Je n’arrive pas à configurer le wifi sur mon portable vaio tz avec ma debian alors que ubuntu le faisait fonctionner sans rien configurer.
La commande dmesg me renvoie dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.26-1-686 (Debian 2.6.26-5) (waldi@debian.org) (gcc version 4.1.3 20080623 (prerelease) (Debian 4.1.2-23)) #1 SMP Wed Sep 10 16:46:13 UTC 2008
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000dc000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003f680000 (usable)
[ 0.000000] BIOS-e820: 000000003f680000 - 000000003f700000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003f700000 - 0000000040000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed00400 (reserved)
[ 0.000000] BIOS-e820: 00000000fed14000 - 00000000fed1a000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed90000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] 118MB HIGHMEM available.
[ 0.000000] 896MB LOWMEM available.
[ 0.000000] found SMP MP-table at [c00f6ba0] 000f6ba0
[ 0.000000] Entering add_active_range(0, 0, 259712) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 229376
[ 0.000000] HighMem 229376 -> 259712
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 259712
[ 0.000000] On node 0 totalpages: 259712
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 1760 pages used for memmap
[ 0.000000] Normal zone: 223520 pages, LIFO batch:31
[ 0.000000] HighMem zone: 237 pages used for memmap
[ 0.000000] HighMem zone: 30099 pages, LIFO batch:7
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] DMI present.
[ 0.000000] ACPI: RSDP 000F6AD0, 0024 (r2 PTLTD )
[ 0.000000] ACPI: XSDT 3F688A2E, 007C (r1 Sony VAIO 6040000 PTL 0)
[ 0.000000] ACPI: FACP 3F68FBF8, 00F4 (r3 Sony VAIO 20070424 PTL 1)
[ 0.000000] ACPI: DSDT 3F689A83, 60F1 (r1 Sony VAIO 20070424 PTL 20050624)
[ 0.000000] ACPI: FACS 3F690FC0, 0040
[ 0.000000] ACPI: APIC 3F68FCEC, 0068 (r1 Sony VAIO 20070424 PTL 5A)
[ 0.000000] ACPI: HPET 3F68FD54, 0038 (r1 Sony VAIO 20070424 PTL 5A)
[ 0.000000] ACPI: MCFG 3F68FD8C, 003C (r1 Sony VAIO 20070424 PTL 5A)
[ 0.000000] ACPI: TCPA 3F68FDC8, 0032 (r1 Sony VAIO 20070424 PTL 5A52)
[ 0.000000] ACPI: SLIC 3F68FDFA, 0176 (r1 Sony VAIO 20070424 PTL 1000000)
[ 0.000000] ACPI: APIC 3F68FF70, 0068 (r1 Sony VAIO 20070424 PTL 0)
[ 0.000000] ACPI: BOOT 3F68FFD8, 0028 (r1 Sony VAIO 20070424 PTL 1)
[ 0.000000] ACPI: SSDT 3F689036, 025F (r1 Sony VAIO 20070424 PTL 20050624)
[ 0.000000] ACPI: SSDT 3F688F90, 00A6 (r1 Sony VAIO 20070424 PTL 20050624)
[ 0.000000] ACPI: SSDT 3F688AAA, 04E6 (r1 Sony VAIO 20070424 PTL 20050624)
[ 0.000000] ACPI: BIOS bug: multiple APIC/MADT found, using 0
[ 0.000000] ACPI: If "acpi_apic_instance=2" works better, notify linux-acpi@vger.kernel.org
[ 0.000000] ACPI: DMI detected: Sony
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] Allocating PCI resources starting at 50000000 (gap: 40000000:bec00000)
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000dc000
[ 0.000000] PM: Registered nosave memory: 00000000000dc000 - 0000000000100000
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] PERCPU: Allocating 37960 bytes of per cpu data
[ 0.000000] NR_CPUS: 8, nr_cpu_ids: 2
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 257683
[ 0.000000] Kernel command line: root=UUID=ff364d34-b8f7-482e-9b23-ca56207e0c82 ro
[ 0.000000] mapped APIC to ffffb000 (fee00000)
[ 0.000000] mapped IOAPIC to ffffa000 (fec00000)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Detected 1064.046 MHz processor.
