Une piste ?
noyau 2.6.22
.config :
[code]
Automatically generated make config: don’t edit
Linux kernel version: 2.6.22
Fri Aug 10 11:17:49 2007
CONFIG_X86_32=y
CONFIG_GENERIC_TIME=y
CONFIG_CLOCKSOURCE_WATCHDOG=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_SEMAPHORE_SLEEPERS=y
CONFIG_X86=y
CONFIG_MMU=y
CONFIG_ZONE_DMA=y
CONFIG_QUICKLIST=y
CONFIG_GENERIC_ISA_DMA=y
CONFIG_GENERIC_IOMAP=y
CONFIG_GENERIC_BUG=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_ARCH_MAY_HAVE_PC_FDC=y
CONFIG_DMI=y
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
Code maturity level options
CONFIG_EXPERIMENTAL=y
CONFIG_BROKEN_ON_SMP=y
CONFIG_LOCK_KERNEL=y
CONFIG_INIT_ENV_ARG_LIMIT=32
General setup
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_IPC_NS is not set
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE is not set
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3 is not set
CONFIG_TASKSTATS is not set
CONFIG_UTS_NS is not set
CONFIG_AUDIT is not set
CONFIG_IKCONFIG is not set
CONFIG_LOG_BUF_SHIFT=14
CONFIG_SYSFS_DEPRECATED=y
CONFIG_RELAY is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_SYSCTL=y
CONFIG_EMBEDDED is not set
CONFIG_UID16=y
CONFIG_SYSCTL_SYSCALL=y
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_ALL is not set
CONFIG_KALLSYMS_EXTRA_PASS is not set
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_ANON_INODES=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLAB=y
CONFIG_SLUB is not set
CONFIG_SLOB is not set
CONFIG_RT_MUTEXES=y
CONFIG_TINY_SHMEM is not set
CONFIG_BASE_SMALL=0
Loadable module support
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_MODVERSIONS=y
CONFIG_MODULE_SRCVERSION_ALL is not set
CONFIG_KMOD=y
Block layer
CONFIG_BLOCK=y
CONFIG_LBD is not set
CONFIG_BLK_DEV_IO_TRACE is not set
CONFIG_LSF is not set
IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_AS=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
CONFIG_DEFAULT_AS is not set
CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED=“cfq”
Processor type and features
CONFIG_TICK_ONESHOT is not set
CONFIG_NO_HZ is not set
CONFIG_HIGH_RES_TIMERS is not set
CONFIG_SMP is not set
CONFIG_X86_PC=y
CONFIG_X86_ELAN is not set
CONFIG_X86_VOYAGER is not set
CONFIG_X86_NUMAQ is not set
CONFIG_X86_SUMMIT is not set
CONFIG_X86_BIGSMP is not set
CONFIG_X86_VISWS is not set
CONFIG_X86_GENERICARCH is not set
CONFIG_X86_ES7000 is not set
CONFIG_PARAVIRT is not set
CONFIG_M386 is not set
CONFIG_M486 is not set
CONFIG_M586 is not set
CONFIG_M586TSC is not set
CONFIG_M586MMX is not set
CONFIG_M686 is not set
CONFIG_MPENTIUMII is not set
CONFIG_MPENTIUMIII=y
CONFIG_MPENTIUMM is not set
CONFIG_MCORE2 is not set
CONFIG_MPENTIUM4 is not set
CONFIG_MK6 is not set
CONFIG_MK7 is not set
CONFIG_MK8 is not set
CONFIG_MCRUSOE is not set
CONFIG_MEFFICEON is not set
CONFIG_MWINCHIPC6 is not set
CONFIG_MWINCHIP2 is not set
CONFIG_MWINCHIP3D is not set
CONFIG_MGEODEGX1 is not set
CONFIG_MGEODE_LX is not set
CONFIG_MCYRIXIII is not set
CONFIG_MVIAC3_2 is not set
CONFIG_MVIAC7 is not set
CONFIG_X86_GENERIC is not set
CONFIG_X86_CMPXCHG=y
CONFIG_X86_L1_CACHE_SHIFT=5
CONFIG_X86_XADD=y
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_ARCH_HAS_ILOG2_U32 is not set
CONFIG_ARCH_HAS_ILOG2_U64 is not set
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_X86_WP_WORKS_OK=y
CONFIG_X86_INVLPG=y
CONFIG_X86_BSWAP=y
CONFIG_X86_POPAD_OK=y
CONFIG_X86_GOOD_APIC=y
CONFIG_X86_INTEL_USERCOPY=y
CONFIG_X86_USE_PPRO_CHECKSUM=y
CONFIG_X86_TSC=y
CONFIG_X86_CMOV=y
CONFIG_X86_MINIMUM_CPU_MODEL=4
CONFIG_HPET_TIMER=y
CONFIG_PREEMPT_NONE is not set
CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
CONFIG_PREEMPT_BKL=y
CONFIG_X86_UP_APIC=y
CONFIG_X86_UP_IOAPIC=y
CONFIG_X86_LOCAL_APIC=y
CONFIG_X86_IO_APIC=y
CONFIG_X86_MCE=y
CONFIG_X86_MCE_NONFATAL=y
CONFIG_X86_MCE_P4THERMAL is not set
CONFIG_VM86=y
CONFIG_TOSHIBA is not set
CONFIG_I8K is not set
CONFIG_X86_REBOOTFIXUPS is not set
CONFIG_MICROCODE=m
CONFIG_MICROCODE_OLD_INTERFACE=y
CONFIG_X86_MSR=m
CONFIG_X86_CPUID=m
Firmware Drivers
CONFIG_EDD is not set
CONFIG_DELL_RBU is not set
CONFIG_DCDBAS is not set
CONFIG_NOHIGHMEM=y
CONFIG_HIGHMEM4G is not set
CONFIG_HIGHMEM64G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_ARCH_FLATMEM_ENABLE=y
CONFIG_ARCH_SPARSEMEM_ENABLE=y
CONFIG_ARCH_SELECT_MEMORY_MODEL=y
CONFIG_ARCH_POPULATES_NODE_MAP=y
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
CONFIG_DISCONTIGMEM_MANUAL is not set
CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_SPARSEMEM_STATIC=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_RESOURCES_64BIT is not set
CONFIG_ZONE_DMA_FLAG=1
CONFIG_NR_QUICK=1
CONFIG_MATH_EMULATION is not set
CONFIG_MTRR=y
CONFIG_SECCOMP=y
CONFIG_HZ_100 is not set
CONFIG_HZ_250=y
CONFIG_HZ_300 is not set
CONFIG_HZ_1000 is not set
CONFIG_HZ=250
CONFIG_KEXEC is not set
CONFIG_PHYSICAL_START=0x100000
CONFIG_RELOCATABLE is not set
CONFIG_PHYSICAL_ALIGN=0x100000
CONFIG_COMPAT_VDSO=y
Power management options (ACPI, APM)
CONFIG_PM=y
CONFIG_PM_LEGACY is not set
CONFIG_PM_DEBUG is not set
