[RESOLU] Squeeze : Pb KDE sur EPIA-EX 1500
J’essaye d’installer KDE sur ma machine, mais cela ne fonctionne pas.
Lorsque je lance la commande suivante : sudo /etc/init.d/kde start
J’obtiens bien l’écran de connexion, mais ensuite après avoir entrée le mot de passe, je vois un nouvel écran ou l’icône du disque dur apparaît et 3 autres icônes qui restent floues.
Puis je reviens à l’écran de connexion, et ainsi de suite.
J’ai installé KDE à partir d’un système sans environnement graphique.
Il n’y a pas d’erreur dans le Xorg.0.log : cat /var/log/Xorg.0.log me donne rien.
Voici les warnings : quote The directory “/usr/X11R6/lib/X11/fonts/misc” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/cyrillic” does not exist.
(WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi/” does not exist.
(WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi/” does not exist.
(WW) The directory “/usr/share/fonts/X11/Type1” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/Type1” does not exist.
(WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi” does not exist.
(WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi” does not exist.
(WW) fonts.dir' not found (or not valid) in "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType". (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist. (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist. (WW) The directory "/usr/share/fonts/X11/Type1" does not exist. (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist. (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist. (WW)fonts.dir’ not found (or not valid) in “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType”.
(WW) AllowEmptyInput is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
(WW) Disabling Generic Keyboard
(WW) Disabling Configured Mouse
(WW) CHROME(0): Manufacturer plainly copied main PCI IDs to subsystem/card IDs.
(WW) CHROME(0): [XvMC] XvMC is not supported on this chipset.
(WW) MLK Trust Keyboard 14909: ignoring absolute axes.
C’est la première fois que j’essaye d’installer KDE, et j’avoue je ne vois pas l’erreur.
Merci pour vos informations.
A+
KDE sans environnement graphique … :118 … :005 :005
[quote=“loreleil”]Salut,
KDE sans environnement graphique … :118 … :005 :005[/quote]Il y a un environnement graphique puisque j’ai un xorg.
J’ai installé kde-base, et je pense que l’environnement est dans ce cas installé aussi. :005
A+
… :whistle:
J’ai rajouté les fonts et recréer le fichier xorg.conf avec la commande : Xorg -config
Voici les warnings que j’obtiens :
quote AllowEmptyInput is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
(WW) Disabling Mouse0
(WW) Disabling Keyboard0
Cette fois en lancant startx, je vois bien la deuxième icone puis j’ai un crash au KCMinit :
le fichier .xsession-error
startkde: Starting up... kdeinit4: preparing to launch /usr/lib/kde4/libkdeinit/libkdeinit4_klauncher.so Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString) kdeinit4: preparing to launch /usr/lib/kde4/libkdeinit/libkdeinit4_kded4.so qUncompress: Z_DATA_ERROR: Input data is corrupted kdeinit4: preparing to launch /usr/bin/kbuildsycoca4 kbuildsycoca4 running... kdeinit4: preparing to launch /usr/lib/kde4/libkdeinit/libkdeinit4_kconf_update.so Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString) kded(3634)/kdecore (KLibrary) kde4Factory: The library "/usr/lib/kde4/solid_hal_power.so" does not offer a qt_plugin_instance function. Invalid D-BUS member name 'idle-hint' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection Invalid D-BUS member name 'is-local' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection Invalid D-BUS member name 'x11-display-device' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection Invalid D-BUS member name 'x11-display' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection Invalid D-BUS member name 'display-device' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection Invalid D-BUS member name 'remote-host-name' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection Invalid D-BUS