[ 0.004000] Console: colour VGA+ 80x25
[ 0.004000] console [tty0] enabled
[ 0.004000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.004000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.004000] Memory: 1020076k/1038848k available (1768k kernel code, 18036k reserved, 749k data, 244k init, 121344k highmem)
[ 0.004000] virtual kernel memory layout:
[ 0.004000] fixmap : 0xfff4c000 - 0xfffff000 ( 716 kB)
[ 0.004000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.004000] vmalloc : 0xf8800000 - 0xff7fe000 ( 111 MB)
[ 0.004000] lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
[ 0.004000] .init : 0xc037d000 - 0xc03ba000 ( 244 kB)
[ 0.004000] .data : 0xc02ba033 - 0xc0375620 ( 749 kB)
[ 0.004000] .text : 0xc0100000 - 0xc02ba033 (1768 kB)
[ 0.004000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated
[ 0.004000] hpet clockevent registered
[ 0.083956] Calibrating delay using timer specific routine.. 2131.34 BogoMIPS (lpj=4262690)
[ 0.084005] Security Framework initialized
[ 0.084005] SELinux: Disabled at boot.
[ 0.084005] Capability LSM initialized
[ 0.084005] Mount-cache hash table entries: 512
[ 0.084005] Initializing cgroup subsys ns
[ 0.084005] Initializing cgroup subsys cpuacct
[ 0.084005] Initializing cgroup subsys devices
[ 0.084005] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.084005] CPU: L2 cache: 2048K
[ 0.084005] CPU: Physical Processor ID: 0
[ 0.084005] CPU: Processor Core ID: 0
[ 0.084005] Intel machine check architecture supported.
[ 0.084005] Intel machine check reporting enabled on CPU#0.
[ 0.084005] using mwait in idle threads.
[ 0.084005] Checking 'hlt' instruction... OK.
[ 0.100006] ACPI: Core revision 20080321
[ 0.116007] ENABLING IO-APIC IRQs
[ 0.116007] ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.155819] CPU0: Intel(R) Core(TM)2 CPU U7500 @ 1.06GHz stepping 02
[ 0.156009] Booting processor 1/1 ip 6000
[ 0.164010] Initializing CPU#1
[ 0.164010] Calibrating delay using timer specific routine.. 2128.01 BogoMIPS (lpj=4256022)
[ 0.164010] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.164010] CPU: L2 cache: 2048K
[ 0.164010] CPU: Physical Processor ID: 0
[ 0.164010] CPU: Processor Core ID: 1
[ 0.164010] Intel machine check architecture supported.
[ 0.164010] Intel machine check reporting enabled on CPU#1.
[ 0.244015] CPU1: Intel(R) Core(TM)2 CPU U7500 @ 1.06GHz stepping 02
[ 0.244015] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[ 0.248015] Brought up 2 CPUs
[ 0.248015] Total of 2 processors activated (4259.35 BogoMIPS).
[ 0.248015] CPU0 attaching sched-domain:
[ 0.248015] domain 0: span 0-1
[ 0.248015] groups: 0 1
[ 0.248015] CPU1 attaching sched-domain:
[ 0.248015] groups: 1 0
[ 0.248015] net_namespace: 660 bytes
[ 0.248015] Booting paravirtualized kernel on bare hardware
[ 0.248015] NET: Registered protocol family 16
[ 0.248015] ACPI: bus type pci registered
[ 0.248015] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.248015] PCI: Not using MMCONFIG.
[ 0.248685] PCI: PCI BIOS revision 2.10 entry at 0xfddef, last bus=10
[ 0.248771] PCI: Using configuration type 1 for base access
[ 0.248882] Setting up standard PCI resources
[ 0.256016] ACPI: EC: Look up EC in DSDT
[ 0.260016] ACPI: BIOS _OSI(Linux) query ignored via DMI
[ 0.261348] ACPI: Interpreter enabled
[ 0.261428] ACPI: (supports S0 S3 S4 S5)
[ 0.261723] ACPI: Using IOAPIC for interrupt routing
[ 0.261885] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.269344] PCI: MCFG area at e0000000 reserved in ACPI motherboard resources
[ 0.269431] PCI: Using MMCONFIG for extended config space
[ 0.276017] ACPI: EC: non-query interrupt received, switching to interrupt mode
[ 0.288018] ACPI: EC: GPE = 0x17, I/O: command/status = 0x66, data = 0x62
[ 0.288018] ACPI: EC: driver started in interrupt mode
[ 0.288018] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.288018] pci 0000:00:1f.0: quirk: region 1000-107f claimed by ICH6 ACPI/GPIO/TCO
[ 0.288018] pci 0000:00:1f.0: quirk: region 1180-11bf claimed by ICH6 GPIO
[ 0.290180] PCI: Transparent bridge - 0000:00:1e.0
[ 0.290352] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.290862] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.291087] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.291308] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.292015] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT]
[ 0.292273] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIB._PRT]
[ 0.308486] ACPI: PCI Interrupt Link [LNKA] (IRQs *10)
[ 0.308486] ACPI: PCI Interrupt Link [LNKB] (IRQs *10)
[ 0.308486] ACPI: PCI Interrupt Link [LNKC] (IRQs *10)
[ 0.308486] ACPI: PCI Interrupt Link [LNKD] (IRQs *10)
[ 0.308486] ACPI: PCI Interrupt Link [LNKE] (IRQs 10) *0, disabled.
