non dans phpmyadmin cela n’a rien a avoir.
fais un
dpkg -l | grep courier
fais un
ii courier-authdaemon 0.58-4.dotdeb.1 Courier authentication daemon
ii courier-authlib 0.58-4.dotdeb.1 Courier authentication library
ii courier-authlib-mysql 0.58-4.dotdeb.1 MySQL support for the Courier authentication
ii courier-authlib-userdb 0.58-4.dotdeb.1 userdb support for the Courier authenticatio
rc courier-authmysql 0.47-4sarge5 Courier Mail Server - MySQL authentication
ii courier-base 0.53.3-5 Courier Mail Server - Base system
ii courier-imap 3.0.8-4sarge5 Courier Mail Server - IMAP server
ii courier-pop 0.47-4sarge5 Courier Mail Server - POP3 server
as tu relancé le demon courier-authd ?
que donne maintenant la commande authtest ?
reposte les fichiers :
/etc/courier/authmysqlrc
/etc/courier/authdaemonrc
Alors apres restart de courier-authdaemon, la commande grep me renvoie la même chose.
[code]MYSQL_SERVER localhost
MYSQL_USERNAME postfix
MYSQL_PASSWORD Mdp
MYSQL_PORT 0
MYSQL_OPT 0
MYSQL_DATABASE postfix
MYSQL_USER_TABLE mailbox
MYSQL_CRYPT_PWFIELD password
MYSQL_UID_FIELD 5000
MYSQL_GID_FIELD 5000
MYSQL_LOGIN_FIELD email
MYSQL_HOME_FIELD “/var/spool/vmail/”
MYSQL_MAILDIR_FIELD CONCAT(SUBSTRING_INDEX(email,’@’,-1),’/’,SUBSTRING_INDEX(email,’@’,1),’/’)
MYSQL_QUOTA_FIELD quota[/code]
[code]##VERSION: $Id: authdaemonrc.in,v 1.8 2001/10/07 02:16:22 mrsam Exp $
##NAME: authmodulelist:0
authmodulelist=“authmysql”
##NAME: authmodulelistorig:1
authmodulelistorig=“authcustom authcram authuserdb authldap authpgsql authmysql authpam”
##NAME: daemons:0
daemons=5
##NAME: version:0
version=""
##NAME: authdaemonvar:0
authdaemonvar=/var/run/courier/authdaemon
commande grep ?
non
que donne la commande
Oups escuse, voila ce que donne la commande:
authtest abuse@pouet.com
[code]Authentication succeeded.
Authenticated: abuse@pouet.com (uid 5000, gid 5000)
Home Directory: /var/spool/vmail/
Maildir: pouet.com/abuse/
Quota: 0
Encrypted Password: .exA82DkSfobY
Cleartext Password: (none)
Options: (none)[/code]
ok donc ca marche
on avance
le pb maintenant c’est que tes paquets imap et pop sont trop anciens (ils correspondent a l’ancienne stable)
donc
aptitude purge courier-imap courier-pop
puis
aptitude update
aptitude install courier-imap courier-pop
UN GRAND MERCI, ca fonctionne
C vrai que j’ai eu ce problème quand j’ai fait une mise a jour de mon serveur en utilisant la commande “Apt-get upgrade”. Et je penses que ca pas du prendre en compte certain packet.
Je te remercie
