Je viens d’essayer lm-sensors, mais sensors-detect ne trouve aucun capteur.
[code]# sensors-detect
sensors-detect revision 5249 (2008-05-11 22:56:25 +0200)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you’re doing.
We can start with probing for (PCI) I2C or SMBus adapters.
Do you want to probe now? (YES/no):
Probing for PCI bus adapters…
Sorry, no supported PCI bus adapters found.
If you have undetectable or unsupported I2C/SMBus adapters, you can have
them scanned by manually loading the modules before running this script.
To continue, we need module i2c-dev' to be loaded. Do you want to loadi2c-dev’ now? (YES/no):
Module loaded successfully.
We are now going to do the I2C/SMBus adapter probings. Some chips may
be double detected; we choose the one with the highest confidence
value in that case.
If you found that the adapter hung after probing a certain address,
you can specify that address to remain unprobed.
Some chips are also accessible through the ISA I/O ports. We have to
write to arbitrary I/O ports to probe them. This is usually safe though.
Yes, you do have ISA I/O ports even if you do not have any ISA slots!
Do you want to scan the ISA I/O ports? (YES/no): no
Some Super I/O chips may also contain sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no): no
Some south bridges, CPUs or memory controllers may also contain
embedded sensors. Do you want to scan for them? (YES/no):
Silicon Integrated Systems SIS5595… No
VIA VT82C686 Integrated Sensors… No
VIA VT8231 Integrated Sensors… No
AMD K8 thermal sensors… No
AMD K10 thermal sensors… No
Intel Core family thermal sensor… No
Intel AMB FB-DIMM thermal sensor… No
Sorry, no sensors were detected.
Either your sensors are not supported, or they are connected to an
I2C or SMBus adapter that is not supported. See
http://www.lm-sensors.org/wiki/FAQ/Chapter3 for further information.
If you find out what chips are on your board, check
http://www.lm-sensors.org/wiki/Devices for driver status.[/code]
A noter que si je répond ‘oui’ aux questions 3 et 4 (‘Do you want to scan the ISA I/O ports?’ et ‘Do you want to scan for Super I/O sensors?’), j’ai droit à un kernel panic.