[ 0.308486] ACPI: PCI Interrupt Link [LNKF] (IRQs *10)
[ 0.308486] ACPI: PCI Interrupt Link [LNKG] (IRQs *10)
[ 0.308486] ACPI: PCI Interrupt Link [LNKH] (IRQs *10)
[ 0.308486] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 0.308486] pnp: PnP ACPI init
[ 0.308486] ACPI: bus type pnp registered
[ 0.316486] pnp: PnP ACPI: found 11 devices
[ 0.316486] ACPI: ACPI bus type pnp unregistered
[ 0.316486] PnPBIOS: Disabled by ACPI PNP
[ 0.316486] PCI: Using ACPI for IRQ routing
[ 0.318944] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.319225] hpet0: 3 64-bit timers, 14318180 Hz
[ 0.320374] ACPI: RTC can wake from S4
[ 0.322947] system 00:01: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.323035] system 00:01: iomem range 0xfed14000-0xfed17fff could not be reserved
[ 0.323140] system 00:01: iomem range 0xfed18000-0xfed18fff could not be reserved
[ 0.323244] system 00:01: iomem range 0xfed19000-0xfed19fff could not be reserved
[ 0.324426] system 00:01: iomem range 0xfed1c000-0xfed1ffff could not be reserved
[ 0.324489] system 00:01: iomem range 0xfed20000-0xfed3ffff could not be reserved
[ 0.324489] system 00:01: iomem range 0xfed40000-0xfed44fff could not be reserved
[ 0.324489] system 00:01: iomem range 0xfed45000-0xfed8ffff could not be reserved
[ 0.324489] system 00:06: ioport range 0x680-0x6ff has been reserved
[ 0.324489] system 00:06: ioport range 0x800-0x80f has been reserved
[ 0.324489] system 00:06: ioport range 0x1000-0x107f has been reserved
[ 0.324489] system 00:06: ioport range 0x1180-0x11bf has been reserved
[ 0.324489] system 00:06: ioport range 0x1640-0x164f has been reserved
[ 0.324489] system 00:06: ioport range 0xfe00-0xfe01 has been reserved
[ 0.358228] PCI: region 0000:09:04.0/9 too large: 0x0000000000000000-0x0000000003ffffff
[ 0.358341] PCI: Bridge: 0000:00:1c.0
[ 0.358420] IO window: 2000-2fff
[ 0.358502] MEM window: 0xf6000000-0xf7ffffff
[ 0.358584] PREFETCH window: 0x00000000f0000000-0x00000000f1ffffff
[ 0.358675] PCI: Bridge: 0000:00:1c.1
[ 0.358751] IO window: disabled.
[ 0.358832] MEM window: 0xfc000000-0xfc0fffff
[ 0.358918] PREFETCH window: disabled.
[ 0.360994] PCI: Bridge: 0000:00:1c.2
[ 0.361073] IO window: 3000-3fff
[ 0.361154] MEM window: 0xf8000000-0xf9ffffff
[ 0.361237] PREFETCH window: 0x00000000f2000000-0x00000000f3ffffff
[ 0.361327] PCI: Bridge: 0000:00:1c.3
[ 0.361406] IO window: 4000-4fff
[ 0.361487] MEM window: 0xfa000000-0xfbffffff
[ 0.361570] PREFETCH window: 0x00000000f4000000-0x00000000f5ffffff
[ 0.361670] PCI: Bus 10, cardbus bridge: 0000:09:04.0
[ 0.361750] IO window: 0x00005000-0x000050ff
[ 0.361832] IO window: 0x00005400-0x000054ff
[ 0.361914] MEM window: 0x50000000-0x53ffffff
[ 0.361997] PCI: Bridge: 0000:00:1e.0
[ 0.362075] IO window: 5000-5fff
[ 0.362143] MEM window: 0xfc100000-0xfc1fffff
[ 0.362143] PREFETCH window: disabled.
