsvg2-2{a} libtiff4{a} libwmf0.2-7{a} libxcomposite1{a} libxcursor1{a} libxdamage1{a}
libxfixes3{a} libxi6{a} libxinerama1{a} libxmuu1{a} libxp6{a} libxrandr2{a} libxtrap6{a}
libxtst6{a} libxv1{a} libxxf86dga1{a} libxxf86misc1{a} libxxf86vm1{a} myspell-en-us{a} psfontmgr{a}
qt4-qtconfig{a} shared-mime-info{a} x11-utils{a} x11-xserver-utils{a} xdg-utils{a}
0 packages upgraded, 77 newly installed, 0 to remove and 11 not upgraded.
Need to get 47.0MB of archives. After unpacking 133MB will be used.
Je sens qu’il y a comme un problème, non?
Une idée ?
Merci d’avance ! ![]()
Merci pour la réponse, effectivement ça a pas mal réduit la liste !
