bonjour,
je pense avoir fais des bêtises avec nano !!
ci joint le fichier xfree86 n°…20 !!!
XFree86 Version 4.3.0.1 (Debian 4.3.0.dfsg.1-14sarge1 20050901212727 fjp@localhost.localdomain)
Release Date: 15 August 2003
X Protocol Version 11, Revision 0, Release 6.6
Build Operating System: Linux 2.6.8-16.0508-2 i686 [ELF]
Build Date: 02 September 2005
This version of XFree86 has been extensively modified by the Debian
Project, and is not supported by the XFree86 Project, Inc., in any
way. Bugs should be reported to the Debian Bug Tracking System; see
<URL: debian.org/Bugs/Reporting >.
We strongly encourage the use of the “reportbug” package and command
to ensure that bug reports contain as much useful information as
possible.
Before filing a bug report, you may want to consult the Debian X FAQ:
XHTML version: file:///usr/share/doc/xfree86-common/FAQ.xhtml
plain text version: file:///usr/share/doc/xfree86-common/FAQ.gz
Module Loader present
OS Kernel: Linux version 2.6.8-2-386 (horms@tabatha.lab.ultramonkey.org) (gcc version 3.3.5 (Debian 1:3.3.5-13)) #1 Tue Aug 16 12:46:35 UTC 2005
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/XFree86.20.log”, Time: Fri Sep 22 20:08:44 2006
(==) Using config file: “/etc/X11/XF86Config-4”
(==) ServerLayout “Default Layout”
() |–>Screen “Default Screen” (0)
() | |–>Monitor “e1770NSL/T”
() | |–>Device “Carte vidéo générique”
() |–>Input Device “Generic Keyboard”
() Option “XkbRules” “xfree86”
() XKB: rules: “xfree86”
() Option “XkbModel” “pc105”
() XKB: model: “pc105”
() Option “XkbLayout” “fr”
() XKB: layout: “fr”
(==) Keyboard: CustomKeycode disabled
() |–>Input Device “Configured Mouse”
(WW) The directory “/usr/lib/X11/fonts/cyrillic” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/lib/X11/fonts/CID” does not exist.
(**) FontPath set to “unix/:7100,/usr/lib/X11/fonts/misc,/usr/lib/X11/fonts/100dpi/:unscaled,/usr/lib/X11/fonts/75dpi/:unscaled,/usr/lib/X11/fonts/Type1,/usr/lib/X11/fonts/Speedo,/usr/lib/X11/fonts/100dpi,/usr/lib/X11/fonts/75dpi”
(==) RgbPath set to “/usr/X11R6/lib/X11/rgb”
(==) ModulePath set to “/usr/X11R6/lib/modules”
(++) using VT number 8
(WW) Open APM failed (/dev/apm_bios) (No such file or directory)
(II) Module ABI versions:
XFree86 ANSI C Emulation: 0.2
XFree86 Video Driver: 0.6
XFree86 XInput driver : 0.4
XFree86 Server Extension : 0.2
XFree86 Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: “bitmap”
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.0.0
Module class: XFree86 Font Renderer
ABI class: XFree86 Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: “pcidata”
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
ABI class: XFree86 Video Driver, version 0.6
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,3168 card 270f,766a rev 03 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,b198 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:0a:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr 00
(II) PCI: 00:0b:0: chip 3388,0021 card 0000,0000 rev 11 class 06,04,00 hdr 01
(II) PCI: 00:0c:0: chip 14f1,2f00 card 148d,1031 rev 01 class 07,80,00 hdr 00
(II) PCI: 00:10:0: chip 1106,3038 card 270f,766a rev 80 class 0c,03,00 hdr 80
(II) PCI: 00:10:1: chip 1106,3038 card 270f,766a rev 80 class 0c,03,00 hdr 80
(II) PCI: 00:10:2: chip 1106,3038 card 270f,766a rev 80 class 0c,03,00 hdr 80
(II) PCI: 00:10:3: chip 1106,3104 card 270f,766a rev 82 class 0c,03,20 hdr 00
(II) PCI: 00:11:0: chip 1106,3177 card 270f,766a rev 00 class 06,01,00 hdr 80
(II) PCI: 00:11:1: chip 1106,0571 card 270f,766a rev 06 class 01,01,8a hdr 00
(II) PCI: 00:11:5: chip 1106,3059 card 270f,766d rev 50 class 04,01,00 hdr 00
(II) PCI: 01:00:0: chip 1002,5964 card 174b,7c13 rev 01 class 03,00,00 hdr 80
