Bonjour à tous, je suis nouveau sur Debian, ancien ubunteros !
J’ai un probleme pendant le boot, voila le message :
[code]killed old client process, removed PID file
Internet Systems Consortium DHCP Client V3.0.4
Copyright 2004-2006 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
Listening on LPF/eth0/00:14:22:f9:7d:fe
Sending on LPF/eth0/00:14:22:f9:7d:fe
Sending on Socket/fallback
DHCPRELEASE on eth0 to 172.16.0.254 port 67
There is already a pid file /var/run/dhclient.eth2.pid with pid 2635
Listening on LPF/eth2/00:13:02:ca:47:ce
Sending on LPF/eth2/00:13:02:ca:47:ce
DHCPRELEASE on eth2 to 192.168.1.1 port 67
send_packet: Network is unreachable
send_packet: please consult README file regarding broadcast address.
DHCPDISCOVER on eth2 to 255.255.255.255 port 67 interval 4
DHCPDISCOVER on eth2 to 255.255.255.255 port 67 interval 10
DHCPDISCOVER on eth2 to 255.255.255.255 port 67 interval 12
DHCPDISCOVER on eth2 to 255.255.255.255 port 67 interval 21
DHCPDISCOVER on eth2 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on eth2 to 255.255.255.255 port 67 interval 6
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 5
DHCPOFFER from 172.16.0.254
DHCPREQUEST on eth0 to 255.255.255.255 port 67
DHCPACK from 172.16.0.254
bound to 172.16.253.158 – renewal in 8344 seconds.
done.[/code]
A cause de ce petit probleme, le boot est tres tres long mais mes interfaces fonctionne normalement.
D’avance merci !
