Bonjour mon serveur web apache2 ne se lance plus.
Info :
[mono]Job for apache2.service failed. See ‘systemctl status apache2.service’ and ‘journalctl -xn’ for details.[/mono]
[mono]? apache2.service - LSB: Apache2 web server
Loaded: loaded (/etc/init.d/apache2)
Active: failed (Result: exit-code) since ven. 2015-10-30 19:16:18 CET; 2min 42s ago
Process: 18073 ExecStart=/etc/init.d/apache2 start (code=exited, status=1/FAILURE)
oct. 30 19:16:18 DebFlo apache2[18073]: Starting web server: apache2 failed!
oct. 30 19:16:18 DebFlo apache2[18073]: The apache2 configtest failed. … (…
oct. 30 19:16:18 DebFlo apache2[18073]: Output of config test was:
oct. 30 19:16:18 DebFlo apache2[18073]: apache2: Syntax error on line 177 of…y
oct. 30 19:16:18 DebFlo apache2[18073]: Action ‘configtest’ failed.
oct. 30 19:16:18 DebFlo apache2[18073]: The Apache error log may have more i…
oct. 30 19:16:18 DebFlo systemd[1]: apache2.service: control process exited…=1
oct. 30 19:16:18 DebFlo systemd[1]: Failed to start LSB: Apache2 web server.
oct. 30 19:16:18 DebFlo systemd[1]: Unit apache2.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.[/mono]
[mono]-- Logs begin at ven. 2015-10-30 18:31:55 CET, end at ven. 2015-10-30 19:17:01 CET. –
oct. 30 19:16:18 DebFlo apache2[18073]: apache2: Syntax error on line 177 of /etc/apache2/apache2.conf: Could not open configuration file /etc/apache2/httpd.conf: No such file or directory
oct. 30 19:16:18 DebFlo apache2[18073]: The Apache error log may have more information.
oct. 30 19:16:18 DebFlo systemd[1]: apache2.service: control process exited, code=exited status=1
– Subject: L’unité (unit) apache2.service a échoué
– Defined-By: systemd
– Support: lists.freedesktop.org/mailman/li … temd-devel
– L’unité (unit) apache2.service a échoué, avec le résultat failed.
oct. 30 19:17:01 DebFlo CRON[18304]: pam_unix(cron:session): session opened for user root by (uid=0)
oct. 30 19:17:01 DebFlo CRON[18305]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
oct. 30 19:17:01 DebFlo CRON[18304]: pam_unix(cron:session): session closed for user root[/mono]
[mono][Sun Oct 25 18:31:48.454963 2015] [mpm_event:notice] [pid 14085:tid 140029441529728] AH00489: Apache/2.4.10 (Debian) configured – resuming normal operations
[Sun Oct 25 18:31:48.455006 2015] [core:notice] [pid 14085:tid 140029441529728] AH00094: Command line: ‘/usr/sbin/apache2’
[Sun Oct 25 18:32:52.827155 2015] [mpm_event:notice] [pid 14085:tid 140029441529728] AH00491: caught SIGTERM, shutting down
[Sun Oct 25 18:32:53.864121 2015] [mpm_prefork:notice] [pid 16063] AH00163: Apache/2.4.10 (Debian) configured – resuming normal operations
[Sun Oct 25 18:32:53.864170 2015] [core:notice] [pid 16063] AH00094: Command line: ‘/usr/sbin/apache2’
[Sun Oct 25 18:32:55.055563 2015] [mpm_prefork:notice] [pid 16063] AH00169: caught SIGTERM, shutting down
[Sun Oct 25 18:32:56.164194 2015] [mpm_prefork:notice] [pid 16178] AH00163: Apache/2.4.10 (Debian) configured – resuming normal operations
[Sun Oct 25 18:32:56.164218 2015] [core:notice] [pid 16178] AH00094: Command line: ‘/usr/sbin/apache2’
[Sun Oct 25 18:50:09.356320 2015] [mpm_prefork:notice] [pid 16178] AH00169: caught SIGTERM, shutting down
[Sun Oct 25 18:50:10.438023 2015] [mpm_prefork:notice] [pid 25651] AH00163: Apache/2.4.10 (Debian) mpm-itk/2.4.7-02 configured – resuming normal operations
[Sun Oct 25 18:50:10.438046 2015] [core:notice] [pid 25651] AH00094: Command line: ‘/usr/sbin/apache2’
[Sun Oct 25 22:27:18.872174 2015] [mpm_prefork:notice] [pid 25651] AH00169: caught SIGTERM, shutting down[/mono]