(II) PCI: 01:00:1: chip 1002,5d44 card 174b,7c12 rev 01 class 03,80,00 hdr 00
(II) PCI: 02:0c:0: chip 104c,8023 card 0000,0000 rev 00 class 0c,00,10 hdr 00
(II) PCI: 02:0d:0: chip 109e,036e card 0000,0000 rev 11 class 04,00,00 hdr 80
(II) PCI: 02:0d:1: chip 109e,0878 card 0000,0000 rev 11 class 04,80,00 hdr 80
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[1] -1 0 0x0000c400 - 0x0000c4ff (0x100) IX[B]
[2] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[3] -1 0 0x0000cc00 - 0x0000ccff (0x100) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xd0000000 - 0xd1ffffff (0x2000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B]
(II) Bus 2: bridge is at (0:11:0), (0,2,2), BCTRL: 0x0006 (VGA_EN is cleared)
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xd3000000 - 0xd30fffff (0x100000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0xd3100000 - 0xd31fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:17:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI:*(1:0:0) ATI Technologies Inc unknown chipset (0x5964) rev 1, Mem @ 0xc0000000/27, 0xd1000000/16, I/O @ 0xc000/8
(–) PCI: (1:0:1) ATI Technologies Inc unknown chipset (0x5d44) rev 1, Mem @ 0xc8000000/27, 0xd1010000/16
(–) PCI: (2:13:0) Brooktree Corporation Bt878 Video Capture rev 17, Mem @ 0xd3100000/12
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MXB
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xb0000000 from 0xbfffffff to 0xafffffff
(II) Active PCI resource ranges:
[0] -1 0 0xd3101000 - 0xd3101fff (0x1000) MX[B]
[1] -1 0 0xd3000000 - 0xd3003fff (0x4000) MX[B]
[2] -1 0 0xd3004000 - 0xd30047ff (0x800) MX[B]
[3] -1 0 0xd3211000 - 0xd32110ff (0x100) MX[B]
[4] -1 0 0xd3200000 - 0xd320ffff (0x10000) MX[B]
[5] -1 0 0xd3210000 - 0xd32100ff (0x100) MX[B]
[6] -1 0 0xb0000000 - 0xafffffff (0x0) MX[B]O
[7] -1 0 0xd3100000 - 0xd3100fff (0x1000) MXB
[8] -1 0 0xd1000000 - 0xd100ffff (0x10000) MXB
[9] -1 0 0xc0000000 - 0xc7ffffff (0x8000000) MXB
[10] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[11] -1 0 0x0000e400 - 0x0000e40f (0x10) IX[B]
[12] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
[13] -1 0 0x0000dc00 - 0x0000dc1f (0x20) IX[B]
[14] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[15] -1 0 0x0000d400 - 0x0000d407 (0x8) IX[B]
[16] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]
[17] -1 0 0x0000c000 - 0x0000c0ff (0x100) IXB
(II) Inactive PCI resource ranges:
[0] -1 0 0xd1010000 - 0xd101ffff (0x10000) MXB
[1] -1 0 0xc8000000 - 0xcfffffff (0x8000000) MXB
(II) Active PCI resource ranges after removing overlaps:
(II) Inactive PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xd3101000 - 0xd3101fff (0x1000) MX[B]
[6] -1 0 0xd3000000 - 0xd3003fff (0x4000) MX[B]
[7] -1 0 0xd3004000 - 0xd30047ff (0x800) MX[B]
[8] -1 0 0xd3211000 - 0xd32110ff (0x100) MX[B]
[9] -1 0 0xd3200000 - 0xd320ffff (0x10000) MX[B]
[10] -1 0 0xd3210000 - 0xd32100ff (0x100) MX[B]
[11] -1 0 0xb0000000 - 0xafffffff (0x0) MX[B]O
[12] -1 0 0xd3100000 - 0xd3100fff (0x1000) MXB
[13] -1 0 0xd1000000 - 0xd100ffff (0x10000) MXB
[14] -1 0 0xc0000000 - 0xc7ffffff (0x8000000) MXB
[15] -1 0 0xd1010000 - 0xd101ffff (0x10000) MXB
[16] -1 0 0xc8000000 - 0xcfffffff (0x8000000) MXB
[17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[18] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[19] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[20] -1 0 0x0000e400 - 0x0000e40f (0x10) IX[B]
[21] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
[22] -1 0 0x0000dc00 - 0x0000dc1f (0x20) IX[B]
[23] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[24] -1 0 0x0000d400 - 0x0000d407 (0x8) IX[B]
[25] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]
[26] -1 0 0x0000c000 - 0x0000c0ff (0x100) IXB
(II) LoadModule: “GLcore”
