Je suis sous Debian Sarge.
Voilà un bon moment que je bloque sur l’activation du direct rendering. J’ai une carte intégrée intel 82845G (autrement dit 845G), le driver dans XFree86 est i810.
Je vous poste ma config de XFree :
[quote]Section "Files"
FontPath “unix/:7100” # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/Speedo"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option “XkbRules” "xfree86"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/psaux"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
Option “ZAxisMapping” "4 5"
EndSection
Identifier "Generic Mouse"
Driver "mouse"
Option “SendCoreEvents” "true"
Option “Device” "/dev/input/mice"
EndSection
Section "Device"
Identifier "Carte vidéo générique"
Driver "i810"
EndSection
Section "Monitor"
Identifier "A17-2"
HorizSync 31-81
VertRefresh 56-75
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Carte vidéo générique"
Monitor "A17-2"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
Modes “1280x1024” “1024x768” “800x600” "640x480"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Generic Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Rien de vraiment spécial, le DRI est activé.
Voici mon Glxinfo :
[quote]name of display: :0.0
display: :0 screen: 0
direct rendering: No
server glx vendor string: Brian Paul
server glx version string: 1.4 Mesa 5.0
server glx extensions:
GLX_MESA_copy_sub_buffer, GLX_MESA_pixmap_colormap,
GLX_MESA_release_buffers, GLX_ARB_get_proc_address, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_SGI_video_sync, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer
client glx vendor string: Brian Paul
client glx version string: 1.4 Mesa 5.0
client glx extensions:
GLX_SGIX_pbuffer
GLX extensions:
GLX_SGIX_pbuffer
OpenGL vendor string: Brian Paul
OpenGL renderer string: Mesa X11
OpenGL version string: 1.4 Mesa 5.0
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_imaging, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_point_parameters, GL_ARB_shadow,
GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_transpose_matrix,
GL_ARB_window_pos, GL_ATI_texture_mirror_once, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_func_separate, GL_EXT_blend_logic_op,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_clip_volume_hint,
GL_EXT_convolution, GL_EXT_compiled_vertex_array, GL_EXT_fog_coord,
GL_EXT_histogram, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels,
GL_EXT_paletted_texture, GL_EXT_point_parameters, GL_EXT_polygon_offset,
GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_shadow_funcs,
GL_EXT_shared_texture_palette, GL_EXT_stencil_wrap,
GL_EXT_stencil_two_side, GL_EXT_texture3D, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_object, GL_EXT_texture_lod_bias,
GL_EXT_vertex_array, GL_HP_occlusion_test, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_MESA_pack_invert, GL_MESA_resize_buffers, GL_MESA_ycbcr_texture,
GL_MESA_window_pos, GL_NV_blend_square, GL_NV_point_sprite,
GL_NV_texture_rectangle, GL_NV_texgen_reflection, GL_NV_vertex_program,
GL_NV_vertex_program1_1, GL_SGI_color_matrix, GL_SGI_color_table,
GL_SGIS_generate_mipmap, GL_SGIS_pixel_texture,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIX_depth_texture, GL_SGIX_pixel_texture, GL_SGIX_shadow,
GL_SGIX_shadow_ambient
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x22 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 0 0 None
0x23 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 16 0 0 None
0x24 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 16 0 0 None
0x25 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 16 0 0 None
0x26 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 16 0 0 None
0x27 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 16 0 0 None
0x28 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 16 0 0 None
0x29 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 16 0 0 None
On constate bien le direct rendering: No
dans mon lsmod, j’ai bien :
(il semble que le dri utilise le i830, qui se refere à la même carte d’après mes recherches).
Je me suis dit que peut être ma carte n’était pas prise en compte par le noyau, mais non :
Donc c’est bien activé…
ce qui m’eclate le plus c’est le log de XFree qui me dit que tout est ok ! (je vous épargne le blabla qui ne nous concerne pas en prenant que des extraits traitants du DRM/DRI)
Bon je ne suis pas fou quand même, il me dit bien : “(II) I810(0): direct rendering: Enabled”
Quelqu’un aurait une idée ? je patauge complètement.
