[Résolu] Problème son - carte nVidia - squeeze
Je me suis mis à debian il y a peu et je rencontre quelques problèmes lors de la configuration via alsa.
Info sur mon ordinateur:
Packard bell easy note SJ81 (pas de troll sur les packard bells siouplait :p)
Version de debian installé: 2.6.32-3-686 Squeeze, 32 bit
Résultat de la commande lspci:
[ul]00:00.0 RAM memory: nVidia Corporation MCP67 Memory Controller (rev a2)
00:01.0 ISA bridge: nVidia Corporation MCP67 ISA Bridge (rev a2)
00:01.1 SMBus: nVidia Corporation MCP67 SMBus (rev a2)
00:01.3 Co-processor: nVidia Corporation MCP67 Co-processor (rev a2)
00:02.0 USB Controller: nVidia Corporation MCP67 OHCI USB 1.1 Controller (rev a2)
00:02.1 USB Controller: nVidia Corporation MCP67 EHCI USB 2.0 Controller (rev a2)
00:04.0 USB Controller: nVidia Corporation MCP67 OHCI USB 1.1 Controller (rev a2)
00:04.1 USB Controller: nVidia Corporation MCP67 EHCI USB 2.0 Controller (rev a2)
00:06.0 IDE interface: nVidia Corporation MCP67 IDE Controller (rev a1)
00:07.0 Audio device: nVidia Corporation MCP67 High Definition Audio (rev a1)
00:08.0 PCI bridge: nVidia Corporation MCP67 PCI Bridge (rev a2)
00:09.0 IDE interface: nVidia Corporation MCP67 AHCI Controller (rev a2)
00:0a.0 Ethernet controller: nVidia Corporation MCP67 Ethernet (rev a2)
00:0b.0 PCI bridge: nVidia Corporation MCP67 PCI Express Bridge (rev a2)
00:0c.0 PCI bridge: nVidia Corporation MCP67 PCI Express Bridge (rev a2)
00:0d.0 PCI bridge: nVidia Corporation MCP67 PCI Express Bridge (rev a2)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:06.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller (rev c0)
02:00.0 VGA compatible controller: nVidia Corporation G86 [GeForce 8600M GS] (rev a1)[/ul]
Soit en plus détaillé pour la carte Audio:
Subsystem: Packard Bell B.V. Device c107
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 10
Memory at f0780000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [44] Power Management version 2
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [6c] HyperTransport: MSI Mapping Enable- Fixed+
Plusieurs réponses ont été trouvés sur le net, aucune n’a été concluante:
J’ai eu droit à:
installation d’alsa-firmware-1.0.20.deb
=> Bien installé, rien n’a changé.
Installation de:
alsa-driver-linuxant_1.0.20.3_all.deb
Qui est censé contenir les bons drivers… Mais lors de l’installation, j’ai droits à de jolies erreurs:
[ul]make dep
make[1]: Entering directory /usr/lib/alsa-driver-linuxant' #@for d in acore i2c drivers isa synth pci aoa soc usb pcmcia misc; do if ! make -C $d prepare; then exit 1; fi; done make[1]: Leaving directory/usr/lib/alsa-driver-linuxant’
make -C /lib/modules/2.6.32-3-686/source SUBDIRS=/usr/lib/alsa-driver-linuxant CPP=“gcc -E” CC=“gcc” modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.32-3-common’
ERROR: Kernel configuration is invalid.
include/linux/autoconf.h or include/config/auto.conf are missing.
Run ‘make oldconfig && make prepare’ on kernel src to fix it.
WARNING: Symbol version dump /usr/src/linux-headers-2.6.32-3-common/Module.symvers
is missing; modules will have no dependencies and modversions.
find: /usr/src/linux-headers-2.6.32-3-common/alsa-kernel/': No such file or directory find:/usr/src/linux-headers-2.6.32-3-common/alsa-kernel/’: No such file or directory
find: /usr/src/linux-headers-2.6.32-3-common/alsa-kernel/': No such file or directory Building modules, stage 2. /usr/src/linux-headers-2.6.32-3-common/scripts/Makefile.modpost:42: include/config/auto.conf: No such file or directory find:/usr/src/linux-headers-2.6.32-3-common/alsa-kernel/’: No such file or directory
make[2]: *** No rule to make target include/config/auto.conf'. Stop. make[1]: *** [modules] Error 2 make[1]: Leaving directory/usr/src/linux-headers-2.6.32-3-common’
make: *** [compile] Error 2[/ul]
Le fichier .config est bien présent dans /usr/src/linux-headers-2.6.32-3-686 (je ne sais pas s’il faut faire autre chose pour ça :/, ni même si l’installation de ce package règlerait mon problème).
Résultat de aplay -l:
aplay: device_list:223: no soundcards found…
Voilà, c’est à peu près tout ce que je peux dire. Je suis sous gnome, le reste tourne nickel :slight_smile:
Merci d’avance à tous ceux qui peuvent m’aider
Il n’aurait pas été plus sage de commencer par la stable ?
stable ou pas, ça devrait fonctionner.
Que te donne les logs ?
Par ex un dmesg
[quote=“piratebab”]stable ou pas, ça devrait fonctionner.
Par ex un dmesg[/quote]
Ben voyons :005 Surtout la squeeze de ce moment !
Alors, si j’ai mis la squeeze au lieu de la lenny, c’est pour une raison, ma carte wifi, dont les pilotes sont présents “de base” dans la squeeze alors qu’avec la lenny, il faut bidouiller un peu avec ndiswrapper et ça me semblait moins “propre” du coup :slight_smile:
Voici le résultat de dmesg:
[ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 2.6.32-3-686 (Debian 2.6.32-9) (maks@debian.org) (gcc version 4.3.4 (Debian 4.3.4-8) ) #1 SMP Thu Feb 25 06:14:20 UTC 2010 [ 0.000000] KERNEL supported cpus: [ 0.000000] Intel GenuineIntel [ 0.000000] AMD AuthenticAMD [ 0.000000] NSC Geode by NSC [ 0.000000] Cyrix CyrixInstead [ 0.000000] Centaur CentaurHauls [ 0.000000] Transmeta GenuineTMx86 [ 0.000000] Transmeta TransmetaCPU [ 0.000000] UMC UMC UMC UMC [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009e000 (usable) [ 0.000000] BIOS-e820: 000000000009e000 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000ce000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 000000007ff50000 (usable) [ 0.000000] BIOS-e820: 000000007ff50000 - 000000007ff61000 (ACPI data) [ 0.000000] BIOS-e820: 000000007ff61000 - 000000007ff62000 (ACPI NVS) [ 0.000000] BIOS-e820: 000000007ff62000 - 0000000080000000 (reserved) [ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved) [ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved) [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved) [ 0.000000] BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved) [ 0.000000] DMI present. [ 0.000000] Phoenix BIOS detected: BIOS may corrupt low RAM, working around it. [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] last_pfn = 0x7ff50 max_arch_pfn = 0x100000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-CEFFF write-protect [ 0.000000] CF000-E3FFF uncachable [ 0.000000] E4000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 0000000000 mask FF80000000 write-back [ 0.000000] 1 disabled [ 0.000000] 2 disabled [ 0.000000] 3 disabled [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] initial memory mapped : 0 - 01800000 [ 0.000000] init_memory_mapping: 0000000000000000-00000000373fe000 [ 0.000000] 0000000000 - 0000400000 page 4k [ 0.000000] 0000400000 - 0037000000 page 2M [ 0.000000] 0037000000 - 00373fe000 page 4k [ 0.000000] kernel direct mapping tables up to 373fe000 @ 10000-16000 [ 0.000000] RAMDISK: 3787e000 - 37fef721 [ 0.000000] Allocated new RAMDISK: 00100000 - 00871721 [ 0.000000] Move RAMDISK from 000000003787e000 - 0000000037fef720 to 00100000 - 00871720 [ 0.000000] ACPI: RSDP 000f81b0 00024 (v02 PTLTD ) [ 0.000000] ACPI: XSDT 7ff5bba2 00074 (v01 PacBel PBNB0008 06040000 LTP 00000000) [ 0.000000] ACPI: FACP 7ff608b6 000F4 (v03 NVIDIA MCP67-M 06040000 PTL_ 000F4240) [ 0.000000] ACPI: DSDT 7ff5bc16 04C2C (v01 NVIDIA MCP67 06040000 MSFT 03000001) [ 0.000000] ACPI: FACS 7ff61fc0 00040 [ 0.000000] ACPI: SLIC 7ff609aa 00176 (v01 PacBel PBNB0008 06040000 00000000) [ 0.000000] ACPI: TCPA 7ff60b20 00032 (v01 Phoeni x 06040000 TL 00000000) [ 0.000000] ACPI: SRAT 7ff60b52 000A0 (v01 AMD HAMMER 06040000 AMD 00000001) [ 0.000000] ACPI: WDAT 7ff60bf2 00104 (v01 PTLTD WDATTBL 06040000 LTP 00000001) [ 0.000000] ACPI: SSDT 7ff60cf6 00206 (v01 PTLTD POWERNOW 06040000 LTP 00000001) [ 0.000000] ACPI: MCFG 7ff60efc 0003C (v01 PTLTD MCFG 06040000 LTP 00000000) [ 0.000000] ACPI: HPET 7ff60f38 00038 (v01 PTLTD HPETTBL 06040000 LTP 00000001) [ 0.000000] ACPI: APIC 7ff60f70 00068 (v01 PTLTD ? APIC 06040000 LTP 00000000) [ 0.000000] ACPI: BOOT 7ff60fd8 00028 (v01 PTLTD $SBFTBL$ 06040000 LTP 00000001) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 1163MB HIGHMEM available. [ 0.000000] 883MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 373fe000 [ 0.000000] low ram: 0 - 373fe000 [ 0.000000] node 0 low ram: 00000000 - 373fe000 [ 0.000000] node 0 bootmap 00012000 - 00018e80 [ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00373fe000] [ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000] [ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000] [ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000] [ 0.000000] #3 [0001000000 - 00014a9314] TEXT DATA BSS ==> [0001000000 - 00014a9314] [ 0.000000] #4 [000009e000 - 0000100000] BIOS reserved ==> [000009e000 - 0000100000] [ 0.000000] #5 [00014aa000 - 00014b00f8] BRK ==> [00014aa000 - 00014b00f8] [ 0.000000] #6 [0000010000 - 0000012000] PGTABLE ==> [0000010000 - 0000012000] [ 0.000000] #7 [0000100000 - 0000871721] NEW RAMDISK ==> [0000100000 - 0000871721] [ 0.000000] #8 [0000012000 - 0000019000] BOOTMAP ==> [0000012000 - 0000019000] [ 0.000000] found SMP MP-table at [c00f8140] f8140 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] Normal 0x00001000 -> 0x000373fe [ 0.000000] HighMem 0x000373fe -> 0x0007ff50 [ 0.000000] Movable zone start PFN for each node [ 0.000000] early_node_map[2] active PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009e [ 0.000000] 0: 0x00000100 -> 0x0007ff50 [ 0.000000] On node 0 totalpages: 523998 [ 0.000000] free_area_init_node: node 0, pgdat c1396fc0, node_mem_map c14b2200 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3950 pages, LIFO batch:0 [ 0.000000] Normal zone: 1736 pages used for memmap [ 0.000000] Normal zone: 220470 pages, LIFO batch:31 [ 0.000000] HighMem zone: 2327 pages used for memmap [ 0.000000] HighMem zone: 295483 pages, LIFO batch:31 [ 0.000000] Using APIC driver default [ 0.000000] Detected use of extended apic ids on hypertransport bus [ 0.000000] ACPI: PM-Timer IO Port: 0x1008 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1]) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1]) [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x10de8201 base: 0xfed00000 [ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs [ 0.000000] nr_irqs_gsi: 24 [ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000ce000 [ 0.000000] PM: Registered nosave memory: 00000000000ce000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:60000000) [ 0.000000] Booting paravirtualized kernel on bare hardware [ 0.000000] NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:2 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 14 pages/cpu @c2800000 s34072 r0 d23272 u2097152 [ 0.000000] pcpu-alloc: s34072 r0 d23272 u2097152 alloc=1*4194304 [ 0.000000] pcpu-alloc: [0] 0 1 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519903 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-3-686 root=UUID=85447b33-1798-4fef-aa15-672bbd5ed2f0 ro quiet [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Enabling fast FPU save and restore... done. [ 0.000000] Enabling unmasked SIMD FPU exception support... done. [ 0.000000] Initializing CPU#0 [ 0.000000] Initializing HighMem for node 0 (000373fe:0007ff50) [ 0.000000] Memory: 2065108k/2096448k available (2429k kernel code, 29788k reserved, 1284k data, 368k init, 1191240k highmem) [ 0.000000] virtual kernel memory layout: [ 0.000000] fixmap : 0xffd56000 - 0xfffff000 (2724 kB) [ 0.000000] pkmap : 0xff400000 - 0xff800000 (4096 kB) [ 0.000000] vmalloc : 0xf7bfe000 - 0xff3fe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf73fe000 ( 883 MB) [ 0.000000] .init : 0xc13a1000 - 0xc13fd000 ( 368 kB) [ 0.000000] .data : 0xc125f44d - 0xc13a0760 (1284 kB) [ 0.000000] .text : 0xc1000000 - 0xc125f44d (2429 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] NR_IRQS:1280 [ 0.000000] Extended CMOS year: 2000 [ 0.000000] spurious 8259A interrupt: IRQ7. [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] hpet clockevent registered [ 0.000000] HPET: 3 timers in total, 0 timers will be used for per-cpu timer [ 0.000000] Fast TSC calibration using PIT [ 0.000000] Detected 1900.076 MHz processor. [ 0.004005] Calibrating delay loop (skipped), value calculated using timer frequency.. 3800.15 BogoMIPS (lpj=7600304) [ 0.004022] Security Framework initialized [ 0.004027] SELinux: Disabled at boot. [ 0.004033] Mount-cache hash table entries: 512 [ 0.004145] Initializing cgroup subsys ns [ 0.004148] Initializing cgroup subsys cpuacct [ 0.004152] Initializing cgroup subsys devices [ 0.004155] Initializing cgroup subsys freezer [ 0.004157] Initializing cgroup subsys net_cls [ 0.004174] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line) [ 0.004177] CPU: L2 Cache: 512K (64 bytes/line) [ 0.004179] CPU: Physical Processor ID: 0 [ 0.004181] CPU: Processor Core ID: 0 [ 0.004184] mce: CPU supports 5 MCE banks [ 0.004194] using C1E aware idle routine [ 0.004202] Performance Events: AMD PMU driver. [ 0.004207] ... version: 0 [ 0.004209] ... bit width: 48 [ 0.004211] ... generic registers: 4 [ 0.004213] ... value mask: 0000ffffffffffff [ 0.004215] ... max period: 00007fffffffffff [ 0.004217] ... fixed-purpose events: 0 [ 0.004219] ... event mask: 000000000000000f [ 0.004222] Checking 'hlt' instruction... OK. [ 0.020895] ACPI: Core revision 20090903 [ 0.028603] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.070879] CPU0: AMD Turion(tm) 64 X2 Mobile Technology TL-58 stepping 01 [ 