Mince, c’est pire qu’avant…
Avant de voir vos réponses, j’ai voulu mettre à jour le pilote nvidia pour voir si ça pouvait régler le problème. Maintenant, X plante au démarrage.
Je vais essayer de vous poster le log.
EDIT : voici le log :
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux newton 2.6.18-4-486 #1 Wed May 9 22:23:40 UTC 2007 i686
Build Date: 04 April 2007
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Jun 27 14:32:14 2007
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Generic Monitor"
(**) | |-->Device "nVidia Corporation MCP51 PCI-X GeForce Go 6100"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(WW) The directory "/usr/X11R6/lib/X11/fonts/misc" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi" does not exist.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType
(==) RgbPath set to "/etc/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.0
X.Org XInput driver : 0.6
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 1.0
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 10de,02f3 card 1043,1382 rev a2 class 05,00,00 hdr 80
(II) PCI: 00:00:1: chip 10de,02fa card 1043,1382 rev a2 class 05,00,00 hdr 80
(II) PCI: 00:00:2: chip 10de,02fe card 1043,1382 rev a2 class 05,00,00 hdr 80
(II) PCI: 00:00:3: chip 10de,02f8 card 1043,1382 rev a2 class 05,00,00 hdr 80
(II) PCI: 00:00:4: chip 10de,02f9 card 1043,1382 rev a2 class 05,00,00 hdr 00
(II) PCI: 00:00:5: chip 10de,02ff card 1043,1382 rev a2 class 05,00,00 hdr 80
(II) PCI: 00:00:6: chip 10de,027f card 1043,1382 rev a2 class 05,00,00 hdr 80
(II) PCI: 00:00:7: chip 10de,027e card 1043,1382 rev a2 class 05,00,00 hdr 80
(II) PCI: 00:02:0: chip 10de,02fc card 0000,0000 rev a1 class 06,04,00 hdr 01
(II) PCI: 00:03:0: chip 10de,02fd card 0000,0000 rev a1 class 06,04,00 hdr 01
(II) PCI: 00:04:0: chip 10de,02fb card 0000,0000 rev a1 class 06,04,00 hdr 01
(II) PCI: 00:05:0: chip 10de,0247 card 1043,1382 rev a2 class 03,00,00 hdr 00
(II) PCI: 00:09:0: chip 10de,0270 card 1043,1367 rev a2 class 05,00,00 hdr 00
(II) PCI: 00:0a:0: chip 10de,0260 card 1043,1367 rev a3 class 06,01,00 hdr 80
(II) PCI: 00:0a:1: chip 10de,0264 card 1043,1367 rev a3 class 0c,05,00 hdr 80
(II) PCI: 00:0a:3: chip 10de,0271 card 1043,1367 rev a3 class 0b,40,00 hdr 80
(II) PCI: 00:0b:0: chip 10de,026d card 1043,1367 rev a3 class 0c,03,10 hdr 80
(II) PCI: 00:0b:1: chip 10de,026e card 1043,1367 rev a3 class 0c,03,20 hdr 80
(II) PCI: 00:0d:0: chip 10de,0265 card 1043,1367 rev a1 class 01,01,8a hdr 00
(II) PCI: 00:10:0: chip 10de,026f card 0000,0000 rev a2 class 06,04,01 hdr 81
(II) PCI: 00:10:1: chip 10de,026c card 1043,1339 rev a2 class 04,03,00 hdr 80
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 02:00:0: chip 10ec,8168 card 1043,11f5 rev 01 class 02,00,00 hdr 00
(II) PCI: 04:01:0: chip 1180,0476 card e000,0000 rev b3 class 06,07,00 hdr 82
(II) PCI: 04:01:1: chip 1180,0552 card 1043,1367 rev 08 class 0c,00,10 hdr 80
(II) PCI: 04:01:2: chip 1180,0822 card 1043,1367 rev 17 class 08,05,00 hdr 80
(II) PCI: 04:01:3: chip 1180,0592 card 1043,1367 rev 08 class 08,80,00 hdr 80
(II) PCI: 04:03:0: chip 14e4,4318 card 1043,120f rev 02 class 02,80,00 hdr 00
(II) PCI: End of PCI scan
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:2:0), (0,1,1), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 2: bridge is at (0:3:0), (0,2,2), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xdf600000 - 0xdf6fffff (0x100000) MX[B]
(II) Bus 3: bridge is at (0:4:0), (0,3,3), BCTRL: 0x0002 (VGA_EN is cleared)