CONFIG_PM_SYSFS_DEPRECATED is not set
CONFIG_SOFTWARE_SUSPEND=y
CONFIG_PM_STD_PARTITION="/dev/hda5"
ACPI (Advanced Configuration and Power Interface) Support
CONFIG_ACPI is not set
CONFIG_APM=y
CONFIG_APM_IGNORE_USER_SUSPEND=y
CONFIG_APM_DO_ENABLE=y
CONFIG_APM_CPU_IDLE=y
CONFIG_APM_DISPLAY_BLANK=y
CONFIG_APM_ALLOW_INTS=y
CONFIG_APM_REAL_MODE_POWER_OFF=y
CPU Frequency scaling
CONFIG_CPU_FREQ is not set
Bus options (PCI, PCMCIA, EISA, MCA, ISA)
CONFIG_PCI=y
CONFIG_PCI_GOBIOS is not set
CONFIG_PCI_GOMMCONFIG is not set
CONFIG_PCI_GODIRECT is not set
CONFIG_PCI_GOANY=y
CONFIG_PCI_BIOS=y
CONFIG_PCI_DIRECT=y
CONFIG_PCIEPORTBUS is not set
CONFIG_ARCH_SUPPORTS_MSI=y
CONFIG_PCI_MSI is not set
CONFIG_PCI_DEBUG is not set
CONFIG_HT_IRQ=y
CONFIG_ISA_DMA_API=y
CONFIG_ISA is not set
CONFIG_MCA is not set
CONFIG_SCx200 is not set
PCCARD (PCMCIA/CardBus) support
CONFIG_PCCARD=m
CONFIG_PCMCIA_DEBUG is not set
CONFIG_PCMCIA=m
CONFIG_PCMCIA_LOAD_CIS is not set
CONFIG_PCMCIA_IOCTL is not set
CONFIG_CARDBUS=y
PC-card bridges
CONFIG_YENTA=m
CONFIG_YENTA_O2=y
CONFIG_YENTA_RICOH=y
CONFIG_YENTA_TI=y
CONFIG_YENTA_ENE_TUNE=y
CONFIG_YENTA_TOSHIBA=y
CONFIG_PD6729 is not set
CONFIG_I82092 is not set
CONFIG_PCCARD_NONSTATIC=m
CONFIG_HOTPLUG_PCI is not set
Executable file formats
CONFIG_BINFMT_ELF=y
CONFIG_BINFMT_AOUT is not set
CONFIG_BINFMT_MISC is not set
Networking
CONFIG_NET=y
Networking options
CONFIG_PACKET=m
CONFIG_PACKET_MMAP=y
CONFIG_UNIX=m
CONFIG_XFRM=y
CONFIG_XFRM_USER=m
CONFIG_XFRM_SUB_POLICY is not set
CONFIG_XFRM_MIGRATE is not set
CONFIG_NET_KEY=m
CONFIG_NET_KEY_MIGRATE is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_ASK_IP_FIB_HASH=y
CONFIG_IP_FIB_TRIE is not set
CONFIG_IP_FIB_HASH=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_MULTIPATH_CACHED is not set
CONFIG_IP_ROUTE_VERBOSE=y
CONFIG_IP_PNP is not set
CONFIG_NET_IPIP=m
CONFIG_NET_IPGRE=m
CONFIG_NET_IPGRE_BROADCAST=y
CONFIG_IP_MROUTE=y
CONFIG_IP_PIMSM_V1=y
CONFIG_IP_PIMSM_V2=y
CONFIG_ARPD is not set
CONFIG_SYN_COOKIES=y
CONFIG_INET_AH=m
CONFIG_INET_ESP=m
CONFIG_INET_IPCOMP=m
CONFIG_INET_XFRM_TUNNEL=m
CONFIG_INET_TUNNEL=m
CONFIG_INET_XFRM_MODE_TRANSPORT=y
CONFIG_INET_XFRM_MODE_TUNNEL=y
CONFIG_INET_XFRM_MODE_BEET=y
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG=“cubic”
CONFIG_TCP_MD5SIG is not set
CONFIG_IP_VS is not set
CONFIG_IPV6 is not set
CONFIG_INET6_XFRM_TUNNEL is not set
CONFIG_INET6_TUNNEL is not set
CONFIG_NETWORK_SECMARK is not set
CONFIG_NETFILTER=y
CONFIG_NETFILTER_DEBUG is not set
CONFIG_BRIDGE_NETFILTER is not set
Core Netfilter Configuration
CONFIG_NETFILTER_NETLINK is not set
CONFIG_NF_CONNTRACK_ENABLED is not set
CONFIG_NF_CONNTRACK is not set
CONFIG_NETFILTER_XTABLES=m
CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set
CONFIG_NETFILTER_XT_TARGET_MARK is not set
CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set
CONFIG_NETFILTER_XT_TARGET_NFLOG is not set
CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set
CONFIG_NETFILTER_XT_MATCH_COMMENT is not set
CONFIG_NETFILTER_XT_MATCH_DCCP is not set
CONFIG_NETFILTER_XT_MATCH_DSCP is not set
CONFIG_NETFILTER_XT_MATCH_ESP is not set
CONFIG_NETFILTER_XT_MATCH_LENGTH is not set
CONFIG_NETFILTER_XT_MATCH_LIMIT is not set
CONFIG_NETFILTER_XT_MATCH_MAC is not set
CONFIG_NETFILTER_XT_MATCH_MARK is not set
CONFIG_NETFILTER_XT_MATCH_POLICY is not set
CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set
CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set
CONFIG_NETFILTER_XT_MATCH_QUOTA is not set
CONFIG_NETFILTER_XT_MATCH_REALM is not set
CONFIG_NETFILTER_XT_MATCH_SCTP is not set
CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set
CONFIG_NETFILTER_XT_MATCH_STRING is not set
CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set
IP: Netfilter Configuration
CONFIG_IP_NF_QUEUE is not set
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_IPRANGE=m
CONFIG_IP_NF_MATCH_TOS=m
CONFIG_IP_NF_MATCH_RECENT=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_AH is not set
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_MATCH_OWNER=m
CONFIG_IP_NF_MATCH_ADDRTYPE is not set
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_TARGET_LOG=m
CONFIG_IP_NF_TARGET_ULOG=m
CONFIG_IP_NF_MANGLE is not set
CONFIG_IP_NF_RAW is not set
CONFIG_IP_NF_ARPTABLES is not set
Bridge: Netfilter Configuration
CONFIG_BRIDGE_NF_EBTABLES is not set
CONFIG_IP_DCCP is not set
CONFIG_IP_SCTP is not set
CONFIG_TIPC is not set
CONFIG_ATM=m
CONFIG_ATM_CLIP is not set
CONFIG_ATM_LANE is not set
CONFIG_ATM_BR2684=m
CONFIG_ATM_BR2684_IPFILTER is not set
CONFIG_BRIDGE=m
CONFIG_VLAN_8021Q is not set
CONFIG_DECNET is not set
CONFIG_LLC=m
CONFIG_LLC2 is not set
CONFIG_IPX is not set
CONFIG_ATALK is not set
CONFIG_X25 is not set
CONFIG_LAPB is not set
CONFIG_ECONET is not set
CONFIG_WAN_ROUTER is not set
QoS and/or fair queueing
CONFIG_NET_SCHED is not set
CONFIG_NET_SCH_FIFO=y
Network testing
CONFIG_NET_PKTGEN is not set
CONFIG_HAMRADIO is not set
CONFIG_IRDA is not set
CONFIG_BT is not set
CONFIG_AF_RXRPC is not set
CONFIG_FIB_RULES=y