0.072001] Booting processor 1 APIC 0x1 ip 0x6000 [ 0.008000] Initializing CPU#1 [ 0.008000] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line) [ 0.008000] CPU: L2 Cache: 512K (64 bytes/line) [ 0.008000] CPU: Physical Processor ID: 0 [ 0.008000] CPU: Processor Core ID: 1 [ 0.156045] CPU1: AMD Turion(tm) 64 X2 Mobile Technology TL-58 stepping 01 [ 0.156152] Brought up 2 CPUs [ 0.156155] Total of 2 processors activated (7600.51 BogoMIPS). [ 0.156150] System has AMD C1E enabled [ 0.156150] Switch to broadcast mode on CPU1 [ 0.156376] CPU0 attaching sched-domain: [ 0.156379] domain 0: span 0-1 level MC [ 0.156382] groups: 0 1 [ 0.156388] CPU1 attaching sched-domain: [ 0.156390] domain 0: span 0-1 level MC [ 0.156393] groups: 1 0 [ 0.156531] devtmpfs: initialized [ 0.156921] regulator: core version 0.5 [ 0.156978] NET: Registered protocol family 16 [ 0.157066] ACPI: bus type pci registered [ 0.157143] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 8 [ 0.157147] PCI: MCFG area at e0000000 reserved in E820 [ 0.157149] PCI: Using MMCONFIG for extended config space [ 0.157151] PCI: Using configuration type 1 for base access [ 0.157552] bio: create slab <bio-0> at 0 [ 0.158065] ACPI: EC: Look up EC in DSDT [ 0.160884] ACPI: Interpreter enabled [ 0.160891] ACPI: (supports S0 S3 S4 S5) [ 0.160909] ACPI: Using IOAPIC for interrupt routing [ 0.161642] [Firmware Bug]: ACPI: ACPI brightness control misses _BQC function [ 0.165760] ACPI: EC: GPE = 0x2, I/O: command/status = 0x66, data = 0x62 [ 0.166046] ACPI: No dock devices found. [ 0.166154] ACPI: PCI Root Bridge [PCI0] (0000:00) [ 0.166373] pci 0000:00:01.1: reg 10 io port: [0x3080-0x30bf] [ 0.166385] pci 0000:00:01.1: reg 20 io port: [0x3040-0x307f] [ 0.166390] pci 0000:00:01.1: reg 24 io port: [0x3000-0x303f] [ 0.166410] pci 0000:00:01.1: PME# supported from D3hot D3cold [ 0.166416] pci 0000:00:01.1: PME# disabled [ 0.166447] pci 0000:00:01.3: reg 10 32bit mmio: [0xf0500000-0xf057ffff] [ 0.166526] pci 0000:00:02.0: reg 10 32bit mmio: [0xf0786000-0xf0786fff] [ 0.166549] pci 0000:00:02.0: supports D1 D2 [ 0.166552] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.166556] pci 0000:00:02.0: PME# disabled [ 0.166580] pci 0000:00:02.1: reg 10 32bit mmio: [0xf0789000-0xf07890ff] [ 0.166607] pci 0000:00:02.1: supports D1 D2 [ 0.166610] pci 0000:00:02.1: PME# supported from D0 D1 D2 D3hot D3cold [ 0.166614] pci 0000:00:02.1: PME# disabled [ 0.166641] pci 0000:00:04.0: reg 10 32bit mmio: [0xf0787000-0xf0787fff] [ 0.166664] pci 0000:00:04.0: supports D1 D2 [ 0.166667] pci 0000:00:04.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.166671] pci 0000:00:04.0: PME# disabled [ 0.166695] pci 0000:00:04.1: reg 10 32bit mmio: [0xf0789400-0xf07894ff] [ 0.166722] pci 0000:00:04.1: supports D1 D2 [ 0.166725] pci 0000:00:04.1: PME# supported from D0 D1 D2 D3hot D3cold [ 0.166729] pci 0000:00:04.1: PME# disabled [ 0.166763] pci 0000:00:06.0: reg 20 io port: [0x30c0-0x30cf] [ 0.166802] pci 0000:00:07.0: reg 10 32bit mmio: [0xf0780000-0xf0783fff] [ 0.166829] pci 0000:00:07.0: PME# supported from D3hot D3cold [ 0.166833] pci 0000:00:07.0: PME# disabled [ 0.166898] pci 0000:00:09.0: reg 10 io port: [0x30f0-0x30f7] [ 0.166903] pci 0000:00:09.0: reg 14 io port: [0x30e4-0x30e7] [ 0.166908] pci 0000:00:09.0: reg 18 io port: [0x30e8-0x30ef] [ 0.166913] pci 0000:00:09.0: reg 1c io port: [0x30e0-0x30e3] [ 0.166918] pci 0000:00:09.0: reg 20 io port: [0x30d0-0x30df] [ 0.166924] pci 0000:00:09.0: reg 24 32bit mmio: [0xf0784000-0xf0785fff] [ 0.166971] pci 0000:00:0a.0: reg 10 32bit mmio: [0xf0788000-0xf0788fff] [ 0.166976] pci 0000:00:0a.0: reg 14 io port: [0x30f8-0x30ff] [ 0.166981] pci 0000:00:0a.0: reg 18 32bit mmio: [0xf0789c00-0xf0789cff] [ 0.166986] pci 0000:00:0a.0: reg 1c 32bit mmio: [0xf0789800-0xf078980f] [ 0.167008] pci 0000:00:0a.0: supports D1 D2 [ 0.167011] pci 0000:00:0a.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.167016] pci 0000:00:0a.0: PME# disabled [ 0.167056] pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.167059] pci 0000:00:0b.0: PME# disabled [ 0.167099] pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.167102] pci 0000:00:0c.0: PME# disabled [ 0.167140] pci 0000:00:0d.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.167144] pci 0000:00:0d.0: PME# disabled [ 0.167258] pci 0000:01:06.0: reg 10 32bit mmio: [0xf0400000-0xf04007ff] [ 0.167265] pci 0000:01:06.0: reg 14 io port: [0x4000-0x407f] [ 0.167298] pci 0000:01:06.0: supports D2 [ 0.167301] pci 0000:01:06.0: PME# supported from D2 D3hot D3cold [ 0.167305] pci 0000:01:06.0: PME# disabled [ 0.167337] pci 0000:00:08.0: transparent bridge [ 0.167341] pci 0000:00:08.0: bridge io port: [0x4000-0x4fff] [ 0.167345] pci 0000:00:08.0: bridge 32bit mmio: [0xf0400000-0xf04fffff] [ 0.167390] pci 0000:02:00.0: reg 10 32bit mmio: [0xce000000-0xceffffff] [ 0.167404] pci 0000:02:00.0: reg 14 64bit mmio pref: [0xd0000000-0xdfffffff] [ 0.167418] pci 0000:02:00.0: reg 1c 64bit mmio: [0xcc000000-0xcdffffff] [ 0.167427] pci 0000:02:00.0: reg 24 io port: [0x5000-0x507f] [ 0.167436] pci 0000:02:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff] [ 0.167538] Switch to broadcast mode on CPU0 [ 0.172074] pci 0000:00:0b.0: bridge io port: [0x5000-0x5fff] [ 0.172077] pci 0000:00:0b.0: bridge 32bit mmio: [0xcc000000-0xceffffff] [ 0.172082] pci 0000:00:0b.0: bridge 64bit mmio pref: [0xd0000000-0xdfffffff] [ 0.172153] pci 0000:00:0d.0: bridge io port: [0x6000-0x6fff] [ 0.172157] pci 0000:00:0d.0: bridge 32bit mmio: [0xf0200000-0xf03fffff] [ 0.172161] pci 0000:00:0d.0: bridge 64bit mmio pref: [0xf0000000-0xf01fffff] [ 0.172171] pci_bus 0000:00: on NUMA node 0 [ 0.172176] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.172254] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2P0._PRT] [ 0.172310] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.XVR0._PRT] [ 0.172340] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.XVR1._PRT] [ 0.172370] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.XVR2._PRT] [ 0.195272] ACPI: PCI Interrupt Link [LNK1] (IRQs 5 7 10 11 14 15) *0, disabled. [ 0.195434] ACPI: PCI Interrupt Link [LNK2] (IRQs 5 7 10 11 14 15) *0, disabled. [ 0.195594] ACPI: PCI Interrupt Link [LNK3] (IRQs 5 7 *10 11 14 15) [ 0.195753] ACPI: PCI Interrupt Link [LNK4] (IRQs 5 7 10 11 14 15) *0, disabled. [ 0.195913] ACPI: PCI Interrupt Link [LK1E] (IRQs 16 17 18 19 20 21 22 23) *0, disabled. [ 0.196086] ACPI: PCI Interrupt Link [LK2E] (IRQs 16 17 18 19 20 21 22 23) *10 [ 0.196246] ACPI: PCI Interrupt Link [LK3E] (IRQs 16 17 18 19 20 21 22 23) *0, disabled. [ 0.196407] ACPI: PCI Interrupt Link [LK4E] (IRQs 16 17 18 19 20 21 22 23) *0, disabled. [ 0.196569] ACPI: PCI Interrupt Link [LSMB] (IRQs 16 17 18 19 20 