Merci à vous.
Jen’ ai cependant pas vu de valeurs de rafraîchissement dans mon fichier de conf.
Je le mets en totalité.
Si quelqu’ un peut y jeter un coup d’ oeil avant que je mette la mention résolu :
XF86Config-4 (XFree86 X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the XF86Config-4 manual page.
(Type “man XF86Config-4” at the shell prompt.)
This file is automatically updated on xserver-xfree86 package upgrades only
if it has not been modified since the last upgrade of the xserver-xfree86
package.
If you have edited this file but would like it to be automatically updated
again, run the following commands as root:
cp /etc/X11/XF86Config-4 /etc/X11/XF86Config-4.custom
md5sum /etc/X11/XF86Config-4 >/var/lib/xfree86/XF86Config-4.md5sum
dpkg-reconfigure xserver-xfree86
Section "Files"
FontPath “unix/:7100” # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/Speedo"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option “XkbRules” "xfree86"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
Option “ZAxisMapping” "4 5"
EndSection
Section "Device"
Identifier "Carte vidéo générique"
Driver "vesa"
EndSection
Section "Monitor"
Identifier "e1770NSL/T"
HorizSync 30-70
VertRefresh 50-160
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Carte vidéo générique"
Monitor "e1770NSL/T"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
