J’ai suivi ce topic pour l’installation des pilotes ati fglrx.
Tout se passe bien mais au reboot, un glxinfo | grep “direct rendering” me renvoi No.
Info :
lsmod
lsmod |grep fglrx
fglrx 2038404 0
agpgart 28336 2 fglrx,nvidia_agp
dmesg
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 2.6.26-1-486 (Debian 2.6.26-13lenny2) (dannf@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-25)) #1 Fri Mar 13 17:25:45 UTC 2009
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f400 (usable)
[ 0.000000] BIOS-e820: 000000000009f400 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007fff0000 (usable)
[ 0.000000] BIOS-e820: 000000007fff0000 - 000000007fff3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007fff3000 - 0000000080000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] Warning only 896MB will be used.
[ 0.000000] Use a HIGHMEM enabled kernel.
[ 0.000000] 896MB LOWMEM available.
[ 0.000000] Entering add_active_range(0, 0, 229376) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 229376
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 229376
[ 0.000000] On node 0 totalpages: 229376
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 1760 pages used for memmap
[ 0.000000] Normal zone: 223520 pages, LIFO batch:31
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] DMI 2.2 present.
[ 0.000000] ACPI: RSDP 000F6BA0, 0014 (r0 Nvidia)
[ 0.000000] ACPI: RSDT 7FFF3000, 002C (r1 Nvidia AWRDACPI 42302E31 AWRD 0)
[ 0.000000] ACPI: FACP 7FFF3040, 0074 (r1 Nvidia AWRDACPI 42302E31 AWRD 0)
[ 0.000000] ACPI: DSDT 7FFF30C0, 48E8 (r1 NVIDIA AWRDACPI 1000 MSFT 100000D)
[ 0.000000] ACPI: FACS 7FFF0000, 0040
[ 0.000000] ACPI: APIC 7FFF79C0, 005A (r1 Nvidia AWRDACPI 42302E31 AWRD 0)
[ 0.000000] Nvidia board detected. Ignoring ACPI timer override.
[ 0.000000] If you got timer trouble try acpi_use_timer_override
[ 0.000000] ACPI: PM-Timer IO Port: 0x4008
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: BIOS IRQ0 pin2 override ignored.
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] Allocating PCI resources starting at 88000000 (gap: 80000000:7ec00000)
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 227584
[ 0.000000] Kernel command line: root=/dev/sda2 ro
[ 0.000000] mapped APIC to ffffb000 (fee00000)
[ 0.000000] mapped IOAPIC to ffffa000 (fec00000)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 0.000000] Detected 2162.780 MHz processor.
[ 0.004000] Console: colour VGA+ 80x25
[ 0.004000] console [tty0] enabled
[ 0.004000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.004000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.004000] Memory: 898584k/917504k available (1694k kernel code, 18280k reserved, 745k data, 320k init, 0k highmem)
[ 0.004000] virtual kernel memory layout:
[ 0.004000] fixmap : 0xfffb3000 - 0xfffff000 ( 304 kB)
[ 0.004000] vmalloc : 0xf8800000 - 0xfffb1000 ( 119 MB)
[ 0.004000] lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
[ 0.004000] .init : 0xc0364000 - 0xc03b4000 ( 320 kB)
[ 0.004000] .data : 0xc02a7b33 - 0xc0362000 ( 745 kB)
[ 0.004000] .text : 0xc0100000 - 0xc02a7b33 (1694 kB)
[ 0.004000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated
[ 0.084023] Calibrating delay using timer specific routine.. 4329.12 BogoMIPS (lpj=8658252)
[ 0.084143] Security Framework initialized
[ 0.084192] SELinux: Disabled at boot.
[ 0.084239] Capability LSM initialized
[ 0.084293] Mount-cache hash table entries: 512
[ 0.084466] Initializing cgroup subsys ns
[ 0.084513] Initializing cgroup subsys cpuacct
[ 0.084560] Initializing cgroup subsys devices
[ 0.084619] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 0.084668] CPU: L2 Cache: 256K (64 bytes/line)
[ 0.084722] CPU: AMD Athlon(tm) XP 2700+ stepping 01
[ 0.084836] Checking 'hlt' instruction... OK.
