essaies peut-être de voir du coté du paquet oinkmaster…
[quote]Snort rules manager
A simple script to manage and update Snort rules with the
capability of disabling, modifying and enabling specific
rules after an update. Oinkmaster will tell you exactly what
has changed since your last update, giving you good
control of your rules. It also can be used to manage updates
from both the official provider (snort.org) and from
home-grown rulesets.
Homepage: oinkmaster.sourceforge.net/[/quote]
par contre je ne pourrai pas t’en dire plus vu que je n’utilise pas Snort