Wireless
CONFIG_CFG80211=m
CONFIG_WIRELESS_EXT=y
CONFIG_MAC80211=m
CONFIG_MAC80211_DEBUG is not set
CONFIG_IEEE80211=m
CONFIG_IEEE80211_DEBUG is not set
CONFIG_IEEE80211_CRYPT_WEP=m
CONFIG_IEEE80211_CRYPT_CCMP is not set
CONFIG_IEEE80211_CRYPT_TKIP=m
CONFIG_IEEE80211_SOFTMAC is not set
CONFIG_RFKILL is not set
Device Drivers
Generic Driver Options
CONFIG_STANDALONE is not set
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
CONFIG_DEBUG_DRIVER is not set
CONFIG_DEBUG_DEVRES is not set
CONFIG_SYS_HYPERVISOR is not set
Connector - unified userspace <-> kernelspace linker
CONFIG_CONNECTOR is not set
CONFIG_MTD is not set
Parallel port support
CONFIG_PARPORT=m
CONFIG_PARPORT_PC=m
CONFIG_PARPORT_SERIAL is not set
CONFIG_PARPORT_PC_FIFO is not set
CONFIG_PARPORT_PC_SUPERIO is not set
CONFIG_PARPORT_PC_PCMCIA is not set
CONFIG_PARPORT_GSC is not set
CONFIG_PARPORT_AX88796 is not set
CONFIG_PARPORT_1284 is not set
Plug and Play support
CONFIG_PNPACPI is not set
Block devices
CONFIG_BLK_DEV_FD=m
CONFIG_PARIDE is not set
CONFIG_BLK_CPQ_DA is not set
CONFIG_BLK_CPQ_CISS_DA is not set
CONFIG_BLK_DEV_DAC960 is not set
CONFIG_BLK_DEV_UMEM is not set
CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=m
CONFIG_BLK_DEV_CRYPTOLOOP is not set
CONFIG_BLK_DEV_NBD is not set
CONFIG_BLK_DEV_SX8 is not set
CONFIG_BLK_DEV_UB is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=4096
CONFIG_BLK_DEV_RAM_BLOCKSIZE=1024
CONFIG_CDROM_PKTCDVD is not set
CONFIG_ATA_OVER_ETH is not set
Misc devices
CONFIG_IBM_ASM is not set
CONFIG_PHANTOM is not set
CONFIG_SGI_IOC4 is not set
CONFIG_TIFM_CORE is not set
CONFIG_IDE=y
CONFIG_BLK_DEV_IDE=y
Please see Documentation/ide.txt for help/info on IDE drives
CONFIG_BLK_DEV_IDE_SATA is not set
CONFIG_BLK_DEV_HD_IDE is not set
CONFIG_BLK_DEV_IDEDISK=y
CONFIG_IDEDISK_MULTI_MODE=y
CONFIG_BLK_DEV_IDECS is not set
CONFIG_BLK_DEV_DELKIN is not set
CONFIG_BLK_DEV_IDECD=m
CONFIG_BLK_DEV_IDETAPE is not set
CONFIG_BLK_DEV_IDEFLOPPY is not set
CONFIG_BLK_DEV_IDESCSI is not set
CONFIG_IDE_TASK_IOCTL is not set
CONFIG_IDE_PROC_FS=y
IDE chipset support/bugfixes
CONFIG_IDE_GENERIC=m
CONFIG_BLK_DEV_CMD640 is not set
CONFIG_BLK_DEV_IDEPCI=y
CONFIG_IDEPCI_SHARE_IRQ=y
CONFIG_IDEPCI_PCIBUS_ORDER=y
CONFIG_BLK_DEV_OFFBOARD is not set
CONFIG_BLK_DEV_GENERIC=m
CONFIG_BLK_DEV_OPTI621 is not set
CONFIG_BLK_DEV_RZ1000 is not set
CONFIG_BLK_DEV_IDEDMA_PCI=y
CONFIG_BLK_DEV_IDEDMA_FORCED is not set
CONFIG_IDEDMA_ONLYDISK is not set
CONFIG_BLK_DEV_AEC62XX is not set
CONFIG_BLK_DEV_ALI15X3 is not set
CONFIG_BLK_DEV_AMD74XX is not set
CONFIG_BLK_DEV_ATIIXP is not set
CONFIG_BLK_DEV_CMD64X is not set
CONFIG_BLK_DEV_TRIFLEX is not set
CONFIG_BLK_DEV_CY82C693 is not set
CONFIG_BLK_DEV_CS5520 is not set
CONFIG_BLK_DEV_CS5530 is not set
CONFIG_BLK_DEV_CS5535 is not set
CONFIG_BLK_DEV_HPT34X is not set
CONFIG_BLK_DEV_HPT366 is not set
CONFIG_BLK_DEV_JMICRON is not set
CONFIG_BLK_DEV_SC1200 is not set
CONFIG_BLK_DEV_PIIX=y
CONFIG_BLK_DEV_IT8213 is not set
CONFIG_BLK_DEV_IT821X is not set
CONFIG_BLK_DEV_NS87415 is not set
CONFIG_BLK_DEV_PDC202XX_OLD is not set
CONFIG_BLK_DEV_PDC202XX_NEW is not set
CONFIG_BLK_DEV_SVWKS is not set
CONFIG_BLK_DEV_SIIMAGE is not set
CONFIG_BLK_DEV_SIS5513 is not set
CONFIG_BLK_DEV_SLC90E66 is not set
CONFIG_BLK_DEV_TRM290 is not set
CONFIG_BLK_DEV_VIA82CXXX is not set
CONFIG_BLK_DEV_TC86C001 is not set
CONFIG_IDE_ARM is not set
CONFIG_BLK_DEV_IDEDMA=y
CONFIG_IDEDMA_IVB is not set
CONFIG_BLK_DEV_HD is not set
SCSI device support
CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=m
CONFIG_SCSI_TGT is not set
CONFIG_SCSI_NETLINK is not set
CONFIG_SCSI_PROC_FS=y
SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=m
CONFIG_CHR_DEV_ST is not set
CONFIG_CHR_DEV_OSST is not set
CONFIG_BLK_DEV_SR=m
CONFIG_BLK_DEV_SR_VENDOR is not set
CONFIG_CHR_DEV_SG=m
CONFIG_CHR_DEV_SCH is not set
Some SCSI devices (e.g. CD jukebox) support multiple LUNs
CONFIG_SCSI_MULTI_LUN is not set
CONFIG_SCSI_CONSTANTS is not set
CONFIG_SCSI_LOGGING is not set
CONFIG_SCSI_SCAN_ASYNC is not set
CONFIG_SCSI_WAIT_SCAN=m
SCSI Transports
CONFIG_SCSI_SPI_ATTRS is not set
CONFIG_SCSI_FC_ATTRS is not set
CONFIG_SCSI_ISCSI_ATTRS is not set
CONFIG_SCSI_SAS_ATTRS is not set
CONFIG_SCSI_SAS_LIBSAS is not set
SCSI low-level drivers
CONFIG_ISCSI_TCP is not set
CONFIG_BLK_DEV_3W_XXXX_RAID is not set
CONFIG_SCSI_3W_9XXX is not set
CONFIG_SCSI_ACARD is not set
CONFIG_SCSI_AACRAID is not set
CONFIG_SCSI_AIC7XXX is not set
CONFIG_SCSI_AIC7XXX_OLD is not set
CONFIG_SCSI_AIC79XX is not set
CONFIG_SCSI_AIC94XX is not set
CONFIG_SCSI_DPT_I2O is not set
CONFIG_SCSI_ADVANSYS is not set
CONFIG_SCSI_ARCMSR is not set
CONFIG_MEGARAID_NEWGEN is not set
CONFIG_MEGARAID_LEGACY is not set
CONFIG_MEGARAID_SAS is not set
CONFIG_SCSI_HPTIOP is not set
CONFIG_SCSI_BUSLOGIC is not set
CONFIG_SCSI_DMX3191D is not set
CONFIG_SCSI_EATA is not set
CONFIG_SCSI_FUTURE_DOMAIN is not set
CONFIG_SCSI_GDTH is not set
CONFIG_SCSI_IPS is not set
CONFIG_SCSI_INITIO is not set
CONFIG_SCSI_INIA100 is not set
