J’ai un problème avec update-notifier depuis un moment, lorsqu’il y a des mises à jour à faire, je clique, je rentre mon mot de passe, il cherche les dépendances, et la fenêtre se ferme toute seule.
Perso, c’est pas trop grave aptitude upgrade fonctionne mais ça ennuie ma femme…
voilà ce que raconte la console :
[code]** (gksu:11044): WARNING **: couldn’t communicate with gnome keyring daemon via dbus: The name org.gnome.keyring was not provided by any .service files
/usr/lib/python2.4/site-packages/apt/init.py:17: FutureWarning: apt API not stable yet
warnings.warn(“apt API not stable yet”, FutureWarning)
/var/lib/python-support/python2.4/UpdateManager/GtkProgress.py:67: GtkWarning: Failed to set text from markup due to error parsing markup: Error on line 1 char 41: Invalid UTF-8 encoded text
self._status.set_markup("%s" % self.op)
current dist not found in meta-release file
Traceback (most recent call last):
File “/usr/bin/update-manager”, line 71, in ?
app.main(options)
File “/var/lib/python-support/python2.4/UpdateManager/UpdateManager.py”, line 759, in main
self.fillstore()
File “/var/lib/python-support/python2.4/UpdateManager/UpdateManager.py”, line 613, in fillstore
self.list.update(self.cache)
File “/var/lib/python-support/python2.4/UpdateManager/UpdateManager.py”, line 204, in update
cache.saveDistUpgrade()
File “/var/lib/python-support/python2.4/UpdateManager/UpdateManager.py”, line 97, in saveDistUpgrade
self.clean()
File “/var/lib/python-support/python2.4/UpdateManager/UpdateManager.py”, line 87, in clean
action_group = apt_pkg.GetPkgActionGroup(self._depcache)
AttributeError: ‘module’ object has no attribute ‘GetPkgActionGroup’
Ça à l’air d’être un pbm de python et comme j’y connais rien…
Une solution ??
Thanks
