Salut, j’ai un ecran ADI Provista 15° j’arrive pas a passer sous la resolution 1024*768
comment je dois faire ?
merci
Déjà lire ca forum.debian-fr.org/viewtopic.php?t=4657
ensuite nous fournir ton fichier xorg.conf ou XF86Config-4 suivant si tu utilise xorg ou xfree.
Il nous faudrait aussi connaitre ta carte graphique
j’utilise XF86Config-4
voila son contenu :
# XF86Config-4 (XFree86 X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the XF86Config-4 manual page.
# (Type "man XF86Config-4" at the shell prompt.)
# This file is automatically updated on xserver-xfree86 package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xfree86
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following commands as root:
# cp /etc/X11/XF86Config-4 /etc/X11/XF86Config-4.custom
# md5sum /etc/X11/XF86Config-4 >/var/lib/xfree86/XF86Config-4.md5sum
# dpkg-reconfigure xserver-xfree86
Section "Files"
FontPath "unix/:7100" # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/Speedo"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
EndSection
ection "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option "XkbRules" "xfree86"
Option "XkbModel" "pc105"
Option "XkbLayout" "fr"
EndSection
Section "InputDevice"
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "Emulate3Buttons" "true"
Option "ZAxisMapping" "4 5"
EndSection
Section "Device"
Identifier "Carte vidéo générique"
Driver "sis"
EndSection
Section "Monitor"
Identifier "Écran générique"
HorizSync 28-50
VertRefresh 43-75
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Carte vidéo générique"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "800x600" "640x480"
EndSubSection
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
ndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
j’utilise une carte Carte vidéo générique de la marque “sis”
quote="Ashgenesis"
Il nous faudrait aussi connaitre ta carte graphique[/quote]Surtout ça: le type de moniteur n’a que trés peu d’importance (les moniteurs sont de nos jours quasi equivalents en terme de capacité, même si c’est trés différent pour ce qui concerne le rendu).
voila plus de detail pour ma carte graphique
0000:01:00.0 VGA compatible controller: Silicon Integrated Systems [SiS] 300/305 PCI/AGP VGA Display Adapter (rev 90)
Essaie de reconfigurer le serveur graphique avec :
Sinon une méthode peut être un peu bourrin consisterait à ajouter dans la section “Screen”, à la ligne “Modes”, juste avant “800x600”, un “1024x768” genre
Depth 24
Modes "1024x768" "800x600" "640x480"
EndSubSection
pour chaque subsection “display”
[quote=“Noxfies”]
Depth 24
EndSubSection
pour chaque subsection “display”[/quote]
+1
Ce n’est pas bourrin, c’est le plus pratique à faire.
merci beaucoup ça a marché je vais essayer maintenant de mettre a jour KDE et GNOME