[ 0.101288] Freeing SMP alternatives: 0k freed
[ 0.101340] ACPI: Core revision 20080321
[ 0.112007] ENABLING IO-APIC IRQs
[ 0.112007] ..TIMER: vector=0x31 apic1=0 pin1=0 apic2=-1 pin2=-1
[ 0.152009] net_namespace: 652 bytes
[ 0.152009] Booting paravirtualized kernel on bare hardware
[ 0.152009] NET: Registered protocol family 16
[ 0.152009] EISA bus registered
[ 0.152009] ACPI: bus type pci registered
[ 0.152009] PCI: PCI BIOS revision 2.10 entry at 0xfb420, last bus=2
[ 0.152009] PCI: Using configuration type 1 for base access
[ 0.152009] Setting up standard PCI resources
[ 0.156009] ACPI: EC: Look up EC in DSDT
[ 0.162877] ACPI: Interpreter enabled
[ 0.162928] ACPI: (supports S0 S1 S4 S5)
[ 0.163111] ACPI: Using IOAPIC for interrupt routing
[ 0.169946] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.170079] pci 0000:00:00.0: nForce2 C1 Halt Disconnect fixup
[ 0.171159] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.171360] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
[ 0.171646] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.AGPB._PRT]
[ 0.216561] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.217224] ACPI: PCI Interrupt Link [LNK2] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.217812] ACPI: PCI Interrupt Link [LNK3] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.218397] ACPI: PCI Interrupt Link [LNK4] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.218981] ACPI: PCI Interrupt Link [LNK5] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.219638] ACPI: PCI Interrupt Link [LUBA] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.220234] ACPI: PCI Interrupt Link [LUBB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.220820] ACPI: PCI Interrupt Link [LMAC] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.221405] ACPI: PCI Interrupt Link [LAPU] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.221994] ACPI: PCI Interrupt Link [LACI] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.222582] ACPI: PCI Interrupt Link [LMCI] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.223239] ACPI: PCI Interrupt Link [LSMB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.223824] ACPI: PCI Interrupt Link [LUB2] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.224415] ACPI: PCI Interrupt Link [LFIR] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.225071] ACPI: PCI Interrupt Link [L3CM] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.225728] ACPI: PCI Interrupt Link [LIDE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.226368] ACPI: PCI Interrupt Link [APC1] (IRQs *16), disabled.
[ 0.226668] ACPI: PCI Interrupt Link [APC2] (IRQs *17)
[ 0.226934] ACPI: PCI Interrupt Link [APC3] (IRQs *18)
[ 0.227202] ACPI: PCI Interrupt Link [APC4] (IRQs *19)
[ 0.227469] ACPI: PCI Interrupt Link [APCE] (IRQs *16), disabled.
[ 0.227828] ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22) *0
[ 0.228251] ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22) *0
[ 0.228669] ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22) *0
[ 0.229086] ACPI: PCI Interrupt Link [APCI] (IRQs 20 21 22) *0
[ 0.229503] ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22) *0
[ 0.229919] ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22) *0, disabled.
[ 0.230318] ACPI: PCI Interrupt Link [APCS] (IRQs *23)
[ 0.230639] ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22) *0
[ 0.231056] ACPI: PCI Interrupt Link [APCM] (IRQs 20 21 22) *0, disabled.
[ 0.231505] ACPI: PCI Interrupt Link [AP3C] (IRQs 20 21 22) *0, disabled.
[ 0.231956] ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22) *0, disabled.
