Xorg.1.log
"Default Screen Section" for depth/fbbpp 24/32
[ 37349.060] (==) intel(0): Depth 24, (–) framebuffer bpp 32
[ 37349.060] (==) intel(0): RGB weight 888
[ 37349.060] (==) intel(0): Default visual is TrueColor
[ 37349.060] (–) intel(0): Integrated Graphics Chipset: Intel® HD Graphics 4400
[ 37349.060] () intel(0): Relaxed fencing enabled
[ 37349.060] () intel(0): Wait on SwapBuffers? enabled
[ 37349.060] () intel(0): Triple buffering? enabled
[ 37349.061] () intel(0): Framebuffer tiled
[ 37349.061] () intel(0): Pixmaps tiled
[ 37349.061] () intel(0): 3D buffers tiled
[ 37349.061] () intel(0): SwapBuffers wait enabled
[ 37349.061] (==) intel(0): video overlay key set to 0x101fe
[ 37349.061] (II) intel(0): Output eDP1 has no monitor section
[ 37349.061] (–) intel(0): found backlight control interface /sys/class/backlight/intel_backlight
[ 37349.061] (II) intel(0): Output DP1 has no monitor section
[ 37349.061] (II) intel(0): Output HDMI1 has no monitor section
[ 37349.061] (II) intel(0): Output DP2 has no monitor section
[ 37349.062] (II) intel(0): Output HDMI2 has no monitor section
[ 37349.062] (II) intel(0): EDID for output eDP1
[ 37349.062] (II) intel(0): Manufacturer: CMN Model: 15be Serial#: 0
[ 37349.062] (II) intel(0): Year: 2012 Week: 44
[ 37349.062] (II) intel(0): EDID Version: 1.4
[ 37349.062] (II) intel(0): Digital Display Input
[ 37349.062] (II) intel(0): 6 bits per channel
[ 37349.062] (II) intel(0): Digital interface is DisplayPort
[ 37349.062] (II) intel(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 37349.062] (II) intel(0): Gamma: 2.20
[ 37349.062] (II) intel(0): No DPMS capabilities specified
[ 37349.062] (II) intel(0): Supported color encodings: RGB 4:4:4
[ 37349.062] (II) intel(0): First detailed timing is preferred mode
[ 37349.062] (II) intel(0): Preferred mode is native pixel format and refresh rate
[ 37349.062] (II) intel(0): redX: 0.585 redY: 0.354 greenX: 0.338 greenY: 0.575
[ 37349.062] (II) intel(0): blueX: 0.152 blueY: 0.118 whiteX: 0.313 whiteY: 0.329
[ 37349.062] (II) intel(0): Manufacturer’s mask: 0
[ 37349.062] (II) intel(0): Supported detailed timing:
[ 37349.062] (II) intel(0): clock: 77.2 MHz Image Size: 344 x 194 mm
[ 37349.062] (II) intel(0): h_active: 1366 h_sync: 1425 h_sync_end 1464 h_blank_end 1608 h_border: 0
[ 37349.062] (II) intel(0): v_active: 768 v_sync: 772 v_sync_end 778 v_blanking: 800 v_border: 0
[ 37349.062] (II) intel(0): clock: 51.5 MHz Image Size: 344 x 194 mm
[ 37349.062] (II) intel(0): Unknown vendor-specific block 2
[ 37349.062] (II) intel(0): EDID (in hex):
[ 37349.062] (II) intel(0): 00ffffffffffff000daebe1500000000
[ 37349.062] (II) intel(0): 2c1601049522137802e915955a569327
[ 37349.062] (II) intel(0): 1e505400000001010101010101010101
[ 37349.062] (II) intel(0): 010101010101281e56f2500020303b27
[ 37349.062] (II) intel(0): 460058c21000001a1b1456f250002030
[ 37349.062] (II) intel(0): 3b27460058c21000001a000000000000
[ 37349.062] (II) intel(0): 00000000000000000000000000000002
[ 37349.062] (II) intel(0): 000c4cff0a3c64140d15640000000064