CONFIG_SCSI_PPA is not set
CONFIG_SCSI_IMM is not set
CONFIG_SCSI_STEX is not set
CONFIG_SCSI_SYM53C8XX_2 is not set
CONFIG_SCSI_QLOGIC_1280 is not set
CONFIG_SCSI_QLA_FC is not set
CONFIG_SCSI_QLA_ISCSI is not set
CONFIG_SCSI_LPFC is not set
CONFIG_SCSI_DC395x is not set
CONFIG_SCSI_DC390T is not set
CONFIG_SCSI_NSP32 is not set
CONFIG_SCSI_DEBUG is not set
CONFIG_SCSI_SRP is not set
PCMCIA SCSI adapter support
CONFIG_PCMCIA_AHA152X is not set
CONFIG_PCMCIA_FDOMAIN is not set
CONFIG_PCMCIA_NINJA_SCSI is not set
CONFIG_PCMCIA_QLOGIC is not set
CONFIG_PCMCIA_SYM53C500 is not set
CONFIG_ATA is not set
Multi-device support (RAID and LVM)
CONFIG_MD is not set
Fusion MPT device support
CONFIG_FUSION is not set
CONFIG_FUSION_SPI is not set
CONFIG_FUSION_FC is not set
CONFIG_FUSION_SAS is not set
IEEE 1394 (FireWire) support
CONFIG_FIREWIRE is not set
CONFIG_IEEE1394 is not set
I2O device support
CONFIG_I2O is not set
CONFIG_MACINTOSH_DRIVERS is not set
Network device support
CONFIG_NETDEVICES=y
CONFIG_DUMMY is not set
CONFIG_BONDING is not set
CONFIG_EQUALIZER is not set
CONFIG_TUN=m
CONFIG_ARCNET is not set
CONFIG_PHYLIB is not set
Ethernet (10 or 100Mbit)
CONFIG_NET_ETHERNET=y
CONFIG_MII=m
CONFIG_HAPPYMEAL is not set
CONFIG_SUNGEM is not set
CONFIG_CASSINI is not set
CONFIG_NET_VENDOR_3COM is not set
Tulip family network device support
CONFIG_NET_TULIP is not set
CONFIG_HP100 is not set
CONFIG_NET_PCI=y
CONFIG_PCNET32 is not set
CONFIG_AMD8111_ETH is not set
CONFIG_ADAPTEC_STARFIRE is not set
CONFIG_B44 is not set
CONFIG_FORCEDETH is not set
CONFIG_DGRS is not set
CONFIG_EEPRO100=m
CONFIG_E100 is not set
CONFIG_FEALNX is not set
CONFIG_NATSEMI is not set
CONFIG_NE2K_PCI is not set
CONFIG_8139CP=m
CONFIG_8139TOO=m
CONFIG_8139TOO_PIO=y
CONFIG_8139TOO_TUNE_TWISTER is not set
CONFIG_8139TOO_8129 is not set
CONFIG_8139_OLD_RX_RESET is not set
CONFIG_SIS900 is not set
CONFIG_EPIC100 is not set
CONFIG_SUNDANCE is not set
CONFIG_TLAN is not set
CONFIG_VIA_RHINE is not set
CONFIG_SC92031 is not set
CONFIG_NET_POCKET is not set
CONFIG_NETDEV_1000=y
CONFIG_ACENIC is not set
CONFIG_DL2K is not set
CONFIG_E1000 is not set
CONFIG_NS83820 is not set
CONFIG_HAMACHI is not set
CONFIG_YELLOWFIN is not set
CONFIG_R8169 is not set
CONFIG_SIS190 is not set
CONFIG_SKGE is not set
CONFIG_SKY2 is not set
CONFIG_SK98LIN is not set
CONFIG_VIA_VELOCITY is not set
CONFIG_TIGON3 is not set
CONFIG_BNX2 is not set
CONFIG_QLA3XXX is not set
CONFIG_ATL1 is not set
CONFIG_NETDEV_10000=y
CONFIG_CHELSIO_T1 is not set
CONFIG_CHELSIO_T3 is not set
CONFIG_IXGB is not set
CONFIG_S2IO is not set
CONFIG_MYRI10GE is not set
CONFIG_NETXEN_NIC is not set
CONFIG_MLX4_CORE is not set
CONFIG_TR is not set
Wireless LAN
CONFIG_WLAN_PRE80211 is not set
CONFIG_WLAN_80211 is not set
USB Network Adapters
CONFIG_USB_CATC is not set
CONFIG_USB_KAWETH is not set
CONFIG_USB_PEGASUS is not set
CONFIG_USB_RTL8150 is not set
CONFIG_USB_USBNET_MII is not set
CONFIG_USB_USBNET=m
CONFIG_USB_NET_AX8817X is not set
CONFIG_USB_NET_CDCETHER=m
CONFIG_USB_NET_DM9601 is not set
CONFIG_USB_NET_GL620A is not set
CONFIG_USB_NET_NET1080 is not set
CONFIG_USB_NET_PLUSB is not set
CONFIG_USB_NET_MCS7830 is not set
CONFIG_USB_NET_RNDIS_HOST is not set
CONFIG_USB_NET_CDC_SUBSET is not set
CONFIG_USB_NET_ZAURUS is not set
CONFIG_NET_PCMCIA is not set
CONFIG_WAN is not set
CONFIG_ATM_DRIVERS=y
CONFIG_ATM_DUMMY is not set
CONFIG_ATM_TCP is not set
CONFIG_ATM_LANAI is not set
CONFIG_ATM_ENI is not set
CONFIG_ATM_FIRESTREAM is not set
CONFIG_ATM_ZATM is not set
CONFIG_ATM_NICSTAR is not set
CONFIG_ATM_IDT77252 is not set
CONFIG_ATM_AMBASSADOR is not set
CONFIG_ATM_HORIZON is not set
CONFIG_ATM_IA is not set
CONFIG_ATM_FORE200E_MAYBE is not set
CONFIG_ATM_HE is not set
CONFIG_FDDI is not set
CONFIG_HIPPI is not set
CONFIG_PLIP is not set
CONFIG_PPP=m
CONFIG_PPP_MULTILINK=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
CONFIG_PPP_DEFLATE=m
CONFIG_PPP_BSDCOMP=m
CONFIG_PPP_MPPE is not set
CONFIG_PPPOE=m
CONFIG_PPPOATM=m
CONFIG_SLIP is not set
CONFIG_SLHC=m
CONFIG_NET_FC is not set
CONFIG_SHAPER is not set
CONFIG_NETCONSOLE is not set
CONFIG_NETPOLL is not set
CONFIG_NET_POLL_CONTROLLER is not set
ISDN subsystem
CONFIG_ISDN is not set
Telephony Support
CONFIG_PHONE is not set
Input device support
CONFIG_INPUT=y
CONFIG_INPUT_FF_MEMLESS is not set
CONFIG_INPUT_POLLDEV is not set
Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
CONFIG_INPUT_JOYDEV=m
CONFIG_INPUT_TSDEV is not set
CONFIG_INPUT_EVDEV=y
CONFIG_INPUT_EVBUG is not set
Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_ATKBD=y
CONFIG_KEYBOARD_SUNKBD is not set
CONFIG_KEYBOARD_LKKBD is not set
CONFIG_KEYBOARD_XTKBD is not set
CONFIG_KEYBOARD_NEWTON is not set
CONFIG_KEYBOARD_STOWAWAY is not set
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=y
CONFIG_MOUSE_PS2_ALPS=y
CONFIG_MOUSE_PS2_LOGIPS2PP=y
CONFIG_MOUSE_PS2_SYNAPTICS=y
CONFIG_MOUSE_PS2_LIFEBOOK=y
CONFIG_MOUSE_PS2_TRACKPOINT=y
CONFIG_MOUSE_PS2_TOUCHKIT is not set
CONFIG_MOUSE_SERIAL is not set