[ 0.362143] ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 0.362143] PCI: Setting latency timer of device 0000:00:1c.0 to 64
[ 0.362143] ACPI: PCI Interrupt 0000:00:1c.1[B] -> GSI 17 (level, low) -> IRQ 17
[ 0.362143] PCI: Setting latency timer of device 0000:00:1c.1 to 64
[ 0.362143] ACPI: PCI Interrupt 0000:00:1c.2[C] -> GSI 18 (level, low) -> IRQ 18
[ 0.362143] PCI: Setting latency timer of device 0000:00:1c.2 to 64
[ 0.362143] ACPI: PCI Interrupt 0000:00:1c.3[D] -> GSI 19 (level, low) -> IRQ 19
[ 0.362304] PCI: Setting latency timer of device 0000:00:1c.3 to 64
[ 0.362324] PCI: Setting latency timer of device 0000:00:1e.0 to 64
[ 0.362349] ACPI: PCI Interrupt 0000:09:04.0[A] -> GSI 20 (level, low) -> IRQ 20
[ 0.362507] PCI: Setting latency timer of device 0000:09:04.0 to 64
[ 0.362554] NET: Registered protocol family 2
[ 0.374276] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.374736] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.375470] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.375877] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.375962] TCP reno registered
[ 0.382314] NET: Registered protocol family 1
[ 0.382574] checking if image is initramfs...<7>Switched to high resolution mode on CPU 1
[ 0.510140] Switched to high resolution mode on CPU 0
[ 0.786128] it is
[ 1.222114] Freeing initrd memory: 5773k freed
[ 1.222154] Simple Boot Flag at 0x36 set to 0x1
[ 1.222199] audit: initializing netlink socket (disabled)
[ 1.222316] type=2000 audit(1224587609.216:1): initialized
[ 1.226134] highmem bounce pool size: 64 pages
[ 1.226134] Total HugeTLB memory allocated, 0
[ 1.226134] VFS: Disk quotas dquot_6.5.1
[ 1.226134] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.226134] msgmni has been set to 1767
[ 1.226134] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.226134] io scheduler noop registered
[ 1.226134] io scheduler anticipatory registered
[ 1.226134] io scheduler deadline registered
[ 1.226134] io scheduler cfq registered (default)
[ 1.226134] pci 0000:00:02.0: Boot video device
[ 1.226134] PCI: Setting latency timer of device 0000:00:1c.0 to 64
[ 1.226134] assign_interrupt_mode Found MSI capability
[ 1.226134] Allocate Port Service[0000:00:1c.0:pcie00]
[ 1.226134] Allocate Port Service[0000:00:1c.0:pcie02]
[ 1.226134] Allocate Port Service[0000:00:1c.0:pcie03]
[ 1.226134] PCI: Setting latency timer of device 0000:00:1c.1 to 64
[ 1.226134] Allocate Port Service[0000:00:1c.1:pcie00]
[ 1.226134] Allocate Port Service[0000:00:1c.1:pcie02]
[ 1.226134] Allocate Port Service[0000:00:1c.1:pcie03]
[ 1.226144] PCI: Setting latency timer of device 0000:00:1c.2 to 64
[ 1.226144] assign_interrupt_mode Found MSI capability
[ 1.226144] Allocate Port Service[0000:00:1c.2:pcie00]
[ 1.226144] Allocate Port Service[0000:00:1c.2:pcie02]
[ 1.226144] Allocate Port Service[0000:00:1c.2:pcie03]
[ 1.226144] PCI: Setting latency timer of device 0000:00:1c.3 to 64
[ 1.226144] Allocate Port Service[0000:00:1c.3:pcie00]
[ 1.226144] Allocate Port Service[0000:00:1c.3:pcie02]
[ 1.226144] Allocate Port Service[0000:00:1c.3:pcie03]
[ 1.230133] isapnp: Scanning for PnP cards...
[ 1.584398] isapnp: No Plug & Play device found
[ 1.588209] hpet_resources: 0xfed00000 is busy
[ 1.588225] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 1.592203] brd: module loaded
[ 1.592203] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.594129] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.594129] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.594129] mice: PS/2 mouse device common for all mice
[ 1.594129] rtc_cmos 00:07: rtc core: registered rtc_cmos as rtc0
[ 1.594129] rtc0: alarms up to one month, y3k
[ 1.594129] cpuidle: using governor ladder
[ 1.594129] cpuidle: using governor menu
[ 1.594216] No iBFT detected.