21 22 23) *10 [ 0.196731] ACPI: PCI Interrupt Link [LUS0] (IRQs 16 17 18 19 20 21 22 23) *11 [ 0.196891] ACPI: PCI Interrupt Link [LUS2] (IRQs 16 17 18 19 20 21 22 23) *7 [ 0.197052] ACPI: PCI Interrupt Link [LMAC] (IRQs 16 17 18 19 20 21 22 23) *11 [ 0.197213] ACPI: PCI Interrupt Link [LAZA] (IRQs 16 17 18 19 20 21 22 23) *10 [ 0.197373] ACPI: PCI Interrupt Link [LGPU] (IRQs 16 17 18 19 20 21 22 23) *0, disabled. [ 0.197537] ACPI: PCI Interrupt Link [LPID] (IRQs 16 17 18 19 20 21 22 23) *0, disabled. [ 0.197698] ACPI: PCI Interrupt Link [LSI0] (IRQs 16 17 18 19 20 21 22 23) *11 [ 0.197859] ACPI: PCI Interrupt Link [Z005] (IRQs 16 17 18 19 20 21 22 23) *5 [ 0.198020] ACPI: PCI Interrupt Link [Z006] (IRQs 16 17 18 19 20 21 22 23) *10 [ 0.198183] ACPI: PCI Interrupt Link [LPMU] (IRQs 16 17 18 19 20 21 22 23) *11 [ 0.198290] vgaarb: device added: PCI:0000:02:00.0,decodes=io+mem,owns=io+mem,locks=none [ 0.198293] vgaarb: loaded [ 0.198365] PCI: Using ACPI for IRQ routing [ 0.198528] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 31 [ 0.198534] hpet0: 3 comparators, 32-bit 25.000000 MHz counter [ 0.208005] Switching to clocksource hpet [ 0.209301] pnp: PnP ACPI init [ 0.209316] ACPI: bus type pnp registered [ 0.211742] pnp: PnP ACPI: found 12 devices [ 0.211745] ACPI: ACPI bus type pnp unregistered [ 0.211749] PnPBIOS: Disabled by ACPI PNP [ 0.211761] system 00:02: iomem range 0xe0000000-0xefffffff has been reserved [ 0.211768] system 00:03: ioport range 0x1000-0x107f has been reserved [ 0.211772] system 00:03: ioport range 0x1080-0x10ff has been reserved [ 0.211776] system 00:03: ioport range 0x1400-0x147f has been reserved [ 0.211780] system 00:03: ioport range 0x1480-0x14ff has been reserved [ 0.211784] system 00:03: ioport range 0x1800-0x187f has been reserved [ 0.211788] system 00:03: ioport range 0x1880-0x18ff has been reserved [ 0.211791] system 00:03: ioport range 0x3040-0x307f has been reserved [ 0.211795] system 00:03: ioport range 0x3000-0x303f has been reserved [ 0.211802] system 00:04: ioport range 0x360-0x361 has been reserved [ 0.211806] system 00:04: ioport range 0x4d0-0x4d1 has been reserved [ 0.211815] system 00:0b: iomem range 0xffc00000-0xffffffff could not be reserved [ 0.211819] system 00:0b: iomem range 0xfec00000-0xfec00fff could not be reserved [ 0.211823] system 00:0b: iomem range 0xfee00000-0xfeefffff could not be reserved [ 0.211827] system 00:0b: iomem range 0xfed00000-0xfed00fff has been reserved [ 0.211831] system 00:0b: iomem range 0xfec80000-0xfec80fff has been reserved [ 0.211835] system 00:0b: iomem range 0xfef00000-0xfef00fff has been reserved [ 0.246630] pci 0000:00:08.0: PCI bridge, secondary bus 0000:01 [ 0.246635] pci 0000:00:08.0: IO window: 0x4000-0x4fff [ 0.246639] pci 0000:00:08.0: MEM window: 0xf0400000-0xf04fffff [ 0.246643] pci 0000:00:08.0: PREFETCH window: disabled [ 0.246651] pci 0000:02:00.0: BAR 6: can't allocate mem resource [0xe0000000-0xdfffffff] [ 0.246654] pci 0000:00:0b.0: PCI bridge, secondary bus 0000:02 [ 0.246658] pci 0000:00:0b.0: IO window: 0x5000-0x5fff [ 0.246662] pci 0000:00:0b.0: MEM window: 0xcc000000-0xceffffff [ 0.246667] pci 0000:00:0b.0: PREFETCH window: 0x000000d0000000-0x000000dfffffff [ 0.246671] pci 0000:00:0c.0: PCI bridge, secondary bus 0000:03 [ 0.246673] pci 0000:00:0c.0: IO window: disabled [ 0.246677] pci 0000:00:0c.0: MEM window: disabled [ 0.246680] pci 0000:00:0c.0: PREFETCH window: disabled [ 0.246684] pci 0000:00:0d.0: PCI bridge, secondary bus 0000:04 [ 0.246687] pci 0000:00:0d.0: IO window: 0x6000-0x6fff [ 0.246691] pci 0000:00:0d.0: MEM window: 0xf0200000-0xf03fffff [ 0.246695] pci 0000:00:0d.0: PREFETCH window: 0x000000f0000000-0x000000f01fffff [ 0.246704] pci 0000:00:08.0: setting latency timer to 64 [ 0.246710] pci 0000:00:0b.0: setting latency timer to 64 [ 0.246716] pci 0000:00:0c.0: setting latency timer to 64 [ 0.246722] pci 0000:00:0d.0: setting latency timer to 64 [ 0.246726] pci_bus 0000:00: resource 0 io: [0x00-0xffff] [ 0.246730] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff] [ 0.246734] pci_bus 0000:01: resource 0 io: [0x4000-0x4fff] [ 0.246737] pci_bus 0000:01: resource 1 mem: [0xf0400000-0xf04fffff] [ 0.246740] pci_bus 0000:01: resource 3 io: [0x00-0xffff] [ 0.246743] pci_bus 0000:01: resource 4 mem: [0x000000-0xffffffff] [ 0.246747] pci_bus 0000:02: resource 0 io: [0x5000-0x5fff] [ 0.246750] pci_bus 0000:02: resource 1 mem: [0xcc000000-0xceffffff] [ 0.246753] pci_bus 0000:02: resource 2 pref mem [0xd0000000-0xdfffffff] [ 0.246757] pci_bus 0000:04: resource 0 io: [0x6000-0x6fff] [ 0.246761] pci_bus 0000:04: resource 1 mem: [0xf0200000-0xf03fffff] [ 0.246764] pci_bus 0000:04: resource 2 pref mem [0xf0000000-0xf01fffff] [ 0.246801] NET: Registered protocol family 2 [ 0.246898] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.247255] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.247907] TCP bind hash table entries: 65536 (order: 7, 524288 bytes) [ 0.248284] TCP: Hash tables configured (established 131072 bind 65536) [ 0.248287] TCP reno registered [ 0.248376] NET: Registered protocol family 1 [ 0.248531] pci 0000:00:00.0: Found enabled HT MSI Mapping [ 0.248584] pci 0000:00:00.0: Found enabled HT MSI Mapping [ 0.248642] pci 0000:00:00.0: Found enabled HT MSI Mapping [ 0.248707] pci 0000:00:00.0: Found enabled HT MSI Mapping [ 0.248774] pci 0000:00:00.0: Found enabled HT MSI Mapping [ 0.248847] pci 0000:00:00.0: Found enabled HT MSI Mapping [ 0.248923] pci 0000:00:00.0: Found enabled HT MSI Mapping [ 0.248947] pci 0000:02:00.0: Boot video device [ 0.248999] Unpacking initramfs... [ 0.474217] Freeing initrd memory: 7621k freed [ 0.478997] Simple Boot Flag at 0x36 set to 0x1 [ 0.479318] audit: initializing netlink socket (disabled) [ 0.479331] type=2000 audit(1272802072.477:1): initialized [ 0.479512] highmem bounce pool size: 64 pages [ 0.479517] HugeTLB registered 4 MB page size, pre-allocated 0 pages [ 0.481043] VFS: Disk quotas dquot_6.5.2 [ 0.481108] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.481182] msgmni has been set to 1723 [ 0.481372] alg: No test for stdrng (krng) [ 0.481427] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.481431] io scheduler noop registered [ 0.481433] io scheduler anticipatory registered [ 0.481436] io scheduler deadline registered [ 0.481475] io scheduler cfq registered (default) [ 0.481583] pcieport 0000:00:0b.0: irq 24 for MSI/MSI-X [ 0.481590] pcieport 0000:00:0b.0: setting latency timer to 64 [ 0.481665] pcieport 0000:00:0c.0: irq 25 for MSI/MSI-X [ 0.481671] pcieport 0000:00:0c.0: setting latency timer to 64 [ 0.481745] pcieport 0000:00:0d.0: irq 26 for MSI/MSI-X [ 0.481750] pcieport 0000:00:0d.0: setting latency timer to 64 [ 0.481883] isapnp: Scanning for PnP cards... [ 0.834920] isapnp: No Plug & Play device found [ 0.836472] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.836851] PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:MSE0] at 0x60,0x64 irq 1,12 [ 0.846489] i8042.c: Detected active multiplexing controller, rev 1.1. [ 0.847150] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 0.847158] serio: i8042 AUX0 port at 0x60,0x64 irq 12 [ 0.847189] serio: i8042 AUX1 port at 0x60,0x64 irq 12 [ 0.847213] serio: i8042 AUX2 port at 0x60,0x64 irq 12 [ 0.847236] serio: i8042 AUX3 port at 0x60,0x64 irq 12 [ 0.847351] mice: PS/2 mouse device common for all mice [ 0.847413] rtc_cmos 00:07: RTC can wake from S4 [ 0.847450] rtc_cmos 00:07: rtc core: registered rtc_cmos as rtc0 [ 0.847490] rtc0: alarms up to one year, y3k, 114 bytes nvram, hpet irqs [ 0.847502] cpuidle: using governor ladder [ 0.847505] cpuidle: using governor menu [ 0.847509] No iBFT detected. [ 0.847930] TCP cubic registered [ 0.848100] NET: Registered protocol family 10 [ 0.848629] lo: Disabled Privacy Extensions [ 0.849015] Mobile IPv6 [ 0.849018] NET: Registered protocol family 17 [ 0.849032] Using IPI No-Shortcut mode [ 0.849104] PM: Resume from disk failed. [ 0.849111] registered taskstats version 1 [ 0.849457] rtc_cmos 00:07: setting system clock to 2010-05-02 12:07:54 UTC (1272802074) [ 0.849521] Freeing unused kernel memory: 368k freed [ 0.849791] Write protecting the kernel text: 2432k [ 0.849819] Write protecting the kernel read-only data: 888k [ 0.879730] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0 [ 0.964040] thermal LNXTHERM:01: registered as thermal_zone0 [ 0.964049] ACPI: Thermal Zone [THRM] (74 C) [ 1.084730] usbcore: registered new interface driver usbfs [ 1.084834] usbcore: registered new interface driver hub [ 1.084940] usbcore: registered new device driver usb [ 1.088156] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64. [ 1.088458] ACPI: PCI Interrupt Link [LMAC] enabled at IRQ 23 [ 1.088471] forcedeth 0000:00:0a.0: PCI INT A -> Link[LMAC] -> GSI 23 (level, low) -> IRQ 23 [ 1.088477] forcedeth 0000:00:0a.0: setting latency timer to 64 [ 1.103221] SCSI subsystem initialized [ 1.115938] Uniform Multi-Platform E-IDE driver [ 1.118836] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.122240] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1 [ 1.122250] ACPI: Power Button [PWRB] [ 1.122514] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2 [ 1.122519] ACPI: Sleep Button [SLPB] [ 1.122747] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input3 [ 1.122803] ACPI: Lid Switch [LID] [ 1.122906] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4 [ 1.122910] ACPI: Power Button [PWRF] [ 1.129413] [Firmware Bug]: ACPI(VGA) defines _DOD but not _DOS [ 1.129491] [Firmware Bug]: ACPI: ACPI brightness control misses _BQC function [ 1.134025] acpi device:0a: registered as cooling_device0 [ 1.134251] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:08/LNXVIDEO:00/input/input5 [ 1.134260] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no) [ 1.156901] libata version 3.00 loaded. [ 1.157965] ACPI: PCI Interrupt Link [LNK3] enabled at IRQ 10 [ 1.157979] firewire_ohci 0000:01:06.0: PCI INT A -> Link[LNK3] -> GSI 10 (level, low) -> IRQ 10 [ 1.236025] firewire_ohci: Added fw-ohci device 0000:01:06.0, OHCI version 1.10 [ 1.604941] forcedeth 0000:00:0a.0: ifname eth0, PHY OUI 0x5043 @ 1, addr 00:14:0b:38:8a:6b [ 1.604946] forcedeth 0000:00:0a.0: highdma pwrctl mgmt lnktim msi desc-v3 [ 1.605353] ACPI: PCI Interrupt Link [LUS2] enabled at IRQ 22 [ 1.605365] ehci_hcd 0000:00:02.1: PCI INT B -> Link[LUS2] -> GSI 22 (level, low) -> IRQ 22 [ 1.605386] ehci_hcd 0000:00:02.1: setting latency timer to 64 [ 1.605390] ehci_hcd 0000:00:02.1: EHCI Host Controller [ 1.605415] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1 [ 1.605442] ehci_hcd 0000:00:02.1: debug port 1 [ 1.605450] ehci_hcd 0000:00:02.1: cache line size of 64 is not supported [ 1.605469] ehci_hcd 0000:00:02.1: irq 22, io mem 0xf0789000 [ 1.616027] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00 [ 1.616051] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.616055] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.616058] usb usb1: Product: EHCI Host Controller [ 1.616060] usb usb1: Manufacturer: Linux 2.6.32-3-686 ehci_hcd [ 1.616063] usb usb1: SerialNumber: 0000:00:02.1 [ 1.616154] usb usb1: configuration #1 chosen from 1 choice [ 1.616188] hub 1-0:1.0: USB hub found [ 1.616197] hub 1-0:1.0: 6 ports detected [ 1.616266] amd74xx 0000:00:06.0: UDMA133 controller [ 1.616272] amd74xx 0000:00:06.0: IDE controller (0x10de:0x0560 rev 0xa1) [ 1.616289] amd74xx 0000:00:06.0: IDE port disabled [ 1.616298] amd74xx 0000:00:06.0: BIOS didn't set cable bits correctly. Enabling workaround. [ 1.616302] amd74xx 0000:00:06.0: not 100% native mode: will probe irqs later [ 1.616308] ide0: BM-DMA at 0x30c0-0x30c7 [ 1.616314] Probing IDE interface ide0... [ 1.736096] firewire_core: created device fw0: GUID 0040ca0143001714, S400 [ 1.928029] usb 1-2: new high speed USB device using ehci_hcd and address 2 [ 2.075627] usb 1-2: New USB device found, idVendor=0bda, idProduct=0158 [ 2.075631] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 2.075634] usb 1-2: Product: USB2.0-CRW [ 2.075636] usb 1-2: Manufacturer: Generic [ 2.075638] usb 1-2: SerialNumber: 20060413092100000 [ 2.075713] usb 1-2: configuration #1 chosen from 1 choice [ 2.352123] hda: MATSHITAUJ-850D, ATAPI CD/DVD-ROM drive [ 2.688054] hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4 [ 2.688329] hda: UDMA/33 mode selected [ 2.688726] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14 [ 2.690857] ahci 0000:00:09.0: version 3.0 [ 2.691136] ACPI: PCI Interrupt Link [LSI0] enabled at IRQ 21 [ 2.691148] ahci 0000:00:09.0: PCI INT A -> Link[LSI0] -> GSI 21 (level, low) -> IRQ 21 [ 2.691193] ahci 0000:00:09.0: irq 27 for MSI/MSI-X [ 2.691199] ahci 0000:00:09.0: controller can do NCQ, turning on CAP_NCQ [ 2.691258] ahci 0000:00:09.0: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0xf impl IDE mode [ 2.691263] ahci 0000:00:09.0: flags: 64bit ncq sntf led clo pmp pio slum part [ 2.691267] ahci 0000:00:09.0: setting latency timer to 64 [ 2.692554] scsi0 : ahci [ 2.692660] scsi1 : ahci [ 2.692720] scsi2 : ahci [ 2.692786] scsi3 : ahci [ 2.692905] ata1: SATA max UDMA/133 abar m8192@0xf0784000 port 0xf0784100 irq 27 [ 2.692910] ata2: SATA max UDMA/133 abar m8192@0xf0784000 port 0xf0784180 irq 27 [ 2.692913] ata3: SATA max UDMA/133 abar m8192@0xf0784000 port 0xf0784200 irq 27 [ 2.692917] ata4: SATA max UDMA/133 abar m8192@0xf0784000 port 0xf0784280 irq 27 [ 2.693244] ACPI: PCI Interrupt Link [Z006] enabled at IRQ 20 [ 