Ok désolé pour le manque de précision, voici mon log Xorg.
Ce qu’il ya c’est que au redémarrage un écran noir et rien d’autres. Je n’ai pas la possibilité de retourné en ligne de commande, je suis obligé de rebooté la machine.
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux debian 2.6.18-4-686 #1 SMP Wed May 9 23:03:12 UTC 2007 i686
Build Date: 04 April 2007
Before reporting problems, check wiki.x.org
Module Loader present
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Wed Aug 8 16:05:01 2007
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
(**) |–>Screen “Default Screen” (0)
(**) | |–>Monitor “Écran générique”
(**) | |–>Device “Nvidia 8400M GT”
(**) |–>Input Device “Generic Keyboard”
(**) |–>Input Device “Configured Mouse”
(**) |–>Input Device “Synaptics Touchpad”
(WW) The directory “/usr/X11R6/lib/X11/fonts/misc” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/Type1” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi” does not exist.
(WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to “/etc/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.0
X.Org XInput driver : 0.6
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: “bitmap”
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor=“X.Org Foundation”
compiled for 7.1.1, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font Bitmap
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor=“X.Org Foundation”
ABI class: X.Org Video Driver, version 1.0
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,2a00 card 104d,9005 rev 0c class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2a01 card 0000,0000 rev 0c class 06,04,00 hdr 01
(II) PCI: 00:1a:0: chip 8086,2834 card 104d,9005 rev 03 class 0c,03,00 hdr 80
(II) PCI: 00:1a:1: chip 8086,2835 card 104d,9005 rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1a:7: chip 8086,283a card 104d,9005 rev 03 class 0c,03,20 hdr 00
(II) PCI: 00:1b:0: chip 8086,284b card 104d,9005 rev 03 class 04,03,00 hdr 00
(II) PCI: 00:1c:0: chip 8086,283f card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1c:1: chip 8086,2841 card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1c:2: chip 8086,2843 card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1c:4: chip 8086,2847 card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1d:0: chip 8086,2830 card 104d,9005 rev 03 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,2831 card 104d,9005 rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,2832 card 104d,9005 rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,2836 card 104d,9005 rev 03 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,2448 card 0000,0000 rev f3 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,2815 card 104d,9005 rev 03 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,2850 card 104d,9005 rev 03 class 01,01,8a hdr 00
(II) PCI: 00:1f:2: chip 8086,2829 card 104d,9005 rev 03 class 01,06,01 hdr 00
(II) PCI: 00:1f:3: chip 8086,283e card 104d,9005 rev 03 class 0c,05,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0426 card 104d,9005 rev a1 class 03,00,00 hdr 00
(II) PCI: 06:00:0: chip 8086,4222 card 8086,1051 rev 02 class 02,80,00 hdr 00
(II) PCI: 08:00:0: chip 11ab,4351 card 104d,9005 rev 16 class 02,00,00 hdr 00
(II) PCI: 09:03:0: chip 104c,8039 card 7000,0000 rev 00 class 06,07,00 hdr 82
(II) PCI: 09:03:1: chip 104c,803a card 104d,9005 rev 00 class 0c,00,10 hdr 80
(II) PCI: 09:03:2: chip 104c,803b card 104d,9005 rev 00 class 01,80,00 hdr 80
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,10), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x001a (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x00002000 - 0x00002fff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xcc000000 - 0xceffffff (0x3000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B]
(II) Bus 2: bridge is at (0:28:0), (0,2,3), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x00003000 - 0x000030ff (0x100) IX[B]
[1] -1 0 0x00003400 - 0x000034ff (0x100) IX[B]
[2] -1 0 0x00003800 - 0x000038ff (0x100) IX[B]
[3] -1 0 0x00003c00 - 0x00003cff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xf6000000 - 0xf7ffffff (0x2000000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0xf0000000 - 0xf1ffffff (0x2000000) MX[B]