[ 1.595006] TCP cubic registered
[ 1.595085] NET: Registered protocol family 17
[ 1.595172] Using IPI No-Shortcut mode
[ 1.598153] registered taskstats version 1
[ 1.598153] rtc_cmos 00:07: setting system clock to 2008-10-21 11:13:30 UTC (1224587610)
[ 1.598153] Freeing unused kernel memory: 244k freed
[ 1.622128] input: AT Translated Set 2 keyboard as /class/input/input0
[ 1.734129] ACPI: SSDT 3F689807, 01B4 (r1 Sony VAIO 20070424 PTL 20050624)
[ 1.735076] ACPI: SSDT 3F689295, 04ED (r1 Sony VAIO 20070424 PTL 20050624)
[ 1.741218] Monitor-Mwait will be used to enter C-1 state
[ 1.741218] Monitor-Mwait will be used to enter C-2 state
[ 1.741218] Monitor-Mwait will be used to enter C-3 state
[ 1.741218] ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
[ 1.741218] ACPI: ACPI0007:00 is registered as cooling_device0
[ 1.741218] ACPI: Processor [CPU0] (supports 8 throttling states)
[ 1.741218] ACPI: SSDT 3F6899BB, 00C8 (r1 Sony VAIO 20070424 PTL 20050624)
[ 1.741218] ACPI: SSDT 3F689782, 0085 (r1 Sony VAIO 20070424 PTL 20050624)
[ 1.742678] Marking TSC unstable due to: TSC halts in idle.
[ 1.745617] ACPI: CPU1 (power states: C1[C1] C2[C2] C3[C3])
[ 1.745964] ACPI: ACPI0007:01 is registered as cooling_device1
[ 1.746049] ACPI: Processor [CPU1] (supports 8 throttling states)
[ 1.749336] ACPI: LNXTHERM:01 is registered as thermal_zone0
[ 1.749545] ACPI: Thermal Zone [ATF0] (63 C)
[ 1.753409] ACPI: LNXTHERM:02 is registered as thermal_zone1
[ 1.753409] ACPI: Thermal Zone [DTS0] (61 C)
[ 1.753432] ACPI: LNXTHERM:03 is registered as thermal_zone2
[ 1.753432] ACPI: Thermal Zone [DTS1] (63 C)
[ 2.011495] ACPI: ACPI Dock Station Driver
[ 2.113217] ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 2.113217] PCI: Setting latency timer of device 0000:02:00.0 to 64
[ 2.113217] sky2 0000:02:00.0: v1.21 addr 0xf6000000 irq 16 Yukon-EC Ultra (0xb4) rev 3
[ 2.117276] sky2 eth0: addr 00:13:a9:fb:c4:b0
[ 2.153927] usbcore: registered new interface driver usbfs
[ 2.153927] usbcore: registered new interface driver hub
[ 2.153927] usbcore: registered new device driver usb
[ 2.157927] USB Universal Host Controller Interface driver v3.0
[ 2.157927] ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 17 (level, low) -> IRQ 17
[ 2.157927] PCI: Setting latency timer of device 0000:00:1d.0 to 64
[ 2.157927] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 2.157927] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 2.157927] uhci_hcd 0000:00:1d.0: irq 17, io base 0x00001820
[ 2.157927] usb usb1: configuration #1 chosen from 1 choice
[ 2.157927] hub 1-0:1.0: USB hub found
[ 2.157927] hub 1-0:1.0: 2 ports detected
[ 2.250078] Uniform Multi-Platform E-IDE driver
[ 2.250078] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 2.267237] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.267329] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.267356] usb usb1: Product: UHCI Host Controller
[ 2.267356] usb usb1: Manufacturer: Linux 2.6.26-1-686 uhci_hcd
[ 2.267356] usb usb1: SerialNumber: 0000:00:1d.0
[ 2.267356] ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 19
[ 2.267356] PCI: Setting latency timer of device 0000:00:1d.1 to 64
[ 2.267356] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 2.267475] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
[ 2.267475] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00001840
[ 2.267475] usb usb2: configuration #1 chosen from 1 choice
[ 2.267475] hub 2-0:1.0: USB hub found
[ 2.267475] hub 2-0:1.0: 2 ports detected
[ 2.271371] ricoh-mmc: Ricoh MMC Controller disabling driver
[ 2.271371] ricoh-mmc: Copyright(c) Philip Langdale
[ 2.376612] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.376706] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.376810] usb usb2: Product: UHCI Host Controller
[ 2.376891] usb usb2: Manufacturer: Linux 2.6.26-1-686 uhci_hcd