CONFIG_MOUSE_APPLETOUCH is not set
CONFIG_MOUSE_VSXXXAA is not set
CONFIG_INPUT_JOYSTICK is not set
CONFIG_INPUT_TABLET is not set
CONFIG_INPUT_TOUCHSCREEN is not set
CONFIG_INPUT_MISC=y
CONFIG_INPUT_PCSPKR=m
CONFIG_INPUT_WISTRON_BTNS is not set
CONFIG_INPUT_ATI_REMOTE is not set
CONFIG_INPUT_ATI_REMOTE2 is not set
CONFIG_INPUT_KEYSPAN_REMOTE is not set
CONFIG_INPUT_POWERMATE is not set
CONFIG_INPUT_YEALINK is not set
CONFIG_INPUT_UINPUT is not set
Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_I8042=y
CONFIG_SERIO_SERPORT is not set
CONFIG_SERIO_CT82C710 is not set
CONFIG_SERIO_PARKBD is not set
CONFIG_SERIO_PCIPS2 is not set
CONFIG_SERIO_LIBPS2=y
CONFIG_SERIO_RAW is not set
CONFIG_GAMEPORT is not set
Character devices
CONFIG_VT=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING is not set
CONFIG_SERIAL_NONSTANDARD=y
CONFIG_COMPUTONE is not set
CONFIG_ROCKETPORT is not set
CONFIG_CYCLADES is not set
CONFIG_DIGIEPCA is not set
CONFIG_MOXA_INTELLIO is not set
CONFIG_MOXA_SMARTIO is not set
CONFIG_MOXA_SMARTIO_NEW is not set
CONFIG_ISI is not set
CONFIG_SYNCLINK is not set
CONFIG_SYNCLINKMP is not set
CONFIG_SYNCLINK_GT is not set
CONFIG_N_HDLC=m
CONFIG_RISCOM8 is not set
CONFIG_SPECIALIX is not set
CONFIG_SX is not set
CONFIG_RIO is not set
CONFIG_STALDRV is not set
Serial drivers
CONFIG_SERIAL_8250=m
CONFIG_SERIAL_8250_PCI=m
CONFIG_SERIAL_8250_CS is not set
CONFIG_SERIAL_8250_NR_UARTS=4
CONFIG_SERIAL_8250_RUNTIME_UARTS=4
CONFIG_SERIAL_8250_EXTENDED is not set
Non-8250 serial port support
CONFIG_SERIAL_CORE=m
CONFIG_SERIAL_JSM is not set
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
CONFIG_PRINTER is not set
CONFIG_PPDEV is not set
CONFIG_TIPAR is not set
IPMI
CONFIG_IPMI_HANDLER is not set
CONFIG_WATCHDOG is not set
CONFIG_HW_RANDOM is not set
CONFIG_NVRAM is not set
CONFIG_RTC is not set
CONFIG_GEN_RTC is not set
CONFIG_R3964 is not set
CONFIG_APPLICOM is not set
CONFIG_SONYPI is not set
CONFIG_AGP=y
CONFIG_AGP_ALI is not set
CONFIG_AGP_ATI=y
CONFIG_AGP_AMD is not set
CONFIG_AGP_AMD64 is not set
CONFIG_AGP_INTEL is not set
CONFIG_AGP_NVIDIA is not set
CONFIG_AGP_SIS is not set
CONFIG_AGP_SWORKS is not set
CONFIG_AGP_VIA is not set
CONFIG_AGP_EFFICEON is not set
CONFIG_DRM is not set
PCMCIA character devices
CONFIG_SYNCLINK_CS is not set
CONFIG_CARDMAN_4000 is not set
CONFIG_CARDMAN_4040 is not set
CONFIG_MWAVE is not set
CONFIG_PC8736x_GPIO is not set
CONFIG_NSC_GPIO is not set
CONFIG_CS5535_GPIO is not set
CONFIG_RAW_DRIVER is not set
CONFIG_HANGCHECK_TIMER is not set
TPM devices
CONFIG_TCG_TPM is not set
CONFIG_TELCLOCK is not set
CONFIG_DEVPORT=y
CONFIG_I2C=m
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_CHARDEV is not set
I2C Algorithms
CONFIG_I2C_ALGOBIT=m
CONFIG_I2C_ALGOPCF is not set
CONFIG_I2C_ALGOPCA is not set
I2C Hardware Bus support
CONFIG_I2C_ALI1535 is not set
CONFIG_I2C_ALI1563 is not set
CONFIG_I2C_ALI15X3 is not set
CONFIG_I2C_AMD756 is not set
CONFIG_I2C_AMD8111 is not set
CONFIG_I2C_I801 is not set
CONFIG_I2C_I810 is not set
CONFIG_I2C_PIIX4 is not set
CONFIG_I2C_NFORCE2 is not set
CONFIG_I2C_OCORES is not set
CONFIG_I2C_PARPORT is not set
CONFIG_I2C_PARPORT_LIGHT is not set
CONFIG_I2C_PROSAVAGE is not set
CONFIG_I2C_SAVAGE4 is not set
CONFIG_I2C_SIMTEC is not set
CONFIG_SCx200_ACB is not set
CONFIG_I2C_SIS5595 is not set
CONFIG_I2C_SIS630 is not set
CONFIG_I2C_SIS96X is not set
CONFIG_I2C_STUB is not set
CONFIG_I2C_TINY_USB is not set
CONFIG_I2C_VIA is not set
CONFIG_I2C_VIAPRO is not set
CONFIG_I2C_VOODOO3 is not set
Miscellaneous I2C Chip support
CONFIG_SENSORS_DS1337 is not set
CONFIG_SENSORS_DS1374 is not set
CONFIG_SENSORS_EEPROM is not set
CONFIG_SENSORS_PCF8574 is not set
CONFIG_SENSORS_PCA9539 is not set
CONFIG_SENSORS_PCF8591 is not set
CONFIG_SENSORS_MAX6875 is not set
CONFIG_I2C_DEBUG_CORE is not set
CONFIG_I2C_DEBUG_ALGO is not set
CONFIG_I2C_DEBUG_BUS is not set
CONFIG_I2C_DEBUG_CHIP is not set
SPI support
CONFIG_SPI is not set
CONFIG_SPI_MASTER is not set
Dallas’s 1-wire bus
CONFIG_W1 is not set
CONFIG_HWMON=y
CONFIG_HWMON_VID is not set
CONFIG_SENSORS_ABITUGURU is not set
CONFIG_SENSORS_AD7418 is not set
CONFIG_SENSORS_ADM1021 is not set
CONFIG_SENSORS_ADM1025 is not set
CONFIG_SENSORS_ADM1026 is not set
CONFIG_SENSORS_ADM1029 is not set
CONFIG_SENSORS_ADM1031 is not set
CONFIG_SENSORS_ADM9240 is not set
CONFIG_SENSORS_K8TEMP is not set
CONFIG_SENSORS_ASB100 is not set
CONFIG_SENSORS_ATXP1 is not set
CONFIG_SENSORS_DS1621 is not set
CONFIG_SENSORS_F71805F is not set
CONFIG_SENSORS_F75375S is not set
CONFIG_SENSORS_FSCHER is not set
CONFIG_SENSORS_FSCPOS is not set
CONFIG_SENSORS_GL518SM is not set
CONFIG_SENSORS_GL520SM is not set
CONFIG_SENSORS_CORETEMP is not set
CONFIG_SENSORS_IT87 is not set
CONFIG_SENSORS_LM63 is not set
CONFIG_SENSORS_LM75 is not set
CONFIG_SENSORS_LM77 is not set
CONFIG_SENSORS_LM78 is not set
CONFIG_SENSORS_LM80 is not set
CONFIG_SENSORS_LM83 is not set
CONFIG_SENSORS_LM85 is not set
CONFIG_SENSORS_LM87 is not set
CONFIG_SENSORS_LM90 is not set
CONFIG_SENSORS_LM92 is not set