(II) Bus 4: bridge is at (0:28:1), (0,4,5), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 4 I/O range:
[0] -1 0 0x00004000 - 0x000040ff (0x100) IX[B]
[1] -1 0 0x00004400 - 0x000044ff (0x100) IX[B]
[2] -1 0 0x00004800 - 0x000048ff (0x100) IX[B]
[3] -1 0 0x00004c00 - 0x00004cff (0x100) IX[B]
(II) Bus 4 non-prefetchable memory range:
[0] -1 0 0xf8000000 - 0xf9ffffff (0x2000000) MX[B]
(II) Bus 4 prefetchable memory range:
[0] -1 0 0xf2000000 - 0xf3ffffff (0x2000000) MX[B]
(II) Bus 6: bridge is at (0:28:2), (0,6,7), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 6 I/O range:
[0] -1 0 0x00005000 - 0x000050ff (0x100) IX[B]
[1] -1 0 0x00005400 - 0x000054ff (0x100) IX[B]
[2] -1 0 0x00005800 - 0x000058ff (0x100) IX[B]
[3] -1 0 0x00005c00 - 0x00005cff (0x100) IX[B]
(II) Bus 6 non-prefetchable memory range:
[0] -1 0 0xfa000000 - 0xfbffffff (0x2000000) MX[B]
(II) Bus 6 prefetchable memory range:
[0] -1 0 0xf4000000 - 0xf5ffffff (0x2000000) MX[B]
(II) Bus 8: bridge is at (0:28:4), (0,8,8), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 8 I/O range:
[0] -1 0 0x00006000 - 0x000060ff (0x100) IX[B]
[1] -1 0 0x00006400 - 0x000064ff (0x100) IX[B]
[2] -1 0 0x00006800 - 0x000068ff (0x100) IX[B]
[3] -1 0 0x00006c00 - 0x00006cff (0x100) IX[B]
(II) Bus 8 non-prefetchable memory range:
[0] -1 0 0xfc000000 - 0xfc0fffff (0x100000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 9: bridge is at (0:30:0), (0,9,13), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 9 I/O range:
[0] -1 0 0x00007000 - 0x000070ff (0x100) IX[B]
[1] -1 0 0x00007400 - 0x000074ff (0x100) IX[B]
[2] -1 0 0x00007800 - 0x000078ff (0x100) IX[B]
[3] -1 0 0x00007c00 - 0x00007cff (0x100) IX[B]
(II) Bus 9 non-prefetchable memory range:
[0] -1 0 0xfc100000 - 0xfc1fffff (0x100000) MX[B]
(II) Bus 9 prefetchable memory range:
[0] -1 0 0x88000000 - 0x89ffffff (0x2000000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) PCI-to-CardBus bridge:
(II) Bus 10: bridge is at (9:3:0), (9,10,13), BCTRL: 0x05c0 (VGA_EN is cleared)
(II) Bus 10 I/O range:
(II) Bus 10 prefetchable memory range:
(–) PCI:*(1:0:0) nVidia Corporation unknown chipset (0x0426) rev 161, Mem @ 0xce000000/24, 0xd0000000/28, 0xcc000000/25, I/O @ 0x2000/7
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xfc101000 - 0xfc101fff (0x1000) MX[B]
[1] -1 0 0xfc104000 - 0xfc107fff (0x4000) MX[B]
[2] -1 0 0xfc102000 - 0xfc1027ff (0x800) MX[B]
[3] -1 0 0xfc000000 - 0xfc003fff (0x4000) MX[B]
[4] -1 0 0xfa000000 - 0xfa000fff (0x1000) MX[B]
[5] -1 0 0x8a000000 - 0x8a0000ff (0x100) MX[B]
[6] -1 0 0xfc404000 - 0xfc4047ff (0x800) MX[B]
[7] -1 0 0xfc404c00 - 0xfc404fff (0x400) MX[B]
[8] -1 0 0xfc400000 - 0xfc403fff (0x4000) MX[B]
[9] -1 0 0xfc404800 - 0xfc404bff (0x400) MX[B]
[10] -1 0 0xcc000000 - 0xcdffffff (0x2000000) MX[B](B)
[11] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
[12] -1 0 0xce000000 - 0xceffffff (0x1000000) MX[B](B)
[13] -1 0 0x00006000 - 0x000060ff (0x100) IX[B]
[14] -1 0 0x00001c00 - 0x00001c1f (0x20) IX[B]
[15] -1 0 0x000018e0 - 0x000018ff (0x20) IX[B]
[16] -1 0 0x000018c8 - 0x000018cb (0x4) IX[B]
[17] -1 0 0x000018d0 - 0x000018d7 (0x8) IX[B]
[18] -1 0 0x000018cc - 0x000018cf (0x4) IX[B]
[19] -1 0 0x000018d8 - 0x000018df (0x8) IX[B]
[20] -1 0 0x000018a0 - 0x000018af (0x10) IX[B]
[21] -1 0 0x00001880 - 0x0000189f (0x20) IX[B]
[22] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
[23] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
[24] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
[25] -1 0 0x00001800 - 0x0000181f (0x20) IX[B]
[26] -1 0 0x00002000 - 0x0000207f (0x80) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xfc101000 - 0xfc101fff (0x1000) MX[B]
[5] -1 0 0xfc104000 - 0xfc107fff (0x4000) MX[B]
[6] -1 0 0xfc102000 - 0xfc1027ff (0x800) MX[B]
[7] -1 0 0xfc000000 - 0xfc003fff (0x4000) MX[B]
[8] -1 0 0xfa000000 - 0xfa000fff (0x1000) MX[B]
[9] -1 0 0x8a000000 - 0x8a0000ff (0x100) MX[B]
[10] -1 0 0xfc404000 - 0xfc4047ff (0x800) MX[B]
[11] -1 0 0xfc404c00 - 0xfc404fff (0x400) MX[B]
[12] -1 0 0xfc400000 - 0xfc403fff (0x4000) MX[B]
[13] -1 0 0xfc404800 - 0xfc404bff (0x400) MX[B]
[14] -1 0 0xcc000000 - 0xcdffffff (0x2000000) MXB
[15] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MXB
[16] -1 0 0xce000000 - 0xceffffff (0x1000000) MXB
