J’ai installé le module nvidia d’après cette méthode :
Au lancement de gdm j’obtiens l’erreur suivante :
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux vulcain 2.6.18-3-amd64 #1 SMP Mon Dec 4 17:04:37 CET 2006 x86_64
Build Date: 07 February 2007
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Feb 25 20:09:18 2007
(==) Using config file: "/etc/X11/xorg.conf"
Error: API mismatch: the NVIDIA kernel module has the version 1.0-7184, but
this X module has the version 1.0-8776. Please make sure that the kernel
module and all NVIDIA driver components have the same version.
(EE) NVIDIA(0): Failed to initialize the NVIDIA kernel module! Please ensure
(EE) NVIDIA(0): that there is a supported NVIDIA GPU in this system, and
(EE) NVIDIA(0): that the NVIDIA device files have been created properly.
(EE) NVIDIA(0): Please consult the NVIDIA README for details.
(EE) NVIDIA(0): *** Aborting ***
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
Voila mon fichier de conf :
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen" 0 0
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "Files"
# path to defoma fonts
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "fr"
Option "XkbVariant" "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ExplorerPS/2"
Option "Emulate3Buttons" "true"
EndSection
Section "Monitor"
Identifier "SyncMaster"
Option "DPMS"
EndSection
Section "Device"
Identifier "NVIDIA Corporation NV43 [GeForce 6600]"
Driver "nvidia"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "NVIDIA Corporation NV43 [GeForce 6600]"
Monitor "SyncMaster"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Pourtant le module est bien chargé :
lsmod | grep nvidia
nvidia 4580556 0
J’ai loupé quelque chose, je crois comprendre que s’est un souci de version :
Comment avoir la bonne version?
