dans le dossier /etc/pure-ftpd/conf j’ai ca :
- Altlog
- ChrootEveryone
- MinUID
- MySQLConfigFile
- NoAnonymous
- PAMAuthenthication
- PureDB
et mysql.conf :
# Sample Pure-FTPd Mysql configuration file. #
# See README.MySQL for explanations. #
# Optional : MySQL server name or IP. Don't define this for unix sockets.
# MYSQLServer 127.0.0.1
# Optional : MySQL port. Don't define this if a local unix socket is used.
# MYSQLPort 3306
# Optional : define the location of mysql.sock if the server runs on this host.
MYSQLSocket /var/run/mysqld/mysqld.sock
# Mandatory : user to bind the server as.
MYSQLUser pureftpd
# Mandatory : user password. You must have a password.
MYSQLPassword ********
# Mandatory : database to open.
MYSQLDatabase pureftpd
# Mandatory : how passwords are stored
# Valid values are : "cleartext", "crypt", "md5" and "password"
# ("password" = MySQL password() function)
# You can also use "any" to try "crypt", "md5" *and* "password"
MYSQLCrypt md5
# In the following directives, parts of the strings are replaced at
# run-time before performing queries :
# \L is replaced by the login of the user trying to authenticate.
# \I is replaced by the IP address the user connected to.
# \P is replaced by the port number the user connected to.
# \R is replaced by the IP address the user connected from.
# \D is replaced by the remote IP address, as a long decimal number.
# Very complex queries can be performed using these substitution strings,
# especially for virtual hosting.
# Query to execute in order to fetch the password
MYSQLGetPW SELECT Password FROM ftpd WHERE User="\L" AND status="1"
# Query to execute in order to fetch the system user name or uid
MYSQLGetUID SELECT Uid FROM ftpd WHERE User="\L" AND status="1"
# Optional : default UID - if set this overrides MYSQLGetUID
#MYSQLDefaultUID 1000
# Query to execute in order to fetch the system user group or gid
MYSQLGetGID SELECT Gid FROM ftpd WHERE User="\L" AND status="1"
# Optional : default GID - if set this overrides MYSQLGetGID
#MYSQLDefaultGID 1000
# Query to execute in order to fetch the home directory
MYSQLGetDir SELECT Dir FROM ftpd WHERE User="\L" AND status="1"
# Optional : query to get the maximal number of files
# Pure-FTPd must have been compiled with virtual quotas support.
MySQLGetQTAFS SELECT QuotaFiles FROM ftpd WHERE User="\L" AND status="1"
# Optional : query to get the maximal disk usage (virtual quotas)
# The number should be in Megabytes.
MySQLGetQTASZ SELECT QuotaSize FROM ftpd WHERE User="\L" AND status="1"
# Optional : ratios. The server has to be compiled with ratio support.
# MySQLGetRatioUL SELECT ULRatio FROM users WHERE User="\L"
# MySQLGetRatioDL SELECT DLRatio FROM users WHERE User="\L"
# Optional : bandwidth throttling.
# The server has to be compiled with throttling support.
# Values are in KB/s .
MySQLGetBandwidthUL SELECT ULBandwidth FROM ftpd WHERE User="\L" AND status="1"
MySQLGetBandwidthDL SELECT DLBandwidth FROM ftpd WHERE User="\L" AND status="1"
# Enable ~ expansion. NEVER ENABLE THIS BLINDLY UNLESS :
# 1) You know what you are doing.
# 2) Real and virtual users match.
# MySQLForceTildeExpansion 1
# If you upgraded your tables to transactionnal tables (Gemini,
# BerkeleyDB, Innobase...), you can enable SQL transactions to
# avoid races. Leave this commented if you are using the
# traditionnal MyIsam databases or old (< 3.23.x) MySQL versions.
# MySQLTransactions On