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
Skipping “/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_clip.o”: No symbols found
Skipping “/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_norm.o”: No symbols found
Skipping “/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_xform.o”: No symbols found
Skipping “/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_vertex.o”: No symbols found
(II) Module GLcore: vendor="The XFree86 Project"
ABI class: XFree86 Server Extension, version 0.2
(II) Reloading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) LoadModule: “dbe”
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
Module class: XFree86 Server Extension
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “ddc”
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) LoadModule: “dri”
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading sub module “drm”
(II) LoadModule: “drm”
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading extension XFree86-DRI
(II) LoadModule: “extmod”
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “freetype”
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 2.0.2
(II) Loading font FreeType
(II) LoadModule: “glx”
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading sub module “GLcore”
(II) Reloading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Loading extension GLX
(II) LoadModule: “int10”
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) LoadModule: “record”
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “speedo”
(II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a
Skipping “/usr/X11R6/lib/modules/fonts/libspeedo.a:spencode.o”: No symbols found
(II) Module speedo: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.0.1
(II) Loading font Speedo
(II) LoadModule: “type1”
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: “vbe”
(II) Loading /usr/X11R6/lib/modules/libvbe.a
(II) Module vbe: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.1.0
(II) LoadModule: “vesa”
(II) Loading /usr/X11R6/lib/modules/drivers/vesa_drv.o
(II) Module vesa: vendor="The XFree86 Project"
Module class: XFree86 Video Driver
(II) LoadModule: “mouse”
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.4
(II) VESA: driver for VESA chipsets: vesa
(II) Primary Device is: PCI 01:00:0
(–) Assigning device section with no busID to primary device
(–) Chipset vesa found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[17] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[18] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[19] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[20] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[21] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[22] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[23] -1 0 0x0000e400 - 0x0000e40f (0x10) IX[B]
[24] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
[25] -1 0 0x0000dc00 - 0x0000dc1f (0x20) IX[B]
[26] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[27] -1 0 0x0000d400 - 0x0000d407 (0x8) IX[B]
[28] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]
[29] -1 0 0x0000c000 - 0x0000c0ff (0x100) IXB
[30] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[31] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module “vbe”
(II) Reloading /usr/X11R6/lib/modules/libvbe.a
(II) Loading sub module “int10”
(II) Reloading /usr/X11R6/lib/modules/linux/libint10.a
(II) VESA(0): initializing int10
(II) VESA(0): Primary V_BIOS segment is: 0xc000
(II) VESA(0): VESA BIOS detected
(II) VESA(0): VESA VBE Version 2.0
(II) VESA(0): VESA VBE Total Mem: 65536 kB
(II) VESA(0): VESA VBE OEM: ATI RADEON 9200
(II) VESA(0): VESA VBE OEM Software Rev: 1.0
(II) VESA(0): VESA VBE OEM Vendor: ATI Technologies Inc.
