comme moi, et j’ai eu le même problème, mais je ne me souviens plus trop comment je l’avais résolu.
Comme je passe par un routeur, déjà, ce n’est pas forcément SPECIFIQUEMENT le fast800 qui pose probleme.
Maintenant, je ne sais pas si tu as le serveur nv ou nvidia, mais si tu es en nvidia, dans ftp://download.nvidia.com/XFree86/Linux … README.txt
j’ai lu [quote]Q: Why do OpenGL applications run so slow?
A: The application is probably using a different library still on your
system, rather than the NVIDIA supplied OpenGL library. Please see
APPENDIX C for details.[/quote] et dans l’appendix C [quote]Problems will arise if applications use the wrong version of a library.
This can be the case if there are either old libGL libraries or stale
symlinks left lying around.[/quote].
J’ai vu aussi: [quote]Q: X takes a long time to start (possibly several minutes). What can I do?
A: Most of the startx delay problems we have found are caused by incorrect data in video BIOSes about what display devices are possibly connected or what i2c port should be used for detection. You can work around these problems with the X config option “IgnoreDisplayDevices” (please see the description in (app-d) APPENDIX D: X CONFIG OPTIONS).[/quote].
déja, si tu es en nvidia, est ce que les modules GLcore et dri sont bien desactivés dans ton XF86config-4 ?
sinon, en nv, est ce qu’elles sont bien activées ?
