-> [mono]$ man journalctl[/mono]
[quote][mono]–since=[/mono], [mono]–until=[/mono]
Start showing entries on or newer than the specified date, or on or older than the specified date, respectively. [mono]Date specifications should be of the format[/mono] "[mono]2012-10-30 18:17:16[/mono]". If the time part is omitted, "00:00:00" is assumed. If only the seconds component is omitted, ":00" is assumed. If the date component is omitted, the current day is assumed. Alternatively the strings [mono]"yesterday", "today", "tomorrow" are understood[/mono], which refer to 00:00:00 of the day before the current day, the current day, or the day after the current day, respectively. "now" refers to the current time. Finally, relative times may be specified, prefixed with "-" or "+", referring to times before or after the current time, respectively.[/quote]
Le journal du jour ?
Remonter le temps ?
Du xx au xx à …h… ?
[quote=“BelZéButh”]$ systemctl -t service -a --full | grep error
$ systemctl --failed[/quote]
[mono]$ man systemd
$ man systemd-journald.service
$ man systemctl
$ man coredumpctl
$ man systemd.journal-fields
$ man journald.conf[/mono]