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:10:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 4: bridge is at (0:16:0), (0,4,8), BCTRL: 0x0202 (VGA_EN is cleared)
(II) Bus 4 I/O range:
[0] -1 0 0x0000e000 - 0x0000efff (0x1000) IX[B]
(II) Bus 4 non-prefetchable memory range:
[0] -1 0 0xdf700000 - 0xdfffffff (0x900000) MX[B]
(II) Bus 4 prefetchable memory range:
[0] -1 0 0xdb000000 - 0xdcffffff (0x2000000) MX[B]
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:24:0), (0,0,5), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-CardBus bridge:
(II) Bus 5: bridge is at (4:1:0), (4,5,8), BCTRL: 0x0583 (VGA_EN is cleared)
(II) Bus 5 I/O range:
[0] -1 0 0x0000e000 - 0x0000e0ff (0x100) IX[B]
[1] -1 0 0x0000e400 - 0x0000e4ff (0x100) IX[B]
(--) PCI:*(0:5:0) nVidia Corporation C51 PCI Express Bridge rev 162, Mem @ 0xde000000/24, 0xc0000000/28, 0xdd000000/24
(--) PCI: (0:10:3) nVidia Corporation MCP51 PMU rev 163, Mem @ 0xdf580000/18
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xdf7fc000 - 0xdf7fdfff (0x2000) MX[B]
[1] -1 0 0xdf7ffc00 - 0xdf7ffcff (0x100) MX[B]
[2] -1 0 0xdf7ff800 - 0xdf7ff8ff (0x100) MX[B]
[3] -1 0 0xdf7ff000 - 0xdf7ff7ff (0x800) MX[B]
[4] -1 0 0xdf6ff000 - 0xdf6fffff (0x1000) MX[B]
[5] -1 0 0xdf5d8000 - 0xdf5dbfff (0x4000) MX[B]
[6] -1 0 0xdf5dfc00 - 0xdf5dfcff (0x100) MX[B]
[7] -1 0 0xdf5de000 - 0xdf5defff (0x1000) MX[B]
[8] -1 0 0xdf580000 - 0xdf5bffff (0x40000) MX[B]
[9] -1 0 0xdd000000 - 0xddffffff (0x1000000) MX[B](B)
[10] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
[11] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B)
[12] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[13] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[14] -1 0 0x00000700 - 0x0000073f (0x40) IX[B]
[15] -1 0 0x00000600 - 0x0000063f (0x40) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xdf7fc000 - 0xdf7fdfff (0x2000) MX[B]
[5] -1 0 0xdf7ffc00 - 0xdf7ffcff (0x100) MX[B]
[6] -1 0 0xdf7ff800 - 0xdf7ff8ff (0x100) MX[B]
[7] -1 0 0xdf7ff000 - 0xdf7ff7ff (0x800) MX[B]
[8] -1 0 0xdf6ff000 - 0xdf6fffff (0x1000) MX[B]
[9] -1 0 0xdf5d8000 - 0xdf5dbfff (0x4000) MX[B]
[10] -1 0 0xdf5dfc00 - 0xdf5dfcff (0x100) MX[B]
[11] -1 0 0xdf5de000 - 0xdf5defff (0x1000) MX[B]
[12] -1 0 0xdf580000 - 0xdf5bffff (0x40000) MX[B]
[13] -1 0 0xdd000000 - 0xddffffff (0x1000000) MX[B](B)
[14] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
[15] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B)
[16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[18] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[19] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[20] -1 0 0x00000700 - 0x0000073f (0x40) IX[B]
[21] -1 0 0x00000600 - 0x0000063f (0x40) IX[B]
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: "ddc"
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
ABI class: X.Org Server Extension, version 0.3
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.1.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
ABI class: X.Org Server Extension, version 0.1
(II) NVIDIA GLX Module 100.14.11 Wed Jun 13 18:58:58 PDT 2007
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.0
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: X.Org Video Driver
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.1
(II) NVIDIA dlloader X Driver 100.14.11 Wed Jun 13 18:23:34 PDT 2007
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 00:05:0
(WW) NVIDIA: No matching Device section for instance (BusID PCI:0:10:3) found
(--) Chipset NVIDIA GPU found
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "wfb"
(II) LoadModule: "wfb"
(II) Loading /usr/lib/xorg/modules/libwfb.so