CONFIG_SENSORS_MAX1619 is not set
CONFIG_SENSORS_MAX6650 is not set
CONFIG_SENSORS_PC87360 is not set
CONFIG_SENSORS_PC87427 is not set
CONFIG_SENSORS_SIS5595 is not set
CONFIG_SENSORS_SMSC47M1 is not set
CONFIG_SENSORS_SMSC47M192 is not set
CONFIG_SENSORS_SMSC47B397 is not set
CONFIG_SENSORS_VIA686A is not set
CONFIG_SENSORS_VT1211 is not set
CONFIG_SENSORS_VT8231 is not set
CONFIG_SENSORS_W83781D is not set
CONFIG_SENSORS_W83791D is not set
CONFIG_SENSORS_W83792D is not set
CONFIG_SENSORS_W83793 is not set
CONFIG_SENSORS_W83L785TS is not set
CONFIG_SENSORS_W83627HF is not set
CONFIG_SENSORS_W83627EHF is not set
CONFIG_SENSORS_HDAPS is not set
CONFIG_SENSORS_APPLESMC is not set
CONFIG_HWMON_DEBUG_CHIP is not set
Multifunction device drivers
CONFIG_MFD_SM501 is not set
Multimedia devices
CONFIG_VIDEO_DEV is not set
CONFIG_DVB_CORE is not set
CONFIG_DAB=y
CONFIG_USB_DABUSB is not set
Graphics support
CONFIG_BACKLIGHT_LCD_SUPPORT is not set
Display device support
CONFIG_DISPLAY_SUPPORT is not set
CONFIG_VGASTATE is not set
CONFIG_FB=y
CONFIG_FIRMWARE_EDID is not set
CONFIG_FB_DDC is not set
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
CONFIG_FB_SYS_FILLRECT is not set
CONFIG_FB_SYS_COPYAREA is not set
CONFIG_FB_SYS_IMAGEBLIT is not set
CONFIG_FB_SYS_FOPS is not set
CONFIG_FB_DEFERRED_IO=y
CONFIG_FB_SVGALIB is not set
CONFIG_FB_MACMODES is not set
CONFIG_FB_BACKLIGHT is not set
CONFIG_FB_MODE_HELPERS is not set
CONFIG_FB_TILEBLITTING is not set
Frame buffer hardware drivers
CONFIG_FB_CIRRUS is not set
CONFIG_FB_PM2 is not set
CONFIG_FB_CYBER2000 is not set
CONFIG_FB_ARC is not set
CONFIG_FB_ASILIANT is not set
CONFIG_FB_IMSTT is not set
CONFIG_FB_VGA16=y
CONFIG_FB_VESA=y
CONFIG_FB_HECUBA is not set
CONFIG_FB_HGA is not set
CONFIG_FB_S1D13XXX is not set
CONFIG_FB_NVIDIA is not set
CONFIG_FB_RIVA is not set
CONFIG_FB_I810 is not set
CONFIG_FB_LE80578 is not set
CONFIG_FB_INTEL is not set
CONFIG_FB_MATROX is not set
CONFIG_FB_RADEON is not set
CONFIG_FB_ATY128 is not set
CONFIG_FB_ATY is not set
CONFIG_FB_S3 is not set
CONFIG_FB_SAVAGE is not set
CONFIG_FB_SIS is not set
CONFIG_FB_NEOMAGIC is not set
CONFIG_FB_KYRO is not set
CONFIG_FB_3DFX is not set
CONFIG_FB_VOODOO1 is not set
CONFIG_FB_VT8623 is not set
CONFIG_FB_CYBLA is not set
CONFIG_FB_TRIDENT is not set
CONFIG_FB_ARK is not set
CONFIG_FB_PM3 is not set
CONFIG_FB_GEODE is not set
CONFIG_FB_VIRTUAL is not set
Console display driver support
CONFIG_VGA_CONSOLE=y
CONFIG_VGACON_SOFT_SCROLLBACK is not set
CONFIG_VIDEO_SELECT=y
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
CONFIG_LOGO is not set
Sound
CONFIG_SOUND=m
Advanced Linux Sound Architecture
CONFIG_SND=m
CONFIG_SND_TIMER=m
CONFIG_SND_PCM=m
CONFIG_SND_RAWMIDI=m
CONFIG_SND_SEQUENCER=m
CONFIG_SND_SEQ_DUMMY=m
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=m
CONFIG_SND_PCM_OSS=m
CONFIG_SND_PCM_OSS_PLUGINS=y
CONFIG_SND_SEQUENCER_OSS=y
CONFIG_SND_DYNAMIC_MINORS is not set
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_VERBOSE_PROCFS=y
CONFIG_SND_VERBOSE_PRINTK is not set
CONFIG_SND_DEBUG is not set
Generic devices
CONFIG_SND_MPU401_UART=m
CONFIG_SND_AC97_CODEC=m
CONFIG_SND_DUMMY is not set
CONFIG_SND_VIRMIDI is not set
CONFIG_SND_MTPAV is not set
CONFIG_SND_MTS64 is not set
CONFIG_SND_SERIAL_U16550 is not set
CONFIG_SND_MPU401 is not set
CONFIG_SND_PORTMAN2X4 is not set
PCI devices
CONFIG_SND_AD1889 is not set
CONFIG_SND_ALS300 is not set
CONFIG_SND_ALS4000 is not set
CONFIG_SND_ALI5451 is not set
CONFIG_SND_ATIIXP is not set
CONFIG_SND_ATIIXP_MODEM is not set
CONFIG_SND_AU8810 is not set
CONFIG_SND_AU8820 is not set
CONFIG_SND_AU8830 is not set
CONFIG_SND_AZT3328 is not set
CONFIG_SND_BT87X is not set
CONFIG_SND_CA0106 is not set
CONFIG_SND_CMIPCI is not set
CONFIG_SND_CS4281 is not set
CONFIG_SND_CS46XX is not set
CONFIG_SND_CS5535AUDIO is not set
CONFIG_SND_DARLA20 is not set
CONFIG_SND_GINA20 is not set
CONFIG_SND_LAYLA20 is not set
CONFIG_SND_DARLA24 is not set
CONFIG_SND_GINA24 is not set
CONFIG_SND_LAYLA24 is not set
CONFIG_SND_MONA is not set
CONFIG_SND_MIA is not set
CONFIG_SND_ECHO3G is not set
CONFIG_SND_INDIGO is not set
CONFIG_SND_INDIGOIO is not set
CONFIG_SND_INDIGODJ is not set
CONFIG_SND_EMU10K1 is not set
CONFIG_SND_EMU10K1X is not set
CONFIG_SND_ENS1370 is not set
CONFIG_SND_ENS1371 is not set
CONFIG_SND_ES1938 is not set
CONFIG_SND_ES1968=m
CONFIG_SND_FM801 is not set
CONFIG_SND_HDA_INTEL is not set
CONFIG_SND_HDSP is not set
CONFIG_SND_HDSPM is not set
CONFIG_SND_ICE1712 is not set
CONFIG_SND_ICE1724 is not set
CONFIG_SND_INTEL8X0 is not set
CONFIG_SND_INTEL8X0M is not set
CONFIG_SND_KORG1212 is not set
CONFIG_SND_MAESTRO3 is not set
CONFIG_SND_MIXART is not set
CONFIG_SND_NM256 is not set
CONFIG_SND_PCXHR is not set
CONFIG_SND_RIPTIDE is not set
CONFIG_SND_RME32 is not set
CONFIG_SND_RME96 is not set
CONFIG_SND_RME9652 is not set
CONFIG_SND_SONICVIBES is not set
CONFIG_SND_TRIDENT is not set
CONFIG_SND_VIA82XX is not set
CONFIG_SND_VIA82XX_MODEM is not set
CONFIG_SND_VX222 is not set