[ 0.232390] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 0.232470] pnp: PnP ACPI init
[ 0.232521] ACPI: bus type pnp registered
[ 0.237639] pnp: PnP ACPI: found 15 devices
[ 0.237690] ACPI: ACPI bus type pnp unregistered
[ 0.237739] PnPBIOS: Disabled by ACPI PNP
[ 0.238042] PCI: Using ACPI for IRQ routing
[ 0.238340] ACPI: RTC can wake from S4
[ 0.238408] system 00:00: ioport range 0x4000-0x407f has been reserved
[ 0.238458] system 00:00: ioport range 0x4080-0x40ff has been reserved
[ 0.238507] system 00:00: ioport range 0x4400-0x447f has been reserved
[ 0.238556] system 00:00: ioport range 0x4480-0x44ff has been reserved
[ 0.238607] system 00:00: ioport range 0x4200-0x427f has been reserved
[ 0.238656] system 00:00: ioport range 0x4280-0x42ff has been reserved
[ 0.238711] system 00:01: ioport range 0x5000-0x503f has been reserved
[ 0.238760] system 00:01: ioport range 0x5100-0x513f has been reserved
[ 0.238818] system 00:02: iomem range 0xd4800-0xd7fff has been reserved
[ 0.238868] system 00:02: iomem range 0xf0000-0xf7fff could not be reserved
[ 0.238917] system 00:02: iomem range 0xf8000-0xfbfff could not be reserved
[ 0.238967] system 00:02: iomem range 0xfc000-0xfffff could not be reserved
[ 0.239017] system 00:02: iomem range 0x7fff0000-0x7fffffff could not be reserved
[ 0.239074] system 00:02: iomem range 0xffff0000-0xffffffff could not be reserved
[ 0.239131] system 00:02: iomem range 0x0-0x9ffff could not be reserved
[ 0.239181] system 00:02: iomem range 0x100000-0x7ffeffff could not be reserved
[ 0.239238] system 00:02: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.239295] system 00:02: iomem range 0xfee00000-0xfee00fff could not be reserved
[ 0.239357] system 00:04: ioport range 0xb78-0xb7b has been reserved
[ 0.239406] system 00:04: ioport range 0xf78-0xf7b has been reserved
[ 0.239455] system 00:04: ioport range 0xa78-0xa7b has been reserved
[ 0.239503] system 00:04: ioport range 0xe78-0xe7b has been reserved
[ 0.239552] system 00:04: ioport range 0xbbc-0xbbf has been reserved
[ 0.239601] system 00:04: ioport range 0xfbc-0xfbf has been reserved
[ 0.239649] system 00:04: ioport range 0x4d0-0x4d1 has been reserved
[ 0.239698] system 00:04: ioport range 0x294-0x297 has been reserved
[ 0.270162] PCI: Bridge: 0000:00:08.0
[ 0.270208] IO window: a000-bfff
[ 0.270256] MEM window: 0xd7000000-0xd8ffffff
[ 0.270303] PREFETCH window: 0x00000000d4000000-0x00000000d4ffffff
[ 0.270356] PCI: Bridge: 0000:00:1e.0
[ 0.270401] IO window: c000-cfff
[ 0.270447] MEM window: 0xd5000000-0xd6ffffff
[ 0.270494] PREFETCH window: 0x00000000c0000000-0x00000000cfffffff
[ 0.270552] PCI: Setting latency timer of device 0000:00:08.0 to 64
[ 0.270573] NET: Registered protocol family 2
[ 0.270691] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.271940] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.273447] TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.273869] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.273919] TCP reno registered
[ 0.274075] NET: Registered protocol family 1
[ 0.274241] checking if image is initramfs... it is
[ 0.772048] Switched to high resolution mode on CPU 0
[ 0.813911] Freeing initrd memory: 7136k freed
[ 0.814638] audit: initializing netlink socket (disabled)
[ 0.814699] type=2000 audit(1238420131.812:1): initialized
[ 0.814856] Total HugeTLB memory allocated, 0
[ 0.814964] VFS: Disk quotas dquot_6.5.1
[ 0.815037] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.815120] msgmni has been set to 1769
[ 0.815263] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.815322] io scheduler noop registered
[ 0.815367] io scheduler anticipatory registered
[ 0.815413] io scheduler deadline registered
[ 0.815463] io scheduler cfq registered (default)
[ 0.815660] pci 0000:02:00.0: Boot video device
[ 0.816036] isapnp: Scanning for PnP cards...
