Hello !
Je me suis inspiré du tuto de Ghost dans Trucs et Astuces.
Ma carte graphique est une RIVA TNT2 Modèle 64 (ce n’est pas l’année de sa fabrication)
Je suis sous Debian Etch, i386, PIII-600.
Voici les packages installés sur mon système (après compilation du module), précédés d’un ‘i’ :
11:32 bluenote@Opale ~% aptitude search nvidia
i nvidia-cg-toolkit - NVIDIA Cg Toolkit installer
p nvidia-glx - NVIDIA binary XFree86 4.x driver
p nvidia-glx-dev - NVIDIA binary XFree86 4.x / Xorg driver development fi
i A nvidia-glx-legacy - NVIDIA binary Xorg driver (legacy version)
i nvidia-glx-legacy-dev - NVIDIA binary Xorg driver development files
v nvidia-kernel-1.0.8776 -
p nvidia-kernel-2.6-486 - NVIDIA binary kernel module for 2.6 series compiled fo
p nvidia-kernel-2.6-686 - NVIDIA binary kernel module for 2.6 series compiled fo
p nvidia-kernel-2.6-k7 - NVIDIA binary kernel module for 2.6 series compiled fo
p nvidia-kernel-2.6.18-4-486 - NVIDIA binary kernel module for Linux 2.6.18-4-486
p nvidia-kernel-2.6.18-4-686 - NVIDIA binary kernel module for Linux 2.6.18-4-686
p nvidia-kernel-2.6.18-4-k7 - NVIDIA binary kernel module for Linux 2.6.18-4-k7
i nvidia-kernel-2.6.18.2686-opale-2 - NVIDIA binary kernel module for Linux 2.6.18.2686-opal
i nvidia-kernel-common - NVIDIA binary kernel module common files
v nvidia-kernel-legacy-1.0.7184 -
p nvidia-kernel-legacy-2.6-486 - NVIDIA binary kernel module for 2.6 series compiled fo
p nvidia-kernel-legacy-2.6-686 - NVIDIA binary kernel module for 2.6 series compiled fo
p nvidia-kernel-legacy-2.6-k7 - NVIDIA binary kernel module for 2.6 series compiled fo
i A nvidia-kernel-legacy-2.6.18-4-486 - NVIDIA binary kernel module for Linux 2.6.18-4-486 (le
p nvidia-kernel-legacy-2.6.18-4-686 - NVIDIA binary kernel module for Linux 2.6.18-4-686 (le
p nvidia-kernel-legacy-2.6.18-4-k7 - NVIDIA binary kernel module for Linux 2.6.18-4-k7 (leg
i nvidia-kernel-legacy-source - NVIDIA binary kernel module source (legacy version)
i nvidia-kernel-source - NVIDIA binary kernel module source
i nvidia-settings - Tool of configuring the NVIDIA graphics driver
p nvidia-xconfig - The NVIDIA X Configuration Tool
Mon noyau est un : 2.6.18.2 version maison : 686-opale-2
Avant la compilation, j’ai fait ceci :
11:23 bluenote@Opale ~% sudo m-a -i prepare
Password:
Récupération des sources du noyau de la version : 2.6.18.2686-opale-2
En-têtes du noyau disponibles dans /lib/modules/2.6.18.2686-opale-2/source
apt-get-y install build-essential
Fait.
zsh: exit 249 sudo m-a -i prepare
Pour compiler/installer :
11:23 bluenote@Opale ~% sudo m-a a-i -i -t -f nvidia-kernel
La compilation semble se passer sans pb.
Le meilleur se trouve ici :
http://marsan.loc.free.fr/Online/Nvidia_module_compilation
(bon courage)
Puis :
11:27 bluenote@Opale ~% sudo depmod -a
Une fois fait, j’ai droit à un joli :
/usr/src/modules/nvidia-kernel/debian/nvidia-kernel-2.6.18.2686-opale-2/lib/modules/2.6.18.2686-opale-2/nvidia/nvidia.ko
et tout un tas de truc autour…
J’ai aussi le module ici :
/lib/modules/2.6.18.2686-opale-2/nvidia/(nvidia.ko)
Il n’est pas dit qu’il faille le charger. J’ai qd même tenté :
12:10 bluenote@Opale /lib/modules/2.6.18.2686-opale-2/nvidia% sudo modprobe nvidia
Password:
FATAL: Error inserting nvidia (/lib/modules/2.6.18.2686-opale-2/nvidia/nvidia.ko): No such device
zsh: exit 1 sudo modprobe nvidia
J’ai sélectionné ‘nvidia’ dans /etc/X11/xorg.conf
Puis :
%sudo invoke-rc.d kdm start
Et là, écran noir, retour en console…
Dans /var/log/Xorg.0.log, j’ai :
(EE) NVIDIA(0): Failed to load the NVIDIA kernel module!
(EE) NVIDIA(0): *** Aborting ***
(II) UnloadModule: "nvidia"
(EE) Screen(s) found, but none have a usable configuration.
Pour information, j’avais exécuté le script d’installation de Nvidia, il y a longtemps. Je ne sais pas s’il y a des modifications dûes à cette tentative, ni comment faire le “ménage”…
S.O.S.