CONFIG_SND_YMFPCI is not set
CONFIG_SND_AC97_POWER_SAVE is not set
USB devices
CONFIG_SND_USB_AUDIO is not set
CONFIG_SND_USB_USX2Y is not set
CONFIG_SND_USB_CAIAQ is not set
PCMCIA devices
CONFIG_SND_VXPOCKET is not set
CONFIG_SND_PDAUDIOCF is not set
System on Chip audio support
CONFIG_SND_SOC is not set
Open Sound System
CONFIG_SOUND_PRIME is not set
CONFIG_AC97_BUS=m
HID Devices
CONFIG_HID=y
CONFIG_HID_DEBUG is not set
USB Input Devices
CONFIG_USB_HID=m
CONFIG_USB_HIDINPUT_POWERBOOK is not set
CONFIG_HID_FF is not set
CONFIG_USB_HIDDEV is not set
USB HID Boot Protocol drivers
CONFIG_USB_KBD is not set
CONFIG_USB_MOUSE is not set
USB support
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB_ARCH_HAS_OHCI=y
CONFIG_USB_ARCH_HAS_EHCI=y
CONFIG_USB=m
CONFIG_USB_DEBUG is not set
Miscellaneous USB options
CONFIG_USB_DEVICEFS=y
CONFIG_USB_DEVICE_CLASS=y
CONFIG_USB_DYNAMIC_MINORS is not set
CONFIG_USB_SUSPEND is not set
CONFIG_USB_OTG is not set
USB Host Controller Drivers
CONFIG_USB_EHCI_HCD=m
CONFIG_USB_EHCI_SPLIT_ISO is not set
CONFIG_USB_EHCI_ROOT_HUB_TT is not set
CONFIG_USB_EHCI_TT_NEWSCHED is not set
CONFIG_USB_EHCI_BIG_ENDIAN_MMIO is not set
CONFIG_USB_ISP116X_HCD is not set
CONFIG_USB_OHCI_HCD=m
CONFIG_USB_OHCI_BIG_ENDIAN_DESC is not set
CONFIG_USB_OHCI_BIG_ENDIAN_MMIO is not set
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_UHCI_HCD=m
CONFIG_USB_SL811_HCD is not set
USB Device Class drivers
CONFIG_USB_ACM is not set
CONFIG_USB_PRINTER=m
NOTE: USB_STORAGE enables SCSI, and ‘SCSI disk support’
may also be needed; see USB_STORAGE Help for more information
CONFIG_USB_STORAGE=m
CONFIG_USB_STORAGE_DEBUG is not set
CONFIG_USB_STORAGE_DATAFAB is not set
CONFIG_USB_STORAGE_FREECOM is not set
CONFIG_USB_STORAGE_ISD200 is not set
CONFIG_USB_STORAGE_DPCM is not set
CONFIG_USB_STORAGE_USBAT is not set
CONFIG_USB_STORAGE_SDDR09 is not set
CONFIG_USB_STORAGE_SDDR55 is not set
CONFIG_USB_STORAGE_JUMPSHOT is not set
CONFIG_USB_STORAGE_ALAUDA is not set
CONFIG_USB_STORAGE_KARMA is not set
CONFIG_USB_LIBUSUAL is not set
USB Imaging devices
CONFIG_USB_MDC800 is not set
CONFIG_USB_MICROTEK is not set
CONFIG_USB_MON=y
USB port drivers
CONFIG_USB_USS720 is not set
USB Serial Converter support
CONFIG_USB_SERIAL is not set
USB Miscellaneous drivers
CONFIG_USB_EMI62 is not set
CONFIG_USB_EMI26 is not set
CONFIG_USB_ADUTUX is not set
CONFIG_USB_AUERSWALD is not set
CONFIG_USB_RIO500 is not set
CONFIG_USB_LEGOTOWER is not set
CONFIG_USB_LCD is not set
CONFIG_USB_BERRY_CHARGE is not set
CONFIG_USB_LED is not set
CONFIG_USB_CYPRESS_CY7C63 is not set
CONFIG_USB_CYTHERM is not set
CONFIG_USB_PHIDGET is not set
CONFIG_USB_IDMOUSE is not set
CONFIG_USB_FTDI_ELAN is not set
CONFIG_USB_APPLEDISPLAY is not set
CONFIG_USB_SISUSBVGA is not set
CONFIG_USB_LD is not set
CONFIG_USB_TRANCEVIBRATOR is not set
CONFIG_USB_IOWARRIOR is not set
CONFIG_USB_TEST is not set
USB DSL modem support
CONFIG_USB_ATM is not set
USB Gadget Support
CONFIG_USB_GADGET is not set
CONFIG_MMC is not set
LED devices
CONFIG_NEW_LEDS is not set
LED drivers
LED Triggers
InfiniBand support
CONFIG_INFINIBAND is not set
EDAC - error detection and reporting (RAS) (EXPERIMENTAL)
CONFIG_EDAC is not set
Real Time Clock
CONFIG_RTC_CLASS is not set
DMA Engine support
CONFIG_DMA_ENGINE is not set
DMA Clients
DMA Devices
Auxiliary Display support
CONFIG_KS0108 is not set
Virtualization
CONFIG_KVM is not set
File systems
CONFIG_EXT2_FS=y
CONFIG_EXT2_FS_XATTR is not set
CONFIG_EXT2_FS_XIP is not set
CONFIG_EXT3_FS=y
CONFIG_EXT3_FS_XATTR is not set
CONFIG_EXT4DEV_FS is not set
CONFIG_JBD=y
CONFIG_JBD_DEBUG is not set
CONFIG_REISERFS_FS is not set
CONFIG_JFS_FS is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_XFS_FS is not set
CONFIG_GFS2_FS is not set
CONFIG_OCFS2_FS is not set
CONFIG_MINIX_FS is not set
CONFIG_ROMFS_FS is not set
CONFIG_INOTIFY=y
CONFIG_INOTIFY_USER=y
CONFIG_QUOTA is not set
CONFIG_DNOTIFY=y
CONFIG_AUTOFS_FS is not set
CONFIG_AUTOFS4_FS=m
CONFIG_FUSE_FS=m
CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=m
CONFIG_JOLIET=y
CONFIG_ZISOFS=y
CONFIG_UDF_FS=m
CONFIG_UDF_NLS=y
DOS/FAT/NT Filesystems
CONFIG_FAT_FS=m
CONFIG_MSDOS_FS=m
CONFIG_VFAT_FS=m
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
CONFIG_NTFS_FS=m
CONFIG_NTFS_DEBUG is not set
CONFIG_NTFS_RW is not set
Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_KCORE=y
CONFIG_PROC_SYSCTL=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL is not set
CONFIG_HUGETLBFS is not set
CONFIG_HUGETLB_PAGE is not set
CONFIG_RAMFS=y
CONFIG_CONFIGFS_FS is not set
Miscellaneous filesystems
CONFIG_ADFS_FS is not set
CONFIG_AFFS_FS is not set
CONFIG_HFS_FS is not set
CONFIG_HFSPLUS_FS is not set
CONFIG_BEFS_FS is not set
CONFIG_BFS_FS is not set
CONFIG_EFS_FS is not set
CONFIG_CRAMFS is not set
CONFIG_VXFS_FS is not set
CONFIG_HPFS_FS is not set
CONFIG_QNX4FS_FS is not set
CONFIG_SYSV_FS is not set
CONFIG_UFS_FS is not set
Network File Systems
CONFIG_NFS_FS=m
CONFIG_NFS_V3=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4 is not set