[ 37349.062] (II) intel(0): Not using default mode “320x240” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “400x300” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “512x384” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “640x480” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “640x512” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “800x600” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “896x672” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “928x696” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “960x720” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “576x432” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “680x384” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “700x525” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “720x450” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “800x512” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “840x525” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “960x540” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “960x600” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Not using default mode “1024x768” (doublescan mode not supported)
[ 37349.062] (II) intel(0): Printing probed modes for output eDP1
[ 37349.062] (II) intel(0): Modeline "1366x768"x60.0 77.20 1366 1425 1464 1608 768 772 778 800 +hsync -vsync (48.0 kHz eP)
[ 37349.062] (II) intel(0): Modeline "1366x768"x40.0 51.47 1366 1425 1464 1608 768 772 778 800 +hsync -vsync (32.0 kHz e)
[ 37349.062] (II) intel(0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
[ 37349.062] (II) intel(0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
[ 37349.062] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 37349.062] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 37349.062] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 37349.062] (II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 37349.062] (II) intel(0): EDID for output DP1
[ 37349.063] (II) intel(0): EDID for output HDMI1
[ 37349.063] (II) intel(0): EDID for output DP2
[ 37349.063] (II) intel(0): EDID for output HDMI2
[ 37349.063] (II) intel(0): Output eDP1 connected
[ 37349.063] (II) intel(0): Output DP1 disconnected
[ 37349.063] (II) intel(0): Output HDMI1 disconnected
[ 37349.063] (II) intel(0): Output DP2 disconnected
[ 37349.063] (II) intel(0): Output HDMI2 disconnected
[ 37349.063] (II) intel(0): Using exact sizes for initial modes
[ 37349.063] (II) intel(0): Output eDP1 using initial mode 1366x768
[ 37349.063] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 37349.063] (II) intel(0): Kernel page flipping support detected, enabling
[ 37349.063] (==) intel(0): DPI set to (96, 96)
[ 37349.063] (II) Loading sub module “fb”
[ 37349.063] (II) LoadModule: “fb”
[ 37349.063] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 37349.063] (II) Module fb: vendor=“X.Org Foundation”
[ 37349.063] compiled for 1.16.4, module version = 1.0.0
[ 37349.063] ABI class: X.Org ANSI C Emulation, version 0.4
[ 37349.063] (II) Loading sub module “dri2”
[ 37349.063] (II) LoadModule: “dri2”
[ 37349.063] (II) Module “dri2” already built-in
[ 37349.063] (==) RADEON(G0): Depth 24, (–) framebuffer bpp 32
[ 37349.063] (II) RADEON(G0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 37349.063] (==) RADEON(G0): Default visual is TrueColor
[ 37349.063] (==) RADEON(G0): RGB weight 888
[ 37349.063] (II) RADEON(G0): Using 8 bits per RGB (8 bit DAC)
[ 37349.063] (–) RADEON(G0): Chipset: “OLAND” (ChipID = 0x6601)
[ 37349.063] (II) Loading sub module “glamoregl”
[ 37349.063] (II) LoadModule: “glamoregl”
[ 37349.064] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 37349.066] (II) Module glamoregl: vendor=“X.Org Foundation”
[ 37349.066] compiled for 1.16.4, module version = 1.0.0
[ 37349.066] ABI class: X.Org ANSI C Emulation, version 0.4
[ 37349.066] (II) glamor: OpenGL accelerated X.org driver based.
[ 37349.088] (II) glamor: EGL version 1.4 (DRI2):
[ 37349.098] (II) RADEON(G0): glamor detected, initialising EGL layer.