[ 2.376975] usb usb2: SerialNumber: 0000:00:1d.1
[ 2.377203] ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 21 (level, low) -> IRQ 21
[ 2.377203] PCI: Setting latency timer of device 0000:00:1d.2 to 64
[ 2.377203] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 2.377342] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
[ 2.377342] uhci_hcd 0000:00:1d.2: irq 21, io base 0x00001860
[ 2.377342] usb usb3: configuration #1 chosen from 1 choice
[ 2.377342] hub 3-0:1.0: USB hub found
[ 2.377342] hub 3-0:1.0: 2 ports detected
[ 2.478111] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.478200] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.478306] usb usb3: Product: UHCI Host Controller
[ 2.478388] usb usb3: Manufacturer: Linux 2.6.26-1-686 uhci_hcd
[ 2.478474] usb usb3: SerialNumber: 0000:00:1d.2
[ 2.481204] ACPI: PCI Interrupt 0000:00:1d.3[A] -> GSI 17 (level, low) -> IRQ 17
[ 2.481204] PCI: Setting latency timer of device 0000:00:1d.3 to 64
[ 2.481204] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 2.481204] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
[ 2.481204] uhci_hcd 0000:00:1d.3: irq 17, io base 0x00001880
[ 2.481204] usb usb4: configuration #1 chosen from 1 choice
[ 2.481204] hub 4-0:1.0: USB hub found
[ 2.481204] hub 4-0:1.0: 2 ports detected
[ 2.514701] Clocksource tsc unstable (delta = -141494548 ns)
[ 2.582548] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.582636] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.582741] usb usb4: Product: UHCI Host Controller
[ 2.582823] usb usb4: Manufacturer: Linux 2.6.26-1-686 uhci_hcd
[ 2.582908] usb usb4: SerialNumber: 0000:00:1d.3
[ 2.585821] ACPI: PCI Interrupt 0000:00:1d.7[D] -> GSI 23 (level, low) -> IRQ 23
[ 2.585821] PCI: Setting latency timer of device 0000:00:1d.7 to 64
[ 2.585821] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 2.585821] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
[ 2.589952] ehci_hcd 0000:00:1d.7: debug port 1
[ 2.590040] PCI: cache line size of 32 is not supported by device 0000:00:1d.7
[ 2.590056] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfc544000
[ 2.603909] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 2.604134] usb usb5: configuration #1 chosen from 1 choice
[ 2.604263] hub 5-0:1.0: USB hub found
[ 2.604350] hub 5-0:1.0: 8 ports detected
[ 2.710187] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.710281] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.710386] usb usb5: Product: EHCI Host Controller
[ 2.710467] usb usb5: Manufacturer: Linux 2.6.26-1-686 ehci_hcd
[ 2.710550] usb usb5: SerialNumber: 0000:00:1d.7
[ 2.710550] ricoh-mmc: Ricoh MMC controller found at 0000:09:04.3 [1180:0843] (rev 11)
[ 2.710550] ricoh-mmc: Controller is now disabled.
[ 2.710550] ACPI: PCI Interrupt 0000:09:04.1[B] -> GSI 21 (level, low) -> IRQ 21
[ 2.763993] ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[21] MMIO=[fc100000-fc1007ff] Max Packet=[2048] IR/IT contexts=[4/4]
[ 2.770020] ICH7: IDE controller (0x8086:0x27df rev 0x02) at PCI slot 0000:00:1f.1
[ 2.770141] ACPI: PCI Interrupt 0000:00:1f.1[B] -> GSI 22 (level, low) -> IRQ 22
[ 2.770305] ICH7: not 100% native mode: will probe irqs later
[ 2.770398] ICH7: IDE port disabled
[ 2.770483] ide0: BM-DMA at 0x1810-0x1817
[ 2.770568] Probing IDE interface ide0...
[ 3.058531] hda: TOSHIBA MK8009GAH, ATA DISK drive
[ 3.233389] usb 5-5: new high speed USB device using ehci_hcd and address 2
[ 3.365948] usb 5-5: configuration #1 chosen from 1 choice
[ 3.366458] usb 5-5: New USB device found, idVendor=054c, idProduct=02d5
[ 3.366549] usb 5-5: New USB device strings: Mfr=0, Product=57, SerialNumber=44
[ 3.366656] usb 5-5: Product: Sony VAIO USB Internal Optical Drive
[ 3.366742] usb 5-5: SerialNumber: 0013A9FBC4B0
[ 3.398214] SCSI subsystem initialized
[ 3.402041] Initializing USB Mass Storage driver...
