[Résolu] Problème lancement Beryl
merci pour tous les tutos et autres réponses que j’ai pu trouver sur le forum,
j’ai presque réussi à lancer Beryl, seulement j’ai une erreur que je n’arrive pas à résoudre, j’ai vu cette erreur un peu partout sur le net mais pas de solutions, l’erreur est la suivante :
Xlib: extension “XFree86-DRI” missing on display “:0.0”.
mon système :
debian + gnome ( installe à partir d’un cd net inst )
résultats de commandes :
fglrxinfo
Xlib:  extension "XFree86-DRI" missing on display ":0.0".
display: :0.0  screen: 0
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.2 (1.5 Mesa 6.5.1)
cat xorg.conf
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
        Identifier     "Default Layout"
        Screen      0  "aticonfig-Screen[0]" 0 0
        InputDevice    "Generic Keyboard"
        InputDevice    "Configured Mouse"
EndSection
Section "Files"
        # path to defoma fonts
        FontPath     "/usr/share/fonts/X11/misc"
        FontPath     "/usr/X11R6/lib/X11/fonts/misc"
        FontPath     "/usr/share/fonts/X11/cyrillic"
        FontPath     "/usr/X11R6/lib/X11/fonts/cyrillic"
        FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
        FontPath     "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
        FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
        FontPath     "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
        FontPath     "/usr/share/fonts/X11/Type1"
        FontPath     "/usr/X11R6/lib/X11/fonts/Type1"
        FontPath     "/usr/share/fonts/X11/100dpi"
        FontPath     "/usr/X11R6/lib/X11/fonts/100dpi"
        FontPath     "/usr/share/fonts/X11/75dpi"
        FontPath     "/usr/X11R6/lib/X11/fonts/75dpi"
        FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
        Load  "bitmap"
        Load  "ddc"
#       Load  "dri"
        Load  "extmod"
        Load  "freetype"
        Load  "glx"
        Load  "int10"
        Load  "vbe"
EndSection
Section "InputDevice"
        Identifier  "Generic Keyboard"
        Driver      "kbd"
        Option      "CoreKeyboard"
        Option      "XkbRules" "xorg"
        Option      "XkbModel" "pc105"
        Option      "XkbLayout" "fr"
        Option      "XkbVariant" "latin9"
EndSection
        Identifier  "Configured Mouse"
        Driver      "mouse"
        Option      "CorePointer"
        Option      "Device" "/dev/input/mice"
        Option      "Protocol" "ImPS/2"
        Option      "Emulate3Buttons" "true"
EndSection
Section "Monitor"
        Identifier   "L1940B"
        HorizSync    30.0 - 83.0
        VertRefresh  56.0 - 75.0
        Option      "DPMS"
EndSection
Section "Monitor"
        Identifier   "aticonfig-Monitor[0]"
        Option      "VendorName" "ATI Proprietary Driver"
        Option      "ModelName" "Generic Autodetecting Monitor"
        Option      "DPMS" "true"
EndSection
Section "Device"
        Identifier  "ATI Technologies Inc Radeon R300 ND [Radeon 9700 Pro]"
        Driver      "ati"
        BusID       "PCI:1:0:0"
EndSection
Section "Device"
        Identifier  "aticonfig-Device[0]"
        Driver      "fglrx"
EndSection
Section "Screen"
        Identifier "Default Screen"
        Device     "ATI Technologies Inc Radeon R300 ND [Radeon 9700 Pro]"
        Monitor    "L1940B"
        DefaultDepth     24
        SubSection "Display"
                Depth     1
                Modes    "1280x1024" "1024x768" "800x600" "640x480"
        EndSubSection
                Depth     4
        EndSubSection
                Depth     8
        EndSubSection
                Depth     15
        EndSubSection
                Depth     16
        EndSubSection
                Depth     24
        EndSubSection
EndSection
Section "Screen"
        Identifier "aticonfig-Screen[0]"
        Device     "aticonfig-Device[0]"
        Monitor    "aticonfig-Monitor[0]"
        DefaultDepth     24
                Viewport   0 0
                Depth     24
        EndSubSection
EndSection
Section "DRI"
        Mode         0666
EndSection
Section "Extensions"
Option "Composite" "Enable"
Endsection
merci pour votre aide !!!
