En effet ,j’ai donc installé alsa-utils mais le phenomène subsiste.
je te joins ce fichier por info est-ce qu’il est correct?
modinfo snd-emu10k1
filename: /lib/modules/2.6.8-2-386/kernel/sound/pci/emu10k1/snd-emu10k1.koauthor: Jaroslav Kysela perex@suse.cz
description: EMU10K1
license: GPL
vermagic: 2.6.8-2-386 preempt 386 gcc-3.3
depends: snd-pcm,snd-ac97-codec,snd-util-mem,snd-page-alloc,snd-rawmidi,snd,snd-hwdep,snd-seq-device
alias: pci:v00001102d00000002svsdbcsci*
alias: pci:v00001102d00000004svsdbcsci*
parm: enable_ir:Enable IR.
parm: max_buffer_size:Maximum sample buffer size in MB.
parm: max_synth_voices:Maximum number of voices for WaveTable.
parm: seq_ports:Allocated sequencer ports for internal synthesizer.
parm: extout:Available external outputs for FX8010. Zero=default.
parm: extin:Available external inputs for FX8010. Zero=default.
parm: enable:Enable the EMU10K1 soundcard.
parm: id:ID string for the EMU10K1 soundcard.
parm: index:Index value for the EMU10K1 soundcard.
bern:/home/bern#