CONFIG_NFS_DIRECTIO is not set
CONFIG_NFSD=m
CONFIG_NFSD_V2_ACL=y
CONFIG_NFSD_V3=y
CONFIG_NFSD_V3_ACL=y
CONFIG_NFSD_V4 is not set
CONFIG_NFSD_TCP is not set
CONFIG_LOCKD=m
CONFIG_LOCKD_V4=y
CONFIG_EXPORTFS=m
CONFIG_NFS_ACL_SUPPORT=m
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=m
CONFIG_SUNRPC_BIND34 is not set
CONFIG_RPCSEC_GSS_KRB5 is not set
CONFIG_RPCSEC_GSS_SPKM3 is not set
CONFIG_SMB_FS=m
CONFIG_SMB_NLS_DEFAULT=y
CONFIG_SMB_NLS_REMOTE=“cp850”
CONFIG_CIFS is not set
CONFIG_NCP_FS is not set
CONFIG_CODA_FS is not set
CONFIG_AFS_FS is not set
CONFIG_9P_FS is not set
Partition Types
CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
Native Language Support
CONFIG_NLS=m
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=m
CONFIG_NLS_CODEPAGE_737 is not set
CONFIG_NLS_CODEPAGE_775 is not set
CONFIG_NLS_CODEPAGE_850=m
CONFIG_NLS_CODEPAGE_852 is not set
CONFIG_NLS_CODEPAGE_855 is not set
CONFIG_NLS_CODEPAGE_857 is not set
CONFIG_NLS_CODEPAGE_860 is not set
CONFIG_NLS_CODEPAGE_861 is not set
CONFIG_NLS_CODEPAGE_862 is not set
CONFIG_NLS_CODEPAGE_863 is not set
CONFIG_NLS_CODEPAGE_864 is not set
CONFIG_NLS_CODEPAGE_865 is not set
CONFIG_NLS_CODEPAGE_866 is not set
CONFIG_NLS_CODEPAGE_869 is not set
CONFIG_NLS_CODEPAGE_936 is not set
CONFIG_NLS_CODEPAGE_950 is not set
CONFIG_NLS_CODEPAGE_932 is not set
CONFIG_NLS_CODEPAGE_949 is not set
CONFIG_NLS_CODEPAGE_874 is not set
CONFIG_NLS_ISO8859_8 is not set
CONFIG_NLS_CODEPAGE_1250 is not set
CONFIG_NLS_CODEPAGE_1251 is not set
CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=m
CONFIG_NLS_ISO8859_2 is not set
CONFIG_NLS_ISO8859_3 is not set
CONFIG_NLS_ISO8859_4 is not set
CONFIG_NLS_ISO8859_5 is not set
CONFIG_NLS_ISO8859_6 is not set
CONFIG_NLS_ISO8859_7 is not set
CONFIG_NLS_ISO8859_9 is not set
CONFIG_NLS_ISO8859_13 is not set
CONFIG_NLS_ISO8859_14 is not set
CONFIG_NLS_ISO8859_15=m
CONFIG_NLS_KOI8_R is not set
CONFIG_NLS_KOI8_U is not set
CONFIG_NLS_UTF8=m
Distributed Lock Manager
CONFIG_DLM is not set
Instrumentation Support
CONFIG_PROFILING is not set
CONFIG_KPROBES is not set
Kernel hacking
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_PRINTK_TIME is not set
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_MAGIC_SYSRQ=y
CONFIG_UNUSED_SYMBOLS=y
CONFIG_DEBUG_FS is not set
CONFIG_HEADERS_CHECK is not set
CONFIG_DEBUG_KERNEL=y
CONFIG_DEBUG_SHIRQ is not set
CONFIG_DETECT_SOFTLOCKUP=y
CONFIG_SCHEDSTATS is not set
CONFIG_TIMER_STATS is not set
CONFIG_DEBUG_SLAB is not set
CONFIG_DEBUG_PREEMPT=y
CONFIG_DEBUG_RT_MUTEXES is not set
CONFIG_RT_MUTEX_TESTER is not set
CONFIG_DEBUG_SPINLOCK is not set
CONFIG_DEBUG_MUTEXES is not set
CONFIG_DEBUG_LOCK_ALLOC is not set
CONFIG_PROVE_LOCKING is not set
CONFIG_DEBUG_SPINLOCK_SLEEP is not set
CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
CONFIG_DEBUG_KOBJECT is not set
CONFIG_DEBUG_BUGVERBOSE=y
CONFIG_DEBUG_INFO is not set
CONFIG_DEBUG_VM is not set
CONFIG_DEBUG_LIST is not set
CONFIG_FRAME_POINTER is not set
CONFIG_FORCED_INLINING=y
CONFIG_RCU_TORTURE_TEST is not set
CONFIG_FAULT_INJECTION is not set
CONFIG_EARLY_PRINTK=y
CONFIG_DEBUG_STACKOVERFLOW is not set
CONFIG_DEBUG_STACK_USAGE is not set
Page alloc debug is incompatible with Software Suspend on i386
CONFIG_DEBUG_RODATA is not set
CONFIG_4KSTACKS is not set
CONFIG_X86_FIND_SMP_CONFIG=y
CONFIG_X86_MPPARSE=y
CONFIG_DOUBLEFAULT=y
Security options
CONFIG_KEYS is not set
CONFIG_SECURITY is not set
Cryptographic options
CONFIG_CRYPTO=y
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_BLKCIPHER=m
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_HMAC=y
CONFIG_CRYPTO_XCBC is not set
CONFIG_CRYPTO_NULL=m
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_MD5=m
CONFIG_CRYPTO_SHA1=m
CONFIG_CRYPTO_SHA256=m
CONFIG_CRYPTO_SHA512=m
CONFIG_CRYPTO_WP512 is not set
CONFIG_CRYPTO_TGR192 is not set
CONFIG_CRYPTO_GF128MUL is not set
CONFIG_CRYPTO_ECB=m
CONFIG_CRYPTO_CBC=m
CONFIG_CRYPTO_PCBC=m
CONFIG_CRYPTO_LRW is not set
CONFIG_CRYPTO_CRYPTD is not set
CONFIG_CRYPTO_DES=m
CONFIG_CRYPTO_FCRYPT is not set
CONFIG_CRYPTO_BLOWFISH=m
CONFIG_CRYPTO_TWOFISH=m
CONFIG_CRYPTO_TWOFISH_COMMON=m
CONFIG_CRYPTO_TWOFISH_586 is not set
CONFIG_CRYPTO_SERPENT=m
CONFIG_CRYPTO_AES=m
CONFIG_CRYPTO_AES_586 is not set
CONFIG_CRYPTO_CAST5=m
CONFIG_CRYPTO_CAST6=m
CONFIG_CRYPTO_TEA is not set
CONFIG_CRYPTO_ARC4=m
CONFIG_CRYPTO_KHAZAD is not set
CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_DEFLATE=m
CONFIG_CRYPTO_MICHAEL_MIC=m
CONFIG_CRYPTO_CRC32C=m
CONFIG_CRYPTO_CAMELLIA is not set
CONFIG_CRYPTO_TEST is not set
Hardware crypto devices
CONFIG_CRYPTO_DEV_PADLOCK is not set
CONFIG_CRYPTO_DEV_GEODE=m
Library routines
CONFIG_BITREVERSE=y
CONFIG_CRC_CCITT=m
CONFIG_CRC16 is not set
CONFIG_CRC_ITU_T is not set
CONFIG_CRC32=y
CONFIG_LIBCRC32C=m
CONFIG_ZLIB_INFLATE=m
CONFIG_ZLIB_DEFLATE=m
CONFIG_PLIST=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT=y
CONFIG_HAS_DMA=y
CONFIG_GENERIC_HARDIRQS=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_X86_BIOS_REBOOT=y
CONFIG_KTIME_SCALAR=y
[/code][/code]