Bonjour, en virant le dièse devant le module DRI dans le xorg ? ici:
[quote]Section "Module"
Load "bitmap"
Load “ddc”
Load “dri”
     Load  "extmod"
     Load  "freetype"
     Load  "glx"
     Load  "int10"
     Load  "vbe" [/quote]
Bonjour :stuck_out_tongue:
change rien :
je l’avais commente apres de multiple essais
ce qui est bizar c’est que j’ai installe les drivers Ati fglrx et lors dulancement de la commande fglrxinfo on dirais bien que non ?
je suis débutant, désolé pour les questions ^^
suite …
quand je mets composite à Disabled dans mon xorg.conf, la commande fglrxinfo donne cela :
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: RADEON 9700 PRO Generic
OpenGL version string: 2.0.6011 (8.28.8)
je ne comprends pas :confused:
Moi non plus, mais bon ATI et moi ça fait 4…
Et là ça ne fonctionne toujours pas ? Et lorsque tu lances beryl dans un terminal ?
A 1ere vue dans la section modules il te manques le dbe
Il te manques aussi l’option [quote]Option “XAANoOffscreenPixmaps” “true”[/quote] dans le device
debian.free.fr/index.php?option= … 9&Itemid=1
J’ai egalement une ATI, je te montres mon xorg pour info
[quote]Section "Files"
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
EndSection
Section "Module"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
Load "dbe"
EndSection
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Driver "mouse"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Device"
Identifier "RV350AP"
Driver "ati"
BusID "PCI:3:0:0"
Option “XAANoOffscreenPixmaps” "true"
EndSection
Section "Monitor"
Identifier "Flatron L1720B"
Option "DPMS"
HorizSync 28-96
VertRefresh 50-75
EndSection
Section "Screen"
Device "RV350AP"
Monitor "Flatron L1720B"
DefaultDepth 24
Depth 1
Modes “1280x1024” “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Screen "Default Screen"
InputDevice “Configured Mouse”
EndSection
Section "DRI"
Mode 0666
EndSection
Option “Composite” "Enable"
EndSection
Bonjour bonjour,
donc :
Ymer : Nan cela ne marche toujours pas :frowning:
le problème est le suivant, si je lance beryl-manager en mettant composite à disabled j’ai une erreur:
Checking for XComposite extension               : failed
No composite extension
beryl: SmcOpenConnection failed: Authentication Rejected, reason : None of the authentication protocols specified are supported and host-based authentication failed
beryl: No composite extension
et si je le lance en le mettant à enabled je n’ais plus cette erreur mais une autre :
Didier : j’ai ajoute tout cela mais sans résultat, que te donne fglrxinfo ? tu utilise l’acceleration 3D de ta carte ati ?
re ^
alors je crois que j’avance, j’ai trouvé sur ce lien :
http://forum.ubuntu-fr.org/viewtopic.php?id=95140
je cite :
Pour info, les drivers propriétaires ATI ne supportent pas l'option composite, alors que les drivers nVidia, eux, la supportent nativement (merci ATI...). Ceux qui souhaitent installer Beryl avec une carte ATI devraient donc suivre la procédure suivante: premièrement, vérifier si la carte graphique supporte la 3D avec les drivers libres. Si c'est le cas, installer Beryl normalement avec les drivers libres. Si ce n'est pas le cas, c'est un peu plus emmerdant: il va falloir utiliser XGL, voir ici. La réussite n'est malheureusement pas garantie...
je vais essayé, cela me parais correct puisque ca explique le composite a enabled qui empeche le driver de se lancer. :stuck_out_tongue:
Hello
A d’accord, effectivement je tourne avec le driver libre
une partie du glxinfo :
[quote]debian:/home/didier# glxinfo
name of display: :0.0
libGL warning: 3D driver claims to not support visual 0x4b
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
Sinon,pour la desinstallation du driver proprietaire, il y a un beau tuto dans la rubrique truc et astuces
forum.debian-fr.org/viewtopic.php?t=7129&start=0
merci à vous j’ai réussi à lancer Beryl en laissant le driver libre, mais cela rame beaucoup :imp:
j’ai pourant un P4 2.4 avec 1.5 gig de ram,
que puis je enlever comme effet pour alléger tout ca ?
En décochant la synchronisation vblank (dans les options générales de Beryl je crois) tu devrais pouvoir gagner un peu de fluidité.
Après le reste c’est toi qui vois, si tu en as besoin ou pas…
ok je vais teste ca, je veux installer Wow avec wine, du coup oblige de mettre les drivers proprio :frowning:
je vais tester plus tard avec XGL donc
de plus sans les drivers proprio le pc fige,
wait and see …
