Merci de ta réponse.
Au vu de tes explications je pense que je m’y prends mal.
Sur le raspberry est connecté une une clé wifi qui est configuré en mode Access Point. Il y a également un cable ethernet sur le port ethernet.
Mon idée était de servir de point d’accès pour les caméras IP et de pouvoir accéder à internet via ethernet
Voici le fichier /etc/network/interfaces :
[quote]auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.0.100
netmask 255.255.255.0
gateway 192.168.0.254
iface wlan0 inet static
address 192.168.0.200
up iptables-restore < /etc/iptables.ipv4.nat[/quote]
Le fichier /etc/iptables.ipv4.nat :
[quote]# Generated by iptables-save v1.4.14 on Sun Jun 2 01:18:36 2013
*filter
:INPUT ACCEPT [28:2008]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [20:2072]
-A FORWARD -i eth0 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -i wlan0 -o eth0 -j ACCEPT
COMMIT
Completed on Sun Jun 2 01:18:36 2013
*nat
REROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:OUTPUT ACCEPT [5:336]
OSTROUTING ACCEPT [4:220]
-A POSTROUTING -o eth0 -j MASQUERADE
COMMIT
Completed on Sun Jun 2 01:18:36 2013[/quote]
Le fichier /etc/udhcpd.conf
[quote]# This is range of IPs that the hostspot will give to client devices
start 192.168.0.201
end 192.168.0.220
The device uDHCP listens on
interface wlan0
The DNS servers client devices will use.
opt dns 192.168.0.254 8.8.8.8 4.2.2.2
opt subnet 255.255.255.0
The Pi’s IP address on wlanÂ0 which we will set up shortly
opt router 192.168.0.200
10 day DHCP lease time in seconds
opt lease 864000
IP static camera 1
static_lease 00:08:10:76:4A:3B 192.168.0.150
If remaining is true (default), udhcpd will store the time
remaining for each lease in the udhcpd leases file. This is
for embedded systems that cannot keep time between reboots.
If you set remaining to no, the absolute time that the lease
expires at will be stored in the dhcpd.leases file.
remaining yes #default: yes
The time period at which udhcpd will write out a dhcpd.leases
file. If this is 0, udhcpd will never automatically write a
lease file. (specified in seconds)
auto_time 7200 #default: 7200 (2 hours)[/quote]
Le fichier /etc/hostapd/hostapd.conf :
[quote]interface=wlan0
driver=nl80211
ssid=My_AP
hw_mode=g
channel=6
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP[/quote]
D’ailleurs avec cette configuration l’interface eth0 se monte bien au démarrage mais pas wlan0. Je suis obligé de faire ifconfig wlan0 192.168.0.200 up pour démarrer l’interface wlan0.
Je précise que ma freebox fait également office de serveur DHCP mais uniquement entre 192.168.0.10 et 192.168.0.50. Il ne devrait théoriquement pas avoir de conflit avec le serveur uDHCP du raspberry.