2.693256] ehci_hcd 0000:00:04.1: PCI INT B -> Link[Z006] -> GSI 20 (level, low) -> IRQ 20 [ 2.693277] ehci_hcd 0000:00:04.1: setting latency timer to 64 [ 2.693281] ehci_hcd 0000:00:04.1: EHCI Host Controller [ 2.693296] ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 2 [ 2.693321] ehci_hcd 0000:00:04.1: debug port 1 [ 2.693329] ehci_hcd 0000:00:04.1: cache line size of 64 is not supported [ 2.693349] ehci_hcd 0000:00:04.1: irq 20, io mem 0xf0789400 [ 2.704026] ehci_hcd 0000:00:04.1: USB 2.0 started, EHCI 1.00 [ 2.704049] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.704052] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.704055] usb usb2: Product: EHCI Host Controller [ 2.704058] usb usb2: Manufacturer: Linux 2.6.32-3-686 ehci_hcd [ 2.704061] usb usb2: SerialNumber: 0000:00:04.1 [ 2.704156] usb usb2: configuration #1 chosen from 1 choice [ 2.704192] hub 2-0:1.0: USB hub found [ 2.704201] hub 2-0:1.0: 6 ports detected [ 2.738665] Initializing USB Mass Storage driver... [ 2.738827] scsi4 : SCSI emulation for USB Mass Storage devices [ 2.738922] usb-storage: device found at 2 [ 2.738925] usb-storage: waiting for device to settle before scanning [ 2.738936] usbcore: registered new interface driver usb-storage [ 2.738940] USB Mass Storage support registered. [ 2.788773] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.789087] ACPI: PCI Interrupt Link [LUS0] enabled at IRQ 19 [ 2.789100] ohci_hcd 0000:00:02.0: PCI INT A -> Link[LUS0] -> GSI 19 (level, low) -> IRQ 19 [ 2.789120] ohci_hcd 0000:00:02.0: setting latency timer to 64 [ 2.789124] ohci_hcd 0000:00:02.0: OHCI Host Controller [ 2.789139] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 3 [ 2.789169] ohci_hcd 0000:00:02.0: irq 19, io mem 0xf0786000 [ 2.846033] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.846037] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.846040] usb usb3: Product: OHCI Host Controller [ 2.846043] usb usb3: Manufacturer: Linux 2.6.32-3-686 ohci_hcd [ 2.846046] usb usb3: SerialNumber: 0000:00:02.0 [ 2.846139] usb usb3: configuration #1 chosen from 1 choice [ 2.846172] hub 3-0:1.0: USB hub found [ 2.846182] hub 3-0:1.0: 6 ports detected [ 2.846497] ACPI: PCI Interrupt Link [Z005] enabled at IRQ 18 [ 2.846507] ohci_hcd 0000:00:04.0: PCI INT A -> Link[Z005] -> GSI 18 (level, low) -> IRQ 18 [ 2.846523] ohci_hcd 0000:00:04.0: setting latency timer to 64 [ 2.846527] ohci_hcd 0000:00:04.0: OHCI Host Controller [ 2.846537] ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 4 [ 2.846562] ohci_hcd 0000:00:04.0: irq 18, io mem 0xf0787000 [ 2.902026] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.902030] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.902033] usb usb4: Product: OHCI Host Controller [ 2.902035] usb usb4: Manufacturer: Linux 2.6.32-3-686 ohci_hcd [ 2.902038] usb usb4: SerialNumber: 0000:00:04.0 [ 2.902109] usb usb4: configuration #1 chosen from 1 choice [ 2.902138] hub 4-0:1.0: USB hub found [ 2.902147] hub 4-0:1.0: 6 ports detected [ 3.012035] ata3: SATA link down (SStatus 0 SControl 300) [ 3.012060] ata4: SATA link down (SStatus 0 SControl 300) [ 3.016028] usb 2-1: new high speed USB device using ehci_hcd and address 2 [ 3.156011] usb 2-1: New USB device found, idVendor=0bda, idProduct=8189 [ 3.156015] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 3.156018] usb 2-1: Product: RTL8187B_WLAN_Adapter [ 3.156020] usb 2-1: Manufacturer: Manufacturer_Realtek [ 3.156023] usb 2-1: SerialNumber: 00e04c000001 [ 3.156089] usb 2-1: configuration #1 chosen from 1 choice [ 3.176032] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 3.176048] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 3.176821] ata2.00: ATA-7: ST9160821AS, 3.ALC, max UDMA/133 [ 3.176825] ata2.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 31/32) [ 3.177028] ata1.00: ATA-7: ST9160821AS, 3.ALC, max UDMA/133 [ 3.177031] ata1.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 31/32) [ 3.178859] ata2.00: configured for UDMA/133 [ 3.179082] ata1.00: configured for UDMA/133 [ 3.179181] scsi 0:0:0:0: Direct-Access ATA ST9160821AS 3.AL PQ: 0 ANSI: 5 [ 3.179380] scsi 1:0:0:0: Direct-Access ATA ST9160821AS 3.AL PQ: 0 ANSI: 5 [ 3.191434] ide-cd driver 5.00 [ 3.192730] ide-cd: hda: ATAPI 24X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache [ 3.192738] Uniform CD-ROM driver Revision: 3.20 [ 3.196845] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB) [ 3.196888] sd 0:0:0:0: [sda] Write Protect is off [ 3.196892] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 3.196920] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 3.197112] sda: [ 3.197307] sd 1:0:0:0: [sdb] 312581808 512-byte logical blocks: (160 GB/149 GiB) [ 3.197352] sd 1:0:0:0: [sdb] Write Protect is off [ 3.197355] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00 [ 3.197378] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 3.197510] sdb: sda1 sda2 [ 3.262743] sd 0:0:0:0: [sda] Attached SCSI disk [ 3.268030] usb 2-2: new high speed USB device using ehci_hcd and address 3 [ 3.350047] sdb1 sdb2 sdb3 < sdb5 > [ 3.380308] sd 1:0:0:0: [sdb] Attached SCSI disk [ 3.502511] usb 2-2: New USB device found, idVendor=5986, idProduct=0130 [ 3.502516] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.502519] usb 2-2: Product: USB2.0 Camera [ 3.502522] usb 2-2: Manufacturer: Bison Corp. [ 3.502624] usb 2-2: configuration #1 chosen from 1 choice [ 3.612039] usb 2-3: new high speed USB device using ehci_hcd and address 4 [ 3.748759] usb 2-3: New USB device found, idVendor=040d, idProduct=6204 [ 3.748764] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 3.748768] usb 2-3: Product: USB 2.0 IDE Bridge [ 3.748770] usb 2-3: Manufacturer: VIA Technologies Inc. [ 3.748773] usb 2-3: SerialNumber: 000000000001 [ 3.748877] usb 2-3: configuration #1 chosen from 1 choice [ 3.750092] scsi5 : SCSI emulation for USB Mass Storage devices [ 3.750217] usb-storage: device found at 4 [ 3.750220] usb-storage: waiting for device to settle before scanning [ 3.795252] PM: Starting manual resume from disk [ 3.795257] PM: Resume from partition 8:21 [ 3.795259] PM: Checking hibernation image. [ 3.795512] PM: Error -22 checking image file [ 3.795515] PM: Resume from disk failed. [ 3.839405] kjournald starting. Commit interval 5 seconds [ 3.839415] EXT3-fs: mounted filesystem with ordered data mode. [ 4.112030] usb 4-4: new low speed USB device using ohci_hcd and address 2 [ 4.324056] usb 4-4: New USB device found, idVendor=046d, idProduct=c016 [ 4.324060] usb 4-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.324064] usb 4-4: Product: Optical USB Mouse [ 4.324067] usb 4-4: Manufacturer: Logitech [ 4.324162] usb 4-4: configuration #1 chosen from 1 choice [ 5.499317] udev: starting version 151 [ 6.256168] input: PC Speaker as /devices/platform/pcspkr/input/input6 [ 6.261496] ACPI: processor limited to max C-state 1 [ 6.261543] processor LNXCPU:00: registered as cooling_device1 [ 6.261585] processor LNXCPU:01: registered as cooling_device2 [ 6.262932] ACPI: AC Adapter [ACAD] (on-line) [ 6.265078] k8temp 0000:00:18.3: Temperature readouts might be wrong - check erratum #141 [ 6.298197] ACPI: Battery Slot [BAT0] (battery present) [ 6.410124] i2c i2c-0: nForce2 SMBus adapter at 0x3040 [ 6.410146] i2c i2c-1: nForce2 SMBus adapter at 0x3000 [ 6.496931] Linux agpgart interface v0.103 [ 6.957863] Synaptics Touchpad, model: 1, fw: 6.3, id: 0x81a0b2, caps: 0xa04713/0x200000 [ 6.993920] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input7 [ 7.699281] nvidia: module license 'NVIDIA' taints kernel. [ 7.699286] Disabling lock debugging due to kernel taint [ 8.578688] usb-storage: device scan complete [ 8.594333] scsi 4:0:0:0: Direct-Access Generic- Multi-Card 1.00 PQ: 0 ANSI: 0 CCS [ 8.692120] Linux video capture interface: v2.00 [ 8.828506] usb-storage: device scan complete [ 8.828588] usbcore: registered new interface driver hiddev [ 8.829264] ACPI: PCI Interrupt Link [LK2E] enabled at IRQ 17 [ 8.829277] nvidia 0000:02:00.0: PCI INT A -> Link[LK2E] -> GSI 17 (level, low) -> IRQ 17 [ 8.829287] nvidia 0000:02:00.0: setting latency timer to 64 [ 8.829292] vgaarb: device changed decodes: PCI:0000:02:00.0,olddecodes=io+mem,decodes=none:owns=io+mem [ 8.829568] NVRM: loading NVIDIA UNIX x86 Kernel Module 195.36.15 Thu Mar 11 21:41:46 PST 2010 [ 8.829711] scsi 5:0:0:0: Direct-Access TOSHIBA MK8025GAS KA02 PQ: 0 ANSI: 2 [ 8.832622] sd 4:0:0:0: [sdc] Attached SCSI removable disk [ 8.833390] sd 5:0:0:0: [sdd] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB) [ 8.833758] sd 5:0:0:0: [sdd] Write Protect is off [ 8.833762] sd 5:0:0:0: [sdd] Mode Sense: 00 00 00 00 [ 8.833765] sd 5:0:0:0: [sdd] Assuming drive cache: write through [ 8.834389] input: Logitech Optical USB Mouse as /devices/pci0000:00/0000:00:04.0/usb4/4-4/4-4:1.0/input/input8 [ 8.834496] generic-usb 0003:046D:C016.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:04.0-4/input0 [ 8.834525] usbcore: registered new interface driver usbhid [ 8.834529] usbhid: v2.6:USB HID core driver [ 8.835431] sd 5:0:0:0: [sdd] Assuming drive cache: write through [ 8.835511] sdd: sdd1 < sdd5 > [ 8.915756] sd 5:0:0:0: [sdd] Assuming drive cache: write through [ 8.915838] sd 5:0:0:0: [sdd] Attached SCSI disk [ 8.985993] cfg80211: Using static regulatory domain info [ 8.985996] cfg80211: Regulatory domain: US [ 8.985999] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 8.986003] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm) [ 8.986006] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) [ 8.986010] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) [ 8.986013] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) [ 8.986016] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) [ 8.986019] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm) [ 8.986382] cfg80211: Calling CRDA for country: US [ 9.051143] uvcvideo: Found UVC 1.00 device USB2.0 Camera (5986:0130) [ 9.053643] input: USB2.0 Camera as /devices/pci0000:00/0000:00:04.1/usb2/2-2/2-2:1.0/input/input9 [ 9.053701] usbcore: registered new interface driver uvcvideo [ 9.053705] USB Video Class driver (v0.1.0) [ 9.508897] phy0: Selected rate control algorithm 'minstrel' [ 9.509669] phy0: hwaddr 00:15:af:4b:37:c5, RTL8187BvE V0 + rtl8225z2, rfkill mask 2 [ 9.531141] rtl8187: Customer ID is 0x00 [ 9.531172] Registered led device: rtl8187-phy0::tx [ 9.531190] Registered led device: rtl8187-phy0::rx [ 9.532020] rtl8187: wireless switch is on [ 9.532055] usbcore: registered new interface driver rtl8187 [ 10.100346] Adding 315384k swap on /dev/sdb5. Priority:-1 extents:1 across:315384k [ 10.273545] EXT3 FS on sda2, internal journal [ 10.450989] loop: module loaded [ 12.147259] fuse init (API version 7.13) [ 12.821434] powernow-k8: Found 1 AMD Turion(tm) 64 X2 Mobile Technology TL-58 processors (2 cpu cores) (version 2.20.00) [ 12.821485] powernow-k8: 0 : fid 0xb (1900 MHz), vid 0x11 [ 12.821488] powernow-k8: 1 : fid 0xa (1800 MHz), vid 0x12 [ 12.821491] powernow-k8: 2 : fid 0x8 (1600 MHz), vid 0x13 [ 12.821494] powernow-k8: 3 : fid 0x0 (800 MHz), vid 0x1e [ 13.004038] Clocksource tsc unstable (delta = -89506338 ns) [ 13.433269] vboxdrv: Trying to deactivate the NMI watchdog permanently... [ 13.433280] vboxdrv: Warning: 2.6.31+ kernel detected. Most likely the hardware performance [ 13.433284] vboxdrv: counter framework which can generate NMIs is active. You have to prevent [ 13.433289] vboxdrv: the usage of hardware performance counters by [ 13.433292] vboxdrv: echo 2 > /proc/sys/kernel/perf_counter_paranoid [ 13.433684] vboxdrv: Found 2 processor cores. [ 13.433855] vboxdrv: fAsync=1 offMin=0x150ed6 offMax=0x150ed6 [ 13.434805] vboxdrv: TSC mode is 'asynchronous', kernel timer mode is 'normal'. [ 13.434813] vboxdrv: Successfully loaded version 3.1.6_OSE (interface 0x00100001). [ 18.634514] Bluetooth: Core ver 2.15 [ 18.635970] NET: Registered protocol family 31 [ 18.635977] Bluetooth: HCI device and connection manager initialized [ 18.635986] Bluetooth: HCI socket layer initialized [ 18.669836] Bluetooth: L2CAP ver 2.14 [ 18.669844] Bluetooth: L2CAP socket layer initialized [ 18.694888] Bluetooth: RFCOMM TTY layer initialized [ 18.694899] Bluetooth: RFCOMM socket layer initialized [ 18.694905] Bluetooth: RFCOMM ver 1.11 [ 18.805734] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 18.805742] Bluetooth: BNEP filters: protocol multicast [ 19.093126] Bridge firewalling registered [ 19.214729] Bluetooth: SCO (Voice Link) ver 0.6 [ 19.214737] Bluetooth: SCO socket layer initialized [ 20.930539] lp: driver loaded but no devices found [ 21.114995] ppdev: user-space parallel port driver [ 25.023253] ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 25.037004] forcedeth 0000:00:0a.0: irq 28 for MSI/MSI-X [ 25.037237] eth0: no link during initialization. [ 25.038060] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 832.426645] wlan0: direct probe to AP fa:e5:e2:24:ec:7e (try 1) [ 832.430553] wlan0: direct probe responded [ 832.430562] wlan0: authenticate with AP fa:e5:e2:24:ec:7e (try 1) [ 832.432769] wlan0: authenticated [ 832.432810] wlan0: associate with AP fa:e5:e2:24:ec:7e (try 1) [ 832.435041] wlan0: RX AssocResp from fa:e5:e2:24:ec:7e (capab=0x401 status=0 aid=1) [ 832.435051] wlan0: associated [ 832.440390] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 842.720052] wlan0: no IPv6 routers present [ 886.017025] CE: hpet increasing min_delta_ns to 15000 nsec
Voilà tout.