[ 37349.098] (II) RADEON(G0): KMS Color Tiling: enabled
[ 37349.098] (II) RADEON(G0): KMS Color Tiling 2D: enabled
[ 37349.098] (II) RADEON(G0): KMS Pageflipping: enabled
[ 37349.098] (II) RADEON(G0): SwapBuffers wait for vsync: enabled
[ 37349.112] (II) RADEON(G0): Output DisplayPort-1-2 has no monitor section
[ 37349.128] (II) RADEON(G0): Output DisplayPort-1-3 has no monitor section
[ 37349.144] (II) RADEON(G0): EDID for output DisplayPort-1-2
[ 37349.160] (II) RADEON(G0): EDID for output DisplayPort-1-3
[ 37349.160] (II) RADEON(G0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 37349.160] (II) RADEON(G0): mem size init: gart size :3fbde000 vram size: s:40000000 visible:3fcc0000
[ 37349.160] (==) RADEON(G0): DPI set to (96, 96)
[ 37349.160] (II) Loading sub module “fb”
[ 37349.160] (II) LoadModule: “fb”
[ 37349.160] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 37349.160] (II) Module fb: vendor=“X.Org Foundation”
[ 37349.160] compiled for 1.16.4, module version = 1.0.0
[ 37349.160] ABI class: X.Org ANSI C Emulation, version 0.4
[ 37349.160] (II) Loading sub module “ramdac”
[ 37349.160] (II) LoadModule: “ramdac”
[ 37349.160] (II) Module “ramdac” already built-in
[ 37349.160] (II) UnloadModule: “modesetting”
[ 37349.160] (II) Unloading modesetting
[ 37349.160] (II) UnloadModule: “fbdev”
[ 37349.160] (II) Unloading fbdev
[ 37349.160] (II) UnloadSubModule: “fbdevhw”
[ 37349.160] (II) Unloading fbdevhw
[ 37349.160] (II) UnloadModule: “vesa”
[ 37349.160] (II) Unloading vesa
[ 37349.160] (==) Depth 24 pixmap format is 32 bpp
[ 37349.160] (II) RADEON(G0): [DRI2] Setup complete
[ 37349.160] (II) RADEON(G0): [DRI2] DRI driver: radeonsi
[ 37349.160] (II) RADEON(G0): [DRI2] VDPAU driver: radeonsi
[ 37349.160] (II) RADEON(G0): Front buffer size: 3072K
[ 37349.160] (II) RADEON(G0): VRAM usage limit set to 937929K
[ 37349.160] (==) RADEON(G0): Backing store enabled
[ 37349.160] (II) RADEON(G0): Direct rendering enabled
[ 37349.212] (II) RADEON(G0): Use GLAMOR acceleration.
[ 37349.212] (II) RADEON(G0): Acceleration enabled
[ 37349.212] (==) RADEON(G0): DPMS enabled
[ 37349.212] (==) RADEON(G0): Silken mouse enabled
[ 37349.214] (II) RADEON(G0): Set up textured video (glamor)
[ 37349.214] (II) RADEON(G0): [XvMC] Associated with GLAMOR Textured Video.
[ 37349.214] (II) RADEON(G0): [XvMC] Extension initialized.
[ 37349.214] (II) RADEON(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 37349.214] (II) intel(0): [DRI2] Setup complete
[ 37349.214] (II) intel(0): [DRI2] DRI driver: i965
[ 37349.214] (II) intel(0): Allocated new frame buffer 1408x768 stride 5632, tiled
[ 37349.215] (II) UXA(0): Driver registered support for the following operations:
[ 37349.215] (II) solid
[ 37349.215] (II) copy
[ 37349.215] (II) composite (RENDER acceleration)
[ 37349.215] (II) put_image
[ 37349.215] (II) get_image
[ 37349.215] (==) intel(0): Backing store enabled
[ 37349.215] (==) intel(0): Silken mouse enabled
[ 37349.215] (II) intel(0): Initializing HW Cursor
[ 37349.215] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 37349.215] (==) intel(0): DPMS enabled
[ 37349.215] (==) intel(0): Intel XvMC decoder enabled
[ 37349.215] (II) intel(0): Set up textured video
[ 37349.215] (II) intel(0): [XvMC] xvmc_vld driver initialized.