[ 1.170597] isapnp: No Plug & Play device found
[ 1.173064] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 1.173258] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.173427] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.173839] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.174049] 00:0b: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.174456] ACPI: PCI Interrupt Link [APC3] enabled at IRQ 18
[ 1.174510] ACPI: PCI Interrupt 0000:01:06.0[A] -> Link [APC3] -> GSI 18 (level, high) -> IRQ 18
[ 1.174793] 0000:01:06.0: ttyS2 at I/O 0xa008 (irq = 18) is a 16450
[ 1.174944] 0000:01:06.0: ttyS3 at I/O 0xa010 (irq = 18) is a 8250
[ 1.175030] Couldn't register serial port 0000:01:06.0: -28
[ 1.176812] brd: module loaded
[ 1.176954] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.179328] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.179378] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.179552] mice: PS/2 mouse device common for all mice
[ 1.179718] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 1.179784] rtc0: alarms up to one year, y3k
[ 1.179928] EISA: Probing bus 0 at eisa.0
[ 1.179993] Cannot allocate resource for EISA slot 4
[ 1.180050] Cannot allocate resource for EISA slot 5
[ 1.180110] EISA: Detected 0 cards.
[ 1.180156] cpuidle: using governor ladder
[ 1.180201] cpuidle: using governor menu
[ 1.180249] No iBFT detected.
[ 1.180752] TCP cubic registered
[ 1.180797] NET: Registered protocol family 17
[ 1.180848] Using IPI Shortcut mode
[ 1.181002] registered taskstats version 1
[ 1.181213] rtc_cmos 00:06: setting system clock to 2009-03-30 13:35:33 UTC (1238420133)
[ 1.181601] Freeing unused kernel memory: 320k freed
[ 1.198146] input: AT Translated Set 2 keyboard as /class/input/input0
[ 1.291030] ACPI: PNP0C0B:00 is registered as cooling_device0
[ 1.291097] ACPI: Fan [FAN] (on)
[ 1.294726] ACPI: ACPI0007:00 is registered as cooling_device1
[ 1.297322] ACPI: LNXTHERM:01 is registered as thermal_zone0
[ 1.298333] ACPI: Thermal Zone [THRM] (42 C)
[ 1.598706] usbcore: registered new interface driver usbfs
[ 1.598785] usbcore: registered new interface driver hub
[ 1.598880] usbcore: registered new device driver usb
[ 1.602780] ACPI: PCI Interrupt Link [APCL] enabled at IRQ 22
[ 1.602840] ACPI: PCI Interrupt 0000:00:02.2[C] -> Link [APCL] -> GSI 22 (level, high) -> IRQ 22
[ 1.602975] PCI: Setting latency timer of device 0000:00:02.2 to 64
[ 1.602979] ehci_hcd 0000:00:02.2: EHCI Host Controller
[ 1.603190] ehci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 1
[ 1.603275] ehci_hcd 0000:00:02.2: selective suspend/wakeup unavailable
[ 1.603329] ehci_hcd 0000:00:02.2: debug port 1
[ 1.603378] PCI: cache line size of 64 is not supported by device 0000:00:02.2
[ 1.603392] ehci_hcd 0000:00:02.2: irq 22, io mem 0xd9083000
[ 1.612029] ehci_hcd 0000:00:02.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 1.612196] usb usb1: configuration #1 chosen from 1 choice
[ 1.612271] hub 1-0:1.0: USB hub found
[ 1.612328] hub 1-0:1.0: 6 ports detected
[ 1.623740] Uniform Multi-Platform E-IDE driver
[ 1.623798] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 1.632720] No dock devices found.
[ 1.640254] SCSI subsystem initialized
[ 1.654354] libata version 3.00 loaded.