[17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[18] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[19] -1 0 0x00006000 - 0x000060ff (0x100) IX[B]
[20] -1 0 0x00001c00 - 0x00001c1f (0x20) IX[B]
[21] -1 0 0x000018e0 - 0x000018ff (0x20) IX[B]
[22] -1 0 0x000018c8 - 0x000018cb (0x4) IX[B]
[23] -1 0 0x000018d0 - 0x000018d7 (0x8) IX[B]
[24] -1 0 0x000018cc - 0x000018cf (0x4) IX[B]
[25] -1 0 0x000018d8 - 0x000018df (0x8) IX[B]
[26] -1 0 0x000018a0 - 0x000018af (0x10) IX[B]
[27] -1 0 0x00001880 - 0x0000189f (0x20) IX[B]
[28] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
[29] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
[30] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
[31] -1 0 0x00001800 - 0x0000181f (0x20) IX[B]
[32] -1 0 0x00002000 - 0x0000207f (0x80) IX[B](B)
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: “ddc”
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor=“X.Org Foundation”
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor=“X.Org Foundation”
ABI class: X.Org Server Extension, version 0.3
(II) Loading sub module “drm”
(II) LoadModule: “drm”
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor=“X.Org Foundation”
(II) Loading extension XFree86-DRI
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor=“X.Org Foundation”
Module class: X.Org Server Extension
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor=“X.Org Foundation & the After X-TT Project”
compiled for 7.1.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor=“NVIDIA Corporation”
compiled for 4.0.2, module version = 1.0.8776
ABI class: X.Org Server Extension, version 0.1
(II) Loading extension GLX
(II) LoadModule: “int10”
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor=“X.Org Foundation”
(II) LoadModule: “vbe”
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor=“X.Org Foundation”
compiled for 7.1.1, module version = 1.1.0
(II) LoadModule: “nvidia”
(II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.o
(II) Module nvidia: vendor=“NVIDIA Corporation”
Module class: X.Org Video Driver
(II) LoadModule: “kbd”
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor=“X.Org Foundation”
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor=“X.Org Foundation”
compiled for 7.1.1, module version = 1.1.1
(II) LoadModule: “synaptics”
(II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
(II) Module synaptics: vendor=“The XFree86 Project”
compiled for 4.2.0, module version = 1.0.0
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.3
(II) NVIDIA X Driver 1.0-8776 Mon Oct 16 21:58:46 PDT 2006
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(–) Chipset NVIDIA GPU found
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor=“X.Org Foundation”
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module “ramdac”
(II) LoadModule: “ramdac”
(II) Loading /usr/lib/xorg/modules/libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 0.1.0
(II) resource ranges after xf86ClaimFixedResources() call:
[32] -1 0 0x00002000 - 0x0000207f (0x80) IXB
(II) resource ranges after probing:
[17] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[18] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[19] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[20] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[21] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[22] -1 0 0x00006000 - 0x000060ff (0x100) IX[B]
[23] -1 0 0x00001c00 - 0x00001c1f (0x20) IX[B]
[24] -1 0 0x000018e0 - 0x000018ff (0x20) IX[B]
[25] -1 0 0x000018c8 - 0x000018cb (0x4) IX[B]
[26] -1 0 0x000018d0 - 0x000018d7 (0x8) IX[B]
[27] -1 0 0x000018cc - 0x000018cf (0x4) IX[B]
[28] -1 0 0x000018d8 - 0x000018df (0x8) IX[B]
[29] -1 0 0x000018a0 - 0x000018af (0x10) IX[B]
[30] -1 0 0x00001880 - 0x0000189f (0x20) IX[B]
[31] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
[32] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
[33] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
[34] -1 0 0x00001800 - 0x0000181f (0x20) IX[B]
[35] -1 0 0x00002000 - 0x0000207f (0x80) IXB
[36] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[37] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
() NVIDIA(0): Depth 24, (–) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
() NVIDIA(0): Enabling RENDER acceleration
