je tente de compiler un nouveau noyau (2.6.18) sur ma debian mais j’ai le probleme suivant lors du demarrage
pourtant j’ai activé tous les modules concernant le PCMCIA dans le .config
Et donc suite a cela, le lecteur CD pcmcia ne fonctionne pas.
D’ou vient le probleme?
Quelques infos sur la config:
16:27 root@em /# uname -r
2.6.18-em
16:28 root@em /# lspci
0000:00:00.0 Host bridge: Intel Corp. 440BX/ZX/DX - 82443BX/ZX/DX Host bridge (rev 03)
0000:00:01.0 PCI bridge: Intel Corp. 440BX/ZX/DX - 82443BX/ZX/DX AGP bridge (rev 03)
0000:00:07.0 ISA bridge: Intel Corp. 82371AB/EB/MB PIIX4 ISA (rev 02)
0000:00:07.1 IDE interface: Intel Corp. 82371AB/EB/MB PIIX4 IDE (rev 01)
0000:00:07.2 USB Controller: Intel Corp. 82371AB/EB/MB PIIX4 USB (rev 01)
0000:00:07.3 Bridge: Intel Corp. 82371AB/EB/MB PIIX4 ACPI (rev 03)
0000:00:08.0 FireWire (IEEE 1394): Sony Corporation CXD3222 i.LINK Controller (rev 02)
0000:00:09.0 Multimedia audio controller: Yamaha Corporation YMF-744B [DS-1S Audio Controller] (rev 02)
0000:00:0a.0 Communication controller: Conexant HSF 56k Data/Fax Modem (Mob WorldW SmartDAA) (rev 01)
0000:00:0b.0 Ethernet controller: Intel Corp. 82557/8/9 [Ethernet Pro 100] (rev 08)
0000:00:0c.0 CardBus bridge: Ricoh Co Ltd RL5c475 (rev 80)
0000:00:0d.0 FLASH memory: Sony Corporation Memory Stick Controller (rev 01)
0000:01:00.0 VGA compatible controller: Neomagic Corporation NM2380 [MagicMedia 256XL+] (rev 10)
16:28 root@em /# lsmod
Module Size Used by
pcmcia 37308 0
firmware_class 10496 1 pcmcia
pcmcia_core 40848 1 pcmcia
ipv6 237792 14
thermal 14600 0
fan 5252 0
button 7056 0
processor 27692 1 thermal
ac 5508 0
battery 10884 0
af_packet 21256 2
parport_pc 33860 0
parport 35144 1 parport_pc
pcspkr 3328 0
snd_ymfpci 59584 0
gameport 15880 1 snd_ymfpci
snd_ac97_codec 85024 1 snd_ymfpci
snd_ac97_bus 2560 1 snd_ac97_codec
snd_pcm_oss 42528 0
snd_mixer_oss 16896 1 snd_pcm_oss
snd_pcm 74888 3 snd_ymfpci,snd_ac97_codec,snd_pcm_oss
eth1394 19204 0
snd_opl3_lib 10752 1 snd_ymfpci
snd_timer 23684 3 snd_ymfpci,snd_pcm,snd_opl3_lib
snd_hwdep 9988 1 snd_opl3_lib
snd_page_alloc 10248 2 snd_ymfpci,snd_pcm
snd_mpu401_uart 8576 1 snd_ymfpci
snd_rawmidi 24352 1 snd_mpu401_uart
snd_seq_device 8332 2 snd_opl3_lib,snd_rawmidi
snd 50660 11 snd_ymfpci,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_opl3_lib,snd_timer,snd_hwdep,snd_mpu401_uart,snd_rawmidi,snd_seq_device
soundcore 10464 1 snd
ohci1394 33712 0
ieee1394 95288 2 eth1394,ohci1394
i2c_piix4 8844 0
i2c_core 21648 1 i2c_piix4
shpchp 36508 0
pci_hotplug 32824 1 shpchp
intel_agp 21660 1
uhci_hcd 22924 0
usbcore 121732 2 uhci_hcd
e100 34184 0
mii 5632 1 e100
agpgart 33840 1 intel_agp
tsdev 7872 0
joydev 9792 0
mousedev 12064 0
psmouse 37000 0
ide_cd 40196 0
cdrom 38560 1 ide_cd
genrtc 9984 0
ext3 129672 1
jbd 56616 1 ext3
ide_disk 15744 3
ide_generic 1664 0 [permanent]
via82cxxx 9220 0 [permanent]
trm290 4484 0 [permanent]
triflex 4096 0 [permanent]
slc90e66 6144 0 [permanent]
sis5513 15240 0 [permanent]
siimage 11648 0 [permanent]
serverworks 8968 0 [permanent]
sc1200 7296 0 [permanent]
rz1000 3072 0 [permanent]
piix 10628 0 [permanent]
pdc202xx_old 10496 0 [permanent]
opti621 4996 0 [permanent]
ns87415 4552 0 [permanent]
hpt366 18048 0 [permanent]
hpt34x 5376 0 [permanent]
generic 5380 0 [permanent]
cy82c693 4868 0 [permanent]
cs5530 5760 0 [permanent]
cs5520 4992 0 [permanent]
cmd64x 11036 0 [permanent]
atiixp 6544 0 [permanent]
amd74xx 14108 0 [permanent]
alim15x3 11532 0 [permanent]
aec62xx 7808 0 [permanent]
pdc202xx_new 8448 0 [permanent]
ide_core 117876 28 ide_cd,ide_disk,ide_generic,via82cxxx,trm290,triflex,slc90e66,sis5513,siimage,serverworks,sc1200,rz1000,piix,pdc202xx_old,opti621,ns87415,hpt366,hpt34x,generic,cy82c693,cs5530,cs5520,cmd64x,atiixp,amd74xx,alim15x3,aec62xx,pdc202xx_new
unix 27056 18
16:30 root@em /# cat /etc/default/pcmcia
# Defaults for pcmcia (sourced by /etc/init.d/pcmcia)
PCMCIA=yes
PCIC=yenta_socket
PCIC_OPTS=
CORE_OPTS=
CARDMGR_OPTS=
Merci d’avance pour l’aide