[ 1.716156] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.716211] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.716269] usb usb1: Product: EHCI Host Controller
[ 1.716315] usb usb1: Manufacturer: Linux 2.6.26-1-486 ehci_hcd
[ 1.716362] usb usb1: SerialNumber: 0000:00:02.2
[ 1.716529] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.61.
[ 1.716940] ACPI: PCI Interrupt Link [APCH] enabled at IRQ 21
[ 1.716994] ACPI: PCI Interrupt 0000:00:04.0[A] -> Link [APCH] -> GSI 21 (level, high) -> IRQ 21
[ 1.717120] PCI: Setting latency timer of device 0000:00:04.0 to 64
[ 1.717152] forcedeth 0000:00:04.0: Invalid Mac address detected: 00:00:00:00:00:00
[ 1.717209] forcedeth 0000:00:04.0: Please complain to your hardware vendor. Switching to a random MAC.
[ 1.720183] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.236629] forcedeth 0000:00:04.0: ifname eth0, PHY OUI 0x732 @ 1, addr 00:00:6c:75:e4:aa
[ 2.236694] forcedeth 0000:00:04.0: timirq lnktim desc-v1
[ 2.236789] NFORCE2: 0000:00:09.0 (rev a2) UDMA133 controller
[ 2.236839] NFORCE2: IDE controller (0x10de:0x0065 rev 0xa2) at PCI slot 0000:00:09.0
[ 2.236922] NFORCE2: not 100% native mode: will probe irqs later
[ 2.236982] ide0: BM-DMA at 0xf000-0xf007
[ 2.237034] ide1: BM-DMA at 0xf008-0xf00f
[ 2.237082] Probing IDE interface ide0...
[ 2.524129] hda: Maxtor 6Y080L0, ATA DISK drive
[ 2.804128] hdb: ST340016A, ATA DISK drive
[ 2.860036] hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 2.860155] hda: host side 80-wire cable detection failed, limiting max speed to UDMA33
[ 2.860213] hda: UDMA/33 mode selected
[ 2.860372] hdb: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 2.860601] hdb: host side 80-wire cable detection failed, limiting max speed to UDMA33
[ 2.860658] hdb: UDMA/33 mode selected
[ 2.860772] Probing IDE interface ide1...
[ 3.596126] hdc: SONY CD-RW CRX220E1, ATAPI CD/DVD-ROM drive
[ 4.380127] hdd: BENQ DVD DD DW1650, ATAPI CD/DVD-ROM drive
[ 4.436034] hdc: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 4.437585] hdc: UDMA/33 mode selected
[ 4.439384] hdd: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 4.439923] hdd: UDMA/33 mode selected
[ 4.440376] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 4.443995] ide1 at 0x170-0x177,0x376 on irq 15
[ 4.449872] sata_sil 0000:01:0b.0: version 2.3
[ 4.449872] ACPI: PCI Interrupt 0000:01:0b.0[A] -> Link [APC3] -> GSI 18 (level, high) -> IRQ 18
[ 4.449872] scsi0 : sata_sil
[ 4.449872] scsi1 : sata_sil
[ 4.449872] ata1: SATA max UDMA/100 mmio m512@0xd8000000 tf 0xd8000080 irq 18
[ 4.449872] ata2: SATA max UDMA/100 mmio m512@0xd8000000 tf 0xd80000c0 irq 18
[ 4.449872] ACPI: PCI Interrupt Link [APCF] enabled at IRQ 20
[ 4.449872] ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [APCF] -> GSI 20 (level, high) -> IRQ 20
[ 4.449872] PCI: Setting latency timer of device 0000:00:02.0 to 64
[ 4.449872] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 4.449872] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
[ 4.449872] ohci_hcd 0000:00:02.0: irq 20, io mem 0xd9085000
[ 4.506097] usb usb2: configuration #1 chosen from 1 choice
[ 4.506178] hub 2-0:1.0: USB hub found
[ 4.506234] hub 2-0:1.0: 3 ports detected