[ 37349.215] (II) intel(0): direct rendering: DRI2 Enabled
[ 37349.215] (==) intel(0): hotplug detection: “enabled”
[ 37349.236] (–) RandR disabled
[ 37349.239] (II) SELinux: Disabled on system
[ 37349.247] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 37349.247] (II) AIGLX: enabled GLX_ARB_create_context
[ 37349.247] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 37349.247] (II) AIGLX: enabled GLX_EXT_create_context_es2_profile
[ 37349.247] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 37349.247] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 37349.247] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[ 37349.247] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[ 37349.247] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 37349.247] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[ 37349.247] (II) AIGLX: Loaded and initialized i965
[ 37349.247] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 37349.255] (II) intel(0): Setting screen physical size to 361 x 203
[ 37349.274] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 37349.274] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 37349.274] (II) LoadModule: “evdev”
[ 37349.275] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 37349.275] (II) Module evdev: vendor=“X.Org Foundation”
[ 37349.275] compiled for 1.16.0, module version = 2.9.0
[ 37349.275] Module class: X.Org XInput Driver
[ 37349.275] ABI class: X.Org XInput driver, version 21.0
[ 37349.275] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 37349.275] () Power Button: always reports core events
[ 37349.275] () evdev: Power Button: Device: “/dev/input/event3”
[ 37349.275] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 37349.275] (–) evdev: Power Button: Found keys
[ 37349.275] (II) evdev: Power Button: Configuring as keyboard
[ 37349.275] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input7/event3”
[ 37349.275] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 37349.275] () Option “xkb_rules” “evdev”
[ 37349.275] () Option “xkb_model” “pc105”
[ 37349.275] () Option “xkb_layout” “es”
[ 37349.286] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[ 37349.286] () Video Bus: Applying InputClass “evdev keyboard catchall”
[ 37349.286] (II) Using input driver ‘evdev’ for ‘Video Bus’
[ 37349.286] () Video Bus: always reports core events
[ 37349.286] () evdev: Video Bus: Device: “/dev/input/event11”
[ 37349.286] (–) evdev: Video Bus: Vendor 0 Product 0x6
[ 37349.286] (–) evdev: Video Bus: Found keys
[ 37349.286] (II) evdev: Video Bus: Configuring as keyboard
[ 37349.286] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input17/event11”
[ 37349.286] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 7)
[ 37349.286] () Option “xkb_rules” “evdev”
[ 37349.286] () Option “xkb_model” “pc105”
[ 37349.286] () Option “xkb_layout” “es”
[ 37349.287] (II) config/udev: Adding input device Video Bus (/dev/input/event12)
[ 37349.287] () Video Bus: Applying InputClass “evdev keyboard catchall”
[ 37349.287] (II) Using input driver ‘evdev’ for ‘Video Bus’
[ 37349.287] () Video Bus: always reports core events
[ 37349.287] () evdev: Video Bus: Device: “/dev/input/event12”
[ 37349.287] (–) evdev: Video Bus: Vendor 0 Product 0x6
[ 37349.287] (–) evdev: Video Bus: Found keys
[ 37349.287] (II) evdev: Video Bus: Configuring as keyboard
[ 37349.287] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3f/LNXVIDEO:01/input/input18/event12”
[ 37349.287] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 8)
[ 37349.287] () Option “xkb_rules” “evdev”
[ 37349.287] () Option “xkb_model” “pc105”
[ 37349.287] () Option “xkb_layout” “es”
[ 37349.287] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[ 37349.287] (II) No input driver specified, ignoring this device.
[ 37349.287] (II) This device may have been added with another device file.
[ 37349.287] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 37349.287] () Sleep Button: Applying InputClass “evdev keyboard catchall”
[ 37349.287] (II) Using input driver ‘evdev’ for ‘Sleep Button’
[ 37349.287] () Sleep Button: always reports core events
[ 37349.287] () evdev: Sleep Button: Device: “/dev/input/event1”
[ 37349.287] (–) evdev: Sleep Button: Vendor 0 Product 0x3
[ 37349.287] (–) evdev: Sleep Button: Found keys
[ 37349.287] (II) evdev: Sleep Button: Configuring as keyboard
[ 37349.287] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5/event1”
[ 37349.287] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 9)
[ 37349.288] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event15)
[ 37349.288] (II) No input driver specified, ignoring this device.
[ 37349.288] (II) This device may have been added with another device file.