(II) VESA(0): VESA VBE OEM Product: V280
(II) VESA(0): VESA VBE OEM Product Rev: 01.00
(**) VESA(0): Depth 24, (–) framebuffer bpp 24
(==) VESA(0): RGB weight 888
(==) VESA(0): Default visual is TrueColor
(==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
(II) Loading sub module “ddc”
(II) Reloading /usr/X11R6/lib/modules/libddc.a
(II) VESA(0): VESA VBE DDC supported
(II) VESA(0): VESA VBE DDC Level 2
(II) VESA(0): VESA VBE DDC transfer in appr. 2 sec.
(II) VESA(0): VESA VBE DDC read successfully
(II) VESA(0): Manufacturer: LTN Model: 1713 Serial#: 16843009
(II) VESA(0): Year: 2003 Week: 31
(II) VESA(0): EDID Version: 1.3
(II) VESA(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
(II) VESA(0): Sync: Separate
(II) VESA(0): Max H-Image Size [cm]: horiz.: 32 vert.: 24
(II) VESA(0): Gamma: 2.88
(II) VESA(0): DPMS capabilities: Off; RGB/Color Display
(II) VESA(0): First detailed timing is preferred mode
(II) VESA(0): redX: 0.631 redY: 0.329 greenX: 0.276 greenY: 0.600
(II) VESA(0): blueX: 0.143 blueY: 0.057 whiteX: 0.283 whiteY: 0.298
(II) VESA(0): Supported VESA Video Modes:
(II) VESA(0): 720x400@70Hz
(II) VESA(0): 720x400@88Hz
(II) VESA(0): 640x480@60Hz
(II) VESA(0): 640x480@67Hz
(II) VESA(0): 640x480@72Hz
(II) VESA(0): 640x480@75Hz
(II) VESA(0): 800x600@56Hz
(II) VESA(0): 800x600@60Hz
(II) VESA(0): 800x600@72Hz
(II) VESA(0): 800x600@75Hz
(II) VESA(0): 832x624@75Hz
(II) VESA(0): 1024x768@87Hz (interlaced)
(II) VESA(0): 1024x768@60Hz
(II) VESA(0): 1024x768@70Hz
(II) VESA(0): 1024x768@75Hz
(II) VESA(0): 1152x870@75Hz
(II) VESA(0): Manufacturer’s mask: 0
(II) VESA(0): Supported Future Video Modes:
(II) VESA(0): #0: hsize: 640 vsize 480 refresh: 85 vid: 22833
(II) VESA(0): #1: hsize: 800 vsize 600 refresh: 85 vid: 22853
(II) VESA(0): #2: hsize: 1024 vsize 768 refresh: 85 vid: 22881
(II) VESA(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) VESA(0): Supported additional Video Mode:
(II) VESA(0): clock: 94.5 MHz Image Size: 306 x 230 mm
(II) VESA(0): h_active: 1024 h_sync: 1072 h_sync_end 1168 h_blank_end 1376 h_border: 0
(II) VESA(0): v_active: 768 v_sync: 769 v_sync_end 772 v_blanking: 808 v_border: 0
(II) VESA(0): Ranges: V min: 50 V max: 160 Hz, H min: 30 H max: 70 kHz, PixClock max 110 MHz
(II) VESA(0): Monitor name: e1770NSL/T
(II) VESA(0): Serial No: 331181459
(II) VESA(0): Searching for matching VESA mode(s):
Mode: 6a (800x600)
ModeAttributes: 0x1b
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
WinFuncPtr: 0xc00050ec
BytesPerScanline: 100
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 14
NumberOfPlanes: 4
BitsPerPixel: 4
NumberOfBanks: 1
MemoryModel: 3
BankSize: 0
NumberOfImages: 3
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
GreenFieldPosition: 0
BlueMaskSize: 0
BlueFieldPosition: 0
RsvdMaskSize: 0
RsvdFieldPosition: 0
DirectColorModeInfo: 0
PhysBasePtr: 0x0
Mode: 102 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 14
NumberOfPlanes: 4
BitsPerPixel: 4
NumberOfBanks: 1
MemoryModel: 3
BankSize: 0
NumberOfImages: 3
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
Mode: 104 (1024x768)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 128
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 4
BitsPerPixel: 4
NumberOfBanks: 1
MemoryModel: 3
BankSize: 0
NumberOfImages: 1
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
Mode: 182 (320x200)
ModeAttributes: 0xbb
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 320
XResolution: 320
YResolution: 200
XCharSize: 8
YCharSize: 8
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 254
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0xc0000000
Mode: 10d (320x200)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 640
XResolution: 320
YResolution: 200
XCharSize: 8
YCharSize: 8
NumberOfPlanes: 1
BitsPerPixel: 15
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 254
RedMaskSize: 5
RedFieldPosition: 10
GreenMaskSize: 5
GreenFieldPosition: 5
BlueMaskSize: 5
RsvdMaskSize: 0
Mode: 10e (320x200)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 320
YResolution: 200
XCharSize: 8
YCharSize: 8
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 254
RedMaskSize: 5
RedFieldPosition: 11
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
*Mode: 10f (320x200)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 960
XResolution: 320
YResolution: 200
XCharSize: 8
YCharSize: 8
NumberOfPlanes: 1
BitsPerPixel: 24
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 254
RedMaskSize: 8
RedFieldPosition: 16
GreenMaskSize: 8
GreenFieldPosition: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 120 (320x200)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 1280
XResolution: 320
YResolution: 200
XCharSize: 8
