Salut, voici quelques logs:
[quote]kern.log:
Jul 11 10:05:21 debian kernel: IPv4 over IPv4 tunneling driver
Jul 11 10:05:21 debian kernel: GRE over IPv4 tunneling driver
Jul 11 10:05:21 debian kernel: IPv6 over IPv4 tunneling driver
Jul 11 10:05:21 debian kernel: Bridge firewalling registered
APRES UN MODPROBE PPP_MPPE:
Jul 11 10:10:17 debian kernel: PPP MPPE Compression module registered
debug:
Jul 11 10:05:47 debian pptpd[1953]: CTRL: Reaping child PPP[1954]
Jul 11 10:09:25 debian pptpd[1988]: CTRL: Reaping child PPP[1989]
Jul 11 10:09:26 debian pptpd[1990]: CTRL: Reaping child PPP[1991]
Jul 11 10:09:27 debian pptpd[1992]: CTRL: Reaping child PPP[1993]
Jul 11 10:09:27 debian pptpd[1994]: CTRL: Reaping child PPP[1995]
Jul 11 10:09:27 debian pptpd[1996]: CTRL: Reaping child PPP[1997]
Jul 11 10:11:20 debian pptpd[2028]: CTRL: Reaping child PPP[2029]
Jul 11 10:11:37 debian pptpd[2031]: CTRL: Reaping child PPP[2032]
daemon.log:
Jul 11 10:14:14 debian pptpd[2047]: CTRL: Client 192.168.3.5 control connection started
Jul 11 10:14:14 debian pptpd[2047]: CTRL: Starting call (launching pppd, opening GRE)
Jul 11 10:14:14 debian pptpd[2047]: GRE: read(fd=6,buffer=80505a0,len=8196) from PTY failed: status = -1 error = Input/output error, usually caused by unexpected termination of pppd, check option syntax and pppd logs
Jul 11 10:14:14 debian pptpd[2047]: CTRL: PTY read or GRE write failed (pty,gre)=(6,7)
Jul 11 10:14:14 debian pptpd[2047]: CTRL: Reaping child PPP[2048]
Jul 11 10:14:14 debian pptpd[2047]: CTRL: Client 192.168.3.5 control connection finished[/quote]
La config de chap-secrets:
[quote]# Secrets for authentication using CHAP
client server secret IP addresses
vpn pptpd vpn *
vpn debi vpn “*”[/quote]
La config de pptpd.conf:
[quote]
TAG: ppp
Path to the pppd program, default ‘/usr/sbin/pppd’ on Linux
#ppp /usr/sbin/pppd
TAG: option
Specifies the location of the PPP options file.
By default PPP looks in ‘/etc/ppp/options’
option /etc/ppp/pptpd-options
TAG: debug
Turns on (more) debugging to syslog
#debug
TAG: stimeout
Specifies timeout (in seconds) on starting ctrl connection
stimeout 10
TAG: noipparam
Suppress the passing of the client’s IP address to PPP, which is
done by default otherwise.
#noipparam
TAG: logwtmp
Use wtmp(5) to record client connections and disconnections.
logwtmp
TAG: bcrelay
Turns on broadcast relay to clients from interface
#bcrelay eth1
TAG: localip
TAG: remoteip
Specifies the local and remote IP address ranges.
Any addresses work as long as the local machine takes care of the
routing. But if you want to use MS-Windows networking, you should
use IP addresses out of the LAN address space and use the proxyarp
option in the pppd options file, or run bcrelay.
You can specify single IP addresses seperated by commas or you can
specify ranges, or both. For example:
192.168.0.234,192.168.0.245-249,192.168.0.254
IMPORTANT RESTRICTIONS:
1. No spaces are permitted between commas or within addresses.
2. If you give more IP addresses than MAX_CONNECTIONS, it will
start at the beginning of the list and go until it gets
MAX_CONNECTIONS IPs. Others will be ignored.
3. No shortcuts in ranges! ie. 234-8 does not mean 234 to 238,
you must type 234-238 if you mean this.
4. If you give a single localIP, that’s ok - all local IPs will
be set to the given one. You MUST still give at least one remote
IP for each simultaneous client.
(Recommended)
#localip 192.168.0.1
#remoteip 192.168.0.234-238,192.168.0.245
or
#localip 192.168.0.234-238,192.168.0.245
#remoteip 192.168.1.234-238,192.168.1.245
localip 192.168.3.210
remoteip 192.168.3.234-238,192.168.3.245[/quote]
voila voila
Je voulais savoir si c’était normale que mon module mppe ne se charge pas automatiquement? en effet je dois faire une modprobe pour le charger:
[quote]debian:~# lsmod
Module Size Used by
autofs4 14476 -
deflate 2600 -
zlib_deflate 19960 -
zlib_inflate 15976 -
des 14824 -
sha1 2120 -
af_key 26776 -
af_packet 12048 -
debian:~# modprobe ppp_mppe
debian:~# lsmod
Module Size Used by
arc4 1512 -
ppp_mppe 5900 -
autofs4 14476 -
deflate 2600 -
des 14824 -
sha1 2120 -
af_key 26776 -
af_packet 12048 -
debian:~#[/quote]