[ 37349.288] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event16)
[ 37349.288] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event17)
[ 37349.288] (II) config/udev: Adding input device Genius Wireless Mouse (/dev/input/event9)
[ 37349.288] () Genius Wireless Mouse: Applying InputClass “evdev pointer catchall”
[ 37349.288] () Genius Wireless Mouse: Applying InputClass “evdev keyboard catchall”
[ 37349.288] (II) Using input driver ‘evdev’ for ‘Genius Wireless Mouse’
[ 37349.288] () Genius Wireless Mouse: always reports core events
[ 37349.288] () evdev: Genius Wireless Mouse: Device: “/dev/input/event9”
[ 37349.288] (–) evdev: Genius Wireless Mouse: Vendor 0x458 Product 0x154
[ 37349.288] (–) evdev: Genius Wireless Mouse: Found 12 mouse buttons
[ 37349.288] (–) evdev: Genius Wireless Mouse: Found scroll wheel(s)
[ 37349.288] (–) evdev: Genius Wireless Mouse: Found relative axes
[ 37349.288] (–) evdev: Genius Wireless Mouse: Found x and y relative axes
[ 37349.288] (–) evdev: Genius Wireless Mouse: Found keys
[ 37349.288] (II) evdev: Genius Wireless Mouse: Configuring as mouse
[ 37349.288] (II) evdev: Genius Wireless Mouse: Configuring as keyboard
[ 37349.288] (II) evdev: Genius Wireless Mouse: Adding scrollwheel support
[ 37349.288] () evdev: Genius Wireless Mouse: YAxisMapping: buttons 4 and 5
[ 37349.288] () evdev: Genius Wireless Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 37349.288] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3.3/2-3.3:1.0/0003:0458:0154.0001/input/input15/event9”
[ 37349.288] (II) XINPUT: Adding extended input device “Genius Wireless Mouse” (type: KEYBOARD, id 10)
[ 37349.288] () Option “xkb_rules” “evdev”
[ 37349.288] () Option “xkb_model” “pc105”
[ 37349.288] () Option “xkb_layout” “es”
[ 37349.288] (II) evdev: Genius Wireless Mouse: initialized for relative axes.
[ 37349.288] () Genius Wireless Mouse: (accel) keeping acceleration scheme 1
[ 37349.288] () Genius Wireless Mouse: (accel) acceleration profile 0
[ 37349.288] () Genius Wireless Mouse: (accel) acceleration factor: 2.000
[ 37349.288] () Genius Wireless Mouse: (accel) acceleration threshold: 4
[ 37349.289] (II) config/udev: Adding input device Genius Wireless Mouse (/dev/input/mouse1)
[ 37349.289] (II) No input driver specified, ignoring this device.
[ 37349.289] (II) This device may have been added with another device file.
[ 37349.289] (II) config/udev: Adding input device Genius Wireless Mouse (/dev/input/event24)
[ 37349.289] (II) config/udev: Adding input device HP HD Webcam (/dev/input/event7)
[ 37349.289] () HP HD Webcam: Applying InputClass “evdev keyboard catchall”
[ 37349.289] (II) Using input driver ‘evdev’ for ‘HP HD Webcam’
[ 37349.289] () HP HD Webcam: always reports core events
[ 37349.289] () evdev: HP HD Webcam: Device: “/dev/input/event7”
[ 37349.289] (–) evdev: HP HD Webcam: Vendor 0x4ca Product 0x7034
[ 37349.289] (–) evdev: HP HD Webcam: Found keys
[ 37349.289] (II) evdev: HP HD Webcam: Configuring as keyboard
[ 37349.289] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.0/input/input13/event7”
[ 37349.289] (II) XINPUT: Adding extended input device “HP HD Webcam” (type: KEYBOARD, id 11)
[ 37349.289] () Option “xkb_rules” “evdev”
[ 37349.289] () Option “xkb_model” “pc105”
[ 37349.289] () Option “xkb_layout” “es”
[ 37349.289] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event19)
[ 37349.289] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event20)
[ 37349.289] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event21)
[ 37349.290] (II) config/udev: Adding input device HDA Intel PCH Dock Line Out (/dev/input/event22)
[ 37349.290] (II) No input driver specified, ignoring this device.
[ 37349.290] (II) This device may have been added with another device file.