YCharSize: 8
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 254
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 192 (320x240)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 320
YResolution: 240
XCharSize: 8
YCharSize: 8
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 254
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
Mode: 193 (320x240)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 320
YResolution: 240
XCharSize: 8
YCharSize: 8
NumberOfPlanes: 1
BitsPerPixel: 15
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 254
RedMaskSize: 5
GreenMaskSize: 5
BlueMaskSize: 5
RsvdMaskSize: 0
Mode: 194 (320x240)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 320
YResolution: 240
XCharSize: 8
YCharSize: 8
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 254
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
*Mode: 195 (320x240)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 320
YResolution: 240
XCharSize: 8
YCharSize: 8
NumberOfPlanes: 1
BitsPerPixel: 24
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 254
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 196 (320x240)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 320
YResolution: 240
XCharSize: 8
YCharSize: 8
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 203
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 1a2 (400x300)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 400
XResolution: 400
YResolution: 300
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 254
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
Mode: 1a3 (400x300)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 800
XResolution: 400
YResolution: 300
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 15
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 254
RedMaskSize: 5
GreenMaskSize: 5
BlueMaskSize: 5
RsvdMaskSize: 0
Mode: 1a4 (400x300)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 400
YResolution: 300
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 254
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
*Mode: 1a5 (400x300)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 1200
XResolution: 400
YResolution: 300
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 24
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 169
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 1a6 (400x300)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 1600
XResolution: 400
YResolution: 300
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 127
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 1b2 (512x384)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 512
XResolution: 512
YResolution: 384
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 254
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
Mode: 1b3 (512x384)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 1024
XResolution: 512
YResolution: 384
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 15
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 169
RedMaskSize: 5
GreenMaskSize: 5
BlueMaskSize: 5
RsvdMaskSize: 0
Mode: 1b4 (512x384)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 512
YResolution: 384
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 169
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
*Mode: 1b5 (512x384)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 1536
XResolution: 512
YResolution: 384
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 24
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 112
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 1b6 (512x384)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 2048
XResolution: 512
YResolution: 384
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 84
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 1c2 (640x350)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 640
YResolution: 350
XCharSize: 8
YCharSize: 14
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 254
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
Mode: 1c3 (640x350)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 640
YResolution: 350
XCharSize: 8
YCharSize: 14
NumberOfPlanes: 1
BitsPerPixel: 15
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 145
RedMaskSize: 5
GreenMaskSize: 5
BlueMaskSize: 5
RsvdMaskSize: 0
Mode: 1c4 (640x350)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 640
YResolution: 350
XCharSize: 8
YCharSize: 14
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 145
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
*Mode: 1c5 (640x350)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 1920
XResolution: 640
YResolution: 350
XCharSize: 8
YCharSize: 14
NumberOfPlanes: 1
BitsPerPixel: 24
