voici le retour de la commande en root sur le système où sudo ne marche pas
strace -u bv -ff -o /tmp/trace sudo whoami
execve("/usr/bin/sudo", [“sudo”, “whoami”], [/* 34 vars */]) = 0
uname({sys=“Linux”, node=“bv-pc”, …}) = 0
brk(0) = 0x8062000
fcntl64(0, F_GETFD) = 0
fcntl64(1, F_GETFD) = 0
fcntl64(2, F_GETFD) = 0
access("/etc/suid-debug", F_OK) = -1 ENOENT (No such file or directory)
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7f5a000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=56485, …}) = 0
mmap2(NULL, 56485, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb7f4c000
close(3) = 0
open("/lib/libpam.so.0", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\340\23”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=29700, …}) = 0
mmap2(NULL, 32656, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7f44000
mmap2(0xb7f4b000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6) = 0xb7f4b000
close(3) = 0
open("/lib/tls/i686/cmov/libdl.so.2", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20\f\0”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=9592, …}) = 0
mmap2(NULL, 12404, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7f40000
mmap2(0xb7f42000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1) = 0xb7f42000
close(3) = 0
open("/lib/tls/i686/cmov/libc.so.6", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\240O\1”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=1241392, …}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7f3f000
mmap2(NULL, 1247388, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7e0e000
mmap2(0xb7f35000, 28672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x127) = 0xb7f35000
mmap2(0xb7f3c000, 10396, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb7f3c000
close(3) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7e0d000
mprotect(0xb7f35000, 20480, PROT_READ) = 0
set_thread_area({entry_number:-1 -> 6, base_addr:0xb7e0d6c0, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
munmap(0xb7f4c000, 56485) = 0
geteuid32() = 0
rt_sigaction(SIGINT, {SIG_IGN}, {SIG_DFL},
= 0
rt_sigaction(SIGQUIT, {SIG_IGN}, {SIG_DFL},
= 0
rt_sigaction(SIGTSTP, {SIG_IGN}, {SIG_DFL},
= 0
rt_sigaction(SIGCHLD, {0x804c7e0, [], SA_RESTART}, {SIG_DFL},
= 0
getrlimit(RLIMIT_CORE, {rlim_cur=0, rlim_max=RLIM_INFINITY}) = 0
setrlimit(RLIMIT_CORE, {rlim_cur=0, rlim_max=RLIM_INFINITY}) = 0
getrlimit(RLIMIT_NOFILE, {rlim_cur=1024, rlim_max=1024}) = 0
close(3) = -1 EBADF (Bad file descriptor)
(j’ai écourté
close(1023) = -1 EBADF (Bad file descriptor)
brk(0) = 0x8062000
brk(0x8083000) = 0x8083000
open("/etc/nsswitch.conf", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=513, …}) = 0
mmap2(NULL, 131072, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7ded000
read(3, “# /etc/nsswitch.conf\n#\n# Example”…, 131072) = 513
read(3, “”, 131072) = 0
close(3) = 0
munmap(0xb7ded000, 131072) = 0
close(3) = 0
open("/lib/tls/i686/cmov/libnss_compat.so.2", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20\21\0”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=30428, …}) = 0
mmap2(NULL, 33392, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7e04000
mmap2(0xb7e0b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6) = 0xb7e0b000
close(3) = 0
open("/lib/tls/i686/cmov/libnsl.so.1", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0p5\0\000”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=76548, …}) = 0
mmap2(NULL, 87808, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7dee000
mmap2(0xb7e00000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x11) = 0xb7e00000
mmap2(0xb7e02000, 5888, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb7e02000
close(3) = 0
close(3) = 0
open("/lib/tls/i686/cmov/libnss_nis.so.2", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0@\34\0\000”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=34320, …}) = 0
mmap2(NULL, 37420, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7de4000
mmap2(0xb7dec000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7) = 0xb7dec000
close(3) = 0
open("/lib/tls/i686/cmov/libnss_files.so.2", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\33”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=38372, …}) = 0
mmap2(NULL, 41620, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7dd9000
mmap2(0xb7de2000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8) = 0xb7de2000
close(3) = 0
open("/etc/passwd", O_RDONLY) = 3
fcntl64(3, F_GETFD) = 0
fcntl64(3, F_SETFD, FD_CLOEXEC) = 0
socket(PF_NETLINK, SOCK_RAW, 0) = 4
bind(4, {sa_family=AF_NETLINK, pid=0, groups=00000000}, 12) = 0