(II) Module wfb: vendor="NVIDIA Corporation"
compiled for 7.1.99.2, module version = 1.0.0
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/lib/xorg/modules/libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 0.1.0
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[16] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[17] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[18] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[19] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[20] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[21] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[22] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[23] -1 0 0x00000700 - 0x0000073f (0x40) IX[B]
[24] -1 0 0x00000600 - 0x0000063f (0x40) IX[B]
[25] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[26] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): NVIDIA GPU GeForce Go 6100 (C51) at PCI:0:5:0 (GPU-0)
(--) NVIDIA(0): Memory: 524288 kBytes
(--) NVIDIA(0): VideoBIOS: 05.51.28.54.23
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(--) NVIDIA(0): Connected display device(s) on GeForce Go 6100 at PCI:0:5:0:
(--) NVIDIA(0): AUO (DFP-0)
(--) NVIDIA(0): AUO (DFP-0): 310.0 MHz maximum pixel clock
(--) NVIDIA(0): AUO (DFP-0): Internal Dual Link LVDS
(II) NVIDIA(0): Assigned Display Device: DFP-0
(WW) NVIDIA(0): No valid modes for "1280x768"; removing.
(WW) NVIDIA(0): No valid modes for "1200x800"; removing.
(WW) NVIDIA(0): No valid modes for "1152x864"; removing.
(WW) NVIDIA(0): No valid modes for "1152x768"; removing.
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0): "1280x800"
(II) NVIDIA(0): "1024x768"
(II) NVIDIA(0): "800x600"
(II) NVIDIA(0): "640x480"
(II) NVIDIA(0): Virtual screen size determined to be 1280 x 800
(++) NVIDIA(0): DPI set to (96, 96); computed from -dpi X commandline option
(==) NVIDIA(0): Disabling 32-bit ARGB GLX visuals.
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xdd000000 - 0xddffffff (0x1000000) MX[B]
[1] 0 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B]
[2] 0 0 0xde000000 - 0xdeffffff (0x1000000) MX[B]
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[7] -1 0 0xdf7fc000 - 0xdf7fdfff (0x2000) MX[B]
[8] -1 0 0xdf7ffc00 - 0xdf7ffcff (0x100) MX[B]
[9] -1 0 0xdf7ff800 - 0xdf7ff8ff (0x100) MX[B]
[10] -1 0 0xdf7ff000 - 0xdf7ff7ff (0x800) MX[B]
[11] -1 0 0xdf6ff000 - 0xdf6fffff (0x1000) MX[B]
[12] -1 0 0xdf5d8000 - 0xdf5dbfff (0x4000) MX[B]
[13] -1 0 0xdf5dfc00 - 0xdf5dfcff (0x100) MX[B]
[14] -1 0 0xdf5de000 - 0xdf5defff (0x1000) MX[B]
[15] -1 0 0xdf580000 - 0xdf5bffff (0x40000) MX[B]
[16] -1 0 0xdd000000 - 0xddffffff (0x1000000) MX[B](B)
[17] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
[18] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B)
[19] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
[20] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
[21] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
[22] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[23] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[24] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[25] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[26] -1 0 0x00000700 - 0x0000073f (0x40) IX[B]
[27] -1 0 0x00000600 - 0x0000063f (0x40) IX[B]
[28] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[29] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) NVIDIA(0): Setting mode "1280x800"
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(**) Option "dpms"
(**) NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) Initializing extension GLX
Ca bloque à GLX, c’est ça ?