[ 37349.290] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event23)
[ 37349.290] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event13)
[ 37349.290] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event14)
[ 37349.290] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 37349.290] () AT Translated Set 2 keyboard: Applying InputClass “evdev keyboard catchall”
[ 37349.290] (II) Using input driver ‘evdev’ for ‘AT Translated Set 2 keyboard’
[ 37349.290] () AT Translated Set 2 keyboard: always reports core events
[ 37349.290] () evdev: AT Translated Set 2 keyboard: Device: “/dev/input/event0”
[ 37349.290] (–) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 37349.290] (–) evdev: AT Translated Set 2 keyboard: Found keys
[ 37349.290] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 37349.290] () Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input0/event0”
[ 37349.290] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 12)
[ 37349.290] () Option “xkb_rules” “evdev”
[ 37349.290] () Option “xkb_model” “pc105”
[ 37349.290] () Option “xkb_layout” “es”
[ 37349.290] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/event8)
[ 37349.290] () PS/2 Generic Mouse: Applying InputClass “evdev pointer catchall”
[ 37349.290] (II) Using input driver ‘evdev’ for ‘PS/2 Generic Mouse’
[ 37349.290] () PS/2 Generic Mouse: always reports core events
[ 37349.290] () evdev: PS/2 Generic Mouse: Device: “/dev/input/event8”
[ 37349.290] (–) evdev: PS/2 Generic Mouse: Vendor 0x2 Product 0x1
[ 37349.290] (–) evdev: PS/2 Generic Mouse: Found 3 mouse buttons
[ 37349.290] (–) evdev: PS/2 Generic Mouse: Found relative axes
[ 37349.291] (–) evdev: PS/2 Generic Mouse: Found x and y relative axes
[ 37349.291] (II) evdev: PS/2 Generic Mouse: Configuring as mouse
[ 37349.291] () evdev: PS/2 Generic Mouse: YAxisMapping: buttons 4 and 5
[ 37349.291] () evdev: PS/2 Generic Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 37349.291] () Option “config_info” “udev:/sys/devices/platform/i8042/serio2/input/input10/event8”
[ 37349.291] (II) XINPUT: Adding extended input device “PS/2 Generic Mouse” (type: MOUSE, id 13)
[ 37349.291] (II) evdev: PS/2 Generic Mouse: initialized for relative axes.
[ 37349.291] () PS/2 Generic Mouse: (accel) keeping acceleration scheme 1
[ 37349.291] () PS/2 Generic Mouse: (accel) acceleration profile 0
[ 37349.291] () PS/2 Generic Mouse: (accel) acceleration factor: 2.000
[ 37349.291] () PS/2 Generic Mouse: (accel) acceleration threshold: 4
[ 37349.291] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/mouse0)
[ 37349.291] (II) No input driver specified, ignoring this device.
[ 37349.291] (II) This device may have been added with another device file.
[ 37349.291] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event18)
[ 37349.291] () SynPS/2 Synaptics TouchPad: Applying InputClass “evdev touchpad catchall”
[ 37349.291] () SynPS/2 Synaptics TouchPad: Applying InputClass “touchpad catchall”
[ 37349.291] () SynPS/2 Synaptics TouchPad: Applying InputClass “Default clickpad buttons”
[ 37349.291] (II) LoadModule: “synaptics”
[ 37349.291] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 37349.291] (II) Module synaptics: vendor=“X.Org Foundation”
[ 37349.291] compiled for 1.16.0.901, module version = 1.8.99
[ 37349.291] Module class: X.Org XInput Driver
[ 37349.291] ABI class: X.Org XInput driver, version 21.0
[ 37349.291] (II) Using input driver ‘synaptics’ for ‘SynPS/2 Synaptics TouchPad’
[ 37349.291] () SynPS/2 Synaptics TouchPad: always reports core events
[ 37349.291] () Option “Device” “/dev/input/event18”
[ 37349.332] (–) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5658 (res 41)
[ 37349.332] (–) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4706 (res 57)
[ 37349.332] (–) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[ 37349.332] (–) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[ 37349.332] (–) synaptics: SynPS/2 Synaptics TouchPad: buttons: left right double triple
[ 37349.332] (–) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[ 37349.332] (–) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 37349.332] () SynPS/2 Synaptics TouchPad: always reports core events
[ 37349.378] () Option “config_info” “udev:/sys/devices/platform/i8042/serio3/input/input14/event18”
[ 37349.378] (II) XINPUT: Adding extended input device “SynPS/2 Synaptics TouchPad” (type: TOUCHPAD, id 14)
[ 37349.378] () synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[ 37349.378] () synaptics: SynPS/2 Synaptics TouchPad: (accel) MaxSpeed is now 1.75
[ 37349.378] () synaptics: SynPS/2 Synaptics TouchPad: (accel) AccelFactor is now 0.038
[ 37349.378] () SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[ 37349.378] () SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[ 37349.378] () SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 37349.378] () SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 37349.378] (–) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 37349.378] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse2)
[ 37349.378] () SynPS/2 Synaptics TouchPad: Ignoring device from InputClass “touchpad ignore duplicates”
[ 37349.378] (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/event10)
[ 37349.378] (II) No input driver specified, ignoring this device.