[ 4.608086] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 4.608138] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.608194] usb usb2: Product: OHCI Host Controller
[ 4.608240] usb usb2: Manufacturer: Linux 2.6.26-1-486 ohci_hcd
[ 4.608288] usb usb2: SerialNumber: 0000:00:02.0
[ 4.608703] ACPI: PCI Interrupt Link [APCG] enabled at IRQ 22
[ 4.608753] ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [APCG] -> GSI 22 (level, high) -> IRQ 22
[ 4.608889] PCI: Setting latency timer of device 0000:00:02.1 to 64
[ 4.608893] ohci_hcd 0000:00:02.1: OHCI Host Controller
[ 4.608964] ohci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 3
[ 4.609035] ohci_hcd 0000:00:02.1: irq 22, io mem 0xd9082000
[ 4.666058] usb usb3: configuration #1 chosen from 1 choice
[ 4.666133] hub 3-0:1.0: USB hub found
[ 4.666189] hub 3-0:1.0: 3 ports detected
[ 4.768045] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 4.768303] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 4.768354] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.768410] usb usb3: Product: OHCI Host Controller
[ 4.768456] usb usb3: Manufacturer: Linux 2.6.26-1-486 ohci_hcd
[ 4.768504] usb usb3: SerialNumber: 0000:00:02.1
[ 4.784709] ata1.00: ATA-6: HDS722512VLSA80, V33OA60A, max UDMA/100
[ 4.784759] ata1.00: 241254720 sectors, multi 16: LBA48
[ 4.808691] ata1.00: configured for UDMA/100
[ 4.912009] usb 2-1: new full speed USB device using ohci_hcd and address 2
[ 5.115163] usb 2-1: configuration #1 chosen from 1 choice
[ 5.118259] usb 2-1: New USB device found, idVendor=046d, idProduct=08d9
[ 5.118310] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.128028] ata2: SATA link down (SStatus 0 SControl 310)
[ 5.128196] scsi 0:0:0:0: Direct-Access ATA HDS722512VLSA80 V33O PQ: 0 ANSI: 5
[ 5.134988] hda: max request size: 128KiB
[ 5.135311] hda: 160086528 sectors (81964 MB) w/2048KiB Cache, CHS=65535/16/63
[ 5.137394] hda: cache flushes supported
[ 5.137497] hda: hda1
[ 5.144458] hdb: max request size: 128KiB
[ 5.145615] hdb: 78165360 sectors (40020 MB) w/2048KiB Cache, CHS=65535/16/63
[ 5.145731] hdb: cache flushes not supported
[ 5.145803] hdb:<4>Driver 'sd' needs updating - please use bus_type methods
[ 5.153170] sd 0:0:0:0: [sda] 241254720 512-byte hardware sectors (123522 MB)
[ 5.153235] sd 0:0:0:0: [sda] Write Protect is off
[ 5.153283] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.153308] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.153425] sd 0:0:0:0: [sda] 241254720 512-byte hardware sectors (123522 MB)
[ 5.153486] sd 0:0:0:0: [sda] Write Protect is off
[ 5.153533] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.153555] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.153617] sda: hdb1
[ 5.160081] sda2 sda3 sda4
[ 5.164681] hdc: ATAPI 52X CD-ROM CD-R/RW drive, 2048kB Cache
[ 5.164897] Uniform CD-ROM driver Revision: 3.20
[ 5.173586] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.205655] hdd: ATAPI 48X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache
[ 5.562272] PM: Starting manual resume from disk
[ 5.612951] kjournald starting. Commit interval 5 seconds
[ 5.612951] EXT3-fs: mounted filesystem with ordered data mode.