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 92
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 1c6 (640x350)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 2560
XResolution: 640
YResolution: 350
XCharSize: 8
YCharSize: 14
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 72
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 100 (640x400)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 640
YResolution: 400
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 254
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
Mode: 183 (640x400)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 640
YResolution: 400
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 15
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 127
RedMaskSize: 5
GreenMaskSize: 5
BlueMaskSize: 5
RsvdMaskSize: 0
Mode: 184 (640x400)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 640
YResolution: 400
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 127
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
*Mode: 185 (640x400)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 640
YResolution: 400
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 24
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 84
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 186 (640x400)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 640
YResolution: 400
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 63
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 101 (640x480)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 203
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
Mode: 110 (640x480)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 15
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 101
RedMaskSize: 5
GreenMaskSize: 5
BlueMaskSize: 5
RsvdMaskSize: 0
Mode: 111 (640x480)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 101
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
*Mode: 112 (640x480)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 24
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 67
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 121 (640x480)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 52
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 103 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 14
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 127
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
Mode: 113 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 14
NumberOfPlanes: 1
BitsPerPixel: 15
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 67
RedMaskSize: 5
GreenMaskSize: 5
BlueMaskSize: 5
RsvdMaskSize: 0
Mode: 114 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 14
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 67
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
*Mode: 115 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 2400
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 14
NumberOfPlanes: 1
BitsPerPixel: 24
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 45
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 122 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 3200
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 14
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 33
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 105 (1024x768)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 84
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
Mode: 116 (1024x768)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 15
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 41
RedMaskSize: 5
GreenMaskSize: 5
BlueMaskSize: 5
RsvdMaskSize: 0
Mode: 117 (1024x768)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 41
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
*Mode: 118 (1024x768)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 3072
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 24
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 27
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 123 (1024x768)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 4096
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 20
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 107 (1280x1024)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 1280
YResolution: 1024
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 50
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
Mode: 119 (1280x1024)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 1280
YResolution: 1024
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 15
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 24
RedMaskSize: 5
GreenMaskSize: 5
BlueMaskSize: 5
RsvdMaskSize: 0