member name 'session-type' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection Invalid D-BUS member name 'unix-user' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection QObject::connect: Cannot connect (null)::accessibilityChanged(bool, const QString) to DeviceAutomounter::deviceMountChanged(bool, const QString) kded(3634)/kdecore (KConfigSkeleton) KCoreConfigSkeleton::writeConfig: kdeinit4: preparing to launch /usr/lib/kde4/libkdeinit/libkdeinit4_kcminit_startup.so kdeinit4: preparing to launch /usr/bin/knotify4 qUncompress: Z_DATA_ERROR: Input data is corrupted Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString) qUncompress: Input data is corrupted kcminit(3657): stream is bad :-( status= 2 X Error: BadAlloc (insufficient resources for operation) 11 Major opcode: 53 (X_CreatePixmap) Resource id: 0x72 X Error: BadDrawable (invalid Pixmap or Window parameter) 9 Extension: 149 (RENDER) Minor opcode: 4 (RenderCreatePicture) Resource id: 0x120000c X Error: BadDrawable (invalid Pixmap or Window parameter) 9 Major opcode: 73 (X_GetImage) Resource id: 0x120000c terminate called after throwing an instance of 'std::bad_alloc' what(): std::bad_alloc KCrash: Application 'kcminit_startup' crashing... kdeinit4: preparing to launch /usr/lib/kde4/libexec/drkonqi kdeinit4: preparing to launch /usr/lib/kde4/libkdeinit/libkdeinit4_ksmserver.so <unknown program name>(3631)/ KStartupInfo::createNewStartupId: creating: "Serveur;1327894564;504831;3631_TIME0" : "unnamed app" QDBusConnection: name 'org.kde.knotify' had owner '' but we thought it was ':1.6' knotify(3658) NotifyBySound::notify: going to play "/usr/share/sounds/KDE-Sys-App-Error-Critical.ogg" qUncompress: Z_DATA_ERROR: Input data is corrupted qUncompress: Input data is corrupted ksmserver(3661): stream is bad :-( status= 1 qUncompress: Input data is corrupted ksmserver(3661): stream is bad :-( status= 2 drkonqi(3659): Unable to find an internal debugger that can work with the KCrash backend params.c:OpenConfFile() - Unable to open configuration file "/root/.smb/smb.conf": Aucun fichier ou dossier de ce type params.c:OpenConfFile() - Unable to open configuration file "/root/.smb/smb.conf.append": Aucun fichier ou dossier de ce type kded(3634)/kdeui (KNotification) KNotification::slotReceivedIdError: Error while contacting notify daemon "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken." kded(3634)/kdecore (KConfigSkeleton) KCoreConfigSkeleton::writeConfig: kded(3634)/kdecore (KConfigSkeleton) KCoreConfigSkeleton::writeConfig: kded(3634)/kdecore (KConfigSkeleton) KCoreConfigSkeleton::writeConfig: kded(3634)/kdecore (KConfigSkeleton) KCoreConfigSkeleton::writeConfig: kded(3634)/kdecore (KConfigSkeleton) KCoreConfigSkeleton::writeConfig: kded(3634)/kdecore (KConfigSkeleton) KCoreConfigSkeleton::writeConfig: Object::connect: No such signal Solid::Button::pressed(int, const QString &) kded(3634)/kdecore (KConfigSkeleton) KCoreConfigSkeleton::writeConfig: Object::connect: No such signal Solid::Button::pressed(int, const QString &) kded(3634)/kdecore (KConfigSkeleton) KCoreConfigSkeleton::writeConfig: KCrash: Application 'ksmserver' crashing... kdeinit4: preparing to launch /usr/lib/kde4/libexec/drkonqi drkonqi(3722): Unable to find an internal debugger that can work with the KCrash backend drkonqi(3722): The specified process does not exist. startkde: Shutting down... klauncher: Exiting on signal 1 startkde: Running shutdown scripts... startkde: Done.
Je n’arrive pas à comprendre l’erreur : “qUncompress: Z_DATA_ERROR: Input data is corrupted”
Bonsoir,
Je viens de tester le live et j’ai le même problème. :blush:
Je crois que je vais abandonner cette option.
A+
Bonsoir,
Je viens de refaire une installation, et lors du 1er lancement de : /etc/init.d/kdm start, j’ai eu le même problème.
Par contre, en exécutant la commande directement : start je n’ai pas eu de problème.
En relançant kdm, le problème est disparue.
Donc le problème est RESOLU, mais je ne sais toujours pas ce qui posait problème.
Merci pour vos réponses.
A+