[ 6.956011] udev: starting version 140
[ 6.956011] udev: deprecated sysfs layout; update the kernel or disable CONFIG_SYSFS_DEPRECATED; some udev features will not work correctly
[ 7.780011] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 8.037302] input: Power Button (FF) as /class/input/input1
[ 8.042734] ACPI: Power Button (FF) [PWRF]
[ 8.042860] input: Power Button (CM) as /class/input/input2
[ 8.054150] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 8.068207] ACPI: Power Button (CM) [PWRB]
[ 8.152363] Linux agpgart interface v0.103
[ 8.192006] input: PC Speaker as /class/input/input3
[ 8.228611] i2c-adapter i2c-0: nForce2 SMBus adapter at 0x5000
[ 8.228611] i2c-adapter i2c-1: nForce2 SMBus adapter at 0x5100
[ 8.291170] agpgart: Detected NVIDIA nForce2 chipset
[ 8.295239] agpgart: AGP aperture is 64M @ 0xd0000000
[ 8.332014] Linux video capture interface: v2.00
[ 8.414203] gspca: USB GSPCA camera found.(ZC3XX)
[ 8.414257] gspca: [spca5xx_probe:4275] Camera type JPEG
[ 8.700317] input: ImExPS/2 Generic Explorer Mouse as /class/input/input4
[ 8.704565] parport_pc 00:0c: reported by Plug and Play ACPI
[ 8.704565] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
[ 8.731434] ACPI: PCI Interrupt Link [APCJ] enabled at IRQ 21
[ 8.731491] ACPI: PCI Interrupt 0000:00:06.0[A] -> Link [APCJ] -> GSI 21 (level, high) -> IRQ 21
[ 8.731649] PCI: Setting latency timer of device 0000:00:06.0 to 64
[ 8.764830] bttv: driver version 0.9.17 loaded
[ 8.764883] bttv: using 8 buffers with 2080k (520 pages) each for capture
[ 9.052007] intel8x0_measure_ac97_clock: measured 52779 usecs
[ 9.052062] intel8x0: clocking to 47501
[ 9.053037] ACPI: PCI Interrupt Link [APC2] enabled at IRQ 17
[ 9.053092] ACPI: PCI Interrupt 0000:01:09.1[A] -> Link [APC2] -> GSI 17 (level, high) -> IRQ 17
[ 9.053558] bt87x0: Using board 1, analog, digital (rate 32000 Hz)
[ 9.054376] bttv: Bt8xx card found (0).
[ 9.054450] ACPI: PCI Interrupt 0000:01:09.0[A] -> Link [APC2] -> GSI 17 (level, high) -> IRQ 17
[ 9.054583] bttv0: Bt878 (rev 17) at 0000:01:09.0, irq: 17, latency: 32, mmio: 0xd4000000
[ 9.054723] bttv0: detected: Leadtek WinFast TV 2000 [card=34], PCI subsystem ID is 107d:6606
[ 9.054782] bttv0: using: Leadtek WinFast 2000/ WinFast 2000 XP [card=34,autodetected]
[ 9.054872] bttv0: gpio: en=00000000, out=00000000 in=00bff501 [init]
[ 9.054923] bttv0: tuner type=5
[ 9.054969] bttv0: i2c: checking for MSP34xx @ 0x80... not found
[ 9.055623] bttv0: i2c: checking for TDA9875 @ 0xb0... not found
[ 9.056290] bttv0: i2c: checking for TDA7432 @ 0x8a... not found
[ 9.076769] tuner' 2-0061: chip found @ 0xc2 (bt878 #0 [sw])
[ 9.213332] tuner-simple 2-0061: creating new instance
[ 9.213387] tuner-simple 2-0061: type set to 5 (Philips PAL_BG (FI1216 and compatibles))
[ 9.222105] bttv0: registered device video0
[ 9.222170] bttv0: registered device vbi0
[ 9.222237] bttv0: registered device radio0
[ 9.222307] bttv0: PLL: 28636363 => 35468950 .. ok
[ 9.252760] input: bttv IR (card=34) as /class/input/input5
[ 9.400011] gspca: [zc3xx_config:669] Find Sensor HV7131R(c)
[ 9.400011] gspca: [spca5xx_getcapability:1249] maxw 640 maxh 480 minw 160 minh 120
[ 9.400011] usbcore: registered new interface driver gspca
[ 9.400011] gspca: gspca driver 01.00.20 registered
[ 9.592464] usbcore: registered new interface driver snd-usb-audio
[ 10.136013] Adding 522104k swap on /dev/sda3. Priority:-1 extents:1 across:522104k
[ 10.352225] EXT3 FS on sda2, internal journal
[ 10.576076] loop: module loaded
[ 10.617376] device-mapper: uevent: version 1.0.3
[ 10.617509] device-mapper: ioctl: 4.13.0-ioctl (2007-10-18) initialised: dm-devel@redhat.com
[ 11.912012] kjournald starting. Commit interval 5 seconds
[ 11.912012] EXT3 FS on sda4, internal journal
[ 11.912012] EXT3-fs: mounted filesystem with ordered data mode.