getsockname(4, {sa_family=AF_NETLINK, pid=3073, groups=00000000}, [12]) = 0
time(NULL) = 1202039627
sendto(4, “\24\0\0\0\22\0\1\3K\253\245G\0\0\0\0\0\241\355\267”, 20, 0, {sa_family=AF_NETLINK, pid=0, groups=00000000}, 12) = 20
recvmsg(4, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"\364\0\0\0\20\0\2\0K\253\245G\1\f\0\0\0\0\4\3\1\0\0\0I"…, 4096}], msg_controllen=0, msg_flags=0}, 0) = 736
recvmsg(4, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"\24\0\0\0\3\0\2\0K\253\245G\1\f\0\0\0\0\0\0\1\0\0\0I\0"…, 4096}], msg_controllen=0, msg_flags=0}, 0) = 20
sendto(4, “\24\0\0\0\26\0\1\3L\253\245G\0\0\0\0\0\241\355\267”, 20, 0, {sa_family=AF_NETLINK, pid=0, groups=00000000}, 12) = 20
recvmsg(4, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"<\0\0\0\24\0\2\0L\253\245G\1\f\0\0\2\10\200\376\1\0\0\0"…, 4096}], msg_controllen=0, msg_flags=0}, 0) = 128
recvmsg(4, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"@\0\0\0\24\0\2\0L\253\245G\1\f\0\0\n\200\200\376\1\0\0"…, 4096}], msg_controllen=0, msg_flags=0}, 0) = 128
recvmsg(4, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"\24\0\0\0\3\0\2\0L\253\245G\1\f\0\0\0\0\0\0\1\0\0\0\24"…, 4096}], msg_controllen=0, msg_flags=0}, 0) = 20
close(4) = 0
open("/etc/localtime", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=2945, …}) = 0
mmap2(NULL, 131072, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7db9000
read(4, “TZif2\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\f\0\0\0\f\0\0”…, 131072) = 2945
close(4) = 0
munmap(0xb7db9000, 131072) = 0
ioctl(0, SNDCTL_TMR_TIMEBASE or TCGETS, {B38400 opost isig icanon echo …}) = 0
readlink("/proc/self/fd/0", “/dev/pts/1”, 4095) = 10
getuid32() = 1000
socket(PF_FILE, SOCK_STREAM, 0) = 4
fcntl64(4, F_GETFL) = 0x2 (flags O_RDWR)
fcntl64(4, F_SETFL, O_RDWR|O_NONBLOCK) = 0
connect(4, {sa_family=AF_FILE, path="/var/run/nscd/socket"}, 110) = -1 ENOENT (No such file or directory)
close(4) = 0
close(4) = 0
open("/etc/passwd", O_RDONLY) = 4
fcntl64(4, F_GETFD) = 0
fcntl64(4, F_SETFD, FD_CLOEXEC) = 0
_llseek(4, 0, [0], SEEK_CUR) = 0
fstat64(4, {st_mode=S_IFREG|0644, st_size=1294, …}) = 0
mmap2(NULL, 1294, PROT_READ, MAP_SHARED, 4, 0) = 0xb7f59000
_llseek(4, 1294, [1294], SEEK_SET) = 0
munmap(0xb7f59000, 1294) = 0
close(4) = 0
open("/etc/shadow", O_RDONLY) = 4
open("/etc/shadow", O_RDONLY) = 5
fcntl64(5, F_GETFD) = 0
fcntl64(5, F_SETFD, FD_CLOEXEC) = 0
_llseek(5, 0, [0], SEEK_CUR) = 0
fstat64(5, {st_mode=S_IFREG|0640, st_size=999, …}) = 0
mmap2(NULL, 999, PROT_READ, MAP_SHARED, 5, 0) = 0xb7f59000
_llseek(5, 999, [999], SEEK_SET) = 0
munmap(0xb7f59000, 999) = 0
close(5) = 0
close(4) = 0
close(4) = 0
close(5) = 0
close(4) = 0
setregid32(-1, 1000) = 0
setreuid32(0, 1000) = 0
getcwd("/home/bv", 4096) = 9
setreuid32(-1, 0) = 0
setuid32(0) = 0
close(4) = 0
close(4) = 0
open("/etc/group", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=820, …}) = 0
mmap2(NULL, 820, PROT_READ, MAP_SHARED, 4, 0) = 0xb7f59000
_llseek(4, 820, [820], SEEK_SET) = 0
munmap(0xb7f59000, 820) = 0
close(4) = 0
stat64("/usr/local/sbin/whoami", 0xbfe17af0) = -1 ENOENT (No such file or directory)
stat64("/usr/local/bin/whoami", 0xbfe17af0) = -1 ENOENT (No such file or directory)
stat64("/usr/sbin/whoami", 0xbfe17af0) = -1 ENOENT (No such file or directory)
stat64("/usr/bin/whoami", {st_mode=S_IFREG|0755, st_size=12560, …}) = 0
setuid32(0) = 0
lstat64("/etc/sudoers", {st_mode=S_IFREG|0440, st_size=457, …}) = 0
setregid32(-1, 0) = 0
setreuid32(0, 1) = 0
open("/etc/sudoers", O_RDONLY) = -1 EACCES (Permission denied)
geteuid32() = 1
setuid32(0) = 0
write(2, “sudo: “, 6) = 6
write(2, “can’t open /etc/sudoers”, 23) = 23
write(2, “: “, 2) = 2
write(2, “Permission denied\n”, 18) = 18
rt_sigprocmask(SIG_BLOCK, [CHLD], [],
= 0
pipe([4, 5]) = 0
clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0xb7e0d708) = 3074
close(4) = 0
fcntl64(5, F_GETFL) = 0x1 (flags O_WRONLY)
fstat64(5, {st_mode=S_IFIFO|0600, st_size=0, …}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7f59000
_llseek(5, 0, 0xbfe1782c, SEEK_CUR) = -1 ESPIPE (Illegal seek)
stat64(”/etc/localtime”, {st_mode=S_IFREG|0644, st_size=2945, …}) = 0
stat64("/etc/localtime", {st_mode=S_IFREG|0644, st_size=2945, …}) = 0
write(5, “To: root\nFrom: bv\nSubject: *** S”…, 207) = 207
close(5) = 0
munmap(0xb7f59000, 4096) = 0
waitpid(-1, 0xbfe17958, WNOHANG) = 0
rt_sigprocmask(SIG_SETMASK, [], NULL,
= 0
time([1202039627]) = 1202039627
socket(PF_FILE, SOCK_DGRAM, 0) = 4
connect(4, {sa_family=AF_FILE, path="/dev/log"}, 16) = 0
send(4, "<81>Feb 3 12:53:47 sudo: "…, 144, MSG_NOSIGNAL) = 144
close(4) = 0
exit_group(1) = ?