[ 37349.378] (II) This device may have been added with another device file.
[ 37349.378] (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/js0)
[ 37349.378] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 37349.379] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event6)
[ 37349.379] () HP WMI hotkeys: Applying InputClass “evdev keyboard catchall”
[ 37349.379] (II) Using input driver ‘evdev’ for ‘HP WMI hotkeys’
[ 37349.379] () HP WMI hotkeys: always reports core events
[ 37349.379] () evdev: HP WMI hotkeys: Device: “/dev/input/event6”
[ 37349.379] (–) evdev: HP WMI hotkeys: Vendor 0 Product 0
[ 37349.379] (–) evdev: HP WMI hotkeys: Found keys
[ 37349.379] (II) evdev: HP WMI hotkeys: Configuring as keyboard
[ 37349.379] () Option “config_info” “udev:/sys/devices/virtual/input/input12/event6”
[ 37349.379] (II) XINPUT: Adding extended input device “HP WMI hotkeys” (type: KEYBOARD, id 15)
[ 37349.379] () Option “xkb_rules” “evdev”
[ 37349.379] () Option “xkb_model” “pc105”
[ 37349.379] () Option “xkb_layout” “es”
[ 37349.379] (II) config/udev: Adding input device HP Wireless hotkeys (/dev/input/event4)
[ 37349.379] () HP Wireless hotkeys: Applying InputClass “evdev keyboard catchall”
[ 37349.379] (II) Using input driver ‘evdev’ for ‘HP Wireless hotkeys’
[ 37349.379] () HP Wireless hotkeys: always reports core events
[ 37349.379] () evdev: HP Wireless hotkeys: Device: “/dev/input/event4”
[ 37349.379] (–) evdev: HP Wireless hotkeys: Vendor 0 Product 0
[ 37349.379] (–) evdev: HP Wireless hotkeys: Found keys
[ 37349.379] (II) evdev: HP Wireless hotkeys: Configuring as keyboard
[ 37349.379] () Option “config_info” “udev:/sys/devices/virtual/input/input8/event4”
[ 37349.379] (II) XINPUT: Adding extended input device “HP Wireless hotkeys” (type: KEYBOARD, id 16)
[ 37349.756] (II) evdev: HP Wireless hotkeys: Close
[ 37349.756] (II) UnloadModule: “evdev”
[ 37349.756] (II) evdev: HP WMI hotkeys: Close
[ 37349.756] (II) UnloadModule: “synaptics”
[ 37349.756] (II) evdev: PS/2 Generic Mouse: Close
[ 37349.756] (II) evdev: AT Translated Set 2 keyboard: Close
[ 37349.756] (II) evdev: HP HD Webcam: Close
[ 37349.756] (II) evdev: Genius Wireless Mouse: Close
[ 37349.756] (II) evdev: Sleep Button: Close
[ 37349.756] (II) evdev: Video Bus: Close
[ 37349.757] (II) evdev: Power Button: Close
[ 37349.757] (II) UnloadModule: “evdev”
[ 37350.829] (EE) Server terminated successfully (0). Closing log file.