[ 3.605910] usb 5-6: new high speed USB device using ehci_hcd and address 3
[ 3.733536] hda: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 3.733609] hda: UDMA/100 mode selected
[ 3.733789] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 3.742497] usb 5-6: configuration #1 chosen from 1 choice
[ 3.742721] hub 5-6:1.0: USB hub found
[ 3.742924] hub 5-6:1.0: 3 ports detected
[ 3.750041] libata version 3.00 loaded.
[ 3.782041] hda: max request size: 512KiB
[ 3.809858] hda: 156301488 sectors (80026 MB), CHS=16383/255/63
[ 3.809909] hda: cache flushes supported
[ 3.809909] hda: hda1 hda2 hda3 hda4
[ 3.847577] usb 5-6: New USB device found, idVendor=0409, idProduct=005a
[ 3.847670] usb 5-6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.054383] ieee1394: Host added: ID:BUS[0-00:1023] GUID[08004603026b312d]
[ 4.092786] usb 5-8: new high speed USB device using ehci_hcd and address 4
[ 4.231028] usb 5-8: configuration #1 chosen from 1 choice
[ 4.232730] usb 5-8: New USB device found, idVendor=05ca, idProduct=183a
[ 4.232730] usb 5-8: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.232730] scsi0 : SCSI emulation for USB Mass Storage devices
[ 4.232730] usb-storage: device found at 2
[ 4.232730] usb-storage: waiting for device to settle before scanning
[ 4.447880] usb 5-6.2: new full speed USB device using ehci_hcd and address 5
[ 4.598079] usb 5-6.2: configuration #1 chosen from 1 choice
[ 4.601332] usb 5-6.2: New USB device found, idVendor=044e, idProduct=300d
[ 4.601422] usb 5-6.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.601526] usb 5-6.2: Product: UGX
[ 4.601603] usb 5-6.2: Manufacturer: ALPS
[ 4.601682] usb 5-6.2: SerialNumber: 01e97580
[ 4.606951] usbcore: registered new interface driver usb-storage
[ 4.606951] USB Mass Storage support registered.
[ 4.762233] kjournald starting. Commit interval 5 seconds
[ 4.762233] EXT3-fs: mounted filesystem with ordered data mode.
[ 6.509285] udevd version 125 started
[ 7.202759] Linux agpgart interface v0.103
[ 7.213598] agpgart: Detected an Intel 945GM Chipset.
[ 7.214545] agpgart: Detected 7932K stolen memory.
[ 7.235858] agpgart: AGP aperture is 256M @ 0xd0000000
[ 7.281269] input: Lid Switch as /class/input/input1
[ 7.327120] ACPI: Lid Switch [LID0]
[ 7.327120] input: Power Button (CM) as /class/input/input2
[ 7.376678] ACPI: Power Button (CM) [PWRB]
[ 7.480317] iwl3945: Intel(R) PRO/Wireless 3945ABG/BG Network Connection driver for Linux, 1.2.26ks
[ 7.480464] iwl3945: Copyright(c) 2003-2008 Intel Corporation
[ 7.480733] ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 17 (level, low) -> IRQ 17
[ 7.480946] PCI: Setting latency timer of device 0000:03:00.0 to 64
[ 7.480971] iwl3945: Detected Intel Wireless WiFi Link 3945ABG
[ 7.570266] iwl3945: Tunable channels: 13 802.11bg, 23 802.11a channels
[ 7.600316] phy0: Selected rate control algorithm 'iwl-3945-rs'
[ 7.687025] ACPI: device:03 is registered as cooling_device2
[ 7.689013] input: Video Bus as /class/input/input3
[ 7.769188] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 8.102455] ACPI: PCI interrupt for device 0000:03:00.0 disabled
[ 8.161979] ACPI: Battery Slot [BAT1] (battery present)
[ 8.218891] sony-laptop: Sony Programmable IO Control Driver v0.6.
[ 8.218891] sony-laptop: detected Type4 model
[ 8.224085] input: Sony Vaio Keys as /class/input/input4
[ 8.276240] input: Sony Vaio Jogdial as /class/input/input5
[ 8.344752] sony-laptop: device allocated minor is 60
[ 8.349635] ACPI: AC Adapter [ACAD] (on-line)
[ 8.350393] sony-laptop: Sony Notebook Control Driver v0.6.
[ 8.610343] ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 19 (level, low) -> IRQ 19
[ 8.610343] PCI: Setting latency timer of device 0000:00:1b.0 to 64
[ 8.644909] Linux video capture interface: v2.00
[ 8.659766] uvcvideo: Found UVC 1.00 device <unnamed> (05ca:183a)
[ 8.659766] uvcvideo: Failed to query (135) UVC control 1 (unit 0) : -32 (exp. 26).
