bonsoir
ce temps pour faire le grand ménage ( windows, debian).Tout est réinstallé a neuf.
ci joint mon X11/xorg.conf d’origine
xorg.conf (X.Org X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Il est pas très renseigné.
Je peux récupérer un x11/xorg.conf chez une amie qui tourne sous ubuntu 7.10. elle peut afficher du 1280*1024
elle a la meme carte graphique que moi.S i je fais un copier collé de sa configuration X11/… Est -ce que cela risque de fonctionner? Est ce que je dois le substituer a mon X11… d’origine. Merci encore