Mode: 11a (1280x1024)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
XResolution: 1280
YResolution: 1024
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 24
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
*Mode: 11b (1280x1024)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 3840
XResolution: 1280
YResolution: 1024
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 24
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 16
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 124 (1280x1024)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0xa000
BytesPerScanline: 5120
XResolution: 1280
YResolution: 1024
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 11
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 0
Mode: 109 (132x25)
ModeAttributes: 0xf
WinAAttributes: 0x6
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0xb800
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 264
XResolution: 132
YResolution: 25
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 4
NumberOfBanks: 1
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
Mode: 10a (132x43)
ModeAttributes: 0xf
WinAAttributes: 0x6
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0xb800
WinBSegment: 0x0
WinFuncPtr: 0x0
XResolution: 132
YResolution: 43
XCharSize: 8
YCharSize: 8
NumberOfPlanes: 1
BitsPerPixel: 4
NumberOfBanks: 1
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
Mode: 130 (132x44)
ModeAttributes: 0xf
WinAAttributes: 0x6
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0xb800
WinBSegment: 0x0
WinFuncPtr: 0x0
XResolution: 132
YResolution: 44
XCharSize: 8
YCharSize: 8
NumberOfPlanes: 1
BitsPerPixel: 4
NumberOfBanks: 1
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
(II) VESA(0): Total Memory: 1024 64KB banks (65536kB)
(II) VESA(0): e1770NSL/T: Using hsync range of 30.00-70.00 kHz
(II) VESA(0): e1770NSL/T: Using vrefresh range of 50.00-160.00 Hz
(II) VESA(0): Not using built-in mode “1280x1024” (width too large for virtual size)
(II) VESA(0): Not using built-in mode “1024x768” (width too large for virtual size)
(–) VESA(0): Virtual size is 800x600 (pitch 800)
() VESA(0): *Built-in mode “800x600”
() VESA(0): *Built-in mode “640x480”
() VESA(0): Built-in mode “640x400”
() VESA(0): Built-in mode “640x350”
(–) VESA(0): Display dimensions: (320, 240) mm
(–) VESA(0): DPI set to (63, 63)
(II) VESA(0): Attempting to use 85Hz refresh for mode “800x600” (115)
(II) VESA(0): Attempting to use 85Hz refresh for mode “640x480” (112)
(II) VESA(0): Attempting to use 85Hz refresh for mode “640x400” (185)
(II) VESA(0): Attempting to use 85Hz refresh for mode “640x350” (1c5)
() VESA(0): Using “Shadow Framebuffer”
(II) Loading sub module “shadow”
(II) LoadModule: “shadow”
(II) Loading /usr/X11R6/lib/modules/libshadow.a
(II) Module shadow: vendor="The XFree86 Project"
ABI class: XFree86 ANSI C Emulation, version 0.2
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
(==) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don’t.
(II) resource ranges after preInit:
(==) VESA(0): Write-combining range (0xc0000000,0x4000000)
(II) VESA(0): virtual address = 0x4028e000,
physical address = 0xc0000000, size = 67108864
(II) VESA(0): VBESetVBEMode failed…Tried again without customized values.
(==) VESA(0): Backing store disabled
() Option “dpms”
() VESA(0): DPMS enabled
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Keyboard “Generic Keyboard” handled by legacy driver
() Option “Protocol” “ImPS/2”
() Configured Mouse: Protocol: “ImPS/2”
() Option “CorePointer”
() Configured Mouse: Core Pointer
() Option “Device” “/dev/input/mice”
() Option “Emulate3Buttons” “true”
() Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
() Option “ZAxisMapping” “4 5”
() Configured Mouse: ZAxisMapping: buttons 4 and 5
(**) Configured Mouse: Buttons: 5
(II) XINPUT: Adding extended input device “Configured Mouse” (type: MOUSE)
(II) Configured Mouse: ps2EnableDataReporting: succeeded
Warning: font renderer for “.pcf” already registered at priority 0
Warning: font renderer for “.pcf.Z” already registered at priority 0
Warning: font renderer for “.pcf.gz” already registered at priority 0
Warning: font renderer for “.snf” already registered at priority 0
Warning: font renderer for “.snf.Z” already registered at priority 0
Warning: font renderer for “.snf.gz” already registered at priority 0
Warning: font renderer for “.bdf” already registered at priority 0
Warning: font renderer for “.bdf.Z” already registered at priority 0
Warning: font renderer for “.bdf.gz” already registered at priority 0
Warning: font renderer for “.pmf” already registered at priority 0
Could not init font path element unix/:7100, removing from list!
