[résolu]Probleme Sound Blaster (et carte son en général)
J’ai réinstallé ma debian après avoir trop joué avec les dépots Sid question de repartir avec de saines bases.
Le problème c’est que mes cartes son qui sont reconnues nativement n’apparaissent plus.
En effet le control de volume me signal gentiment :
De plus lspci | grep Audio n’affiche que :
Mais un lscpi :
00:00.0 RAM memory: nVidia Corporation MCP55 Memory Controller (rev a1) 00:01.0 ISA bridge: nVidia Corporation MCP55 LPC Bridge (rev a2) 00:01.1 SMBus: nVidia Corporation MCP55 SMBus (rev a2) 00:02.0 USB Controller: nVidia Corporation MCP55 USB Controller (rev a1) 00:02.1 USB Controller: nVidia Corporation MCP55 USB Controller (rev a2) 00:04.0 IDE interface: nVidia Corporation MCP55 IDE (rev a1) 00:05.0 IDE interface: nVidia Corporation MCP55 SATA Controller (rev a2) 00:05.1 IDE interface: nVidia Corporation MCP55 SATA Controller (rev a2) 00:05.2 IDE interface: nVidia Corporation MCP55 SATA Controller (rev a2) 00:06.0 PCI bridge: nVidia Corporation MCP55 PCI bridge (rev a2) 00:06.1 Audio device: nVidia Corporation MCP55 High Definition Audio (rev a2) 00:08.0 Bridge: nVidia Corporation MCP55 Ethernet (rev a2) 00:09.0 Bridge: nVidia Corporation MCP55 Ethernet (rev a2) 00:0a.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2) 00:0b.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2) 00:0c.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2) 00:0d.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2) 00:0e.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2) 00:0f.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2) 00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration 00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map 00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller 00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control 01:00.0 Network controller: RaLink RT2561/RT61 rev B 802.11g 01:01.0 Multimedia audio controller: Creative Labs SB Live! EMU10k1 (rev 0a) 01:01.1 Input device controller: Creative Labs SB Live! Game Port (rev 0a) 07:00.0 VGA compatible controller: nVidia Corporation Unknown device 0295 (rev a1) debian
J’avoue ne pas saisir d’ou vien le problème… Comment récuperer le son?
Merci d’avance,
Stun
Regardes un peu ma réponse à ce post:
forum.debian-fr.org/viewtopic.php?t=9779
Il me semble que tu es sur la carte-son de la carte-mère[nVidia … (rev a2)]
édit quoique! :smt017 ça doit être autre chose!
forum.debian-fr.org/viewtopic.php?t=9963
Non malheureusement, j’ai testé avec le chipset integré activé et désactivé.
Je vai sessayer des alsaconf de ce pas.
Merci pour ta réponse.
Edit :
Le adduser.conf était mal configuré…
Un petit adduser audio à résolu le problème merci a vous.