Encore une fois merci pour vos réponses.
Il est beaucoup plus simple pour un débutant d’utiliser une sid que squeeze, et c’est encore plus vrai en ce moment.
Ta carte son est identifiée en tout début de boot via le BIOs, et ensuite, plus rien.
As tu vérifié qu’elle a bien un driver linux ?
Il faut peut être le charger en tant que module.
Un début de réponse ici: http://www.linuxquestions.org/questions/linux-hardware-18/no-sound-with-nvidia-mcp67-hda-629627/
Merci beaucoup pour le lien vu que la config a l’air d’être exactement la même :slightly_smiling:
Par contre, petit souci du à ma méconnaissance de linux:
(pour info, je n’ai pas de /dev/sdp ni de fichier /var/lib/alsa/asound.state)
j’ai installé
i alsa-oss - ALSA wrapper for OSS applications
i liboss-salsa2
Je ne comprends pas comment lancer le service (avec modprobe, le fichier /etc/modprobe.d/sound n’existant pas, et pour tester un :
modprobe “nomduservice” je ne connais pas le nom du service.
J’ai rajouté un:
options snd-hda-intel model=auto
A la fin de /etc/modprobe.d/alsa-base.conf
mais ça n’a rien changé (après reboot, alsa reload ou alsactl init)
J’ai bien trouvé cette page:
tldp.org/HOWTO/Alsa-sound-5.html
Mais tous les modprobe snd-hda-intel
me donne:
FATAL: Module snd_hda_intel not found.
Ici, on m’indique que je ne devrai pas avoir de problème (oui, c’est ubuntu, mais bon…)
doc.ubuntu-fr.org/liste_portables_packard_bell
Si tu as des conseils/pistes à me donner, je suis preneur :confused:
Merci d’avance.
brakbabord.fr/index.php?post/200 … s-machines
Ici, on me dit que je devrai avoir des problèmes de son (sj81 :/)
ls /lib/modules/
find / -name snd-*
find / -name *.ko
uname -a
lsmod
vérifie si le module n’est pas blacklisté dans /etc/modprobe.d/blacklist (ce qui m’étonnerai vu qu’il refuse de se charger)
[quote=“dchost99”]ls /lib/modules/
find / -name snd-*
find / -name *.ko
uname -a
lsmod
vérifie si le module n’est pas blacklisté dans /etc/modprobe.d/blacklist (ce qui m’étonnerai vu qu’il refuse de se charger)[/quote]
find / -name snd-*
/usr/src/linux-source-2.6.32/sound/soc/atmel/snd-soc-afeb9260.c
/usr/src/linux-source-2.6.32/drivers/staging/go7007/snd-go7007.c
/usr/src/modules/alsa-driver/alsa-kernel/soc/atmel/snd-soc-afeb9260.c
/usr/src/modules/alsa-driver/soc/atmel/snd-soc-afeb9260.c
find / -name *.ko
=> bcp bcp bcp de résultat (2500 lignes, je les ai mise dans un fichier si tu veux les voir :slight_smile: )
uname -a
Linux aba 2.6.32-3-686 #1 SMP Thu Feb 25 06:14:20 UTC 2010 i686 GNU/Linux
Et le module n’est pas blacklisté
Voilà :slight_smile:
bonjour mon pcfixe a la même carte audio que toi.
Je t’assure que le module est bien présent depuis le kernel 2.6.22 (ou 24 je ne sais plus)
Eventuellement recompiler alsa avec le bon module mais tu dois avoir un autre pbm car ce module est présent.
As tu compilé ton noyau toi même?
As tu essayé de compiler alsa ?
désinstalle alsa-driver-linuxant_1.0.20.3_all.deb et autre pulseaudio si tu l’as installé.
réinstalle alsa, ton kernel, headers
reboote et en console alsamixer
Je regarde ce soir ou doit se trouve le module
alsa-project.org/main/index. … dor-Nvidia
De retour à la maison
Voila ce j’ai
$ lspci | grep Audio
00:10.1 Audio device: nVidia Corporation MCP51 High Definition Audio (rev a2)
Mince ce n’est pas exactement la même carte audio.
est tu certain que ta carte audio ne soit pas géré par alsa?
Je pense que oui alsa-project.org/main/index. … -hda-intel
ls /lib/modules/
c’est peut-être juste le chemin des modules qui est faux …
lsmod
voila ce que j’ai, il peut voir la différence.
find / -name snd* | grep hda /lib/modules/2.6.26-1-amd64/kernel/sound/pci/hda/snd-hda-intel.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-codec-nvhdmi.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-codec-intelhdmi.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-codec-via.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-codec-analog.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-codec-si3054.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-codec-cmedia.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-codec-ca0110.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-codec-conexant.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-codec-idt.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-codec-cirrus.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-codec-atihdmi.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-intel.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-codec-realtek.ko /lib/modules/2.6.32-3-amd64/kernel/sound/pci/hda/snd-hda-codec.ko /lib/modules/2.6.26-2-amd64/kernel/sound/pci/hda/snd-hda-intel.ko
voila la raison
ton kernel c’est un 686
2.6.32-3-686
alors que les modules ce trouve dans
tu dois avoir plusieurs kernel et les chemin des modules ne correspondent pas
reinstall un kernel debian qui va te générer un lib/modules et un initrd
si non démarre le kernel amd64 pour tester
moi je n’ai pas de problème de son :018 c’est aba qui en a
Il doit avoir normalement un résulat avec:
C’est pourquoi je lui suggère de virer son paquet alsa-driver-linuxant et réinstaller alsa, le kernel.
edit: Pour info le fichier snd-hda-intel.ko se trouve dans le paquet linux-image packages.debian.org/search?searc … &arch=i386
:119
bon j’vais prendre un café …ça va me réveiller :mrgreen:
CA MARCHE !!!
Merci beaucoup, une simple réinstallation du linux-image a suffit à tout faire fonctionner :slight_smile:
En espérant que ça aide d’autres personnes aussi. Merci encore !
Windows, c’est fini, et dire que c’était l’os de mon premier amour (oui bon, le seul on va dire :/)