[ 11.929024] kjournald starting. Commit interval 5 seconds
[ 11.929024] EXT3 FS on hdb1, internal journal
[ 11.929024] EXT3-fs: mounted filesystem with ordered data mode.
[ 12.025221] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 13.229304] NET: Registered protocol family 10
[ 13.229819] lo: Disabled Privacy Extensions
[ 23.692017] eth0: no IPv6 routers present
[ 25.966850] serial8250: too much work for irq18
[ 25.968220] serial8250: too much work for irq18
[ 25.977307] serial8250: too much work for irq18
[ 25.987465] serial8250: too much work for irq18
[ 25.999936] serial8250: too much work for irq18
[ 26.006668] serial8250: too much work for irq18
[ 26.009421] serial8250: too much work for irq18
[ 26.013328] serial8250: too much work for irq18
[ 26.016040] serial8250: too much work for irq18
[ 26.157866] gspca: [spca5xx_set_light_freq:1932] Sensor currently not support light frequency banding filters.
[ 26.157999] gspca: [gspca_set_isoc_ep:945] ISO EndPoint found 0x81 AlternateSet 7
[ 31.034947] fglrx: module license 'Proprietary. (C) 2002 - ATI Technologies, Starnberg, GERMANY' taints kernel.
[ 31.061742] [fglrx] Maximum main memory to use for locked dma buffers: 805 MBytes.
[ 31.061807] [fglrx] vendor: 1002 device: 4e44 count: 1
[ 31.062123] [fglrx] ioport: bar 1, base 0xc000, size: 0x100
[ 31.062368] ACPI: PCI Interrupt Link [APC4] enabled at IRQ 19
[ 31.062377] ACPI: PCI Interrupt 0000:02:00.0[A] -> Link [APC4] -> GSI 19 (level, high) -> IRQ 19
[ 31.062759] [fglrx] Driver built-in PAT support is enabled successfully
[ 31.062801] [fglrx] module loaded - fglrx 8.58.2 [Feb 4 2009] with 1 minors
[ 51.656170] gspca: [spca5xx_set_light_freq:1932] Sensor currently not support light frequency banding filters.
[ 51.656239] gspca: [gspca_set_isoc_ep:945] ISO EndPoint found 0x81 AlternateSet 7
[ 55.732596] process `skype' is using obsolete setsockopt SO_BSDCOMPAT
Mon xorg.conf :
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "aticonfig-Screen[0]-0" 0 0
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "Files"
# path to defoma fonts
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "fr"
Option "XkbVariant" "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "Emulate3Buttons" "false"
Option "Buttons" "7"
Option "ZAxisMapping" "4 5"
Option "ButtonMapping" "1 2 3 7 6"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]-0"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-0"
Driver "fglrx"
Option "VideoOverlay" "on"
Option "OpenGLOverlay" "off"
BusID "PCI:2:0:0"
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]-0"
Device "aticonfig-Device[0]-0"
Monitor "aticonfig-Monitor[0]-0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
Je suis sous Sid, sur un kernel 2.6.26. J’ai une ati 9700pro.
Comment résoudre mon problème ? Merci d’avance.
Admin : Je me suis trompé de catégorie
Pouvez-vous déplacer ce message dans la catégorie support ? Merci.