[ 8.659766] uvcvideo: Failed to query (129) UVC control 1 (unit 0) : -32 (exp. 26).
[ 8.659897] uvcvideo: Failed to initialize the device (-5).
[ 8.660247] usbcore: registered new interface driver uvcvideo
[ 8.660333] USB Video Class driver (v0.1.0)
[ 8.776395] Bluetooth: Core ver 2.11
[ 8.809738] NET: Registered protocol family 31
[ 8.809738] Bluetooth: HCI device and connection manager initialized
[ 8.809738] Bluetooth: HCI socket layer initialized
[ 8.867902] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.03 (30-Apr-2008)
[ 8.870052] iTCO_wdt: failed to reset NO_REBOOT flag, reboot disabled by hardware
[ 8.870182] iTCO_wdt: No card detected
[ 8.966538] Bluetooth: HCI USB driver ver 2.9
[ 8.970538] usbcore: registered new interface driver hci_usb
[ 9.022955] input: PC Speaker as /class/input/input6
[ 9.046669] Yenta: CardBus bridge found at 0000:09:04.0 [104d:900e]
[ 9.046787] PCI: Bus 10, cardbus bridge: 0000:09:04.0
[ 9.046868] IO window: 0x00005000-0x000050ff
[ 9.046952] IO window: 0x00005400-0x000054ff
[ 9.047036] PREFETCH window: 0x54400000-0x547fffff
[ 9.047120] MEM window: 0x50000000-0x53ffffff
[ 9.087197] intel_rng: FWH not detected
[ 9.172696] Yenta: ISA IRQ mask 0x0cb8, PCI irq 20
[ 9.172790] Socket status: 30000006
[ 9.172872] Yenta: Raising subordinate bus# of parent bus (#09) from #0a to #0d
[ 9.174769] pcmcia: parent PCI bridge I/O window: 0x5000 - 0x5fff
[ 9.174856] cs: IO port probe 0x5000-0x5fff: clean.
[ 9.175436] pcmcia: parent PCI bridge Memory window: 0xfc100000 - 0xfc1fffff
[ 9.270767] usb-storage: device scan complete
[ 9.270767] scsi 0:0:0:0: CD-ROM MATSHITA DVD-RAM UJ-852S 1.30 PQ: 0 ANSI: 0
[ 9.281291] input: PS/2 Mouse as /class/input/input7
[ 9.353793] input: AlpsPS/2 ALPS GlidePoint as /class/input/input8
[ 9.454767] Error: Driver 'pcspkr' is already registered, aborting...
[ 9.729295] Driver 'sr' needs updating - please use bus_type methods
[ 9.733930] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 9.733930] Uniform CD-ROM driver Revision: 3.20
[ 9.734160] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 9.852487] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 10.707875] Adding 465876k swap on /dev/hda3. Priority:-1 extents:1 across:465876k
[ 11.336140] EXT3 FS on hda2, internal journal
[ 12.359200] kjournald starting. Commit interval 5 seconds
[ 12.359200] EXT3 FS on hda4, internal journal
[ 12.359200] EXT3-fs: mounted filesystem with ordered data mode.
[ 13.453668] sky2 eth0: enabling interface
[ 21.038432] [drm] Initialized drm 1.1.0 20060810
[ 21.042435] ACPI: PCI Interrupt 0000:00:02.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 21.042435] PCI: Setting latency timer of device 0000:00:02.0 to 64
[ 21.042435] [drm] Initialized i915 1.6.0 20060119 on minor 0
Le driver est bien iwl3945.
Un iwconfig me renvoie [code]iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wmaster0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:""
Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated
Tx-Power=0 dBm
Retry min limit:7 RTS thr:off Fragment thr=2352 B
Encryption key:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0[/code]
La carte wifi est bien reconnu bien qu’aucun réseau ne soit configuré.
Un lsmod renvoi lsmod | grep iwl3945
iwl3945 78772 0
firmware_class 6816 2 pcmcia,iwl3945
mac80211 139680 1 iwl3945
led_class 3908 1 iwl3945
cfg80211 21576 2 iwl3945,mac80
Le module semble chargé.
Un scan renvoi iwlist wlan0 scan
wlan0 Interface doesn't support scanning : Network is down
Je pensais que le iwlist scan scanner les réseau dispos à proximité mais apparemment ça ne marche pas
