Bonjour ,
J’ai un petit problème avec libx11
Mon linux :
Linux debian 2.6.18-5-amd64 #1 SMP Tue Oct 2 20:37:02 UTC 2007 x86_64 GNU/Linux
Mon matos :
00:00.0 Memory controller: nVidia Corporation CK804 Memory Controller (rev a3)
00:01.0 ISA bridge: nVidia Corporation CK804 ISA Bridge (rev a3)
00:01.1 SMBus: nVidia Corporation CK804 SMBus (rev a2)
00:02.0 USB Controller: nVidia Corporation CK804 USB Controller (rev a2)
00:02.1 USB Controller: nVidia Corporation CK804 USB Controller (rev a3)
00:06.0 IDE interface: nVidia Corporation CK804 IDE (rev a2)
00:07.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev a3)
00:08.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev a3)
00:09.0 PCI bridge: nVidia Corporation CK804 PCI Bridge (rev a2)
00:0a.0 Bridge: nVidia Corporation CK804 Ethernet Controller (rev a3)
00:0b.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:0c.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:0d.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:0e.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTra nsport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Con troller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscella neous Control
01:00.0 VGA compatible controller: nVidia Corporation G70 [GeForce 7800 GT] (rev a1)
05:06.0 Multimedia audio controller: VIA Technologies Inc. VT1720/24 [Envy24PT/H T] PCI Multi-Channel Audio Controller (rev 01)
05:07.0 FireWire (IEEE 1394): VIA Technologies, Inc. IEEE 1394 Host Controller ( rev 80)
J’ai téléchargé VMware-server-1.0.3-44356
Lors de l’install j’ai le message d’erreur suivant :
The correct version of one or more libraries needed to run VMware Server may be
missing. This is the output of ldd /usr/bin/vmware:
linux-gate.so.1 => (0xffffe000)
libm.so.6 => /lib32/libm.so.6 (0xf7efb000)
libdl.so.2 => /lib32/libdl.so.2 (0xf7ef7000)
libpthread.so.0 => /lib32/libpthread.so.0 (0xf7ee6000)
libX11.so.6 => not found
libXtst.so.6 => not found
libXext.so.6 => not found
libXt.so.6 => not found
libICE.so.6 => not found
libSM.so.6 => not found
libXrender.so.1 => not found
libz.so.1 => not found
libc.so.6 => /lib32/libc.so.6 (0xf7db9000)
/lib/ld-linux.so.2 (0xf7f30000)
le reste de l’install se déroule normalement.
Lorsque je lance vmware :
/usr/lib/vmware/bin/vmware: error while loading shared libraries: libX11.so.6: c annot open shared object file: No such file or directory
( A noter que j’ai le même problème avec le jeu ennemi territory lorsque je le lance )
Or libx11 est bien installé.
Je ne trouve la solution nul part donc je viens demander de l’aide ici.
Merci par avance.
Cordialement.
